Papywizard on MacOS
bruper
by bruper » Sat Mar 13, 2010 1:09 am
Could I please ask what's is the Papywizard-2.1.11_PySide.zip ?
Also, I can't mange to understand the BT dongle trick, sometime It appears on Mac BT preference as 7 different dvices, sometime doesn't appear at all, I have to take it out and put it in again to appear...
It seems that PW BT is showing to BT Mac preference that it connects, but then when I go to PW/Hardware/Connect it doesn't, instead it says that it cannot connect because Axis 2 is not working, I quit then I do the dongle trick, I relaunch and now it works, same sort of thing happened yesterday as well. Cannot pinpoint at the moment. OS 10.6.2, PW 2.1.5.
I saw, can't remember where, some issue about Merlin firmware, where was it? Is it related to?
thanks
Bruno
_____
Merlin mount, Sony EX3 with Adaptimax and some Nikon lenses, Canon 60D with some Canon & Tokina lenses, etc. PapyWizard on MBP 17" 2.93 GHz, OS 10.6.6
by fma38 » Sat Mar 13, 2010 8:05 am
The PySide zip archive is Papywizard source using PySide python Qt bindings... It should not be in the MacOS dir...
bruper
by bruper » Fri Mar 19, 2010 1:36 pm
Could I please ask the members running PW+BT on MAC what OS version are using? I wish I could pin point the intermittent (mostly not working) problem of 10.6.2 with the connection...:(
Bruno
_____
by fma38 » Fri Mar 19, 2010 2:00 pm
BTW, for MacOS, you could try to use PySide:
http://www.pyside.org/files/pyside-qt4.5+0.2.2.zip
Then, use the version of Papywizard I made for this binding:
http://www.papywizard.org/static/download/src/papywizard-2.1.11_PySide.zip
PySide is still in heavy developement, but I think there will be ready-to-use packages for all distros, and it will be easier for everyone to install. As the N900 will only run PySide (it already does, in fact, and I asked a french guy to make some tests with his N900), I will switch to that binding one day (with automatic fallback to PyQt if not available).
bruper
by bruper » Fri Mar 19, 2010 2:33 pm
Thanks Frédéric,
is you post from today not conficting with the one from 2010-03-13 07:05:41?
Anyway, I installed http://www.pyside.org/files/pyside-qt4.5+0.2.2.zip
unfortunately I don't understand any thing from what is inside the folder of http://www.papywizard.org/static/downlo … PySide.zip
wish there was some instructions somewhere...
Bruno
_____
by fma38 » Fri Mar 19, 2010 3:28 pm
No conflict; in my previous post, I said that this archive was in the wrong place. It is a source, not a pre-build package for MacOS. But as it is a source, it is possible to use it on every plateform, as long as you have all libs installed. So, if you install PySide (and other small libs, like pyserial or bluetooth), you will be able to use it on your Mac.
Just unzip the archive somewhere, go to the root dir, and run:
$ ./Papywizard.py
bruper
by bruper » Fri Mar 19, 2010 5:47 pm
gosh, I did study "Basic" in the beginning of the 80's, I did work with all kind of big refrigerators computer before desktop-video (until beginning of the 90's) but in the past 20 years I'm guilty to have used only the logic's of Mac... mea culpa, now I'll have to learn everything from scratch (almost) to use the Merlin with BT in my MBP...:D
Bruno
_____
by mediavets » Fri Mar 19, 2010 5:57 pm
bruper wrote:gosh, I did study "Basic" in the beginning of the 80's, I did work with all kind of big refrigerators computer before desktop-video (until beginning of the 90's) but in the past 20 years I'm guilty to have used only the logic's of Mac... mea culpa, now I'll have to learn everything from scratch (almost) to use the Merlin with BT in my MBP...:D
Or do yourself a favour - and preserve a few brain cells - and get a used Nokia N800 Internet tablet.
Previous
