New Merlin Synscan AZ Goto User
Socke
by Socke » Sat Jul 21, 2012 12:27 pm
I thought, this could be interesting ;)
Until now, i only found 1 source, and that's a beta, newer than the original one. The original firmware has problems with big panos, this beta hasn't. I just asked the poster about a newer final one, but he hasn't heard of celestron about a newer one (see last post).
So head over to timescapes.org
The firmware had been downloaded 15 times until i stumbled on it. I'm curious, how far it will go now :D
Mateusz Malinowski
by Mateusz Malinowski » Mon Jul 23, 2012 7:57 pm
Last edited by Mateusz Malinowski on Tue Jul 24, 2012 9:50 am, edited 1 time in total.
yoshiharra
by yoshiharra » Wed Aug 01, 2012 2:32 am
Socke wrote:I thought, this could be interesting ;)
Socke, thanks to you, I have successfully updated the firmware of my Merlin AZ GoTo head! This is crazy! :P
Thanks again for a wonderful find!:D
Canon EOS T3i, EF 100-400mm, Tokina 100mm, Sigma 15mm, Samyang 8mm, Nodal Ninja 5L & R10, Merlin - Papywizard on Nokia N810
Mateusz Malinowski
by Mateusz Malinowski » Wed Aug 08, 2012 8:19 pm
Socke, Yoshiharra
can You check 5,6,7,8 speed rate in hand controller? Does it work fine?
Socke
by Socke » Sat Aug 25, 2012 2:43 pm
checked. Work fine in astronomical mode. Don't work in panorama mode.
Mateusz Malinowski
by Mateusz Malinowski » Sat Aug 25, 2012 3:01 pm
I find also
1.
If use video tracking up/down - time duration don't stop after time I declare. And there is no question "Start over?
For example I declared 2 minutes tracking. After 2 minutes slewing is stopped (OK), but time on hand controller screen don't stop. Only when I use esc key -> is question "Start over".
If use left/right tracking - time duration stop after time I declare (OK).
2. video tracking by left/right AND up/down in ONE TRACK don't work perfect. Up/down tracking is 1-2seconds longer. Should stopped in the same time.
Socke
by Socke » Wed Aug 29, 2012 12:06 pm
should we check this? is it different to the original merlin-handcontroller behaviour?
Mateusz Malinowski
by Mateusz Malinowski » Wed Aug 29, 2012 12:58 pm
Socke wrote:should we check this? is it different to the original merlin-handcontroller behaviour?
It is not necessary to chceck. I think if You have bug with 5,6,7,8 speed rate You (and other with merlin) will have other bugs I wrote. Just wanted to inform.
"is it different to the original merlin-handcontroller behaviour" - 3.09 firmware is designed to allview mount, not merlin. So ...
Socke
by Socke » Mon Sep 03, 2012 2:54 pm
i don't think it's a bug, as it works in astronomical mode, and the merlin had only that mode. Do the speed rates work in pano-mode for the allview? If i should make a guess, i'd say NO :)
Socke
by Socke » Mon Feb 04, 2013 1:22 pm
For those, who want to stay with an official source for the firmware:
Celestron offers exactly the same firmware (with the b18 in it's name) as a fix for the allview since October 2012:
http://www.celestron.com/c3/support3/index.php?_m=downloads&_a=viewdownload&downloaditemid=808&nav=0,6
edit: typo
Mateusz Malinowski
by Mateusz Malinowski » Sun May 05, 2013 10:13 am
New motor controller firmware (2.14) available for allview mount http://www.skywatcher.com/swtinc/customer_support.php?id=146&class1=1&class2=115
Anyone try this on merlin/panogear with allview firmware?
Previous
