PapyWizard and Ubuntu
olihar
by olihar » Wed Mar 25, 2009 7:46 pm
Hi there gang, great project you have going here.
First of all I will explain a little what I will be working on with this project, I am doing my BA in Interaction Design and got interested in trying to capture "pieces of time in space". I look forward to get down into this and I am trying to order a Merlin from the UK as we speak. (some postal request info needed) I have as well ordered a a BlueSMiRF Silver to hook up to it to connect. Hopefully I will get that in the next 2 weeks.
I have been looking around for some used Nokia N800 or N810 to use in this project. I have however been looking more into getting a eeePC and run Ubuntu on it. So I can use that device for something else then this project as well. As well the eeePC will most likely be a little cheaper then the Nokia in the end.
I however have been very excited about the whole Mac implementations as I am a Mac only user, and have seen iPhone talks here on more then one occasion, I do understand that there are many problems with the whole iPhone so I am not even going to mention that more for now.
What I have been doing now is I got the
Papywizard.app.zip -- MacOS 10.5 binary (more or less release 1.9.6)
and that seems to run fine, as far as I can see in the forum it does not work with the device as of now (bluetooth), I cant try as I have not made it yet.
So
I installed Ubuntu with VmWare and have that up and running on my Mac, fine enough I don't have that much experience with Linux but a little. So what I did was I tried to follow the Wiki and tried to install the program. Like so, open Terminal and go to the right folder and type in.
$ sudo python setup.py install --prefix=/usr/local
I can see the application is there but I am not able to open it. usr/local/share/applications. as well it is under applications and graphic in the head menu, nothing happens when I click it.
Any ideas what I am doing wrong?
As I would be very interested to get it running on a eeePC. As well I cant try anything with a Nokia device as I will hold a little with buying one of them.
and again great job guys and I look forward to some more writing here in the future.
To whom that are interested in seeing some of my work using a Nodal Ninja. Can go here. http://www.olihar.com/gallery/pages/Panorama
Best
Olafur Haraldsson
by fma38 » Wed Mar 25, 2009 8:56 pm
Hello and welcome!
What Papywizard version did you download? Can you try to run:
$ papywizard.sh
from your shell? What is the error?
bigwade
by bigwade » Wed Mar 25, 2009 9:05 pm
Hi Olafur, welcome here
Just curious, why do you want to buy a Merlin from UK ?
Is it cheaper than from Teleskop Austria ?
geraldcor
by geraldcor » Wed Mar 25, 2009 10:20 pm
I run papywizard on my eeepc running easy peasy (an ubuntu variant for netbooks). You seem to have installed it correctly. Just do as Frédéric said and type papywizard.sh from the terminal. It runs really well on my eeepc and the battery life is very agreeable.
If I may slip in an iPhone news item, Apple has just released the new SDK for os 3.0 which opens up the bluetooth interface. Now I know the iphone won't run python (will it?), but it is one step closer to papywizard on the iphone, although that would require a rewrite in objective C and that doesn't sound too fun :).
Greg
Canon Rebel XT XTi
EF-S 18-55 IS, EF-S 17-85 IS, EF 50 1.8
Asus EEEpc, OLPC, Arduino (In the works)
Papywizard of course
tarnis
by tarnis » Thu Mar 26, 2009 1:30 pm
I ran it on Ubuntu no problems launching when I d/led the source and just ran it from the command prompt. The only real problem I ran into was configuring the bluetooth adaptor to use a serial port...wasn't a big deal yet so I haven't asked if anyone has any suggestions while the topic is open though. I'm probably going with a netbook as well so will be needing to do it once I order. At the time was just trying to so it if was a windows issue when the bluetooth chip was giving me problems.
olihar
by olihar » Thu Mar 26, 2009 1:34 pm
fma38 wrote:Hello and welcome!
$ papywizard.sh
I am probably doing something completely wrong here due to lack and rusty knowledge about Ubuntu haven't used it in such a long time.
I downloaded both
Papywizard 2.0.0 -- Source (ChangeLog)
and
Papywizard svn -- Source (ChangeLog)
to give a try.
anyways this is the error I get when I type in $ papywizard.sh
Just as an additional question on the side regarding the Mac version of the program, how is that going? Are there any updates coming this way or any information on complying a own version when updates are coming, instead having to wait for someone to do it.
bigwade wrote:Hi Olafur, welcome here
I did end up trying to place an order with Teleskop Austria. I am waiting for a reply from them. I do have to say that got to be one of the worst online user experiences I have ever seen and been through. They need to do some serious changes.
geraldcor wrote:I run papywizard on my eeepc running easy peasy (an ubuntu variant for netbooks). You seem to have installed it correctly. Just do as Frédéric said and type papywizard.sh from the terminal. It runs really well on my eeepc and the battery life is very agreeable.
Greg
Just a quick note regarding the eeePC, I am still going to hold buying one as I will just try out with Ubuntu on my Mac for starters. The question is.
How did you add bluetooth to the computer, are you using a dongle or did you do some kind of hacking to get it internal into the computer, please share info regarding this. And ether way what did you buy?
tarnis wrote:I ran it on Ubuntu no problems launching when I d/led the source and just ran it from the command prompt. The only real problem I ran into was configuring the bluetooth adaptor to use a serial port...wasn't a big deal yet so I haven't asked if anyone has any suggestions while the topic is open though. I'm probably going with a netbook as well so will be needing to do it once I order. At the time was just trying to so it if was a windows issue when the bluetooth chip was giving me problems.
Yes keep me in the loop about your findings, or if anyone has a simple solution regarding this.
teleskop-austria
by teleskop-austria » Thu Mar 26, 2009 2:57 pm
dear Olihar,
sorry for the problems or uncertainities with our website, I will urge the webdesigner to update the procedure!
Your Order has arrived properly, and we will ship the Merlin tomorrow. If you have additional remarks, just send
us an email please.
regards, Tommy
olihar
by olihar » Thu Mar 26, 2009 3:17 pm
teleskop-austria wrote:dear Olihar,
us an email please.
regards, Tommy
Thanks for the email and quick reply, I have sent a response regarding few things.
geraldcor
by geraldcor » Thu Mar 26, 2009 4:35 pm
On the eeepc, I don't use bluetooth. I use the FTDI usb to serial converter and a custom end to plug into the merlin. The $20 price tag seemed quite a bit better than the $70+ price tag so I can't give you any help on the bluetooth situation, sorry. Hope all else works out for you.
Greg
Canon Rebel XT XTi
by fma38 » Thu Mar 26, 2009 8:32 pm
olihar, you need to install the PyQt package. Try:
$ sudo aptitude install python2.5-qt4
olihar
by olihar » Fri Mar 27, 2009 1:46 pm
fma38 wrote:olihar, you need to install the PyQt package. Try:
Ahh now it works(I thought I had installed the qt4 already), now hardware wise I just need to wait for the Merlin to start testing hardware, Software runs just fine. 2.0.0 does. The Trunk-r1638 does not however.
Thanks for your help, I will surly ask for some more a little later on.
by fma38 » Fri Mar 27, 2009 5:51 pm
The svn branch might be broken, these days, as I'm working on plugins...
olihar
by olihar » Thu Apr 02, 2009 12:39 pm
Hi there again.
I just received my Merlin, I had already made the BlueSMIRF with 12v to 5v using a mobile phone charger.
I am however unable to connect to it using Papywizard 2.0.0. I am getting the red light on the BlueSMIRF board.
I get this error.
More details on this error, I do not understand what a stylesheet has to do with bluetooth.
This is what I get in the bluetooth manager in Ubuntu, So I can see it thats for sure.
I am runnning Ubuntu with VmWare on a Mac with Leopard if that changes anything.
EDIT: are there any changes I need to do to bluetooth/serial settings before I can get this to work?
by fma38 » Thu Apr 02, 2009 1:05 pm
You need to install the python bluetooth binding:
$ sudo aptitude install python-bluez
About the log, the CSS error occurs at startup; it is not really an error (teh traceback should be in blue, with the DEBUG type, and not in purple, with the EXCEPTION type). Can you please post the entire log (using the code /code tags)?
olihar
by olihar » Thu Apr 02, 2009 4:10 pm
fma38 wrote:You need to install the python bluetooth binding:
Ahh yeah I have been looking for if it had something to do with Bluetooth and Python.
Here is the Log. I just started up the program and did nothing else. for this log.
2009-04-02 16:39:23,456::MainThread::INFO::Starting Papywizard...
2009-04-02 16:39:23,961::MainThread::INFO::Importing modules...
2009-04-02 16:39:24,015::MainThread::DEBUG::Shooting.start(): loading user external shooting scriptTraceback (most recent call last):  File "papywizard/model/shooting.py", line 70, in <module>    file, pathname, description = imp.find_module("shoot", [config.USER_CONFIG_DIR])ImportError: No module named shoot
2009-04-02 16:39:24,019::MainThread::WARNING::No user external shooting script found
2009-04-02 16:39:25,334::MainThread::INFO::Loading i18n files...
2009-04-02 16:39:25,342::MainThread::DEBUG::Papywizard.i18n(): locale=en_US
2009-04-02 16:39:25,343::MainThread::WARNING::Can't find qt translation file
2009-04-02 16:39:25,344::MainThread::INFO::Loading Style Sheets...
2009-04-02 16:39:25,357::MainThread::WARNING::No user Style Sheet found
2009-04-02 16:39:25,361::MainThread::INFO::Loading configuration...
2009-04-02 16:39:25,377::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['2', '0', '0'], user=[u'2', u'0', u'0']
2009-04-02 16:39:25,378::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2009-04-02 16:39:25,379::MainThread::INFO::Creating model...
2009-04-02 16:39:25,428::MainThread::INFO::Loading default presets
2009-04-02 16:39:25,441::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2009-04-02 16:39:25,470::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2009-04-02 16:39:25,471::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2009-04-02 16:39:25,472::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2009-04-02 16:39:25,472::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2009-04-02 16:39:25,473::MainThread::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2009-04-02 16:39:25,475::MainThread::INFO::Loading user presets
2009-04-02 16:39:25,475::MainThread::WARNING::No user presets found
2009-04-02 16:39:25,476::MainThread::INFO::Starting Spy...
2009-04-02 16:39:25,476::MainThread::DEBUG::Spy.__init__(): yaw=0.0, pitch=0.0
2009-04-02 16:39:25,530::Spy::INFO::Starting Spy...
2009-04-02 16:39:25,590::MainThread::INFO::Creating GUI...
I just made my first test, I need to get a rail for the NP.
by fma38 » Thu Apr 02, 2009 6:38 pm
Good!
olihar
by olihar » Tue Apr 07, 2009 9:34 pm
Hi there again. I have been doing some further tests and looking into railing system.
I however went out to do a large panorama, well that was the plan, doing a sphere using a 50mm lens.
I tried 3 times and at some random internals the computer stopped communicating with Merlin.
I am using the BlueSMIRF.
I will post some part of the Log here, its most likely after I had restarted once Ubuntu so its not all there.
Just as a note now, I am not able to use the Merlin what so ever, the BlueSMIRF has the Red light and the Green Light on constantly now, its like its frozen. It is only supposed to have the Red light and then the Green one when its doing something. I am not by any way able to connect to it now. Any suggestions? Do you know how to restart the card? I really would like this to work as I was planning on some testing in the Easter H.
EDIT: I had to take some of the Code below away because of Letter count warning from the Forum system.
2009-04-07 16:38:39,664::MainThread::INFO::Starting Papywizard...
2009-04-07 16:38:39,738::MainThread::INFO::Importing modules...
2009-04-07 16:38:39,834::MainThread::DEBUG::Shooting.start(): loading user external shooting scriptTraceback (most recent call last):  File "papywizard/model/shooting.py", line 70, in <module>    file, pathname, description = imp.find_module("shoot", [config.USER_CONFIG_DIR])ImportError: No module named shoot
2009-04-07 16:38:39,841::MainThread::WARNING::No user external shooting script found
2009-04-07 16:38:39,979::MainThread::INFO::Loading i18n files...
2009-04-07 16:38:39,983::MainThread::DEBUG::Papywizard.i18n(): locale=en_US
2009-04-07 16:38:39,984::MainThread::WARNING::Can't find qt translation file
2009-04-07 16:38:39,984::MainThread::INFO::Loading Style Sheets...
2009-04-07 16:38:39,987::MainThread::WARNING::No user Style Sheet found
2009-04-07 16:38:39,988::MainThread::INFO::Loading configuration...
2009-04-07 16:38:39,995::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['2', '0', '0'], user=[u'2', u'0', u'0']
2009-04-07 16:38:39,996::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2009-04-07 16:38:39,996::MainThread::INFO::Creating model...
2009-04-07 16:38:40,000::MainThread::INFO::Loading default presets
2009-04-07 16:38:40,032::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2009-04-07 16:38:40,033::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2009-04-07 16:38:40,034::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2009-04-07 16:38:40,035::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2009-04-07 16:38:40,035::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2009-04-07 16:38:40,037::MainThread::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2009-04-07 16:38:40,038::MainThread::INFO::Loading user presets
2009-04-07 16:38:40,039::MainThread::WARNING::No user presets found
2009-04-07 16:38:40,039::MainThread::INFO::Starting Spy...
2009-04-07 16:38:40,040::MainThread::DEBUG::Spy.__init__(): yaw=0.0, pitch=0.0
2009-04-07 16:38:40,041::Spy::INFO::Starting Spy...
2009-04-07 16:38:40,042::MainThread::INFO::Creating GUI...
2009-04-07 16:38:51,562::MainThread::INFO::Connecting to real hardware...
2009-04-07 16:39:08,780::MainThread::INFO::Now connected to real hardware
2009-04-07 16:41:00,424::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 16:41:00,426::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 16:41:49,226::MainThread::INFO::Set hardware reference
2009-04-07 16:42:43,779::Shooting::INFO::Start shooting process...
2009-04-07 16:42:43,849::Shooting::INFO::Moving
2009-04-07 16:43:12,961::Shooting::INFO::Stabilization
2009-04-07 16:43:13,463::Shooting::INFO::Shutter cycle
2009-04-07 16:43:14,326::Shooting::INFO::Moving
2009-04-07 16:43:20,247::Shooting::INFO::Stabilization
2009-04-07 16:43:20,751::Shooting::INFO::Shutter cycle
2009-04-07 16:43:21,609::Shooting::INFO::Moving
2009-04-07 16:43:27,552::Shooting::INFO::Stabilization
2009-04-07 16:43:28,051::Shooting::INFO::Shutter cycle
2009-04-07 16:43:28,911::Shooting::INFO::Moving
2009-04-07 16:43:34,854::Shooting::INFO::Stabilization
2009-04-07 16:43:35,355::Shooting::INFO::Shutter cycle
2009-04-07 16:43:36,209::Shooting::INFO::Moving
2009-04-07 16:43:42,167::Shooting::INFO::Stabilization
2009-04-07 16:43:42,667::Shooting::INFO::Shutter cycle
2009-04-07 16:43:43,522::Shooting::INFO::Moving
2009-04-07 16:43:49,529::Shooting::INFO::Stabilization
2009-04-07 16:43:50,031::Shooting::INFO::Shutter cycle
2009-04-07 16:43:50,891::Shooting::INFO::Moving
2009-04-07 16:43:56,891::Shooting::INFO::Stabilization
2009-04-07 16:43:57,391::Shooting::INFO::Shutter cycle
2009-04-07 16:43:58,265::Shooting::INFO::Moving
2009-04-07 16:44:04,299::Shooting::INFO::Stabilization
2009-04-07 16:44:04,799::Shooting::INFO::Shutter cycle
2009-04-07 16:44:05,666::Shooting::INFO::Moving
2009-04-07 16:44:11,718::Shooting::INFO::Stabilization
2009-04-07 16:44:12,219::Shooting::INFO::Shutter cycle
2009-04-07 16:44:13,136::Shooting::INFO::Moving
2009-04-07 16:44:19,287::Shooting::INFO::Stabilization
2009-04-07 16:44:19,787::Shooting::INFO::Shutter cycle
2009-04-07 16:44:20,653::Shooting::INFO::Moving
2009-04-07 16:44:27,082::Shooting::INFO::Stabilization
2009-04-07 16:44:27,583::Shooting::INFO::Shutter cycle
2009-04-07 16:44:28,444::Shooting::INFO::Moving
2009-04-07 16:44:34,452::Shooting::INFO::Stabilization
2009-04-07 16:44:34,951::Shooting::INFO::Shutter cycle
2009-04-07 16:44:35,822::Shooting::INFO::Moving
2009-04-07 16:44:41,841::Shooting::INFO::Stabilization
2009-04-07 16:44:42,343::Shooting::INFO::Shutter cycle
2009-04-07 16:44:43,203::Shooting::INFO::Moving
2009-04-07 16:44:49,438::Shooting::INFO::Stabilization
2009-04-07 16:44:49,939::Shooting::INFO::Shutter cycle
2009-04-07 16:44:50,814::Shooting::INFO::Moving
2009-04-07 16:44:56,825::Shooting::INFO::Stabilization
2009-04-07 16:44:57,327::Shooting::INFO::Shutter cycle
2009-04-07 16:44:58,277::Shooting::INFO::Moving
2009-04-07 16:45:04,404::Shooting::INFO::Stabilization
2009-04-07 16:45:04,903::Shooting::INFO::Shutter cycle
2009-04-07 16:45:05,766::Shooting::INFO::Moving
2009-04-07 16:45:11,752::Shooting::INFO::Stabilization
2009-04-07 16:45:12,251::Shooting::INFO::Shutter cycle
2009-04-07 16:45:13,121::Shooting::INFO::Moving
2009-04-07 16:45:19,153::Shooting::INFO::Stabilization
2009-04-07 16:45:19,655::Shooting::INFO::Shutter cycle
2009-04-07 16:45:20,513::Shooting::INFO::Moving
2009-04-07 16:45:26,641::Shooting::INFO::Stabilization
2009-04-07 16:45:27,143::Shooting::INFO::Shutter cycle
2009-04-07 16:45:28,003::Shooting::INFO::Moving
2009-04-07 16:45:34,042::Shooting::INFO::Stabilization
2009-04-07 16:45:34,543::Shooting::INFO::Shutter cycle
2009-04-07 16:45:35,416::Shooting::INFO::Moving
2009-04-07 16:45:41,415::Shooting::INFO::Stabilization
2009-04-07 16:45:41,915::Shooting::INFO::Shutter cycle
2009-04-07 16:45:42,839::Shooting::INFO::Moving
2009-04-07 16:45:48,955::Shooting::INFO::Stabilization
2009-04-07 16:45:49,451::Shooting::INFO::Shutter cycle
2009-04-07 16:45:50,316::Shooting::INFO::Moving
2009-04-07 16:45:56,332::Shooting::INFO::Stabilization
2009-04-07 16:45:56,831::Shooting::INFO::Shutter cycle
2009-04-07 16:45:57,704::Shooting::INFO::Moving
2009-04-07 16:46:03,774::Shooting::INFO::Stabilization
2009-04-07 16:46:04,275::Shooting::INFO::Shutter cycle
2009-04-07 16:46:05,179::Shooting::INFO::Moving
2009-04-07 16:46:11,178::Shooting::INFO::Stabilization
2009-04-07 16:46:11,679::Shooting::INFO::Shutter cycle
2009-04-07 16:46:12,559::Shooting::INFO::Moving
2009-04-07 16:46:18,745::Shooting::INFO::Stabilization
2009-04-07 16:46:19,247::Shooting::INFO::Shutter cycle
2009-04-07 16:46:20,114::Shooting::INFO::Moving
2009-04-07 16:46:26,695::Shooting::INFO::Stabilization
2009-04-07 16:46:27,195::Shooting::INFO::Shutter cycle
2009-04-07 16:46:28,066::Shooting::INFO::Moving
2009-04-07 16:46:34,292::Shooting::INFO::Stabilization
2009-04-07 16:46:34,795::Shooting::INFO::Shutter cycle
2009-04-07 16:46:35,658::Shooting::INFO::Moving
2009-04-07 16:46:42,550::Shooting::INFO::Stabilization
2009-04-07 16:46:43,051::Shooting::INFO::Shutter cycle
2009-04-07 16:46:43,794::Shooting::INFO::Moving
2009-04-07 16:46:49,988::Shooting::INFO::Stabilization
2009-04-07 16:46:50,487::Shooting::INFO::Shutter cycle
2009-04-07 16:46:51,361::Shooting::INFO::Moving
2009-04-07 16:46:57,305::Shooting::INFO::Stabilization
2009-04-07 16:46:57,807::Shooting::INFO::Shutter cycle
2009-04-07 16:46:58,724::Shooting::INFO::Moving
2009-04-07 16:47:04,852::Shooting::INFO::Stabilization
2009-04-07 16:47:05,351::Shooting::INFO::Shutter cycle
2009-04-07 16:47:06,205::Shooting::INFO::Moving
2009-04-07 16:47:12,485::Shooting::INFO::Stabilization
2009-04-07 16:47:12,987::Shooting::INFO::Shutter cycle
2009-04-07 16:47:13,654::Shooting::INFO::Moving
2009-04-07 16:47:19,901::Shooting::INFO::Stabilization
2009-04-07 16:47:20,403::Shooting::INFO::Shutter cycle
2009-04-07 16:47:21,278::Shooting::INFO::Moving
2009-04-07 16:47:27,541::Shooting::INFO::Stabilization
2009-04-07 16:47:28,043::Shooting::INFO::Shutter cycle
2009-04-07 16:47:28,898::Shooting::INFO::Moving
2009-04-07 16:47:34,911::Shooting::INFO::Stabilization
2009-04-07 16:47:35,411::Shooting::INFO::Shutter cycle
2009-04-07 16:47:36,274::Shooting::INFO::Moving
2009-04-07 16:47:42,269::Shooting::INFO::Stabilization
2009-04-07 16:47:42,773::Shooting::INFO::Shutter cycle
2009-04-07 16:47:43,697::Shooting::INFO::Moving
2009-04-07 16:47:49,818::Shooting::INFO::Stabilization
2009-04-07 16:47:50,319::Shooting::INFO::Shutter cycle
2009-04-07 16:47:51,186::Shooting::INFO::Moving
2009-04-07 16:47:57,269::Shooting::INFO::Stabilization
2009-04-07 16:47:57,771::Shooting::INFO::Shutter cycle
2009-04-07 16:47:58,647::Shooting::INFO::Moving
2009-04-07 16:48:04,665::Shooting::INFO::Stabilization
2009-04-07 16:48:05,171::Shooting::INFO::Shutter cycle
2009-04-07 16:48:06,023::Shooting::INFO::Moving
2009-04-07 16:48:12,009::Shooting::INFO::Stabilization
2009-04-07 16:48:12,511::Shooting::INFO::Shutter cycle
2009-04-07 16:48:13,374::Shooting::INFO::Moving
2009-04-07 16:48:19,411::Shooting::INFO::Stabilization
2009-04-07 16:48:19,911::Shooting::INFO::Shutter cycle
2009-04-07 16:48:20,773::Shooting::INFO::Moving
2009-04-07 16:48:24,260::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 16:48:24,261::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2009-04-07 16:48:26,980::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 16:48:26,981::Spy::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2009-04-07 16:48:30,006::Shooting::INFO::Stabilization
2009-04-07 16:48:30,507::Shooting::INFO::Shutter cycle
2009-04-07 16:48:31,256::Shooting::INFO::Moving
2009-04-07 16:48:33,619::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):  File "papywizard/model/shooting.py", line 540, in start    self.hardware.gotoPosition(yaw, pitch)  File "papywizard/hardware/head.py", line 159, in gotoPosition    self.waitEndOfDrive()  File "papywizard/hardware/head.py", line 166, in waitEndOfDrive    self.yawAxis.waitEndOfDrive()  File "papywizard/hardware/axis.py", line 377, in waitEndOfDrive    if not self.isMoving():  File "papywizard/hardware/axis.py", line 409, in isMoving    if status[1] != '0':IndexError: string index out of range
2009-04-07 16:48:33,620::Shooting::ERROR::Shoot process failed
2009-04-07 16:50:51,344::Shooting::INFO::Start shooting process...
2009-04-07 16:50:51,413::Shooting::INFO::Moving
2009-04-07 16:51:20,725::Shooting::INFO::Stabilization
2009-04-07 16:51:21,227::Shooting::INFO::Shutter cycle
2009-04-07 16:51:22,098::Shooting::INFO::Moving
2009-04-07 16:51:28,019::Shooting::INFO::Stabilization
2009-04-07 16:51:28,519::Shooting::INFO::Shutter cycle
2009-04-07 16:51:29,383::Shooting::INFO::Moving
2009-04-07 16:51:35,308::Shooting::INFO::Stabilization
2009-04-07 16:51:35,811::Shooting::INFO::Shutter cycle
2009-04-07 16:51:36,680::Shooting::INFO::Moving
2009-04-07 16:51:42,616::Shooting::INFO::Stabilization
2009-04-07 16:51:43,115::Shooting::INFO::Shutter cycle
2009-04-07 16:51:43,983::Shooting::INFO::Moving
2009-04-07 16:51:49,971::Shooting::INFO::Stabilization
2009-04-07 16:51:50,471::Shooting::INFO::Shutter cycle
2009-04-07 16:51:51,333::Shooting::INFO::Moving
2009-04-07 16:51:57,981::Shooting::INFO::Stabilization
2009-04-07 16:51:58,483::Shooting::INFO::Shutter cycle
2009-04-07 16:51:59,349::Shooting::INFO::Moving
2009-04-07 16:52:05,349::Shooting::INFO::Stabilization
2009-04-07 16:52:05,851::Shooting::INFO::Shutter cycle
2009-04-07 16:52:06,703::Shooting::INFO::Moving
2009-04-07 16:52:12,712::Shooting::INFO::Stabilization
2009-04-07 16:52:13,211::Shooting::INFO::Shutter cycle
2009-04-07 16:52:14,079::Shooting::INFO::Moving
2009-04-07 16:52:20,106::Shooting::INFO::Stabilization
2009-04-07 16:52:20,607::Shooting::INFO::Shutter cycle
2009-04-07 16:52:21,493::Shooting::INFO::Moving
2009-04-07 16:52:27,935::Shooting::INFO::Stabilization
2009-04-07 16:52:28,435::Shooting::INFO::Shutter cycle
2009-04-07 16:52:29,192::Shooting::INFO::Moving
2009-04-07 16:52:35,335::Shooting::INFO::Stabilization
2009-04-07 16:52:35,835::Shooting::INFO::Shutter cycle
2009-04-07 16:52:36,706::Shooting::INFO::Moving
2009-04-07 16:52:42,899::Shooting::INFO::Stabilization
2009-04-07 16:52:43,399::Shooting::INFO::Shutter cycle
2009-04-07 16:52:44,259::Shooting::INFO::Moving
2009-04-07 16:52:50,255::Shooting::INFO::Stabilization
2009-04-07 16:52:50,755::Shooting::INFO::Shutter cycle
2009-04-07 16:52:51,615::Shooting::INFO::Moving
2009-04-07 16:52:57,652::Shooting::INFO::Stabilization
2009-04-07 16:52:58,155::Shooting::INFO::Shutter cycle
2009-04-07 16:52:58,991::Shooting::INFO::Moving
2009-04-07 16:53:05,036::Shooting::INFO::Stabilization
2009-04-07 16:53:05,535::Shooting::INFO::Shutter cycle
2009-04-07 16:53:06,477::Shooting::INFO::Moving
2009-04-07 16:53:12,642::Shooting::INFO::Stabilization
2009-04-07 16:53:13,143::Shooting::INFO::Shutter cycle
2009-04-07 16:53:13,997::Shooting::INFO::Moving
2009-04-07 16:53:20,415::Shooting::INFO::Stabilization
2009-04-07 16:53:20,915::Shooting::INFO::Shutter cycle
2009-04-07 16:53:21,782::Shooting::INFO::Moving
2009-04-07 16:53:27,783::Shooting::INFO::Stabilization
2009-04-07 16:53:28,283::Shooting::INFO::Shutter cycle
2009-04-07 16:53:29,138::Shooting::INFO::Moving
2009-04-07 16:53:35,144::Shooting::INFO::Stabilization
2009-04-07 16:53:35,647::Shooting::INFO::Shutter cycle
2009-04-07 16:53:36,504::Shooting::INFO::Moving
2009-04-07 16:53:42,585::Shooting::INFO::Stabilization
2009-04-07 16:53:43,087::Shooting::INFO::Shutter cycle
2009-04-07 16:53:43,952::Shooting::INFO::Moving
2009-04-07 16:53:49,959::Shooting::INFO::Stabilization
2009-04-07 16:53:50,459::Shooting::INFO::Shutter cycle
2009-04-07 16:53:51,416::Shooting::INFO::Moving
2009-04-07 16:53:57,769::Shooting::INFO::Stabilization
2009-04-07 16:53:58,271::Shooting::INFO::Shutter cycle
2009-04-07 16:53:59,134::Shooting::INFO::Moving
2009-04-07 16:54:05,133::Shooting::INFO::Stabilization
2009-04-07 16:54:05,635::Shooting::INFO::Shutter cycle
2009-04-07 16:54:06,494::Shooting::INFO::Moving
2009-04-07 16:54:12,507::Shooting::INFO::Stabilization
2009-04-07 16:54:13,011::Shooting::INFO::Shutter cycle
2009-04-07 16:54:13,865::Shooting::INFO::Moving
2009-04-07 16:54:19,921::Shooting::INFO::Stabilization
2009-04-07 16:54:20,423::Shooting::INFO::Shutter cycle
2009-04-07 16:54:21,294::Shooting::INFO::Moving
2009-04-07 16:54:27,334::Shooting::INFO::Stabilization
2009-04-07 16:54:27,835::Shooting::INFO::Shutter cycle
2009-04-07 16:54:28,708::Shooting::INFO::Moving
2009-04-07 16:54:34,715::Shooting::INFO::Stabilization
2009-04-07 16:54:35,215::Shooting::INFO::Shutter cycle
2009-04-07 16:54:36,104::Shooting::INFO::Moving
2009-04-07 16:54:42,212::Shooting::INFO::Stabilization
2009-04-07 16:54:42,715::Shooting::INFO::Shutter cycle
2009-04-07 16:54:43,571::Shooting::INFO::Moving
2009-04-07 16:54:50,414::Shooting::INFO::Stabilization
2009-04-07 16:54:50,915::Shooting::INFO::Shutter cycle
2009-04-07 16:54:51,651::Shooting::INFO::Moving
2009-04-07 16:54:57,822::Shooting::INFO::Stabilization
2009-04-07 16:54:58,323::Shooting::INFO::Shutter cycle
2009-04-07 16:54:59,191::Shooting::INFO::Moving
2009-04-07 16:55:05,235::Shooting::INFO::Stabilization
2009-04-07 16:55:05,735::Shooting::INFO::Shutter cycle
2009-04-07 16:55:06,608::Shooting::INFO::Moving
2009-04-07 16:55:12,599::Shooting::INFO::Stabilization
2009-04-07 16:55:13,099::Shooting::INFO::Shutter cycle
2009-04-07 16:55:14,081::Shooting::INFO::Moving
2009-04-07 16:55:20,158::Shooting::INFO::Stabilization
2009-04-07 16:55:20,659::Shooting::INFO::Shutter cycle
2009-04-07 16:55:21,515::Shooting::INFO::Moving
2009-04-07 16:55:27,533::Shooting::INFO::Stabilization
2009-04-07 16:55:28,034::Shooting::INFO::Shutter cycle
2009-04-07 16:55:28,905::Shooting::INFO::Moving
2009-04-07 16:55:34,916::Shooting::INFO::Stabilization
2009-04-07 16:55:35,415::Shooting::INFO::Shutter cycle
2009-04-07 16:55:36,270::Shooting::INFO::Moving
2009-04-07 16:55:42,326::Shooting::INFO::Stabilization
2009-04-07 16:55:42,827::Shooting::INFO::Shutter cycle
2009-04-07 16:55:43,723::Shooting::INFO::Moving
2009-04-07 16:55:49,708::Shooting::INFO::Stabilization
2009-04-07 16:55:50,207::Shooting::INFO::Shutter cycle
2009-04-07 16:55:51,071::Shooting::INFO::Moving
2009-04-07 16:55:57,068::Shooting::INFO::Stabilization
2009-04-07 16:55:57,571::Shooting::INFO::Shutter cycle
2009-04-07 16:55:58,501::Shooting::INFO::Moving
2009-04-07 16:56:04,864::Shooting::INFO::Stabilization
2009-04-07 16:56:05,363::Shooting::INFO::Shutter cycle
2009-04-07 16:56:06,220::Shooting::INFO::Moving
2009-04-07 16:56:12,237::Shooting::INFO::Stabilization
2009-04-07 16:56:12,739::Shooting::INFO::Shutter cycle
2009-04-07 16:56:13,594::Shooting::INFO::Moving
2009-04-07 16:56:19,645::Shooting::INFO::Stabilization
2009-04-07 16:56:20,147::Shooting::INFO::Shutter cycle
2009-04-07 16:56:21,005::Shooting::INFO::Moving
2009-04-07 16:56:27,035::Shooting::INFO::Stabilization
2009-04-07 16:56:27,535::Shooting::INFO::Shutter cycle
2009-04-07 16:56:28,404::Shooting::INFO::Moving
2009-04-07 16:56:34,394::Shooting::INFO::Stabilization
2009-04-07 16:56:34,895::Shooting::INFO::Shutter cycle
2009-04-07 16:56:35,760::Shooting::INFO::Moving
2009-04-07 16:56:42,347::Shooting::INFO::Stabilization
2009-04-07 16:56:42,847::Shooting::INFO::Shutter cycle
2009-04-07 16:56:43,712::Shooting::INFO::Moving
2009-04-07 16:56:50,149::Shooting::INFO::Stabilization
2009-04-07 16:56:50,651::Shooting::INFO::Shutter cycle
2009-04-07 16:56:51,509::Shooting::INFO::Moving
2009-04-07 16:56:57,564::Shooting::INFO::Stabilization
2009-04-07 16:56:58,063::Shooting::INFO::Shutter cycle
2009-04-07 16:56:58,936::Shooting::INFO::Moving
2009-04-07 16:57:04,946::Shooting::INFO::Stabilization
2009-04-07 16:57:05,447::Shooting::INFO::Shutter cycle
2009-04-07 16:57:06,322::Shooting::INFO::Moving
2009-04-07 16:57:12,334::Shooting::INFO::Stabilization
2009-04-07 16:57:12,835::Shooting::INFO::Shutter cycle
2009-04-07 16:57:13,694::Shooting::INFO::Moving
2009-04-07 16:57:19,705::Shooting::INFO::Stabilization
2009-04-07 16:57:20,207::Shooting::INFO::Shutter cycle
2009-04-07 16:57:21,109::Shooting::INFO::Moving
2009-04-07 16:57:27,476::Shooting::INFO::Stabilization
2009-04-07 16:57:27,979::Shooting::INFO::Shutter cycle
2009-04-07 16:57:28,845::Shooting::INFO::Moving
2009-04-07 16:57:35,107::Shooting::INFO::Stabilization
2009-04-07 16:57:35,607::Shooting::INFO::Shutter cycle
2009-04-07 16:57:36,465::Shooting::INFO::Moving
2009-04-07 16:57:42,502::Shooting::INFO::Stabilization
2009-04-07 16:57:43,003::Shooting::INFO::Shutter cycle
2009-04-07 16:57:43,739::Shooting::INFO::Moving
2009-04-07 16:57:49,861::Shooting::INFO::Stabilization
2009-04-07 16:57:50,363::Shooting::INFO::Shutter cycle
2009-04-07 16:57:51,230::Shooting::INFO::Moving
2009-04-07 16:57:57,222::Shooting::INFO::Stabilization
2009-04-07 16:57:57,728::Shooting::INFO::Shutter cycle
2009-04-07 16:57:58,588::Shooting::INFO::Moving
2009-04-07 16:58:04,836::Shooting::INFO::Stabilization
2009-04-07 16:58:05,335::Shooting::INFO::Shutter cycle
2009-04-07 16:58:06,089::Shooting::INFO::Moving
2009-04-07 16:58:12,249::Shooting::INFO::Stabilization
2009-04-07 16:58:12,751::Shooting::INFO::Shutter cycle
2009-04-07 16:58:13,623::Shooting::INFO::Moving
2009-04-07 16:58:20,479::Shooting::INFO::Stabilization
2009-04-07 16:58:20,983::Shooting::INFO::Shutter cycle
2009-04-07 16:58:21,709::Shooting::INFO::Moving
2009-04-07 16:58:27,630::Shooting::INFO::Stabilization
2009-04-07 16:58:28,131::Shooting::INFO::Shutter cycle
2009-04-07 16:58:29,001::Shooting::INFO::Moving
2009-04-07 16:58:35,003::Shooting::INFO::Stabilization
2009-04-07 16:58:35,503::Shooting::INFO::Shutter cycle
2009-04-07 16:58:36,362::Shooting::INFO::Moving
2009-04-07 16:58:42,398::Shooting::INFO::Stabilization
2009-04-07 16:58:42,899::Shooting::INFO::Shutter cycle
2009-04-07 16:58:43,826::Shooting::INFO::Moving
2009-04-07 16:58:49,975::Shooting::INFO::Stabilization
2009-04-07 16:58:50,475::Shooting::INFO::Shutter cycle
2009-04-07 16:58:51,342::Shooting::INFO::Moving
2009-04-07 16:58:57,810::Shooting::INFO::Stabilization
2009-04-07 16:58:58,311::Shooting::INFO::Shutter cycle
2009-04-07 16:58:59,175::Shooting::INFO::Moving
2009-04-07 16:59:05,137::Shooting::INFO::Stabilization
2009-04-07 16:59:05,658::Shooting::INFO::Shutter cycle
2009-04-07 16:59:06,499::Shooting::INFO::Moving
2009-04-07 16:59:12,543::Shooting::INFO::Stabilization
2009-04-07 16:59:13,043::Shooting::INFO::Shutter cycle
2009-04-07 16:59:13,904::Shooting::INFO::Moving
2009-04-07 16:59:19,920::Shooting::INFO::Stabilization
2009-04-07 16:59:20,419::Shooting::INFO::Shutter cycle
2009-04-07 16:59:21,293::Shooting::INFO::Moving
2009-04-07 16:59:27,525::Shooting::INFO::Stabilization
2009-04-07 16:59:28,027::Shooting::INFO::Shutter cycle
2009-04-07 16:59:28,780::Shooting::INFO::Moving
2009-04-07 16:59:34,911::Shooting::INFO::Stabilization
2009-04-07 16:59:35,411::Shooting::INFO::Shutter cycle
2009-04-07 16:59:36,280::Shooting::INFO::Moving
2009-04-07 16:59:42,289::Shooting::INFO::Stabilization
2009-04-07 16:59:42,791::Shooting::INFO::Shutter cycle
2009-04-07 16:59:43,650::Shooting::INFO::Moving
2009-04-07 16:59:49,646::Shooting::INFO::Stabilization
2009-04-07 16:59:50,147::Shooting::INFO::Shutter cycle
2009-04-07 16:59:51,005::Shooting::INFO::Moving
2009-04-07 16:59:57,053::Shooting::INFO::Stabilization
2009-04-07 16:59:57,555::Shooting::INFO::Shutter cycle
2009-04-07 16:59:58,442::Shooting::INFO::Moving
2009-04-07 17:00:04,852::Shooting::INFO::Stabilization
2009-04-07 17:00:05,351::Shooting::INFO::Shutter cycle
2009-04-07 17:00:06,322::Shooting::INFO::Moving
2009-04-07 17:00:12,446::Shooting::INFO::Stabilization
2009-04-07 17:00:12,947::Shooting::INFO::Shutter cycle
2009-04-07 17:00:13,831::Shooting::INFO::Moving
2009-04-07 17:00:20,030::Shooting::INFO::Stabilization
2009-04-07 17:00:20,531::Shooting::INFO::Shutter cycle
2009-04-07 17:00:21,393::Shooting::INFO::Moving
2009-04-07 17:00:27,406::Shooting::INFO::Stabilization
2009-04-07 17:00:27,907::Shooting::INFO::Shutter cycle
2009-04-07 17:00:28,787::Shooting::INFO::Moving
2009-04-07 17:00:34,752::Shooting::INFO::Stabilization
2009-04-07 17:00:35,251::Shooting::INFO::Shutter cycle
2009-04-07 17:00:36,116::Shooting::INFO::Moving
2009-04-07 17:00:42,154::Shooting::INFO::Stabilization
2009-04-07 17:00:42,659::Shooting::INFO::Shutter cycle
2009-04-07 17:00:43,398::Shooting::INFO::Moving
2009-04-07 17:00:49,772::Shooting::INFO::Stabilization
2009-04-07 17:00:50,271::Shooting::INFO::Shutter cycle
2009-04-07 17:00:51,215::Shooting::INFO::Moving
2009-04-07 17:00:57,337::Shooting::INFO::Stabilization
2009-04-07 17:00:57,839::Shooting::INFO::Shutter cycle
2009-04-07 17:00:58,708::Shooting::INFO::Moving
2009-04-07 17:01:04,705::Shooting::INFO::Stabilization
2009-04-07 17:01:05,207::Shooting::INFO::Shutter cycle
2009-04-07 17:01:06,078::Shooting::INFO::Moving
2009-04-07 17:01:12,073::Shooting::INFO::Stabilization
2009-04-07 17:01:12,575::Shooting::INFO::Shutter cycle
2009-04-07 17:01:13,447::Shooting::INFO::Moving
2009-04-07 17:01:19,499::Shooting::INFO::Stabilization
2009-04-07 17:01:19,999::Shooting::INFO::Shutter cycle
2009-04-07 17:01:20,734::Shooting::INFO::Moving
2009-04-07 17:01:26,998::Shooting::INFO::Stabilization
2009-04-07 17:01:27,499::Shooting::INFO::Shutter cycle
2009-04-07 17:01:28,375::Shooting::INFO::Moving
2009-04-07 17:01:34,295::Shooting::INFO::Stabilization
2009-04-07 17:01:34,795::Shooting::INFO::Shutter cycle
2009-04-07 17:01:35,707::Shooting::INFO::Moving
2009-04-07 17:01:41,834::Shooting::INFO::Stabilization
2009-04-07 17:01:42,335::Shooting::INFO::Shutter cycle
2009-04-07 17:01:43,208::Shooting::INFO::Moving
2009-04-07 17:01:50,040::Shooting::INFO::Stabilization
2009-04-07 17:01:50,543::Shooting::INFO::Shutter cycle
2009-04-07 17:01:51,384::Shooting::INFO::Moving
2009-04-07 17:01:57,426::Shooting::INFO::Stabilization
2009-04-07 17:01:57,927::Shooting::INFO::Shutter cycle
2009-04-07 17:01:58,793::Shooting::INFO::Moving
2009-04-07 17:02:04,851::Shooting::INFO::Stabilization
2009-04-07 17:02:05,351::Shooting::INFO::Shutter cycle
2009-04-07 17:02:06,242::Shooting::INFO::Moving
2009-04-07 17:02:12,235::Shooting::INFO::Stabilization
2009-04-07 17:02:12,735::Shooting::INFO::Shutter cycle
2009-04-07 17:02:13,657::Shooting::INFO::Moving
2009-04-07 17:02:19,765::Shooting::INFO::Stabilization
2009-04-07 17:02:20,267::Shooting::INFO::Shutter cycle
2009-04-07 17:02:21,130::Shooting::INFO::Moving
2009-04-07 17:02:27,155::Shooting::INFO::Stabilization
2009-04-07 17:02:27,655::Shooting::INFO::Shutter cycle
2009-04-07 17:02:28,511::Shooting::INFO::Moving
2009-04-07 17:02:34,581::Shooting::INFO::Stabilization
2009-04-07 17:02:35,083::Shooting::INFO::Shutter cycle
2009-04-07 17:02:35,942::Shooting::INFO::Moving
2009-04-07 17:02:41,951::Shooting::INFO::Stabilization
2009-04-07 17:02:42,451::Shooting::INFO::Shutter cycle
2009-04-07 17:02:43,310::Shooting::INFO::Moving
2009-04-07 17:02:49,335::Shooting::INFO::Stabilization
2009-04-07 17:02:49,835::Shooting::INFO::Shutter cycle
2009-04-07 17:02:50,711::Shooting::INFO::Moving
2009-04-07 17:02:56,690::Shooting::INFO::Stabilization
2009-04-07 17:02:57,191::Shooting::INFO::Shutter cycle
2009-04-07 17:02:58,118::Shooting::INFO::Moving
2009-04-07 17:03:00,755::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:00,757::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2009-04-07 17:03:01,755::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:01,757::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2009-04-07 17:03:02,755::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:02,757::Shooting::WARNING::Axis._sendCmd(): axis 2 can't sent command. Retrying...
2009-04-07 17:03:03,755::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:03,757::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:04,755::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:04,756::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:05,755::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:05,757::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:05,759::Spy::EXCEPTION::Spy.refresh(): can't read positionTraceback (most recent call last):  File "papywizard/controller/spy.py", line 157, in refresh    yaw, pitch = self.__model.hardware.readPosition()  File "papywizard/hardware/head.py", line 149, in readPosition    yaw = self.yawAxis.read()  File "papywizard/hardware/axis.py", line 273, in read    value = self._sendCmd("j")  File "papywizard/hardware/axis.py", line 243, in _sendCmd    raise HardwareError("Axis %d can't send command" % self._num)HardwareError: Axis 1 can't send command
2009-04-07 17:03:06,755::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:06,758::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:07,756::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:07,758::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:08,759::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:08,760::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:09,760::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:09,762::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:09,763::Spy::EXCEPTION::Spy.refresh(): can't read positionTraceback (most recent call last):  File "papywizard/controller/spy.py", line 157, in refresh    yaw, pitch = self.__model.hardware.readPosition()  File "papywizard/hardware/head.py", line 149, in readPosition    yaw = self.yawAxis.read()  File "papywizard/hardware/axis.py", line 273, in read    value = self._sendCmd("j")  File "papywizard/hardware/axis.py", line 243, in _sendCmd    raise HardwareError("Axis %d can't send command" % self._num)HardwareError: Axis 1 can't send command
2009-04-07 17:03:10,764::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:10,766::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:11,763::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:11,766::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:12,768::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:12,770::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:13,768::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:13,769::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:13,771::Spy::EXCEPTION::Spy.refresh(): can't read positionTraceback (most recent call last):  File "papywizard/controller/spy.py", line 157, in refresh    yaw, pitch = self.__model.hardware.readPosition()  File "papywizard/hardware/head.py", line 149, in readPosition    yaw = self.yawAxis.read()  File "papywizard/hardware/axis.py", line 273, in read    value = self._sendCmd("j")  File "papywizard/hardware/axis.py", line 243, in _sendCmd    raise HardwareError("Axis %d can't send command" % self._num)HardwareError: Axis 1 can't send command
2009-04-07 17:03:14,767::Shooting::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:14,769::Shooting::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:14,770::Shooting::EXCEPTION::Shooting.start()Traceback (most recent call last):  File "papywizard/model/shooting.py", line 619, in start    self.hardware.stopAxis()  File "papywizard/hardware/head.py", line 194, in stopAxis    self.yawAxis.stop()  File "papywizard/hardware/axis.py", line 372, in stop    self._sendCmd("L")  File "papywizard/hardware/axis.py", line 243, in _sendCmd    raise HardwareError("Axis %d can't send command" % self._num)HardwareError: Axis 1 can't send command
2009-04-07 17:03:14,771::Shooting::ERROR::Shoot process failed
2009-04-07 17:03:15,767::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:15,769::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:16,768::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:16,770::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:17,773::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:17,775::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:17,775::Spy::EXCEPTION::Spy.refresh(): can't read positionTraceback (most recent call last):  File "papywizard/controller/spy.py", line 157, in refresh    yaw, pitch = self.__model.hardware.readPosition()  File "papywizard/hardware/head.py", line 149, in readPosition    yaw = self.yawAxis.read()  File "papywizard/hardware/axis.py", line 273, in read    value = self._sendCmd("j")  File "papywizard/hardware/axis.py", line 243, in _sendCmd    raise HardwareError("Axis %d can't send command" % self._num)HardwareError: Axis 1 can't send command
2009-04-07 17:03:19,276::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: timed out
2009-04-07 17:03:19,277::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:19,764::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 129, in sendCmd    c = self._sock.recv(1)  File "<string>", line 5, in recvBluetoothError: (110, 'Connection timed out')
2009-04-07 17:03:19,765::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:19,766::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 126, in sendCmd    self._sock.send(":%s\r" % cmd)  File "<string>", line 5, in sendBluetoothError: (107, 'Transport endpoint is not connected')
2009-04-07 17:03:19,781::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:19,782::Spy::EXCEPTION::Spy.refresh(): can't read positionTraceback (most recent call last):  File "papywizard/controller/spy.py", line 157, in refresh    yaw, pitch = self.__model.hardware.readPosition()  File "papywizard/hardware/head.py", line 149, in readPosition    yaw = self.yawAxis.read()  File "papywizard/hardware/axis.py", line 273, in read    value = self._sendCmd("j")  File "papywizard/hardware/axis.py", line 243, in _sendCmd    raise HardwareError("Axis %d can't send command" % self._num)HardwareError: Axis 1 can't send command
2009-04-07 17:03:20,283::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 126, in sendCmd    self._sock.send(":%s\r" % cmd)  File "<string>", line 5, in sendBluetoothError: (107, 'Transport endpoint is not connected')
2009-04-07 17:03:20,285::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:20,286::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 126, in sendCmd    self._sock.send(":%s\r" % cmd)  File "<string>", line 5, in sendBluetoothError: (107, 'Transport endpoint is not connected')
2009-04-07 17:03:20,287::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:20,288::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 126, in sendCmd    self._sock.send(":%s\r" % cmd)  File "<string>", line 5, in sendBluetoothError: (107, 'Transport endpoint is not connected')
2009-04-07 17:03:20,289::Spy::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-07 17:03:20,290::Spy::EXCEPTION::Spy.refresh(): can't read positionTraceback (most recent call last):  File "papywizard/controller/spy.py", line 157, in refresh    yaw, pitch = self.__model.hardware.readPosition()  File "papywizard/hardware/head.py", line 149, in readPosition    yaw = self.yawAxis.read()  File "papywizard/hardware/axis.py", line 273, in read    value = self._sendCmd("j")  File "papywizard/hardware/axis.py", line 243, in _sendCmd    raise HardwareError("Axis %d can't send command" % self._num)HardwareError: Axis 1 can't send command
2009-04-07 17:03:20,792::Spy::EXCEPTION::Axis._sendCmdTraceback (most recent call last):  File "papywizard/hardware/axis.py", line 236, in _sendCmd    answer = self.__driver.sendCmd(cmd)  File "papywizard/hardware/bluetoothDriver.py", line 126, in sendCmd    self._sock.send(":%s\r" % cmd)  File "<string>", line 5, in sendBluetoothError: (107, 'Transport endpoint is not connected')
by fma38 » Tue Apr 07, 2009 10:40 pm
Mmm, it seems that you have some troubles with the Bluetooth module... You don't have a serial-TTL converter so you can test with a serial line?
olihar
by olihar » Tue Apr 07, 2009 11:43 pm
fma38 wrote:Mmm, it seems that you have some troubles with the Bluetooth module... You don't have a serial-TTL converter so you can test with a serial line?
Nope, I do not. I wonder if that would be better to have as well, anything you would req. for using with a Mac, As of now running Ubuntu. And I guess that should work with a Mac as well. its only the bluetooth that is not working on the Mac side right?
Any suggestions as well how I should reset the BlueSMIRF? I have left it unplugged for some time and tried again but same things, both lights are on right in the beginning.
by mediavets » Wed Apr 08, 2009 12:06 am
Seems it is not so simple to reset:
http://forum.sparkfun.com/viewtopic.php?p=30660&sid=cc25daf3a39d0635fb772eefc36854dd
You might be better off with a different device? Say the Teleskop-Austria BT device?
olihar
by olihar » Wed Apr 08, 2009 12:28 am
Yeah I saw that forum post after doing some Google-ing. It sounds amazing to me that you cant reset this without mayor hassle.
olihar
by olihar » Wed Apr 08, 2009 7:54 pm
Hi again, I unplugged the BlueSMIRF and left the Merlin on since last posting.
Now I tried to again to plug it in and I only get the Red light like it should be and I can see it with my computer.
I wonder if the Merlin somehow got stuck on a loop? Clogging up the card.
I will report more on how it goes tomorrow as I will try some more tests.
olihar
by olihar » Thu Apr 09, 2009 9:26 am
EDIT:
I now tried to connect it with Papywizard using Ubuntu, as I said before I saw the card fine on the Mac(just using the mac os bluetooth, to see if the card was there) so I thought things where fine. But.
As soon as I try to connect to the card using Papywizard it freezes again. I wonder what is going on.
Here is the Log.
2009-04-09 10:14:07,978::MainThread::INFO::Starting Papywizard...
2009-04-09 10:14:08,949::MainThread::INFO::Importing modules...
2009-04-09 10:14:09,211::MainThread::DEBUG::Shooting.start(): loading user external shooting script
2009-04-09 10:14:09,213::MainThread::WARNING::No user external shooting script found
2009-04-09 10:14:09,575::MainThread::INFO::Loading i18n files...
2009-04-09 10:14:09,610::MainThread::DEBUG::Papywizard.i18n(): locale=en_US
2009-04-09 10:14:09,673::MainThread::WARNING::Can't find qt translation file
2009-04-09 10:14:09,676::MainThread::INFO::Loading Style Sheets...
2009-04-09 10:14:09,709::MainThread::WARNING::No user Style Sheet found
2009-04-09 10:14:09,711::MainThread::INFO::Loading configuration...
2009-04-09 10:14:09,729::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['2', '0', '0'], user=[u'2', u'0', u'0']
2009-04-09 10:14:09,730::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2009-04-09 10:14:09,731::MainThread::INFO::Creating model...
2009-04-09 10:14:09,737::MainThread::INFO::Loading default presets
2009-04-09 10:14:09,792::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2009-04-09 10:14:09,794::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2009-04-09 10:14:09,795::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2009-04-09 10:14:09,796::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2009-04-09 10:14:09,797::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2009-04-09 10:14:09,798::MainThread::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2009-04-09 10:14:09,800::MainThread::INFO::Loading user presets
2009-04-09 10:14:09,801::MainThread::WARNING::No user presets found
2009-04-09 10:14:09,801::MainThread::INFO::Starting Spy...
2009-04-09 10:14:09,805::MainThread::DEBUG::Spy.__init__(): yaw=0.0, pitch=0.0
2009-04-09 10:14:09,806::Spy::INFO::Starting Spy...
2009-04-09 10:14:09,809::MainThread::INFO::Creating GUI...
2009-04-09 10:16:05,605::MainThread::INFO::Connecting to real hardware...
2009-04-09 10:16:12,239::Dummy-4::EXCEPTION::BluetoothDriver.init()
  File "papywizard/hardware/bluetoothDriver.py", line 76, in init
    self._sock.connect((self.__deviceAddress, 1))
  File "<string>", line 5, in connect
BluetoothError: (112, 'Host is down')
2009-04-09 10:16:12,244::Dummy-4::EXCEPTION::Shooting.switchToRealHardware()
  File "papywizard/model/shooting.py", line 378, in switchToRealHardware
    self.realHardware.init()
  File "papywizard/hardware/head.py", line 82, in init
    self.driver.init()
  File "papywizard/hardware/bluetoothDriver.py", line 85, in init
    raise HardwareError(msg)
HardwareError: Host is down
2009-04-09 10:16:12,344::MainThread::ERROR::Can't connect to hardware
Host is down
2009-04-09 10:16:14,103::MainThread::INFO::Go to simulation mode
2009-04-09 10:17:17,907::MainThread::INFO::Connecting to real hardware...
2009-04-09 10:17:33,070::Dummy-4::EXCEPTION::Axis._sendCmd
2009-04-09 10:17:33,071::Dummy-4::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-09 10:17:34,072::Dummy-4::EXCEPTION::Axis._sendCmd
2009-04-09 10:17:34,074::Dummy-4::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-09 10:17:35,076::Dummy-4::EXCEPTION::Axis._sendCmd
2009-04-09 10:17:35,078::Dummy-4::WARNING::Axis._sendCmd(): axis 1 can't sent command. Retrying...
2009-04-09 10:17:35,079::Dummy-4::EXCEPTION::Shooting.switchToRealHardware()
  File "papywizard/hardware/head.py", line 90, in init
    self.yawAxis.init()
  File "papywizard/hardware/axis.py", line 252, in init
    self._sendCmd("L")
2009-04-09 10:17:35,148::MainThread::ERROR::Can't connect to hardware
by fma38 » Thu Apr 09, 2009 10:21 am
So, after that, Papywizard is frozen? It shouldn't...
olihar
by olihar » Thu Apr 09, 2009 11:06 am
fma38 wrote:So, after that, Papywizard is frozen? It shouldn't...
Sorry if I wrote the sentence wrong, the BlueSMIRF is frozen again. Papywizard is fine it just can't connect to the card.
