Problem installing on N8x0
by mediavets » Wed Feb 03, 2010 2:12 pm
I've installed Papywizard on N800 tablets many times before by follwing these instructions:
http://www.autopano.net/wiki-en/action/view/Install_Papywizard_v2_on_Nokia_N8x0
I haven't done it for a while but this time it's failing when I attempt to install the PyQT stuff:
http://www.autopano.net/wiki-en/action/view/Install_Papywizard_v2_on_Nokia_N8x0#Install_the_required_program_packages_-_godmode.2C_Python_2.5_runtime_and_PyQt
When I enter this command:
# apt-get install python2.5-qt4-core python2.5-qt4-gui python2.5-qt4-network
I get an error message:
E: Couldn't find package python2.5-qt4-core
Why is that?
Where did I go wrong this time?
Any ideas please?
by fma38 » Wed Feb 03, 2010 2:16 pm
What give:
$ apt-cache search qt4
by mediavets » Wed Feb 03, 2010 2:35 pm
fma38 wrote:What give:
Frederic,
Thanks for the quick response.
It was my fault, of course - I discovered an overlooked typo I made when creating a new catalogue entry for maemo-extras-devel - old age is a terrible thing.:(
Solved now. Papywizard installed and working fine.
by fma38 » Wed Feb 03, 2010 4:56 pm
Good!
120to120
by 120to120 » Mon Feb 22, 2010 11:16 pm
Hi all,
please help!
Nokia N810 + Pw 1.6.1 Installation-----OK!
Nokia N810 + Pw 2.1.16-1 ----- NO----OK!
Nokia N810 ---- not install GodMode possible.
Thanks for the help.
Joseph
(*Merlin/Orion_BT - teleskop-austria.*); FTDI USB-TTL cable; Macbook (Intel) OS X10.5.6 / ext. Bluetooth Dongle_VIVANCO_B1002270209 / PW 2.1.20; Go-To / TA *Nokia N810 / PW 2.1.20 * Sony F717 / Sony R1 ; JJC SR-828; 15m Mast;
by fma38 » Fri Mar 19, 2010 8:36 am
Could you describe a little more your problem, Joseph? Please post the commands you gave, and the answers you got...
Another N810 user has problems to become root on its N810. He installed godmod, but when he tries 'sudo gainroot', the system answers:
"Enable RD mode to gain root privileges"
I found this on the net:
"Also the old and messy way was enabling R&D mode, editing gainroot script and removing the IF condition. After that you can disable R&D mode and use sudo gainroot without R&D mode."
Did anyone have to do such modification? I never had to enable R&D mode, nor modify the gainroot script on my N800...
Paul
by Paul » Fri Mar 19, 2010 8:45 am
I have got the same problems on first run on my N810.
Gave it a second try and every thing works fine.
Paul
