Tarnis wrote:I just stumbled across this looking for something else... says it has an RJ-11 jack on it and price wise actually looks worth it compared to the parallax board if it works?
http://www.adorama.com/ONBAETX.html
Of course once I found it, it seems like a fairly common product that I'd of thought someone else might have spotted so maybe it's no good?
joelb wrote:I saw in previous posts that the Merlin (and I presume Skywatcher brand is the same)
Joel
fma38 wrote:Joel, it seems that Papywizard is unable to re-read its own output chars... The two resistors are maybe too high for this module. Could you try a 100 Ohm on the RX side only (leave 220 Ohm on TX)? You may leave the common point of the 2 resistors unconnected from the Merlin, as long as the error occurs at line 129 in the bluetoothDriver.py module. Once the error occurs at line 135, then try to reconnect the common point to the Merlin...
claudevh wrote:If you are interrested into those tests I have summarized in a document :
http://www.autopano.fr/wiki/images-fr/e/e2/Merlin_Interface_study.pdf
bigwade wrote:and there are other Ursaminor distributors if TA is not responding.
http://www.ursaminor.hu/contact_en.html
