Lens distortion
Archive of all documentation suggestions for Autopano (last post in 2012).
This forum is closed - you cannot create new topics or comments here!
Lens distortion
by GURL » Tue Mar 24, 2009 11:07 am
http://www.autopano.net/forum/p41739-today-08-08-20#p41739
Adjust lens distortion option enables correction of the lens barrel/pincushion distortions.
When using a long focal, it can often be disabled (100 mm or more.) The shorter the focal, the more you need it. For fisheyes, you always need it.
Usefulness will also depend on the quality of the lens (super zooms could need it even at their longest focal setting.)
by gkaefer » Thu Nov 26, 2009 12:58 pm
found here from Ronald Tichelaar #9:
http://www.autopano.net/forum/t7796-stitching-vertical-images
link to PTlens (to reduce disortion before stitching images with AP):
http://epaperpress.com/ptlens/
lg
