Wireless tethered shooting
by fma38 » Tue May 04, 2010 5:44 pm
Starting from this great idea:
http://webuser.fh-furtwangen.de/~dersch/gphoto/remote.html
I tried a different approach. Instead of running gphoto2 on the device, I used usbip, a nice freature added in recent linux kernels.
So, I compiled a very light version of OpenWRT for my NSLU2, connected my camera to the NSLU2, configured usbip to export my camera, and was able to use gphoto2 from another computer :P :) :D It is even possible to download the images!
I think this is a very elegant solution. Next step will be to compile a better firmware, setup a wifi connection (using a usb-wifi or ethernet-wifi device, or switching to another hardware, with integrated wifi), and make some scripts to automate the camera export (tricky part).
I will also give a try to USB Server, another solution to export usb device over ip (there is a NSLU2 package for OpenWRT).
jeongyun
by jeongyun » Tue May 04, 2010 9:32 pm
I wonder if usb/ip would work on nokia handhelds?
I've been researching same topic as you but slightly different approach.
Wireless usb and other linux handhelds.
open pandora for example.
by fma38 » Tue May 04, 2010 11:30 pm
Having the usbip client working on the N8x0 will be the next step. But this will require to cross-compile the package and the kernel module. I will need some help for this point, as I failed to install the (strange) Nokia toolchain, some months ago...
If you are interested, here is an interesting thread:
http://talk.maemo.org/showthread.php?t=41870
