Autopano_Giga_Documentation
Archive of all documentation suggestions for Autopano (last post in 2012).
This forum is closed - you cannot create new topics or comments here!
SimDC
by SimDC » Mon Mar 26, 2012 12:05 am
in
http://www.autopano.net/wiki-en/action/view/Autopano_Giga_-_Main_Window_-_Plugin_wizard
Clicking on Finish will crate new files that are copies of the source files (renamed) into a new group them in the folder containing the source images.
"into a new group them" ??
Split preview
Cocher la case pour afficher ou cacher le résultat. L'aperçu dans la fenêtre permet de visualiser l'effet des corrections par différence.
en vf ?
in
http://www.autopano.net/wiki-en/action/view/Bracket_:_Using_Stacks
Note: it is possible that this process does not work according to the make and model of camera. ->
Note: according to the make and model of camera it is possible that this process does not work.
Les images de menus devraient etres celles de la version anglaise pour etre comprises.
... Then open the panorama editor. You can see the corrisponding result (layer editor) : -> corresponding ?
