Ups (can´t upload the txt) how do I do this without copy/paste (it's a little bit long).
2009-10-27 11:34:38,979::Main::INFO::Starting Papywizard...
2009-10-27 11:34:38,994::Main::INFO::Importing modules...
2009-10-27 11:34:39,088::Main::INFO::Loading i18n files...
2009-10-27 11:34:39,104::Main::DEBUG::Papywizard.i18n(): locale=pt_PT
2009-10-27 11:34:39,104::Main::WARNING::Can't find qt translation file
2009-10-27 11:34:39,104::Main::WARNING::Can't find papywizard translation file
2009-10-27 11:34:39,104::Main::INFO::Loading Style Sheets...
2009-10-27 11:34:39,104::Main::WARNING::No user Style Sheet found
2009-10-27 11:34:39,104::Main::INFO::Loading configuration...
2009-10-27 11:34:39,104::Main::DEBUG::ConfigManager.__init__(): versions: dist=['2', '1', '12'], user=[u'2', u'1', u'12']
2009-10-27 11:34:39,104::Main::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2009-10-27 11:34:39,104::Main::INFO::Load plugins...
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_lowLimit, key=LOW_LIMIT, default=-360.0
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_highLimit, key=HIGH_LIMIT, default=360.0
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_speed, key=SPEED, default=30
2009-10-27 11:34:39,104::Main::TRACE::AbstractPlugin._loadConfig()
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._loadConfig(): key=Simulation_yawAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._loadConfig(): key=Simulation_yawAxis/SPEED, defaultValue=30
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._loadConfig(): key=Simulation_yawAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'SPEED': 30, 'LOW_LIMIT': -360.0}
2009-10-27 11:34:39,104::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'yawAxis'
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._loadConfig(): key=Simulation_pitchAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._loadConfig(): key=Simulation_pitchAxis/SPEED, defaultValue=30
2009-10-27 11:34:39,104::Main::DEBUG::AbstractPlugin._loadConfig(): key=Simulation_pitchAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'SPEED': 30, 'LOW_LIMIT': -360.0}
2009-10-27 11:34:39,119::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'pitchAxis'
2009-10-27 11:34:39,119::Main::TRACE::AbstractShutterPlugin._defineConfig()
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_timeValue, key=TIME_VALUE, default=0.5
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_mirrorLockup, key=MIRROR_LOCKUP, default=False
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_bracketingNbPicts, key=BRACKETING_NB_PICTS, default=1
2009-10-27 11:34:39,119::Main::TRACE::AbstractPlugin._loadConfig()
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Simulation_shutter/TIME_VALUE, defaultValue=0.5
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Simulation_shutter/BRACKETING_NB_PICTS, defaultValue=1
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Simulation_shutter/MIRROR_LOCKUP, defaultValue=False
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): config={'TIME_VALUE': 0.5, 'BRACKETING_NB_PICTS': 1, 'MIRROR_LOCKUP': False}
2009-10-27 11:34:39,119::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'shutter'
2009-10-27 11:34:39,119::Main::TRACE::MerlinOrionAxis._init()
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_lowLimit, key=LOW_LIMIT, default=-360.0
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_highLimit, key=HIGH_LIMIT, default=360.0
2009-10-27 11:34:39,119::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_driverType, key=DRIVER_TYPE, default=bluetooth
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_alternateDrive, key=ALTERNATE_DRIVE, default=True
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_inertiaAngle, key=INERTIA_ANGLE, default=1.0
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_yawAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_yawAxis/INERTIA_ANGLE, defaultValue=1.0
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_yawAxis/ALTERNATE_DRIVE, defaultValue=True
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_yawAxis/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_yawAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'INERTIA_ANGLE': 1.0, 'ALTERNATE_DRIVE': True, 'DRIVER_TYPE': u'serial', 'LOW_LIMIT': -360.0}
2009-10-27 11:34:39,119::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'yawAxis'
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/INERTIA_ANGLE, defaultValue=1.0
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/ALTERNATE_DRIVE, defaultValue=True
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,119::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_alternateDrive, key=ALTERNATE_DRIVE, default=True
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_inertiaAngle, key=INERTIA_ANGLE, default=1.0
2009-10-27 11:34:39,134::Main::TRACE::AbstractPlugin._loadConfig()
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/INERTIA_ANGLE, defaultValue=1.0
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/ALTERNATE_DRIVE, defaultValue=True
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_pitchAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'INERTIA_ANGLE': 1.0, 'ALTERNATE_DRIVE': True, 'DRIVER_TYPE': u'serial', 'LOW_LIMIT': -360.0}
2009-10-27 11:34:39,134::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'pitchAxis'
2009-10-27 11:34:39,134::Main::TRACE::MerlinOrionShutter._init()
2009-10-27 11:34:39,134::Main::TRACE::AbstractStandardShutterPlugin._init()
2009-10-27 11:34:39,134::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_driverType, key=DRIVER_TYPE, default=bluetooth
2009-10-27 11:34:39,134::Main::TRACE::AbstractStandardShutterPlugin._defineConfig()
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_timeValue, key=TIME_VALUE, default=0.5
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_mirrorLockup, key=MIRROR_LOCKUP, default=False
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_bracketingNbPicts, key=BRACKETING_NB_PICTS, default=1
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_pulseWidthHigh, key=PULSE_WIDTH_HIGH, default=200
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_pulseWidthLow, key=PULSE_WIDTH_LOW, default=200
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_shutter/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_shutter/PULSE_WIDTH_LOW, defaultValue=200
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_shutter/MIRROR_LOCKUP, defaultValue=False
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_shutter/BRACKETING_NB_PICTS, defaultValue=1
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_shutter/TIME_VALUE, defaultValue=0.5
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Merlin-Orion_shutter/PULSE_WIDTH_HIGH, defaultValue=200
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': u'serial', 'PULSE_WIDTH_LOW': 200, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200}
2009-10-27 11:34:39,134::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'shutter'
2009-10-27 11:34:39,134::Main::TRACE::GenericTetheredShutter._defineConfig()
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_mirrorLockupCommand, key=MIRROR_LOCKUP_COMMAND, default=gphoto2 --capture-image
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_shootCommand, key=SHOOT_COMMAND, default=gphoto2 --capture-image
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Generic Tethered_shutter/BRACKETING_NB_PICTS, defaultValue=1
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Generic Tethered_shutter/MIRROR_LOCKUP_COMMAND, defaultValue=gphoto2 --capture-image
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Generic Tethered_shutter/SHOOT_COMMAND, defaultValue=gphoto2 --capture-image
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Generic Tethered_shutter/MIRROR_LOCKUP, defaultValue=False
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): config={'BRACKETING_NB_PICTS': 1, 'MIRROR_LOCKUP_COMMAND': 'gphoto2 --capture-image', 'SHOOT_COMMAND': 'gphoto2 --capture-image', 'MIRROR_LOCKUP': False}
2009-10-27 11:34:39,134::Main::DEBUG::PluginsManager.register(): added 'Generic Tethered' plugin with capacity 'shutter'
2009-10-27 11:34:39,134::Main::TRACE::TimelordShutter._defineConfig()
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=Program path, key=PROGRAM_PATH, default=C:\Program Files\OxfordEye\Timelord\Timelord.exe
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=LRD file path, key=LRD_FILE, default=C:\Documents and Settings\win2k\My Documents\timelord.lrd
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Timelord_shutter/PROGRAM_PATH, defaultValue=C:\Program Files\OxfordEye\Timelord\Timelord.exe
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Timelord_shutter/LRD_FILE, defaultValue=C:\Documents and Settings\win2k\My Documents\timelord.lrd
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): config={'PROGRAM_PATH': 'C:\\Program Files\\OxfordEye\\Timelord\\Timelord.exe', 'LRD_FILE': 'C:\\Documents and Settings\\win2k\\My Documents\\timelord.lrd'}
2009-10-27 11:34:39,134::Main::DEBUG::PluginsManager.register(): added 'Timelord' plugin with capacity 'shutter'
2009-10-27 11:34:39,134::Main::TRACE::PololuServoAxis._init()
2009-10-27 11:34:39,134::Main::TRACE::PololuServoHardware._init()
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_lowLimit, key=LOW_LIMIT, default=-360.0
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_highLimit, key=HIGH_LIMIT, default=360.0
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_channel, key=CHANNEL, default=1
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_speed, key=SPEED, default=30
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_direction, key=DIRECTION, default=forward
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_angle1ms, key=ANGLE_1MS, default=120.0
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_neutralPos, key=NEUTRAL_POSITION, default=3000
2009-10-27 11:34:39,134::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_yawAxis/NEUTRAL_POSITION, defaultValue=3000
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_yawAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_yawAxis/ANGLE_1MS, defaultValue=120.0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_yawAxis/DIRECTION, defaultValue=forward
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_yawAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_yawAxis/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_yawAxis/SPEED, defaultValue=30
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_yawAxis/CHANNEL, defaultValue=1
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): config={'NEUTRAL_POSITION': 3000, 'HIGH_LIMIT': 360.0, 'ANGLE_1MS': 120.0, 'DIRECTION': PyQt4.QtCore.QString(u'forward'), 'LOW_LIMIT': -360.0, 'DRIVER_TYPE': 'bluetooth', 'SPEED': 30, 'CHANNEL': 1}
2009-10-27 11:34:39,151::Main::DEBUG::PluginsManager.register(): added 'Pololu Servo' plugin with capacity 'yawAxis'
2009-10-27 11:34:39,151::Main::TRACE::PololuServoAxis._init()
2009-10-27 11:34:39,151::Main::TRACE::PololuServoHardware._init()
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_lowLimit, key=LOW_LIMIT, default=-360.0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_highLimit, key=HIGH_LIMIT, default=360.0
2009-10-27 11:34:39,151::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_driverType, key=DRIVER_TYPE, default=bluetooth
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_channel, key=CHANNEL, default=2
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_speed, key=SPEED, default=30
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_direction, key=DIRECTION, default=forward
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_angle1ms, key=ANGLE_1MS, default=120.0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_neutralPos, key=NEUTRAL_POSITION, default=3000
2009-10-27 11:34:39,151::Main::TRACE::AbstractPlugin._loadConfig()
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_pitchAxis/NEUTRAL_POSITION, defaultValue=3000
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_pitchAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_pitchAxis/ANGLE_1MS, defaultValue=120.0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_pitchAxis/DIRECTION, defaultValue=forward
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_pitchAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_pitchAxis/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_pitchAxis/SPEED, defaultValue=30
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_pitchAxis/CHANNEL, defaultValue=2
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): config={'NEUTRAL_POSITION': 3000, 'HIGH_LIMIT': 360.0, 'ANGLE_1MS': 120.0, 'DIRECTION': PyQt4.QtCore.QString(u'forward'), 'LOW_LIMIT': -360.0, 'DRIVER_TYPE': 'bluetooth', 'SPEED': 30, 'CHANNEL': 2}
2009-10-27 11:34:39,151::Main::DEBUG::PluginsManager.register(): added 'Pololu Servo' plugin with capacity 'pitchAxis'
2009-10-27 11:34:39,151::Main::TRACE::PololuServoShutter._init()
2009-10-27 11:34:39,151::Main::TRACE::AbstractStandardShutterPlugin._init()
2009-10-27 11:34:39,151::Main::TRACE::AbstractStandardShutterPlugin._defineConfig()
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_timeValue, key=TIME_VALUE, default=0.5
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_mirrorLockup, key=MIRROR_LOCKUP, default=False
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_bracketingNbPicts, key=BRACKETING_NB_PICTS, default=1
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_pulseWidthHigh, key=PULSE_WIDTH_HIGH, default=200
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_pulseWidthLow, key=PULSE_WIDTH_LOW, default=200
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_channel, key=CHANNEL, default=0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_valueOff, key=VALUE_OFF, default=0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_valueOn, key=VALUE_ON, default=127
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_shutter/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_shutter/VALUE_OFF, defaultValue=0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_shutter/PULSE_WIDTH_LOW, defaultValue=200
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_shutter/MIRROR_LOCKUP, defaultValue=False
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_shutter/BRACKETING_NB_PICTS, defaultValue=1
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_shutter/TIME_VALUE, defaultValue=0.5
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_shutter/VALUE_ON, defaultValue=127
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_shutter/PULSE_WIDTH_HIGH, defaultValue=200
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): key=Pololu Servo_shutter/CHANNEL, defaultValue=0
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'VALUE_OFF': 0, 'PULSE_WIDTH_LOW': 200, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'VALUE_ON': 127, 'PULSE_WIDTH_HIGH': 200, 'CHANNEL': 0}
2009-10-27 11:34:39,151::Main::DEBUG::PluginsManager.register(): added 'Pololu Servo' plugin with capacity 'shutter'
2009-10-27 11:34:39,151::Main::TRACE::EOSUtilityShutter._defineConfig()
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_programPath, key=PROGRAM_PATH, default=C:\Program Files\Papywizard\EOSBracket.exe
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_eosUtilityVersion, key=EOS_UTILITY_VERSION, default=new
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_bracketingStops, key=BRACKETING_STOPS, default=1
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_bracketingType, key=BRACKETING_TYPE, default=0-+
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_dryRun, key=DRY_RUN, default=True
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_bulbEnable, key=BULB_ENABLE, default=False
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_bulbBseExposure, key=BULB_BASE_EXPOSURE, default=1
2009-10-27 11:34:39,151::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_focusEnable, key=FOCUS_ENABLE, default=False
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_focusDirection, key=FOCUS_DIRECTION, default=far
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_focusStep, key=FOCUS_STEP, default=medium
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_focusStepCount, key=FOCUS_STEP_COUNT, default=1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_focusNbPicts, key=FOCUS_NB_PICTS, default=1
2009-10-27 11:34:39,167::Main::TRACE::AbstractPlugin._loadConfig()
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/FOCUS_DIRECTION, defaultValue=far
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/BRACKETING_TYPE, defaultValue=0-+
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/BULB_ENABLE, defaultValue=False
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/DRY_RUN, defaultValue=True
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/BULB_BASE_EXPOSURE, defaultValue=1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/FOCUS_NB_PICTS, defaultValue=1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/BRACKETING_NB_PICTS, defaultValue=1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/FOCUS_STEP_COUNT, defaultValue=1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/FOCUS_ENABLE, defaultValue=False
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/EOS_UTILITY_VERSION, defaultValue=new
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/PROGRAM_PATH, defaultValue=C:\Program Files\Papywizard\EOSBracket.exe
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/BRACKETING_STOPS, defaultValue=1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=EOS Utility_shutter/FOCUS_STEP, defaultValue=medium
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): config={'FOCUS_DIRECTION': PyQt4.QtCore.QString(u'far'), 'BRACKETING_TYPE': '0-+', 'BULB_ENABLE': False, 'DRY_RUN': True, 'BULB_BASE_EXPOSURE': 1, 'FOCUS_NB_PICTS': 1, 'BRACKETING_NB_PICTS': 1, 'FOCUS_STEP_COUNT': 1, 'FOCUS_ENABLE': False, 'EOS_UTILITY_VERSION': PyQt4.QtCore.QString(u'new'), 'PROGRAM_PATH': 'C:\\Program Files\\Papywizard\\EOSBracket.exe', 'BRACKETING_STOPS': '1', 'FOCUS_STEP': PyQt4.QtCore.QString(u'medium')}
2009-10-27 11:34:39,167::Main::DEBUG::PluginsManager.register(): added 'EOS Utility' plugin with capacity 'shutter'
2009-10-27 11:34:39,167::Main::TRACE::UrsaMinorUsbShutter._init()
2009-10-27 11:34:39,167::Main::TRACE::AbstractStandardShutterPlugin._init()
2009-10-27 11:34:39,167::Main::TRACE::UrsaMinorUsbShutter._defineConfig()
2009-10-27 11:34:39,167::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_driverType, key=DRIVER_TYPE, default=bluetooth
2009-10-27 11:34:39,167::Main::TRACE::AbstractStandardShutterPlugin._defineConfig()
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_timeValue, key=TIME_VALUE, default=0.5
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_mirrorLockup, key=MIRROR_LOCKUP, default=False
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_bracketingNbPicts, key=BRACKETING_NB_PICTS, default=1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_pulseWidthHigh, key=PULSE_WIDTH_HIGH, default=200
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_pulseWidthLow, key=PULSE_WIDTH_LOW, default=200
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_triggerLine, key=TRIGGER_LINE, default=RTS
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_triggerLineInverted, key=TRIGGER_LINE_INVERTED, default=False
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=Ursa Minor USB_shutter/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=Ursa Minor USB_shutter/TRIGGER_LINE_INVERTED, defaultValue=False
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=Ursa Minor USB_shutter/PULSE_WIDTH_LOW, defaultValue=200
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=Ursa Minor USB_shutter/MIRROR_LOCKUP, defaultValue=False
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=Ursa Minor USB_shutter/BRACKETING_NB_PICTS, defaultValue=1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=Ursa Minor USB_shutter/TRIGGER_LINE, defaultValue=RTS
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=Ursa Minor USB_shutter/TIME_VALUE, defaultValue=0.5
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=Ursa Minor USB_shutter/PULSE_WIDTH_HIGH, defaultValue=200
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'TRIGGER_LINE_INVERTED': False, 'PULSE_WIDTH_LOW': 200, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TRIGGER_LINE': 'RTS', 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200}
2009-10-27 11:34:39,167::Main::DEBUG::PluginsManager.register(): added 'Ursa Minor USB' plugin with capacity 'shutter'
2009-10-27 11:34:39,167::Main::TRACE::PixOrbAxis._init()
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_lowLimit, key=LOW_LIMIT, default=-360.0
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_highLimit, key=HIGH_LIMIT, default=360.0
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_speedIndex, key=SPEED_INDEX, default=9
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_axisWithBreak, key=AXIS_WITH_BREAK, default=False
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_axisAccuracy, key=AXIS_ACCURACY, default=0.1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/AXIS_ACCURACY, defaultValue=0.1
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/SPEED_INDEX, defaultValue=9
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/AXIS_WITH_BREAK, defaultValue=False
2009-10-27 11:34:39,167::Main::DEBUG::AbstractPlugin._loadConfig(): config={'AXIS_ACCURACY': 0.10000000000000001, 'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'SPEED_INDEX': 9, 'AXIS_WITH_BREAK': False}
2009-10-27 11:34:39,181::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_driverType, key=DRIVER_TYPE, default=bluetooth
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_speedIndex, key=SPEED_INDEX, default=9
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_axisWithBreak, key=AXIS_WITH_BREAK, default=False
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_axisAccuracy, key=AXIS_ACCURACY, default=0.1
2009-10-27 11:34:39,181::Main::TRACE::AbstractPlugin._loadConfig()
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/AXIS_ACCURACY, defaultValue=0.1
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/SPEED_INDEX, defaultValue=9
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_yawAxis/AXIS_WITH_BREAK, defaultValue=False
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): config={'AXIS_ACCURACY': 0.10000000000000001, 'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'SPEED_INDEX': 9, 'AXIS_WITH_BREAK': False}
2009-10-27 11:34:39,181::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'yawAxis'
2009-10-27 11:34:39,181::Main::TRACE::PixOrbAxis._init()
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_lowLimit, key=LOW_LIMIT, default=-360.0
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_highLimit, key=HIGH_LIMIT, default=360.0
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_pitchAxis/AXIS_ACCURACY, defaultValue=0.1
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_pitchAxis/HIGH_LIMIT, defaultValue=360.0
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_pitchAxis/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_pitchAxis/LOW_LIMIT, defaultValue=-360.0
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_pitchAxis/SPEED_INDEX, defaultValue=9
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_pitchAxis/AXIS_WITH_BREAK, defaultValue=False
2009-10-27 11:34:39,181::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'pitchAxis'
2009-10-27 11:34:39,181::Main::TRACE::PixOrbShutter._init()
2009-10-27 11:34:39,181::Main::TRACE::AbstractStandardShutterPlugin._init()
2009-10-27 11:34:39,181::Main::TRACE::AbstractStandardShutterPlugin._defineConfig()
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_timeValue, key=TIME_VALUE, default=0.5
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_mirrorLockup, key=MIRROR_LOCKUP, default=False
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_bracketingNbPicts, key=BRACKETING_NB_PICTS, default=1
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_pulseWidthHigh, key=PULSE_WIDTH_HIGH, default=200
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_pulseWidthLow, key=PULSE_WIDTH_LOW, default=200
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_shutter/DRIVER_TYPE, defaultValue=bluetooth
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_shutter/PULSE_WIDTH_LOW, defaultValue=200
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_shutter/MIRROR_LOCKUP, defaultValue=False
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_shutter/BRACKETING_NB_PICTS, defaultValue=1
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_shutter/TIME_VALUE, defaultValue=0.5
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): key=PixOrb_shutter/PULSE_WIDTH_HIGH, defaultValue=200
2009-10-27 11:34:39,181::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 200, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200}
2009-10-27 11:34:39,181::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'shutter'
2009-10-27 11:34:39,197::Main::DEBUG::DslrRemoteProShutter._defineConfig()
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_mirrorLockup, key=MIRROR_LOCKUP, default=False
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_userExposureCompensationList, key=USER_EXPOSURE_COMPENSATION_LIST, default=-2, 0, +2
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_dryRun, key=DRY_RUN, default=False
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_outputDir, key=OUTPUT_DIR, default=C:\Users\Paulo
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_filenamePrefix, key=FILENAME_PREFIX, default=
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._addConfigKey(): attr=_cameraExposureCompensationList, key=CAMERA_EXPOSURE_COMPENSATION_LIST, default=±2@1/2
2009-10-27 11:34:39,197::Main::TRACE::AbstractPlugin._loadConfig()
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._loadConfig(): key=DSLR Remote Pro_shutter/USER_EXPOSURE_COMPENSATION_LIST, defaultValue=-2, 0, +2
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._loadConfig(): key=DSLR Remote Pro_shutter/DRY_RUN, defaultValue=False
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._loadConfig(): key=DSLR Remote Pro_shutter/MIRROR_LOCKUP, defaultValue=False
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._loadConfig(): key=DSLR Remote Pro_shutter/FILENAME_PREFIX, defaultValue=
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._loadConfig(): key=DSLR Remote Pro_shutter/CAMERA_EXPOSURE_COMPENSATION_LIST, defaultValue=±2@1/2
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._loadConfig(): key=DSLR Remote Pro_shutter/OUTPUT_DIR, defaultValue=C:\Users\Paulo
2009-10-27 11:34:39,197::Main::DEBUG::AbstractPlugin._loadConfig(): config={'USER_EXPOSURE_COMPENSATION_LIST': '-2, 0, +2', 'DRY_RUN': False, 'MIRROR_LOCKUP': False, 'FILENAME_PREFIX': '', 'CAMERA_EXPOSURE_COMPENSATION_LIST': u'\xb12@1/2', 'OUTPUT_DIR': 'C:\\Users\\Paulo'}
2009-10-27 11:34:39,197::Main::DEBUG::PluginsManager.register(): added 'DSLR Remote Pro' plugin with capacity 'shutter'
2009-10-27 11:34:39,197::Main::INFO::Loading user plugins...
2009-10-27 11:34:39,197::Main::DEBUG::PluginsManager.register(): parsing 'C:\Users\Paulo\AppData\Roaming\papywizard2\plugins' dir...
2009-10-27 11:34:39,197::Main::INFO::Activate plugins...
2009-10-27 11:34:39,197::Main::TRACE::MerlinOrionHardware.activate()
2009-10-27 11:34:39,197::Merlin-Orion_yawAxis::DEBUG::MerlinOrionAxis.run(): start thread
2009-10-27 11:34:39,197::Merlin-Orion_pitchAxis::DEBUG::MerlinOrionAxis.run(): start thread
2009-10-27 11:34:39,197::Main::INFO::Creating model...
2009-10-27 11:34:39,213::Main::INFO::Loading default presets
2009-10-27 11:34:39,213::Main::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2009-10-27 11:34:39,213::Main::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2009-10-27 11:34:39,213::Main::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2009-10-27 11:34:39,213::Main::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2009-10-27 11:34:39,213::Main::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2009-10-27 11:34:39,213::Main::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2009-10-27 11:34:39,213::Main::INFO::Loading user presets
2009-10-27 11:34:39,213::Main::WARNING::No user presets found
2009-10-27 11:34:39,213::Main::INFO::Starting Spy...
2009-10-27 11:34:39,213::Main::INFO::Creating GUI...
2009-10-27 11:34:39,213::Spy::INFO::Starting Spy...
2009-10-27 11:34:39,213::Spy::INFO::Spy suspended
2009-10-27 11:34:39,306::Main::WARNING::MainController.__getFullScreenFlag(): fix fullScreenFlag property!!!
2009-10-27 11:34:41,954::Main::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2009-10-27 11:34:41,954::Main::INFO::Starting connection. Please wait...
2009-10-27 11:34:41,986::Main::DEBUG::PluginsConnector.start(): 'yawAxis' establish connection
2009-10-27 11:34:44,046::Main::DEBUG::PluginsConnector.start(): 'yawAxis' init
2009-10-27 11:34:45,121::Main::EXCEPTION::MerlinOrionHardware._sendCmd
File "papywizard\plugins\merlinOrionPlugins.pyo", line 176, in _sendCmd
File "papywizard\hardware\serialDriver.pyo", line 115, in read
IOError: Timeout while reading on serial bus (size=1, data='')
2009-10-27 11:34:45,121::Main::WARNING::MerlinOrionHardware._sendCmd(): Merlin-Orion axis 1 can't sent command 'L1'. Retrying...
2009-10-27 11:34:46,183::Main::EXCEPTION::MerlinOrionHardware._sendCmd
2009-10-27 11:34:46,183::Main::WARNING::MerlinOrionHardware._sendCmd(): Merlin-Orion axis 1 can't sent command 'L1'. Retrying...
2009-10-27 11:34:47,259::Main::EXCEPTION::MerlinOrionHardware._sendCmd
2009-10-27 11:34:47,259::Main::WARNING::MerlinOrionHardware._sendCmd(): Merlin-Orion axis 1 can't sent command 'L1'. Retrying...
2009-10-27 11:34:47,259::Main::EXCEPTION::PluginsConnector.connectPlugins()
File "papywizard\plugins\pluginsConnector.pyo", line 89, in start
File "papywizard\plugins\merlinOrionPlugins.pyo", line 339, in init
File "papywizard\plugins\merlinOrionPlugins.pyo", line 207, in _initMerlinOrion
File "papywizard\plugins\merlinOrionPlugins.pyo", line 193, in _sendCmd
HardwareError: Merlin-Orion axis 1 can't send command 'L1'
2009-10-27 11:34:47,259::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' establish connection
2009-10-27 11:34:47,259::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' init
2009-10-27 11:34:48,319::Main::EXCEPTION::MerlinOrionHardware._sendCmd
2009-10-27 11:34:48,319::Main::WARNING::MerlinOrionHardware._sendCmd(): Merlin-Orion axis 2 can't sent command 'L2'. Retrying...
2009-10-27 11:34:49,381::Main::EXCEPTION::MerlinOrionHardware._sendCmd
2009-10-27 11:34:49,381::Main::WARNING::MerlinOrionHardware._sendCmd(): Merlin-Orion axis 2 can't sent command 'L2'. Retrying...
2009-10-27 11:34:50,441::Main::EXCEPTION::MerlinOrionHardware._sendCmd
2009-10-27 11:34:50,441::Main::WARNING::MerlinOrionHardware._sendCmd(): Merlin-Orion axis 2 can't sent command 'L2'. Retrying...
2009-10-27 11:34:50,441::Main::EXCEPTION::PluginsConnector.connectPlugins()
File "papywizard\plugins\pluginsConnector.pyo", line 108, in start
HardwareError: Merlin-Orion axis 2 can't send command 'L2'
2009-10-27 11:34:50,441::Main::DEBUG::PluginsConnector.start(): 'shutter' establish connection
2009-10-27 11:34:50,441::Main::DEBUG::PluginsConnector.start(): 'shutter' init
2009-10-27 11:34:51,517::Main::EXCEPTION::MerlinOrionHardware._sendCmd
2009-10-27 11:34:51,517::Main::WARNING::MerlinOrionHardware._sendCmd(): Merlin-Orion axis 1 can't sent command 'L1'. Retrying...
2009-10-27 11:34:52,594::Main::EXCEPTION::MerlinOrionHardware._sendCmd
2009-10-27 11:34:52,594::Main::WARNING::MerlinOrionHardware._sendCmd(): Merlin-Orion axis 1 can't sent command 'L1'. Retrying...
2009-10-27 11:34:53,654::Main::EXCEPTION::MerlinOrionHardware._sendCmd
2009-10-27 11:34:53,654::Main::WARNING::MerlinOrionHardware._sendCmd(): Merlin-Orion axis 1 can't sent command 'L1'. Retrying...
2009-10-27 11:34:53,654::Main::EXCEPTION::PluginsConnector.connectPlugins()
File "papywizard\plugins\pluginsConnector.pyo", line 126, in start
File "papywizard\plugins\merlinOrionPlugins.pyo", line 521, in init
2009-10-27 11:34:53,654::Main::ERROR::Connection failed to start
2009-10-27 11:34:57,102::Main::DEBUG::MainController.__onActionHardwareConnectToggled(False)
2009-10-27 11:34:57,118::Main::DEBUG::PluginsConnector.start(): 'yawAxis' stop connection
2009-10-27 11:34:57,118::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' stop connection
2009-10-27 11:34:57,118::Main::DEBUG::PluginsConnector.start(): 'shutter' stop connection
