Main and usefull topics
by fma38 » Wed Aug 19, 2009 1:18 pm
If you see other usefull topics I can put here, feel free to tell me...
claudevh
by claudevh » Wed Aug 19, 2009 6:52 pm
Hi Frederic,
You can add :
http://www.autopano.net/wiki-en/action/view/PapyMerlin_FAQ
In progress ...!
:cool: Claude :cool:
by fma38 » Wed Aug 19, 2009 9:20 pm
The idea was to put only links on forums topics, here...
by mediavets » Mon Dec 17, 2012 6:16 pm
Frédéric (fma38), the developer of Papywizard, has asked me to let everyone know that's he's managed to get the Papywizard project web site back online:
http://www.papywizard.org
rruiz
Liked in: 5 posts
Re: Main and usefull topics
by rruiz » Sun May 17, 2015 2:14 pm
Non of these links are working.
[merlin/orion] Interface
Bluetooth Interface for Merlin ready (Teleskop Austria bluetooth interface)
I want to know if this b&h head could works:
http://www.bhphotovideo.com/c/product/7 ... Mount.html
claudevh
by claudevh » Sun May 17, 2015 3:31 pm
Yes this can work , but quite heavy !
Let us know where you live and we can better help you ...
rruiz
Liked in: 5 posts
by rruiz » Sun May 17, 2015 3:35 pm
Thanks a lot.
I live at Mexico but would be at New York taking some vacation days. Can you help me?
Thanks anticipated
by klausesser » Sun May 17, 2015 3:40 pm
rruiz wrote:Non of these links are working.
Afaik somebody here has one - but i don´t know how it works.
In the price-range i would suggest the Merlin/Orion head. Very much users, much experience, many add-ons.
There are some kind of controlling it:
Papywizard on Notebook via USB --> serial translator - cheap.
PapyWizard on a Nokia 800/810 mini-tablet via Bluetooth - old but cheap. Works not bad . .
The T&C touch-control - 200.-€, but flawlessly working, very small and very much elaborated. More than
400 sold units so far. No problems at all. Plug and play.
The Panoshoot - well . . long story. Afaik never worked as expected. Kolor took it off the list.
claudevh
by claudevh » Sun May 17, 2015 3:42 pm
Yes, it can work but quite heavy ...
You can get the BT module from:
http://magasin.skivr.com/en/accessoires-panogear/155-bluetooth-module-for-panogear-merlin-head.html
by klausesser » Sun May 17, 2015 3:44 pm
claudevh wrote:Yes, it can work but quite heavy ...
Sorry, Claude - i forgot!
rruiz
Liked in: 5 posts
by rruiz » Sun May 17, 2015 5:17 pm
Thanks Claude / Klausesser; resolved my issue in regards the Bluetooth >> will buy at magasin.skivr
Will continue searching for Merlin/Orion head.
I don´t know why but I can´t find a USA/America dealer for this specific model. I know it was discontinued and one of the substitute was the intial one I mentioned from b&h.
Regards
by klausesser » Sun May 17, 2015 5:34 pm
rruiz wrote:Thanks Claude / Klausesser; resolved my issue in regards the Bluetooth >> will buy at magasin.skivr
Regards
Afaik it´s named completely different is the US. Will have a look.
by mediavets » Sun May 17, 2015 5:47 pm
rruiz wrote:Will continue searching for Merlin/Orion head.
I don't think it is marketed in the USA anymore. But it is widely available in Europe.
claudevh
by claudevh » Sun May 17, 2015 9:43 pm
As said by Mediavets...
This is not marketed in North America.
The All View have replaced the Merlin head ... and several "panographers" are using the Allview with Papywizard, or PandroidWizard without any problems except the weight !
You must also know that the Allview has a handcontroler who is able to take panorama (natively) without external software.
claudevh
by claudevh » Sun May 17, 2015 9:53 pm
A dedicated "Topic" about Allview exist in the Kolor forum:
http://www.kolor.com/forum/viewforum.php?f=45
rruiz
Liked in: 5 posts
Generator for dji Phantom Pictures
by rruiz » Tue May 19, 2015 1:36 am
I used the Generator from Kevin:
http://exposedbykevin.com/PapySpheric/papyspheric.html
Manually I took several night pics using a Phantom 2 vision drone:
http://www.dji.com/product/phantom-2-vision-plus/spec
Sensor size of 1/2.3"
Based on their specs it generated 195 pictures to create a partial pano.
In the real world, manually I took 21 pictures trying to overlap them and the pano was fine!
What I did wrong with the generator? What inputs would be the correct ones?
The botton line is>>
I want to take more night panos, so I am trying to figure out how to obtain good stitching on those dificult cases using my drone.
Regards
by mediavets » Tue May 19, 2015 4:09 am
Where did you get the focal length of 14mm from and those sensor dimensions.
Is the drone camera mounted in portrait or landscape orientation?
I saw someone claim a focal length of 5mm and sensor dimension of 6.17 x 4.55 mm for Phantom 2 vision plus and those values generated a preset with 28 images to cover a full sphere.
rruiz
Liked in: 5 posts
by rruiz » Tue May 19, 2015 5:21 am
Another example more clear... the Inspire1 has a 20mm with 1/2.3"(since I will also be using this drone)
http://www.dji.com/product/inspire-1/spec
http://es.wikipedia.org/wiki/Formato_de ... rSizes.svg
Or do I am missunderstanding FOCAL LENGHT and SENSOR SIZE? Please correct me !
