Thethered bracketing with EOS Utility and Papywizard
Re: Thethered bracketing with EOS Utility and Papywizard
by klausesser » Sun Mar 22, 2015 2:14 pm
pwaitzman wrote: will be AETTR to maintain correct exposure during sunset.
What´s "AETTR"??
Do you mean something with AutoExposure? Don´t use this for shooting panos with bracketing. NEVER.
The point with bracketing is to have different exposures. So take a measuring manually and set
the time for the correct exposure, resp. an optimal exposure. The camera takes under- and overexposed pictures then.
That´s what you need.
I really don´t know what "AETTR" is.
pwaitzman
by pwaitzman » Sun Mar 22, 2015 8:52 pm
Klause,
see the link in the magic lantern manual:
http://wiki.magiclantern.fm/userguide#e ... right_ettr
http://wiki.magiclantern.fm/ettr
it allows automatic exposure setting to limit over exposed pixels. i tought i would experiment to see if it adjusts the "0" EV shot and brackets around that or if it would set the exposure on all of the brackets. If the later is the case (and i suspect that it might be) then, as you say, that pretty much defeats the purpose. but i thought i would give it a try and see what happens.
pwaitzman
by pwaitzman » Sun Mar 22, 2015 8:56 pm
but again ... i may be over complicating the whole thing!
by klausesser » Sun Mar 22, 2015 9:19 pm
pwaitzman wrote:but again ... i may be over complicating the whole thing!
Seems so . . ;)
The trick is to set the optimal value for "0". Look for an average point of brightness and set this one as "0".
The rest happens from alone.
pwaitzman
by pwaitzman » Mon Mar 23, 2015 12:41 am
but if the optimal value is changing then ...
i've been thinking about bracketed panoramic shots at sunrise or sunsets where the exposure requirements will likely change during the shoot since with the longer exposures included in the brackets might be 25 or 30 seconds or so. i like shooting sunrise or sunsets but i haven't tried a panoramic, so i'm thinking about how i can change the baseline during the process.
paul
pwaitzman
by pwaitzman » Mon Mar 23, 2015 12:46 am
looks like ML bracket will work in aperture priority maybe i'll just try that for starters.
i told you ... i'm over complicating again.
Previous
