Interface and camera connection
by mediavets » Sun Mar 15, 2009 12:51 am
120to120 wrote:Sorry,
I think the cable is not. Please a picture!
2.5 mm jack to Merlin ------- usb cable to camera?
Thank you for that.
I use the Gentled Jump to trigger the shutter of the D40 via IR.
Merlin cannot control a D40 via USB.
If you camera(s) offer a means of triggering the shutter using a wired remote, or an IR remote, than use those methods with Merlin/Papywizard, rather than connecting via USB, which is tricky and for which there no off-the self- solutions AFAIK.
OTOH this special cable - mentioned previously - should work for your Canon S5is, Merlin-USB:
http://www.autopano.net/forum/p40738-today-00-14-33#p40738
But contact James Gentles to check before ordering; you will have add a 2.5mm jack plug and provide power to it, probably easiest to do with batteries. Ask James how best to do this and make sure he knows you want to use it for a Merlin head and Papywizard, he may be able to make up a special variant of it for you.
120to120
by 120to120 » Sun Mar 15, 2009 12:36 pm
Did the simple Merlin / Orion Silver Head.
2.5 mm jack is MONO!
(*Merlin/Orion_BT - teleskop-austria.*); FTDI USB-TTL cable; Macbook (Intel) OS X10.5.6 / ext. Bluetooth Dongle_VIVANCO_B1002270209 / PW 2.1.20; Go-To / TA *Nokia N810 / PW 2.1.20 * Sony F717 / Sony R1 ; JJC SR-828; 15m Mast;
Previous
