How to n810 + Papywizard V2
joni
by joni » Mon Mar 23, 2009 7:22 pm
Hi all;
Just my new n810 is arrived with maemo OS2008, v1.207.42-19, and I'm lost with it...
Please, I need help for how to install all the necessary Papywizard V2 packages (step to step, if it's possible) and how to form them.
Thanks a lot. Best,
Joni.
by mediavets » Mon Mar 23, 2009 7:33 pm
Joni,
I recommend that you update the OS to latest version of OS2008.
I am hoping you have a Windows PC. If so then get the Nokia Wizard here:
http://europe.nokia.com/A4305010
Follow the instructions to update (re-flash) OS2008.
If instead you have a Mac let us know and we'll point you to instructions for updating OS2008 using a Mac.
Then go here to install Papywizard - this should install Papywizard 1.6.1:
http://www.autopano.net/wiki/action/view/Install_Papywizard_on_Nokia_770_N800_N810
I suggest you start with 1.6.1 since you have to jump through a few more (currently not thoroughly documented) hoops to install v2.x.
If you get stuck post here and we'll do our best to sort you out.
Good luck.
Perhaps you would be willing update your forum profile so we have some idea of where you are located?
joni
by joni » Mon Mar 23, 2009 7:45 pm
Thanks Andrew;
Yes, I've a Mac. Sorry...
I already have n770 with Papywizard 1.6.1 installed and it works fine, but I like to know the new V2... It's very interesting for me but I'm lost with V2.
Thanks again,
Joni.
bigwade
by bigwade » Mon Mar 23, 2009 7:59 pm
this is the one you need.
RX-44_DIABLO_5.2008.43-7_PR_COMBINED_MR0_ARM.bin
Your N810 can be flashed with the 770 flasher.
Just start the 770 fasher and during the proces connect the N810 with a mini usb cable (should be in the N810 box) to your mac.
Follow instructions and wait.
The process is about 2-3 minutes, maybe longer.
Disconnect the Nokia it will restart on it's own if I remember right.
Then follow instructions to install the PW project.
grtz!
link at 20.45
by mediavets » Mon Mar 23, 2009 8:02 pm
joni wrote:Thanks Andrew;
Thanks again,
Joni.
Joni,
OK try these instructions for updating OS2008 using a Mac running OSX:
http://workshop.nseries.com/2008/01/how-to-flash-an-n800-image-from-mac-os-x/152
I k now nothing about Macs so hope this works for you. If you get stuck come back here.
Update - just seen Frank's post above - I suggest you take his advice.
If it works OK, then follow instructions for installing Papywizard.
When you have Papywizard v1.6.1 running on N800 then post your success here and we'll help you upgrade Papywizard to version 2.x.
From a user standpoint the differences between 1.6.1 and 2.x are quite subtle.
Good luck.
bigwade
by bigwade » Mon Mar 23, 2009 8:50 pm
How to flash a Nokia N810 with a Mac:
http://tinyurl.com/csbc43
Mac-Flasher and Nokia OS:
http://tinyurl.com/c5enyf
about 100Mb
After flashing the OS be sure to get the N810 connected WiFi with the internet to get access to the PW stuff.
Good luck !
