[Papywizard] Multi format preset generator
sjhenry
by sjhenry » Tue Jul 21, 2009 3:38 pm
Frederic,
Thanks for the explanation. I should be more clear.
Georg,
This preset needs two information. The first information is about the source camera system so that the script can calculate the FOV etc for each shot. It also needs to calculate the target or output FOV. In order to calculate that it needs to know of the target format, its focal length and its orientation. This is similar to what you enter as number of shots or FOV in the Papywizard.
The beauty of the script is to simulate multiple format with multiple lens at your hand with your source camera and lens.
The current script is not checking for any FOV restriction of the source and target formats whether the output FOV is smaller than the source FOV. The example you gave source 18 mm and targe 400mm, it will still create a preset which has only one shot.
I am showing here the toopltip generated in that case.
<tooltip>
Source:
Format: 35mm (1.6 Crop, 3:2 Aspect Ratio, Portrait orientation)
Focal Length: 18mm lens, overlap: 25%, Horizontal FOV: 33.9, Vertical FOV: 53.3
Rows: 1, Columns: 1
Target:
Format: 6X17(Landscape orientation)
Focal Length: 400mm lens, Horizontal FOV: 23.7, Vertical FOV: 8
Horizontal Size: 1608, Vertical Size: 536
Mosaic Horizontal FOV: 49.9, Vertical FOV: 64.6
Mosaic Horizontal Size: 3343, Vertical Size: 4328
</tooltip>
As you see, the ouput FOV is smaller than the input FOV. So you do a crop 1608,536 pixels of 4272, 2848 pixels of the one shot taken by Reble XSI as mentioned in the tooltip.
Jones.
sjhenry
by sjhenry » Wed Jul 22, 2009 2:39 am
As per the request of one of the Papywizard users, I added 12 different medium format camera/digital back system to the crop factor drop down. All the 35mm format now show up as
35mm(1.0 Crop)
35mm(1.3 Crop)
etc
All the medium format camera/digital back will show up as
MF(56.0X41.5)
MF(56.0X36.0)
etc
where the first number is the width of the medium format camera/digital back sensor in mm
and the second number is the height of the medium format camera/digital back sensor in mm
Please use the first thread to update your version of the script and also refer to the "Crop Factor" section to identify the 35mm crop and medium format camera by its sensor size.
Jones
by AlexandreJ » Wed Jul 29, 2009 1:32 pm
About crop factor.
You can use the huge list provided with autopano to calculate the sensor scale. It's a file called cameras.txt and gives sensors scale for about 1100 camera now.
This file can be found in installation folder of autopano ( ressources folder ).
sjhenry
by sjhenry » Fri Jul 31, 2009 1:52 pm
Alexandre,
Thanks for information about the crop readily available. Let me take a look at the file and see how it can be included in the script. It will make it easier to choose by the camera name rather than the crop factor.
Jones
mark_anderson_us
by mark_anderson_us » Sat May 15, 2010 1:21 am
what am i missing here?
where do i specify my fov for the shot. i tried a couple of different sets of values and the most i could get is 116-degrees
i'd expect to be able to enter my fov and overlap to get the presets
regards
mark
Canon EOS 30D with BG-E2 grip
50mm f1.4, 16-35mm f2.8L, 28-70mm f2.8L, 70-200mm f2.8L, 100mm f2.8 Macro
Gitzo 2531, Merlin/Orion
by fma38 » Sat May 15, 2010 7:28 am
This preset generator simulates a lens, which then results in a total fov, depending on the crop factor of the camera sensor used behind. If you want to give a fov, just use Papywizard, which can do that.
rruiz
Liked in: 5 posts
Re: [Papywizard] Multi format preset generator
by rruiz » Sun May 17, 2015 12:35 am
Dear Jones
I do aerial panos.
https://drive.google.com/folderview?id= ... sp=sharing
Here are some files for your reference.
An example of a final result is something like this:
https://www.google.com/maps/views/u/0/v ... 90&fovy=75
There was no problem using Autopano Giga Pro, but in some other cases I need to simulate papywizard method.
My concern, and question is:
WHAT PARAMETERS NEED TO BE ENTERED FOR A PARCIAL PANORAMA, THAT AT THE END OF THE DAY WILL BE A 360x180 ?
Regards
Roberto
Previous
