PapySpheric: a Python program to build templates for panospheres
gerardm
by gerardm » Tue Jun 29, 2010 10:00 pm
Has anyone been able to generate an .xml?
Used Dashcode on the Mac and added some code from an earlier post. Works great! Thanks! Gurl!
sparks60
by sparks60 » Sat Sep 25, 2010 9:28 pm
I have spent some time making presets for papywizard but they were never quite right
so after members pointing me to the Papyspheric preset maker i read all the info and had a go.
I used portable Python and changed the settings in the program to suite my camera and ran it.
A couple of things that i found that may be useful are that you cannot select and paste the output using the right click mouse
in windows as it does not work so you have to select all the text and use control + V on the keyboard which does copy it all.
The second thing is that if you paste the text into Notepad it makes a bit of a mess even with word wrap selected
which makes it very difficult to see what's going on, i found if you use Wordpad instead it looks the same as the program output
and is very easy to see and edit.
You can save the file as a RTF as a backup which keeps all the text in order when you load it again.
The output for my camera did not look right when i first looked at it and the pitch values seemed as if they would
not work correctly but i spent some time copying and pasting into a XML file for the preset and thought i would test it out.
I was very pleasantly surprised after taking all the images on the Merlin and putting them through Autopano that it stitched
almost perfectly and was one of the best presets i had got so far.
I should have had a lot more faith and would just like to say thanks to the Author Georges (GURL)
for taking the time to write a great little program which is very useful to create presets.
One thing i would love to see if its at all possible and if Georges has the time and this would be that the output
of the program be in a similar order to presets with 0 being straight ahead and +90 at top and -90 at the nadir.
It would make it so much easier to copy the coordinates over to make the preset and probably cut down on mistakes
when copying all the numbers across.
Thanks again
Steve
Rick
by Rick » Sat Apr 09, 2011 5:07 pm
Hello
Python 2.6.4 installed, copied the code and saved as a .py file
module runs but just open another python window with nothing inside ....
What is the problem ?
Rick
by GURL » Thu Apr 14, 2011 6:14 pm
The problem is that papyspheric want Python 3.1 (not 2.6.4)
Though this was probably a mistake, not knowing the customs of the Python country I used the most recent stable version...
wjh31
by wjh31 » Tue Apr 19, 2011 8:50 am
Ok i might not be a super coder, but here's a minor edit:
Changed:
1:Now adds "<pict " and "/>" to each pictch/yaw position in the output for easier conversion to xml
2:The direction of each row is reversed relative to the previous, to keep the head from swinging all the way back to the start, i.e will now go:
rather than
3:added a couple more data points to the sensor sizes at the start of the script
# Version 0.0.2 - mardi 19 Avril 2011
# my camera: 23 x 15.5 mm
# Olypus: 13 x 17.3 mm
# Nikon APS-C: 23.6 x 15.8 mm
# Pentax K20D 23.4 x 15.6 mm
# Canon APS-C: 22.3 x 14.9 mm
# Full frame: 36 x 24mm
#####################  THE  9  PARAMETERS  YOU  MUST  SET  ARE  THERE
f= 50               # mm, for example 50 mm
Vside= 22.3        # mm, for example 36 mm  \  portrait / landscape
Hside= 14.9         # mm, for example 24 mm  /  orientation found there
phiMin= -90         # degrees, from -90 (nadir) toward 90
phiMax= 90         # degrees, up to 90 (zenith) toward -90
Hoverlap= 0.5      # horizontal overlap, coef from 0 to 0.5 (0% to 50 %)
Voverlap= 0.5       # vertical overlap, coef from 0 up to more than 0.5
panoheadPhiMin= -90 # degrees, from -90 (nadir)  \ avoids the camera or lens
panoheadPhiMax= 90  # degrees, up to 90 (zenith) / hitting the pano head !
from math import *
assert f > 1 and f < 1001, "f: improper focal length"
assert Vside > 1 and Vside < 100, "Vside: improper size"
assert Hside > 1 and Hside < 100, "Vside: improper size"
assert phiMin >= -90 and phiMin < 85, "phiMin not between -90 and +85"
assert phiMax <= 90 and phiMax > -85, "phiMax not between -85 and +90"
assert phiMin != phiMax, "phiMin, phiMax: min and max are equal"
assert phiMin < phiMax, "phiMin, phiMax: min and max are inverted"
assert Hoverlap >= 0, "Hoverlap: minimum possible value is 0"
assert Hoverlap < 0.96, "Hoverlap: maximum possible value is 0.95"
assert Voverlap >= 0, "Voverlap: minimum value is 0"
assert Voverlap < 0.96, "Voverlap: maximum value is 0.95"
assert panoheadPhiMin >= -90, "panoheadPhiMin: extreme value is -90"
assert panoheadPhiMax <= 90, "panoheadPhiMax: maximum value is 90"
assert panoheadPhiMin < panoheadPhiMax, "panoheadPhiMin, panoheadPhiMax:" \
       + "Pano-head extreme top & bottom positions are stupid!"
trueVside=  Vside
trueHside=  Hside
trueVfov=   degrees(2 * atan (trueVside / 2 / f))
trueHfov=   degrees(2 * atan (trueHside / 2 / f))
if phiMax - trueVfov / 2 > panoheadPhiMax :
    print("\nCAUTION! ...panorama phiMax incompatible",
          "with pano-head phiMax has been reduced!\n")
    phiMax= panoheadPhiMax - trueVfov / 2
if phiMin + trueVfov / 2 < panoheadPhiMin :
    phiMin= panoheadPhiMin + trueVfov / 2
    print("\nCAUTION! ...panorama phiMin incompatible",
          "with pano-head phiMin has been adjusted!\n")
truePhiMin= phiMin
truePhiMax= phiMax
print("Camera:")
print("    Sensor size         ", repr(trueHside)[0:4] + " x " + repr(trueVside),"mm")
print("    Focal length        ", repr(f)[0:5], "mm")
print("    Lens vertical FOV   ", round(degrees(2 * atan (trueVside / 2 / f))), "deg")
print("    Lens horizontal FOV ", round(degrees(2 * atan (trueHside / 2 / f))), "deg")
print("\nPanorama:")
print("    Top at              ", repr(phiMax)[0:5], "deg")
print("    Bottom at           ", repr(phiMin)[0:5], "deg")
print("    vertical FOV        ", repr(phiMax - phiMin)[0:5], "deg")
print("    Vertical overlap    ", repr(int(100 * Voverlap))+" %")
print("    Horizontal overlap  ", repr(int(100 * Hoverlap))+" %")
if panoheadPhiMin != -90 or panoheadPhiMax != 90 :
    print("\nPano-head:")
    if panoheadPhiMin != -90  :
        print("    downward limit", int(panoheadPhiMin), " deg")
    if panoheadPhiMax != 90 :
        print("    upward limit", int(panoheadPhiMax), " deg")
print(" ")
totalImgNb= int(0)
if trueVfov > trueHfov :
    optimalZenith= 90 - ((trueVfov - trueHfov) / 2)
    optimalNadir= -90 + ((trueVfov - trueHfov) / 2)
else :
    optimalZenith = 90
    optimalNadir = -90               # overlap between zenith disc and top row
if panoheadPhiMax >= optimalZenith \
    and truePhiMax > 90 - (trueHfov / 2 * (1 - max(Voverlap, Hoverlap))) :
    zenith= "yes"
    phiMax= phiMax - (min(trueHfov, trueVfov) / 2 * (1 - max(Voverlap, Hoverlap)))
    totalImgNb= totalImgNb + 1
else :
    zenith= "no"                        # no overlap with zenith hole is wanted
    phiMax= phiMax - (trueVfov * Voverlap / 2)
    print("# phiMax moved downward by", repr(trueVfov * Voverlap / 2)[0:5],
          "deg -----------------------> 0 % overlap with zenith hole")
if (panoheadPhiMin <= optimalNadir) \
    and abs(truePhiMin) > 90 - (trueVfov / 2 * (1 - max(Voverlap, Hoverlap))) :
    nadir=  "yes"
    phiMin= phiMin + (min(trueHfov, trueVfov) / 2 * (1 - max(Voverlap, Hoverlap)))
else :
    nadir= "no"                          # no overlap with nadir hole is wanted
    phiMin= phiMin + (trueVfov * Voverlap / 2)
    print("# phiMin moved upward by", repr(trueVfov * Voverlap / 2)[0:5],
          "deg -------------------------> 0 % overlap with nadir hole")
Vfov=   trueVfov  * (1 - Voverlap)
Hfov=   trueHfov  * (1 - Hoverlap)
Vside=  2 * f * tan(radians(Vfov / 2))
Hside=  2 * f * tan(radians(Hfov / 2))
linV=   1 - Vside / trueVside # Out of disc part of zenith and/or nadir
linH=   1 - Hside / trueHside # not taken into account tough it should be!
if int(linV) != int(linH) :
    print("# Linear vertical overlap   --> ", repr(100 * (linV))[0:5],
          "% of source pixels")
    print("# Linear horizontal overlap --> ", repr(100 * (linH))[0:5],
else :
    print("# Linear overlap --> ", repr(100 * (linV))[0:5],
anglV=  1 - Vfov / trueVfov # idem about out of disc part of zenith, nadir
anglH=  1 - Hfov / trueHfov
if int(100 * (anglV + anglH)) != int(100 * (linV + linH)) :
    if int(anglV) != int(anglH) :
        print("# Angular vertical overlap   --> ", repr(100 * anglV)[0:5], "%")
        print("# Angular horizontal overlap --> ", repr(100 * anglH)[0:5], "%")
    else :
        print("# Angular overlap --> ", repr(100 * anglV)[0:5], "%")
rowNb= (phiMax - phiMin) // Vfov
if rowNb * Vfov < phiMax - phiMin :
    rowNb= rowNb + 1
dPitch= (phiMax - phiMin) / rowNb
sigmaPhi= rowNb * trueVfov
if nadir == "yes" :
    sigmaPhi= sigmaPhi + (trueVfov + trueHfov )/ 2 / 2 # sic!
if zenith == "yes" :
    sigmaPhi= sigmaPhi +  + (trueVfov + trueHfov )/ 2 / 2  # sic!
VangularExcess= (sigmaPhi - (truePhiMax - truePhiMin)) / sigmaPhi
toPrint= "\n" + "Number of rows: " + repr(int(rowNb))
    toPrint= toPrint + " + zenith"
if nadir == "yes" :
    toPrint= toPrint + " + nadir"
print (toPrint + "\n")
print("# Lens vertical angles :    ",
      repr(trueVfov * Voverlap / 2)[0:4], "+", repr(Vfov)[0:4], "+",
      repr(trueVfov * Voverlap / 2)[0:4], "=",repr(trueVfov)[0:4] + " deg")
print("# Lens horizontal angles :  ",
      repr(trueHfov * Hoverlap / 2)[0:4], "+", repr(Hfov)[0:4], "+",
      repr(trueHfov * Hoverlap / 2)[0:4], "=", repr(trueHfov)[0:4] + " deg")
if zenith == "yes" or nadir == "yes" :
    if Hfov < Vfov :
        print("# Zenith and Nadir angles:  ", repr(Hfov / 2)[0:4], "+",
              repr(trueHfov / 2)[0:4] + "deg")
    else :
        print("# Zenith and Nadir angles:  ", repr(Vfov / 2)[0:4], "+",
              repr(trueVfov / 2)[0:4] + " deg")
print("# Modified phiMax = " + repr(phiMax)[0:4] + " deg")
print("# Modified phiMin = " + repr(phiMin)[0:5] + " deg")
print("# Row to row delta Pitch = " +
      repr(dPitch)[0:4] + " deg -----------------------> " +
      repr(int(100 * VangularExcess)) +
      " % vertical angular excess (total angle: " +
      repr(int(sigmaPhi)) + " deg)")
print("#############################")
if nadir== "yes" :
        print("\nNadir shoot at " + repr(optimalNadir)[0:5] + " deg\n")
    else :
        print("\nNadir shoot at -90 deg\n")
    pitchList=  [repr(optimalNadir)[0:5]]           ## 1 ##
    imgNbList=  [int(1)]                            ## 2 ##
    imgYawList= ["0.0"]                             ## 3 ##
else :
    pitchList=  []                                  ## 1 ##
    imgNbList=  []                                  ## 2 ##
    imgYawList= []                                  ## 3 ##
if rowNb != 1 :
    prevTop= phiMin
else :
    prevTop= (phiMin + phiMax) / 2 - Vfov / 2
i= 0
while i < rowNb :                              # begin rows loop <-----------------------------
    bottom= prevTop
    top= prevTop + dPitch
    pitch= (bottom + top) / 2
    if pitch < 0 :
        pitchList= pitchList + [repr(pitch)[0:5]]    ## 1 ##
    else :
        pitchList= pitchList + [repr(pitch)[0:4]]    ## 1 ##
    if abs(bottom) < abs(top) :        # the smaller the distance
        largeCirclePitch= abs(bottom)  # between a circle and the equator
        smallCirclePitch= abs(top)     # ... the larger this circle is
    else:
        largeCirclePitch= abs(top)
        smallCirclePitch= abs(bottom)
    largePitch=  largeCirclePitch
    midlePitch=  (largeCirclePitch + smallCirclePitch) / 2
    smallPitch=  smallCirclePitch
# midlePitch (degrees, unsigned) points to the circle where images
# sides must be adjacent
    MoHSD= f / cos(radians(dPitch / 2)) # MoHSD: Middle of Horizontal Sides
                                        # Distance from sphere center
    circleRadius= MoHSD * cos (radians(midlePitch))
    largeRadius=  MoHSD * cos (radians(largePitch))
    smallRadius=  MoHSD * cos (radians(smallPitch))
    # angle under which is seen an image (decreased for overlap) in the:
    unadjdYaw= degrees(2 * (atan(Hside / 2 / circleRadius)))   # middle circle horizontal plane
    largedYaw= degrees(2 * (atan(trueHside / 2 / largeRadius)))# largest circle horizontal plane
    smalldYaw= degrees(2 * (atan(trueHside / 2 / smallRadius)))# smallest circle horizontal plane
    imgNb= 360 // unadjdYaw
    if imgNb * unadjdYaw < 360 :
        imgNb = imgNb + 1
    dYaw = 360 / imgNb
    if largedYaw < dYaw :
        imgNb= 360 // largedYaw
        if imgNb * largedYaw < 360 :
            imgNb = imgNb + 1
        dYaw = 360 / imgNb
        selected= "# based on LARGE circle, dYaw: " + repr(dYaw)[0:5] + " deg"
    else :
        selected= "# based on MIDLE circle, dYaw: " + repr(dYaw)[0:5] + " deg"
    imgNbList= imgNbList + [int(imgNb)]                ## 2 ##
    HexcessContiguous= (imgNb * unadjdYaw - 360) / 360
    toPrint = "\nrow " + repr(i + 1).ljust(2) + " of " + repr(int(rowNb)) \
            + ", pitch: " + repr(int(pitch)) \
            + " deg      # top overlap at " + repr(int(round(top))) \
            + " deg, bottom overlap at " + repr(int(round(bottom))) + " deg"
    print (toPrint)
    print("                                " + selected)
    if abs(round(top)) == abs(round(bottom)) :
        toPrint= "                                # large circle is any -----> "
    elif largeCirclePitch == abs(bottom) :
        toPrint= "                                # large circle at bottom --> "
    else:
        toPrint= "                                # large circle at top -----> "
    HexcessLarge= (largedYaw - dYaw) / largedYaw
    toPrint= toPrint + repr(int(100 * HexcessLarge)) + " % overlap"
    print (toPrint)
    toPrint=     "             deg                # small circle ------------> "
    HexcessSmall= (smalldYaw - dYaw) / smalldYaw
    toPrint= toPrint + repr(int(100 * HexcessSmall)) + " % overlap"
    print (toPrint)
    dYaw = 360 / imgNb
    j= 0                                  # begin images loop <-----------------
    while j < imgNb :
        imgYawList= imgYawList + [repr(j * dYaw)[0:5]]  ## 3 ##
        print ("    ", repr(j + 1).ljust(2), "yaw:", int(j * dYaw))
        j= j + 1                          # end   images loop <-----------------
    i= i + 1
    prevTop= top                          # end   rows loop <-------------------
        print("\nZenith shoot at " + repr(optimalZenith)[0:4] + " deg")
    else :
        print("\nZenith shoot at 90 deg")
    pitchList= pitchList +  [repr(optimalZenith)[0:4]]   ## 1 ##
    imgNbList= imgNbList + [int(1)]                      ## 2 ##
    imgYawList= imgYawList + ["0.0"]                     ## 3 ##
print("\nTotal number of images: " + repr(totalImgNb) + "\n")
print("#############################\n")
k= 0
for i in range(len(pitchList)) :
    pitchString= 'pitch="' + pitchList[i] + '" yaw="'
    if pitchString[7] == '-' and pitchString[9] == '.' :
        pitchString= pitchString[0:10]+pitchString[11:]
    if i%2!=0:
        for j in range(imgNbList[i]) :
            yawString= imgYawList[k] + '"'; k= k + 1;
            print("<pict " + pitchString + yawString +"/>")
    else:
            yawString= imgYawList[k+imgNbList[i]-2*j-1] + '"'; k= k + 1;
    print("")
#print("the following is buggy...")
#totalArea= totalImgNb * trueVside * trueHside
#imgDiag = sqrt((trueVside)**2 + (trueHside)**2)
#r = sqrt(f**2 + (imgDiag / 2)**2)
#wrapingCylinderHeight = r * (  sin(radians(abs(truePhiMax)))
#                             + sin(radians(abs(truePhiMin))))
#wrapingCylinderArea= 2 * pi * r * wrapingCylinderHeight
kevshu
by kevshu » Sun Oct 16, 2011 11:31 pm
I modified the code to write to an xml file, and it takes an argument for focal length. Just setup the script for your camera, and then run it with the desired focal length.
# Version 0.0.3 - Oct 16, 2011
Vside= 36        # mm, for example 36 mm  \  portrait / landscape
Hside= 24         # mm, for example 24 mm  /  orientation found there
Hoverlap= 0.23      # horizontal overlap, coef from 0 to 0.5 (0% to 50 %)
Voverlap= 0.23       # vertical overlap, coef from 0 up to more than 0.5
import os
import sys
if len(sys.argv)>1:
    f = int(sys.argv[1])
from math import *
trueVside=  Vside
trueHside=  Hside
truePhiMin= phiMin
truePhiMax= phiMax
print("Camera:")
print(" ")
totalImgNb= int(0)
else :
    optimalZenith = 90
    zenith= "yes"
else :
    nadir=  "yes"
else :
else :
    else :
    rowNb= rowNb + 1
if nadir == "yes" :
if nadir == "yes" :
    if Hfov < Vfov :
    else :
if nadir== "yes" :
    else :
else :
if rowNb != 1 :
    prevTop= phiMin
else :
i= 0
    bottom= prevTop
    if pitch < 0 :
    else :
    else:
        imgNb = imgNb + 1
    dYaw = 360 / imgNb
            imgNb = imgNb + 1
        dYaw = 360 / imgNb
    else :
    print (toPrint)
    else:
    print (toPrint)
    print (toPrint)
    dYaw = 360 / imgNb
    while j < imgNb :
    i= i + 1
    else :
xml_file = open(repr(f)[0:5]+ "mm sphere_preset.xml", 'w')
header = "<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<papywizard>\n    <preset name=\""+repr(f)[0:5]+ "mm sphere\">\n        <tooltip>\n"
xml_file.write(header)
xml_file.write("Total number of images: " + repr(totalImgNb) + "\n")
xml_file.write("Camera:\n")
xml_file.write("    Sensor size         "+ repr(trueHside)[0:4] + " x " + repr(trueVside)+"mm\n")
xml_file.write("    Focal length        "+ repr(f)[0:5]+ "mm\n")
xml_file.write("    Lens vertical FOV   "+ str(round(degrees(2 * atan (trueVside / 2 / f))))+ "deg\n")
xml_file.write("    Lens horizontal FOV "+ str(round(degrees(2 * atan (trueHside / 2 / f))))+ "deg\n")
xml_file.write("\nPanorama:\n")
xml_file.write("    Top at              "+ repr(phiMax)[0:5]+ "deg\n")
xml_file.write("    Bottom at           "+ repr(phiMin)[0:5]+ "deg\n")
xml_file.write("    vertical FOV        "+ repr(phiMax - phiMin)[0:5]+ "deg\n")
xml_file.write("    Vertical overlap    "+ repr(int(100 * Voverlap))+" %\n")
xml_file.write("    Horizontal overlap  "+ repr(int(100 * Hoverlap))+" %\n")
header2 = "        </tooltip>\n        <shoot>\n"
xml_file.write(header2)
k= 0
    if i%2!=0:
            xml_file.write("           <pict " + pitchString + yawString +"/>\n")
    else:
    print("")
    xml_file.write("\n")
footer = "         </shoot>\n    </preset>\n\n</papywizard>"
xml_file.write(footer)
xml_file.close()
print("Papywizard preset XML saved as:  "+repr(f)[0:5]+ "mm sphere_preset.xml")
After you save the file to a .py, and setup your sensor size. Just run the script with the focal length as an argument. Eg. "python sphere_calc.py 24" will make a xml file called "24mm sphere_preset.xml"
edit: I edited this line in the script:
if len(sys.argv)>1:
at the top of the script and changed the 0 to 1. There is always 1 argument being sent to the script, and that's the script name. So this now either works with the data in the file, or with a focal length argument.
Kevin Schumacher
Canon 5Dmk2, 15mm Fisheye, 24-70mm, 100mm Macro, 100-400mm, Nodal Ninja 3
Orion GoTo Mount, BT Ver2 Module, Papywizard on Fujitsu LifeBook U810
dekemp
by dekemp » Tue Oct 18, 2011 8:53 pm
I'm not shure if im doing this correctly but i get an error
  File "C:/Users/1337/Desktop/test", line 27, in <module>
IndexError: list index out of range
edit: i was doing it wrong :(. I got one last question. I have a DX sensor. should i typ in the 55mm DX or the 82.5mm FX ?
kevshu
by kevshu » Wed Oct 19, 2011 2:38 am
dekemp wrote:I'm not shure if im doing this correctly but i get an error
Looking at sensor sizes http://en.wikipedia.org/wiki/Nikon_DX_format, a DX is 23.7mm x 15.5mm (depending on camera).
I plan on putting a simple gui to this script since I think it would be a nice tool for people to have easy access to. Hopefully early next week I should have time to finish it up and post it.
Kevin Schumacher
dekemp
by dekemp » Wed Oct 19, 2011 1:34 pm
I meant that my lens is a DX 18-55, and I want to make a script for the 55mm. Do I have to put in the 55mm or the FX equivalent that is 55*1.5=82.5mm in the script?
by fma38 » Thu Oct 20, 2011 2:50 pm
The script uses 24x36 as default sensor size (Hside/Vside). So you need to enter the corrected focal (55 * 1.5 = 82.5mm).
Or you can modify the script with your sensor size:
Vside= 23.6
Hside= 15.8
and then give the real focal (55mm).
pu2wxp
by pu2wxp » Tue Oct 25, 2011 9:33 pm
fma38 wrote:The script uses 24x36 as default sensor size (Hside/Vside). So you need to enter the corrected focal (55 * 1.5 = 82.5mm).
Vside= 23.6
Hside= 15.8
I have an error too:
  File "/Users/lucianocorrea/Pictures/#panoramicas#/PRESETS/NOVOS-PRESETS/papysheric.py", line 137, in <module>
ZeroDivisionError: float division by zero
I am trying to create a preset with this:
f= 35               # mm, for example 50 mm
Luciano Correa
Vista Panoramica
Campos do Jordao SP Brasil
by mediavets » Tue Oct 25, 2011 11:42 pm
The script works OK for me.
Here's the output it created using your parameters:
<?xml version="1.0" encoding="utf-8"?>
<papywizard>
    <preset name="35mm sphere">
        <tooltip>
Total number of images: 46
Camera:
    Sensor size         24 x 36mm
    Focal length        35mm
    Lens vertical FOV   54deg
    Lens horizontal FOV 38deg
Panorama:
    Top at              75.42deg
    Bottom at           -75.4deg
    vertical FOV        150.8deg
    Vertical overlap    23 %
    Horizontal overlap  23 %
        </tooltip>
        <shoot>
           <pict pitch="-81.7" yaw="0.0"/>
           <pict pitch="-56.5" yaw="0.0"/>
           <pict pitch="-56.5" yaw="40.0"/>
           <pict pitch="-56.5" yaw="80.0"/>
           <pict pitch="-56.5" yaw="120.0"/>
           <pict pitch="-56.5" yaw="160.0"/>
           <pict pitch="-56.5" yaw="200.0"/>
           <pict pitch="-56.5" yaw="240.0"/>
           <pict pitch="-56.5" yaw="280.0"/>
           <pict pitch="-56.5" yaw="320.0"/>
           <pict pitch="-18.8" yaw="332.3"/>
           <pict pitch="-18.8" yaw="304.6"/>
           <pict pitch="-18.8" yaw="276.9"/>
           <pict pitch="-18.8" yaw="249.2"/>
           <pict pitch="-18.8" yaw="221.5"/>
           <pict pitch="-18.8" yaw="193.8"/>
           <pict pitch="-18.8" yaw="166.1"/>
           <pict pitch="-18.8" yaw="138.4"/>
           <pict pitch="-18.8" yaw="110.7"/>
           <pict pitch="-18.8" yaw="83.07"/>
           <pict pitch="-18.8" yaw="55.38"/>
           <pict pitch="-18.8" yaw="27.69"/>
           <pict pitch="-18.8" yaw="0.0"/>
           <pict pitch="18.8" yaw="0.0"/>
           <pict pitch="18.8" yaw="27.69"/>
           <pict pitch="18.8" yaw="55.38"/>
           <pict pitch="18.8" yaw="83.07"/>
           <pict pitch="18.8" yaw="110.7"/>
           <pict pitch="18.8" yaw="138.4"/>
           <pict pitch="18.8" yaw="166.1"/>
           <pict pitch="18.8" yaw="193.8"/>
           <pict pitch="18.8" yaw="221.5"/>
           <pict pitch="18.8" yaw="249.2"/>
           <pict pitch="18.8" yaw="276.9"/>
           <pict pitch="18.8" yaw="304.6"/>
           <pict pitch="18.8" yaw="332.3"/>
           <pict pitch="56.5" yaw="320.0"/>
           <pict pitch="56.5" yaw="280.0"/>
           <pict pitch="56.5" yaw="240.0"/>
           <pict pitch="56.5" yaw="200.0"/>
           <pict pitch="56.5" yaw="160.0"/>
           <pict pitch="56.5" yaw="120.0"/>
           <pict pitch="56.5" yaw="80.0"/>
           <pict pitch="56.5" yaw="40.0"/>
           <pict pitch="56.5" yaw="0.0"/>
           <pict pitch="81.7" yaw="0.0"/>
         </shoot>
    </preset>
</papywizard>
pu2wxp
by pu2wxp » Wed Oct 26, 2011 2:45 am
Reporting ... I was trying on my iMac with Python 2.7
I installed on my Macbook to Python 3.2 and it worked perfect.
Luciano Correa
Vista Panoramica
dekemp
by dekemp » Tue Apr 03, 2012 10:17 pm
Any news on the GUI?
I'm trying to run the script but it doesn't make a xml file. And when i run it in the pyhton GUI (run module) it is completely diffrend and unusable for papywizard.
by fma38 » Wed Apr 04, 2012 7:47 am
The zero division error comes from the way different python major releases deal with integer division:
In python 2.x:
1 / 2 = 0
In python 3.x :
1 / 2 = 0.5
If you want a float division in python 2.x, you need to write:
1 / 2. = 0.5
or
1. / 2 = 0.5
So, just change the lines 48/49 from:
to:
trueVfov=   degrees(2 * atan (trueVside / 2. / f))
trueHfov=   degrees(2 * atan (trueHside / 2. / f))
kevshu
by kevshu » Fri Apr 26, 2013 5:43 am
Here's a web interface for creating the PapySpheric templates. I'll keep this hosted at this location.
http://exposedbykevin.com/PapySpheric/papyspheric.html
Source & html available for download http://exposedbykevin.com/PapySpheric/papyspheric_2.7.2_cgi_web.zip
Kevin Schumacher
by fma38 » Fri Apr 26, 2013 7:27 am
Good job! I added a link to your converter on Papywizard web site...
BTW, I started, some months ago, to re-write GURL's script in a more pythonic way (more object), but I'm stuck on the maths; there are too many global vars and so, and it is hard to find what is needed and what is optionnal.
Could someone re-write the maths in a programming-language independant way? I could then write something more robust, which could be integrated to Papywizard or in another applications...
Thanks!
claudevh
by claudevh » Fri Apr 26, 2013 11:34 am
Hello Kevin,
I wish to thank-you ! :)
This is a long time we are all waiting for a Web interface of PapySpheric ...
I have try to save your sources on my PC but without success (the Zip file is empty ...!?)
Could-you see this small problem ?
:cool: Claude :cool:
kevshu
by kevshu » Fri Apr 26, 2013 3:38 pm
The problem was the name of the script. I guess the internet doesn't like .CGI files being downloaded or emailed. I renamed the file to a .TXT and put instructions to rename to .CGI in the zip.
Kevin Schumacher
AlexKuro
by AlexKuro » Fri Apr 26, 2013 6:31 pm
fma38 wrote:BTW, I started, some months ago, to re-write GURL's script in a more pythonic way (more object), but I'm stuck on the maths; there are too many global vars and so, and it is hard to find what is needed and what is optionnal.
Take a look at this script, maybe you will find it usefull. Its more pythonic and way easier to embed, but math there not that good.
https://github.com/snable/pano_360_tools/blob/master/papy-conf2.py
by fma38 » Fri Apr 26, 2013 8:15 pm
Thanks!
Previous
