Possible tethered controller
Greg Nuspel
by Greg Nuspel » Thu Mar 11, 2010 1:26 pm
I was looking at http://www.microarmsystems.com/2157/144201.html as a possible tethered controller. Now that there is a Linux version I was wondering if it would run on this unit. This would make a totally self-contained unit. I was also thinking that it maybe possible to activate it with a wireless device where no communication other than start/stop would be required, this could be ZigBee, infrared, bluetooth, etc. Nice thing is this unit could have other applications installed such as depth of field calculator, gps logging, etc.
The unit has the following software:
Linux development tools and kernel source code package
- arm-linux-gcc-3.3.2 used for compiling Qtopia
- arm-linux-gcc-3.4.1 used for compiling kernel
- arm-linux-gcc-2.95.3 used for compiling vivi
- mkyaffsimage yaffs filesystem image maker
- linux-2.6.13 kernel images and source code for MINI2440
So my question is; can a version be compiled to run on this unit?
--Greg Nuspel
by fma38 » Thu Mar 11, 2010 2:18 pm
You mean 'can *Papywizard* be compiled...'? I don't know if there is enough space to compile/run python + PyQt. I don't even know if there is a PyQt port for Qtopia... I will ask.
But I think you can compile gphoto2, for exemple, and write a simple GUI in C++ with Qtopia. But I've no knowledge for such dev. Try to find an active forum with Mini2440 board gurus, and see what they do with it.
by fma38 » Thu Mar 11, 2010 4:17 pm
A usefull link with usefull links at the bottom:
http://linuxsoftware.co.nz/wiki/Mini2440
Angstrom distro could be a nice solution:
http://www.angstrom-distribution.org
gphoto2 is packaged, pyqt too!
I suggest you dig this way, to see if it can be installed on Mini2440:
http://code.google.com/p/mini2440/downloads/list
It (partially) runs on N800:
http://linuxtogo.org/gowiki/AngstromAndN800
Greg Nuspel
by Greg Nuspel » Thu Mar 11, 2010 5:01 pm
OK I'm going to see what I can do with one of these.
--Greg Nuspel
jeongyun
by jeongyun » Thu Mar 11, 2010 6:50 pm
What would be advantages of these development boards over a used linux handheld devices, for example Nikia N800?
Greg Nuspel
by Greg Nuspel » Thu Mar 11, 2010 7:20 pm
Everything in one package, nothing to be forgotten at home. Not like I've done that in the last week ;)
--Greg Nuspel
regnirps
by regnirps » Sun Mar 14, 2010 1:34 am
Hi Greg. That three compiler junk is over a year old. Check www.andahammer.com or friendlyarm.net. Microarmsystems is some school chum of the guy who manufactures the boards in China and he lets him sell a few, but support is nill.
You can download all new Qtopia type SW or the preferred Angstrom with Qt/E.
Cheers.
Charlie Regnirps
