replacement crown for Merlin: demand poll
teleskop-austria
by teleskop-austria » Fri Mar 20, 2009 6:07 pm
hello dear Merlin friends,
please post here if you need a replacement crown for the Merlin mount,
we want to check if there is demand to develop and produce such a product.
thank you very much
Tommy Nawratil
(teleskop-austria.com)
by mediavets » Fri Mar 20, 2009 6:59 pm
teleskop-austria wrote:hello dear Merlin friends,
thank you very much
Tommy Nawratil
Same old problem - uncertainty (on my part) about what you are offering.
If you are seeking to prove there's no demand then fine... but if you really want to find out what demand might be I think you have to spell out the offer in more detail.
It would of course, at least in my case, depend upon precisely what you are offering, and at what price, and what shipping costs are. And what methods of payment you would accept. And what lead times on delivery from order are.
I'm not ready to sign a blank cheque.
I don't want a crown replacement 'at any price'.
And I don't want something that I have to take to a local machine shop to have more work done on it.
So I'll wait and see what Frank (bigwade) has to tell us about the part you are making for him.
by fma38 » Fri Mar 20, 2009 7:13 pm
I think it would be nice to have some sort of universal crown. Using the idea of SpeedyPan, we could make a thin base, with the friction face, and taped holes. Then, several discs, with different thickness, with holes so the screws can go to the taped holes.
We should carfully choose the thickness, so it will answer to several needs. Same for the holes: it is not difficult to have several holes for different needs (some for the Manfrotto rail).
Hope I'm clear...
Paul
by Paul » Fri Mar 20, 2009 7:14 pm
Andrew,
it's really a hen and egg problem ...
how TA should now what to offer without detailled demand from Merliners
anybody has a different cam with a couple of lenses, different rails, different QRs
anybody has different meanings how to use the Merlin
Paul
bigwade
by bigwade » Fri Mar 20, 2009 7:40 pm
fma38 wrote:I think it would be nice to have some sort of universal crown. Using the idea of SpeedyPan, we could make a thin base, with the friction face, and taped holes. Then, several discs, with different thickness, with holes so the screws can go to the taped holes.
Hope I'm clear...
That is a good idea.
And now we have to find out what camera's are used most to get to the prefered A value.
Canon 450D/5D/5DMk2
by fma38 » Fri Mar 20, 2009 7:51 pm
bigwade wrote:And now we have to find out what camera's are used most to get to the prefered A value.
Yep! I use a Canon 20D (don't remember the A value...)
SpeedyPan
by SpeedyPan » Fri Mar 20, 2009 8:14 pm
I think the crown should be as thin as possible. 10mm should be possible. Then it would be great to have a rail on it which is thinner than the Manfrotto 357 (which is 20mm in total).
Lets suppose we manage to create an 10mm rail system... we would get a system that would allow up to A=62mm. That would be enough, I think... even a D3 owner could do the additional trick with separating the vertical Merlin arm 10mm apart and would be fine.
The missing mm for the smaller cams could be filled by an quick release system like Paul's or by distance plates between the cam and the rail.
In my case (as an example) with A=42 I would need the crown with the rail (20mm), the quick release system (18mm I think) and a 2mm distance plate. If I would switch to a A=43mm, I would only need an 1mm distance plate for maybe 2-3€, if I would switch to a D700 (A=49mm) I would have to forget the quick release and buy an 9mm distance plate and so on....
Hmm... of course I would also have to buy a new 1/4" screw with any new cam.
For sure this is still a workaround solution, but maybe one we can live with.
The best solution at all would be to build a new housing for Merlin with an longer and movable vertical arm :cool:
Clauss Rodeon VR
Canon 7D
Paul
by Paul » Fri Mar 20, 2009 8:31 pm
SpeedyPan wrote:The best solution at all would be to build a new housing for Merlin with an longer and movable vertical arm :cool:
it should go without a new housing:
just adding to profiles 20x20 where the two parts join
T-slot nuts to lock the the upper part and the lower part can be slideable to a specified clearance
if the crown thickness is less than 16mm one could not use the rail in max length as it collides with the vertical arm
rail:
a cheap and very stable solution are these profiles 40x10mm with two slots ~10.-€ per meter
QRs are mountable slideable with T-slot nuts
Paul
by fma38 » Fri Mar 20, 2009 8:32 pm
Yes, why not? But it will increase the final price...
bigwade
by bigwade » Fri Mar 20, 2009 8:51 pm
Can we stay OT ?
Crown design and needs ?
I agree if some one could mail the chineese factory to make a basic Merlin with very small footprint and more space...
for the same amount of money and maybe a little faster..
grtz!
SpeedyPan
by SpeedyPan » Fri Mar 20, 2009 8:54 pm
If I wouldn't love my Merlin that much I would disassemble it this night to check this out ;)
Paul... would the solution you think of also move up the vertical arm?
Clauss Rodeon VR
Canon 7D
SpeedyPan
by SpeedyPan » Fri Mar 20, 2009 8:56 pm
Paul... how thick is your POM crown?
Clauss Rodeon VR
Canon 7D
Paul
by Paul » Fri Mar 20, 2009 8:58 pm
POM crown is 17mm thick
SpeedyPan wrote:Paul... would the solution you think of also move up the vertical arm?
yes, it moves the vertical arm up 2cm
Paul
teleskop-austria
by teleskop-austria » Fri Mar 20, 2009 8:59 pm
hello Andrew,
this thread is to check if there is enough demand for such a replacement crown. If we get a dozen or more "yes", then lets go to work and design and produce something, which will be offered then. Nobody is obliged to buy the thing by voting now, its just to get an idea about the demand, even before we know exactly how the thing will look like. It's not the first time we produce such specialized devices. Before producing its not unwise to see if there is possibly a market, isn't it?
So if you possibly could need such a thing, just vote yes.
I am very happy to read about all these ideas, thank you SpeedyPan, fma38, Paul, bigwade! Go on brainstorming!
regarz, Tommy
PS(t): My goodness, while I write this 7 new posts appeared...
PPS: We could tell our chinese friends to produce a new housing, but we would be obliged to
buy 1000 pieces or so...
Last edited by teleskop-austria on Fri Mar 20, 2009 9:03 pm, edited 1 time in total.
bigwade
by bigwade » Fri Mar 20, 2009 9:07 pm
Paul wrote:-----------------------------------------------------------------------------
rail:
http://www.alcom-worldwide.com/de/images/s1054010.jpg
So with the standard Merlin, the base should be 17mm, right ?
And these nice rails 40x10mm can be used.
Don't forget the camera screw at the back of the rail..
That makes 27mm.
Is that enough to mount most camera's with or without QM ?
And what should be the size of the adjustment rings ?
2mm ? 3mm? 5mm ?
Paul
by Paul » Fri Mar 20, 2009 9:12 pm
bigwade wrote:Don't forget the camera screw at the back of the rail..
forget the cam screw if you need max clearance, cam can be fixed with either a sliding plate or a QR
fortunately my E-510 has a small A, so I can slide the QR to get the NPP I need for different focal lenghts
Paul
SpeedyPan
by SpeedyPan » Fri Mar 20, 2009 9:18 pm
rail:
That makes 27mm.
2mm ? 3mm? 5mm ?
The screw doesn't really need to come out of the rail... look at your Manfrotto rail.
Crown=17mm + rail=10mm would mean A=max. 55mm... I think ;)
Clauss Rodeon VR
Canon 7D
bigwade
by bigwade » Fri Mar 20, 2009 9:18 pm
teleskop-austria wrote:PPS: We could tell our chinese friends to produce a new housing, but we would be obliged to
Just ask them ?
It's crisis in China too
If they can make it with the slimmest housing possible, ext. power, same ore better specs..
You will sell 250+ of these units, I'm sure..
But hey, let's stay OT :)
bigwade
by bigwade » Fri Mar 20, 2009 9:20 pm
SpeedyPan wrote:The screw doesn't really need to come out of the rail... look at your Manfrotto rail.
Yep ! :) you are right !
bigwade
by bigwade » Fri Mar 20, 2009 9:25 pm
SpeedyPan wrote:Crown=17mm + rail=10mm would mean A=max. 55mm... I think ;)
digged it up here:
http://upload.wikimedia.org/wikipedia/commons/3/3a/All_Camera_to_be_pub.pdf
SpeedyPan
by SpeedyPan » Fri Mar 20, 2009 9:40 pm
teleskop-austria wrote:hello Andrew,
regarz, Tommy
Tommy
I completely understand you, but maybe you ask the wrong guys. We are a dirty dozen of freaks and some of us allready modified their crowns. I have seen POM, alloy, wood, a cut one and my perspex one.
You should think of and ask thousands of photographers out there that allready bought (or plan to buy) a Nodal Ninja, Kaidan, Manfrotto, MK or any other panorama head. Some of these heads costs even more than Merlin+Bluetooth+Nokia and I can see very few benefits of these against the Merlin. This are the guys you can sell to many crowns... and Merlins... and Bluetooth modules.
But these people doesn't even know of Merlin. And many (or most) of these who found Merlin by accident don't have the skills or the time to make it work by reading hundreds of posts, soldering cables, building crowns and so on. Your bluetooth module made it much easier... for example to me.
Best, Helmut
Clauss Rodeon VR
Canon 7D
by mediavets » Fri Mar 20, 2009 9:50 pm
Tommy,
Yes.
bigwade
by bigwade » Fri Mar 20, 2009 10:01 pm
SpeedyPan wrote:Tommy
Is it ?
It's the Papywizard control software what made this Merlin community.
So Tommy is asking it to the right guys I think.
Freaks........ maybe :)
The rest will follow........
by klausesser » Fri Mar 20, 2009 10:07 pm
A bit OffTopic - bit i think kit fits in here:
Here´s an idea to cut off a piece of the Merlin´s base to get a stronger downlook-angle which results in a smaller footprint/Nadir-hole. That´s small enough to close it with one additional shot.
In the marked area no mechabnical or otherwise vital parts are located.
I´ll be talking to a mechanic next week - for him it should be easy to do.
Of course this is only relevant for shooting spheres . . but that´s an ideal task for the Merlin - shooting from a mast or a high tripod. When i use my Gitzo No.5 i can lift the head up to about 3,5m without additional parts.
But the footprint is too big to close it easily.
Gordon
by Gordon » Fri Mar 20, 2009 10:41 pm
I'd liked to vote yes.
Gordon
2000th Member :D
GigaPixel Experimenter
