Install papywizard on Linux problems
geraldcor
by geraldcor » Sun Mar 01, 2009 10:02 pm
Hello all,
I am back with more silly questions.
I am trying to install papywizard on an OLPC http://laptop.org/en/ which runs a variation of fedora. I can't use a .deb package so I downloaded the source, ran python setup.py install --prefix=/usr/local and all seems to have gone well up to this point. I can't seem to figure out how to launch the program now. I tried ./papywizard.sh (from /usr/local/bin) but that gave me an error. I basically have to do everything from the command line and I'm not sure how to get the program running.
This is the error I get when running papywizard.sh
bash-3.2# ./papywizard.sh
  File "<string>", line 1, in <module>
ImportError: No module named papywizard.scripts.main
Any ideas out there? Thank you for all of your help so far. (Orion should arrive tomorrow :D
Greg
Canon Rebel XT XTi
EF-S 18-55 IS, EF-S 17-85 IS, EF 50 1.8
Asus EEEpc, OLPC, Arduino (In the works)
Papywizard of course
bigwade
by bigwade » Sun Mar 01, 2009 11:58 pm
Hey Greg,
can you add some info in your profile ?
Location etc.
grtz!
by fma38 » Mon Mar 02, 2009 12:01 am
What version are you trying to run?
Did you try to run:
$ papywizard.sh
instead of:
$ ./papywizard.sh
from a dir other than /usr/local/bin?
What python version are you running? Can you check you have papywizard tree installed in /usr/local/lib/python<version>/site-packages? Does it works if you run papywizard from the source dir (using ./papywizard.sh, this time)?
You should also fin a entry in the desktop menu, under 'Graphics' sub-menu. Does it work if you launch it from there?
geraldcor
by geraldcor » Mon Mar 02, 2009 12:32 am
bigwade, I will update my profile. I forget those things :)
I installed 1.6.1
papywizard.sh from a dir other than /usr/local/bin? Nope
Python 2.5 papywizard tree is installed.
Run Papywizard from the source directory? YES! That seems to work (at least it starts)
Hm. Very interesting. I suppose I could just continue to run it from this source directory that I downloaded and call it good unless there are any problems that could arise from running it this way? Thanks for your help.
p.s. I am used to things being very difficult to get running on the olpc. It's worth it when things do work because it only draws 7 watts!
Canon Rebel XT XTi
by fma38 » Mon Mar 02, 2009 8:10 am
From your home dir, can you try:
$ PYTHONPATH=/usr/local/lib/python2.5/site-packages papywizard.sh
(check if /usr/local/lib/python2.5/site-packages is the correct path).
geraldcor
by geraldcor » Mon Mar 02, 2009 6:45 pm
Ah that might work. I will try that when I get home tonight. Thanks.
Greg
Canon Rebel XT XTi
tarnis
by tarnis » Sat Apr 11, 2009 12:32 am
Thought this wasn't working then found I had python 2.6 so I put in
$ PYTHONPATH=/usr/local/lib/python2.6/site-packages papywizard.sh
which works... sorry not a major unix guy. I know I'm supposed to put the path into a .rc(or something...) file somewhere. Mind telling me where? :) I'm running ubuntu.
thanks,
Matt
by fma38 » Sat Apr 11, 2009 11:00 am
I don't understand why the /usr/local/lib/python2.6/site-packages dir is not automaticall in the path...
What is the result of:
$ python
>>> import sys
>>> print sys.path
(without exporting the PYTHONPATH var as you did above).
