Papywizard on MacOS
by mediavets » Wed May 13, 2009 8:04 pm
olihar wrote:I connected to the Merlin with bluetooth using serial in Papywizard.
http://img.skitch.com/20090512-gfb31dxtcgts1tsbr2i83jash7.jpg
Connects fine and seems to work well as far as I have tested.
Are you using the Telskop-Austria BT device on the Merlin head?
Is the Bluetooth hardware for your Mac a standard built-in device or a USB external device.
You seem to be the first to get BT working on a Mac so it will help others to know more.
olihar
by olihar » Wed May 13, 2009 8:17 pm
Yes I am using the Bluetooth from Telskop as my BlueSmirf broke.
It is the bluetooth card in the Mac.
Well it is not bluetooth per say, MacOs connect to the Bluetooth and then Papywizard connects to that through serial driver.
Here are a couple of screenshots.
I don't have the Merlin here so that's why I get error below
That should work.
by mediavets » Wed May 13, 2009 10:08 pm
Olihar,
Thanks for that detailed explanation - that should make it easy for other Mac users to get it working this way.
jeremyp
by jeremyp » Sat May 30, 2009 12:05 pm
Sorry for the long delay - I modified the path to find the LightBlueAqua framework.
http://www.happiestdays.com/downloads/papywizard-r1836.zip
OSX users please report your bluetooth testing with this version.
by fma38 » Sun May 31, 2009 9:52 am
Did someone try this new release? Is the bluetooth driver working?
olihar
by olihar » Sun May 31, 2009 10:51 am
I will try and test it tomorrow, as I don't have the Merlin here with me.
by fma38 » Sun May 31, 2009 11:12 am
In fact, you don't need the Merlin; just go in the 'Hardware > Plugins...' menu, select the 'Drivers' tab, and click on the bluetooth 'Choose...' button. If you see an error, please report the message (you need to open the log windows, as the message shown in the error dialog box is not correct). If you can scan all your bluetooth devices arround (cellphoen, laptop...), it means that it works.
olihar
by olihar » Sun May 31, 2009 1:33 pm
Hmm I just installed the papywizard from jeremyp, Somethings seems to be off.
There is no hardware tab in configure and simulation mode is not possible and more things are strange. See screenshot.
EDIT: aah sorry I can see things have been moved around now, will report very soon if bluetooth works.
olihar
by olihar » Sun May 31, 2009 1:55 pm
All right so..
When I go to choose in bluetooth Papywizard locks up completely. I don't know How I can get you a log file for that as is locks up completely.
When I tried to manually enter a bluetooth address and then connect I got an error and here is the log... Bare in mind that This bluetooth address is my other Mac so that might be the reason for it not to work. I can try with Merlin tomorrow.
2009-05-31 14:46:43,171::MainThread::INFO::Starting Papywizard...
2009-05-31 14:46:43,298::MainThread::INFO::Importing modules...
2009-05-31 14:46:44,244::MainThread::INFO::Loading i18n files...
2009-05-31 14:46:44,253::MainThread::DEBUG::Papywizard.i18n(): locale=en_US
2009-05-31 14:46:44,254::MainThread::WARNING::Can't find qt translation file
2009-05-31 14:46:44,255::MainThread::INFO::Loading Style Sheets...
2009-05-31 14:46:44,279::MainThread::WARNING::No user Style Sheet found
2009-05-31 14:46:44,279::MainThread::INFO::Loading configuration...
2009-05-31 14:46:44,287::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['2', '1', '6'], user=[u'2', u'1', u'6']
2009-05-31 14:46:44,287::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2009-05-31 14:46:44,288::MainThread::INFO::Load plugins...
2009-05-31 14:46:44,302::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,302::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'yawAxis'
2009-05-31 14:46:44,303::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,303::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'pitchAxis'
2009-05-31 14:46:44,304::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,304::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'shutter'
2009-05-31 14:46:44,307::MainThread::TRACE::MerlinOrionYawAxis._init()
2009-05-31 14:46:44,308::MainThread::TRACE::MerlinOrionAxis._init()
2009-05-31 14:46:44,308::MainThread::TRACE::MerlinOrionHardware._init()
2009-05-31 14:46:44,308::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,309::MainThread::DEBUG::PluginManager.register(): added 'Merlin/Orion' plugin with capacity 'yawAxis'
2009-05-31 14:46:44,309::MainThread::TRACE::MerlinOrionPitchAxis._init()
2009-05-31 14:46:44,310::MainThread::TRACE::MerlinOrionAxis._init()
2009-05-31 14:46:44,310::MainThread::TRACE::MerlinOrionHardware._init()
2009-05-31 14:46:44,311::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,311::MainThread::DEBUG::PluginManager.register(): added 'Merlin/Orion' plugin with capacity 'pitchAxis'
2009-05-31 14:46:44,312::MainThread::TRACE::MerlinOrionShutter._init()
2009-05-31 14:46:44,312::MainThread::TRACE::MerlinOrionHardware._init()
2009-05-31 14:46:44,312::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,313::MainThread::DEBUG::PluginManager.register(): added 'Merlin/Orion' plugin with capacity 'shutter'
2009-05-31 14:46:44,314::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,314::MainThread::DEBUG::PluginManager.register(): added 'Tethered' plugin with capacity 'shutter'
2009-05-31 14:46:44,315::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,316::MainThread::DEBUG::PluginManager.register(): added 'Timelord' plugin with capacity 'shutter'
2009-05-31 14:46:44,317::MainThread::TRACE::PololuServoYawAxis._init()
2009-05-31 14:46:44,318::MainThread::TRACE::PololuServoAxis._init()
2009-05-31 14:46:44,318::MainThread::TRACE::PololuServoHardware._init()
2009-05-31 14:46:44,318::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,319::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'yawAxis'
2009-05-31 14:46:44,319::MainThread::TRACE::PololuServoPitchAxis._init()
2009-05-31 14:46:44,319::MainThread::TRACE::PololuServoAxis._init()
2009-05-31 14:46:44,320::MainThread::TRACE::PololuServoHardware._init()
2009-05-31 14:46:44,320::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,320::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'pitchAxis'
2009-05-31 14:46:44,320::MainThread::TRACE::PololuServoShutter._init()
2009-05-31 14:46:44,321::MainThread::TRACE::PololuServoHardware._init()
2009-05-31 14:46:44,321::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,321::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'shutter'
2009-05-31 14:46:44,322::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-31 14:46:44,323::MainThread::DEBUG::PluginManager.register(): added 'EOS Utility' plugin with capacity 'shutter'
2009-05-31 14:46:44,323::MainThread::INFO::Loading user plugins...
2009-05-31 14:46:44,323::MainThread::DEBUG::PluginManager.register(): parsing '/Users/olihar/.config/papywizard2/plugins' dir...
2009-05-31 14:46:44,323::MainThread::INFO::Activate plugins...
2009-05-31 14:46:44,324::MainThread::TRACE::MerlinOrionHardware.activate()
2009-05-31 14:46:44,325::MainThread::TRACE::MerlinOrionHardware.activate()
2009-05-31 14:46:44,325::MainThread::TRACE::MerlinOrionShutter.activate()
2009-05-31 14:46:44,325::MainThread::INFO::Creating model...
2009-05-31 14:46:44,338::MainThread::WARNING::Shooting.__init__(): Remove self.hardware compatibility
2009-05-31 14:46:44,338::MainThread::INFO::Loading default presets
2009-05-31 14:46:44,348::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2009-05-31 14:46:44,349::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2009-05-31 14:46:44,349::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2009-05-31 14:46:44,350::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2009-05-31 14:46:44,350::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2009-05-31 14:46:44,352::MainThread::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2009-05-31 14:46:44,353::MainThread::INFO::Loading user presets
2009-05-31 14:46:44,353::MainThread::WARNING::No user presets found
2009-05-31 14:46:44,353::MainThread::INFO::Starting Spy...
2009-05-31 14:46:44,354::Spy::INFO::Starting Spy...
2009-05-31 14:46:44,355::MainThread::INFO::Creating GUI...
2009-05-31 14:46:44,436::MainThread::WARNING::MainController.__onKeyPressed(): fix fullScreenFlag property!!!
2009-05-31 14:46:47,214::MainThread::TRACE::MainController.__onActionHelpViewLogActivated()
2009-05-31 14:47:01,903::MainThread::TRACE::AbstractModalDialogController._onRejected()
2009-05-31 14:47:11,446::MainThread::TRACE::MainController.__onActionHardwarePreferencesActivated()
2009-05-31 14:47:14,809::MainThread::TRACE::ConfigController.__onYawAxisConfigurePushButtonClicked()
2009-05-31 14:47:14,831::MainThread::DEBUG::AbstractPluginController._initWidgets(): created 'Main' tab
2009-05-31 14:47:14,831::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Low limit' field
2009-05-31 14:47:14,832::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'High limit' field
2009-05-31 14:47:14,833::MainThread::DEBUG::AbstractPluginController._initWidgets(): created 'Driver' tab
2009-05-31 14:47:14,835::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Type' field
2009-05-31 14:47:14,836::MainThread::DEBUG::AbstractPluginController._initWidgets(): created 'Misc' tab
2009-05-31 14:47:14,837::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Alternate drive' field
2009-05-31 14:47:14,838::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Inertia angle' field
2009-05-31 14:47:17,805::MainThread::TRACE::AbstractModalDialogController._onRejected()
2009-05-31 14:47:45,691::MainThread::TRACE::ConfigController._onAccepted()
2009-05-31 14:47:45,693::MainThread::INFO::Configuration saved
2009-05-31 14:47:49,088::MainThread::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2009-05-31 14:47:49,089::MainThread::INFO::Establishing connection...
2009-05-31 14:47:49,090::Dummy-2::TRACE::MerlinOrionAxis.establishConnection()
2009-05-31 14:47:49,092::Dummy-2::TRACE::BluetoothDriver._init()
2009-05-31 14:47:49,092::Dummy-2::DEBUG::BluetoothDriver._init(): trying to connect to 00:1f:5b:e4:00:7f...
2009-05-31 14:47:49,807::Dummy-2::EXCEPTION::BluetoothDriver._init()
  File "papywizard/hardware/bluetoothDriver.pyc", line 75, in _init
  File "lightblue/_bluetoothsockets.pyc", line 381, in connect
error: (-536870195, u'Cannot connect to 1 on 00:1f:5b:e4:00:7f')
2009-05-31 14:47:49,808::Dummy-2::EXCEPTION::MainController.__establishConnection().connect()
  File "papywizard/controller/mainController.pyc", line 949, in connect
  File "papywizard/plugins/merlinOrionPlugins.pyc", line 257, in establishConnection
  File "papywizard/hardware/hardwarePlugin.pyc", line 79, in establishConnection
  File "papywizard/hardware/abstractDriver.pyc", line 91, in establishConnection
2009-05-31 14:47:49,808::Dummy-2::TRACE::MerlinOrionAxis.establishConnection()
2009-05-31 14:47:49,808::Dummy-2::TRACE::BluetoothDriver._init()
2009-05-31 14:47:49,809::Dummy-2::DEBUG::BluetoothDriver._init(): trying to connect to 00:1f:5b:e4:00:7f...
2009-05-31 14:47:50,916::Dummy-2::EXCEPTION::BluetoothDriver._init()
error: (268435459, u'Cannot connect to 1 on 00:1f:5b:e4:00:7f')
2009-05-31 14:47:50,916::Dummy-2::EXCEPTION::MainController.__establishConnection().connect()
  File "papywizard/controller/mainController.pyc", line 956, in connect
2009-05-31 14:47:50,917::Dummy-2::TRACE::MerlinOrionShutter.establishConnection()
2009-05-31 14:47:50,917::Dummy-2::TRACE::BluetoothDriver._init()
2009-05-31 14:47:50,917::Dummy-2::DEBUG::BluetoothDriver._init(): trying to connect to 00:1f:5b:e4:00:7f...
2009-05-31 14:47:52,210::Dummy-2::EXCEPTION::BluetoothDriver._init()
2009-05-31 14:47:52,211::Dummy-2::EXCEPTION::MainController.__establishConnection().connect()
  File "papywizard/controller/mainController.pyc", line 963, in connect
  File "papywizard/plugins/merlinOrionPlugins.pyc", line 495, in establishConnection
2009-05-31 14:47:52,211::Dummy-2::DEBUG::MainController.__onHardwareConnected(): flag=False
2009-05-31 14:47:52,214::MainThread::ERROR::Can't establish connection
One or more plugin failed to connect:
yawAxis
pitchAxis
shutter
2009-05-31 14:47:58,250::MainThread::DEBUG::MainController.__onActionHardwareConnectToggled(False)
2009-05-31 14:47:58,251::MainThread::INFO::Shuting down connection...
2009-05-31 14:47:58,251::MainThread::INFO::Connection shutdown
2009-05-31 14:48:07,370::MainThread::TRACE::MainController.__onActionHelpViewLogActivated()
by fma38 » Mon Jun 01, 2009 12:08 am
Ok, so it seems that the bluetooth module is correclty loaded (Yes, it is normal that you can't connect) :)
Good job, Jeremy!!!
But I don't understand why it freezes with the Choose button... Did you way long enough? It takes some time to search for BT devices arround (~10s). BTW, once you killed the app, you can read the log, as they are stored in your /tmp dir... Is there any interesting informations, there, after freezing?
It seems that the find_devices() function of the bluetooth module does not work very well (at least, it does not see any device for Jeremy, and seems to freeze for you). But anyway, it is possible to manually enter the address, and it should work.
If someone else could confirm...
FINE-ART
by FINE-ART » Mon Jun 01, 2009 10:19 am
Désolé pour le Français ,
je viens de tester , la connexion Mac vers Merlin fonctionne
lorsque je connecte Papywizard à  la Merlin , il affiche que des plugin ( les 3 ) ne se connecte pas , je ressaye et ça marche , Papywizard est connecté à  la Merlin
je teste un déplacement par exemple à  droite de la Merlin , la commande s'exécute, la merlin tourne bien à  droite mais ne s'arrête pas il faut que je mette la merlin sur off pour l'arrêter .
mais je viens de retester , ça a marché un peu lorsque je commande le déplacement , mais ensuite c'est reparti en continu .
j'ai l'impression que c'est une sorte de rebond , comme si le clique souris sur la flèche de déplacement entraîne une boucle comme si le clique de la souris était maintenu en continu . D'ailleurs lorsque j'ai coupé la merlin , j'ai vu les click se faire encore alors que l'avais lâché la souris , un peu comme un magnéto qui répète des actions !!!!!
le LOG
2009-06-01 11:12:57,774::MainThread::INFO::Starting Papywizard...
2009-06-01 11:12:57,836::MainThread::INFO::Importing modules...
2009-06-01 11:12:58,541::MainThread::INFO::Loading i18n files...
2009-06-01 11:12:58,546::MainThread::DEBUG::Papywizard.i18n(): locale=fr_FR
2009-06-01 11:12:58,546::MainThread::WARNING::Can't find qt translation file
2009-06-01 11:12:58,547::MainThread::INFO::Loading Style Sheets...
2009-06-01 11:12:58,574::MainThread::WARNING::No user Style Sheet found
2009-06-01 11:12:58,575::MainThread::INFO::Loading configuration...
2009-06-01 11:12:58,579::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['2', '1', '6'], user=[u'2', u'1', u'6']
2009-06-01 11:12:58,580::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2009-06-01 11:12:58,580::MainThread::INFO::Load plugins...
2009-06-01 11:12:58,595::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,596::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'yawAxis'
2009-06-01 11:12:58,596::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,596::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'pitchAxis'
2009-06-01 11:12:58,597::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,597::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'shutter'
2009-06-01 11:12:58,599::MainThread::TRACE::MerlinOrionYawAxis._init()
2009-06-01 11:12:58,599::MainThread::TRACE::MerlinOrionAxis._init()
2009-06-01 11:12:58,599::MainThread::TRACE::MerlinOrionHardware._init()
2009-06-01 11:12:58,599::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,600::MainThread::DEBUG::PluginManager.register(): added 'Merlin/Orion' plugin with capacity 'yawAxis'
2009-06-01 11:12:58,600::MainThread::TRACE::MerlinOrionPitchAxis._init()
2009-06-01 11:12:58,600::MainThread::TRACE::MerlinOrionAxis._init()
2009-06-01 11:12:58,601::MainThread::TRACE::MerlinOrionHardware._init()
2009-06-01 11:12:58,601::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,601::MainThread::DEBUG::PluginManager.register(): added 'Merlin/Orion' plugin with capacity 'pitchAxis'
2009-06-01 11:12:58,601::MainThread::TRACE::MerlinOrionShutter._init()
2009-06-01 11:12:58,602::MainThread::TRACE::MerlinOrionHardware._init()
2009-06-01 11:12:58,602::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,602::MainThread::DEBUG::PluginManager.register(): added 'Merlin/Orion' plugin with capacity 'shutter'
2009-06-01 11:12:58,603::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,603::MainThread::DEBUG::PluginManager.register(): added 'Tethered' plugin with capacity 'shutter'
2009-06-01 11:12:58,604::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,604::MainThread::DEBUG::PluginManager.register(): added 'Timelord' plugin with capacity 'shutter'
2009-06-01 11:12:58,605::MainThread::TRACE::PololuServoYawAxis._init()
2009-06-01 11:12:58,605::MainThread::TRACE::PololuServoAxis._init()
2009-06-01 11:12:58,606::MainThread::TRACE::PololuServoHardware._init()
2009-06-01 11:12:58,606::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,606::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'yawAxis'
2009-06-01 11:12:58,606::MainThread::TRACE::PololuServoPitchAxis._init()
2009-06-01 11:12:58,606::MainThread::TRACE::PololuServoAxis._init()
2009-06-01 11:12:58,607::MainThread::TRACE::PololuServoHardware._init()
2009-06-01 11:12:58,607::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,607::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'pitchAxis'
2009-06-01 11:12:58,607::MainThread::TRACE::PololuServoShutter._init()
2009-06-01 11:12:58,608::MainThread::TRACE::PololuServoHardware._init()
2009-06-01 11:12:58,608::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,608::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'shutter'
2009-06-01 11:12:58,609::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 11:12:58,609::MainThread::DEBUG::PluginManager.register(): added 'EOS Utility' plugin with capacity 'shutter'
2009-06-01 11:12:58,609::MainThread::INFO::Loading user plugins...
2009-06-01 11:12:58,609::MainThread::DEBUG::PluginManager.register(): parsing '/Users/yh/.config/papywizard2/plugins' dir...
2009-06-01 11:12:58,610::MainThread::INFO::Activate plugins...
2009-06-01 11:12:58,610::MainThread::TRACE::MerlinOrionHardware.activate()
2009-06-01 11:12:58,610::MainThread::TRACE::MerlinOrionShutter.activate()
2009-06-01 11:12:58,610::MainThread::INFO::Creating model...
2009-06-01 11:12:58,613::MainThread::WARNING::Shooting.__init__(): Remove self.hardware compatibility
2009-06-01 11:12:58,614::MainThread::INFO::Loading default presets
2009-06-01 11:12:58,621::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2009-06-01 11:12:58,621::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2009-06-01 11:12:58,622::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2009-06-01 11:12:58,622::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2009-06-01 11:12:58,622::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2009-06-01 11:12:58,623::MainThread::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2009-06-01 11:12:58,624::MainThread::INFO::Loading user presets
2009-06-01 11:12:58,624::MainThread::WARNING::No user presets found
2009-06-01 11:12:58,625::MainThread::INFO::Starting Spy...
2009-06-01 11:12:58,625::MainThread::INFO::Creating GUI...
2009-06-01 11:12:58,625::Spy::INFO::Starting Spy...
2009-06-01 11:12:58,684::MainThread::WARNING::MainController.__onKeyPressed(): fix fullScreenFlag property!!!
A+
Yvon
by fma38 » Mon Jun 01, 2009 3:52 pm
Tout ça en bluetooth? Il manque le reste des logs, là , non ? Es-tu bien passé en mode debug ?
Sinon, concernant les symptômes, cela veux dire que la communication merdoie : si la Merlin ne reçoit pas l'ordre d'arrêt (ou ne le comprend pas), elle continue. Et le GUI est un peu dans les choux (mon code a besoin d'un peu plus de robustesse à  ce niveau, j'avoue).
Pour résumer, il semble que la communication bluetooth soit un peu ératique...
macbenutzer
by macbenutzer » Mon Jun 01, 2009 6:58 pm
Hi Frederic,
i now got the last version for OS X (the download was about 30 minutes after all).
When trying to connect via the known "serial/bluetooth" way i can connect to the head as before.
When i try to connect via bluetooth from Papywizard directly the application hangs when trying to select a BT connection. I can not select "Cancel" or "Select" nor select the bar where the available bluetooth devices should be shown.
Here is what i got from the console after + 1 minute (there are hundreds of equal entries within the time i waited):
01.06.09 20:00:01 papywizard[4742] *** _NSAutoreleaseNoPool(): Object 0x1851b8c0 of class __NSCFDate autoreleased with no pool in place - just leaking
Stack: (0x9040c73f 0x90318e32 0x17179855 0x17179d6c 0x17190825 0x171a7b63 0x308505 0x376832 0x378173 0x37679d 0x378173 0x37679d 0x378173 0x37679d 0x376700 0x378173 0x322488 0x308505 0x37182d 0x39e88f 0x97161095 0x97160f52)
And here is what the log says after another try - i restarted Papywizard after it crashed to read the log:
2009-06-01 19:55:00,475::MainThread::INFO::Starting Papywizard...
2009-06-01 19:55:00,586::MainThread::INFO::Importing modules...
2009-06-01 19:55:01,844::MainThread::INFO::Loading i18n files...
2009-06-01 19:55:01,853::MainThread::DEBUG::Papywizard.i18n(): locale=de_DE
2009-06-01 19:55:01,854::MainThread::WARNING::Can't find qt translation file
2009-06-01 19:55:01,855::MainThread::INFO::Loading Style Sheets...
2009-06-01 19:55:01,871::MainThread::WARNING::No user Style Sheet found
2009-06-01 19:55:01,871::MainThread::INFO::Loading configuration...
2009-06-01 19:55:01,878::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['2', '1', '6'], user=[u'2', u'1', u'6']
2009-06-01 19:55:01,879::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2009-06-01 19:55:01,879::MainThread::INFO::Load plugins...
2009-06-01 19:55:01,895::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,896::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'yawAxis'
2009-06-01 19:55:01,897::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,898::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'pitchAxis'
2009-06-01 19:55:01,898::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,899::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'shutter'
2009-06-01 19:55:01,901::MainThread::TRACE::MerlinOrionYawAxis._init()
2009-06-01 19:55:01,902::MainThread::TRACE::MerlinOrionAxis._init()
2009-06-01 19:55:01,902::MainThread::TRACE::MerlinOrionHardware._init()
2009-06-01 19:55:01,902::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,903::MainThread::DEBUG::PluginManager.register(): added 'Merlin/Orion' plugin with capacity 'yawAxis'
2009-06-01 19:55:01,903::MainThread::TRACE::MerlinOrionPitchAxis._init()
2009-06-01 19:55:01,903::MainThread::TRACE::MerlinOrionAxis._init()
2009-06-01 19:55:01,904::MainThread::TRACE::MerlinOrionHardware._init()
2009-06-01 19:55:01,904::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,904::MainThread::DEBUG::PluginManager.register(): added 'Merlin/Orion' plugin with capacity 'pitchAxis'
2009-06-01 19:55:01,905::MainThread::TRACE::MerlinOrionShutter._init()
2009-06-01 19:55:01,905::MainThread::TRACE::MerlinOrionHardware._init()
2009-06-01 19:55:01,905::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,906::MainThread::DEBUG::PluginManager.register(): added 'Merlin/Orion' plugin with capacity 'shutter'
2009-06-01 19:55:01,907::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,907::MainThread::DEBUG::PluginManager.register(): added 'Tethered' plugin with capacity 'shutter'
2009-06-01 19:55:01,908::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,908::MainThread::DEBUG::PluginManager.register(): added 'Timelord' plugin with capacity 'shutter'
2009-06-01 19:55:01,910::MainThread::TRACE::PololuServoYawAxis._init()
2009-06-01 19:55:01,910::MainThread::TRACE::PololuServoAxis._init()
2009-06-01 19:55:01,911::MainThread::TRACE::PololuServoHardware._init()
2009-06-01 19:55:01,911::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,911::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'yawAxis'
2009-06-01 19:55:01,912::MainThread::TRACE::PololuServoPitchAxis._init()
2009-06-01 19:55:01,912::MainThread::TRACE::PololuServoAxis._init()
2009-06-01 19:55:01,912::MainThread::TRACE::PololuServoHardware._init()
2009-06-01 19:55:01,913::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,913::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'pitchAxis'
2009-06-01 19:55:01,913::MainThread::TRACE::PololuServoShutter._init()
2009-06-01 19:55:01,914::MainThread::TRACE::PololuServoHardware._init()
2009-06-01 19:55:01,914::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,914::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'shutter'
2009-06-01 19:55:01,915::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-06-01 19:55:01,916::MainThread::DEBUG::PluginManager.register(): added 'EOS Utility' plugin with capacity 'shutter'
2009-06-01 19:55:01,916::MainThread::INFO::Loading user plugins...
2009-06-01 19:55:01,916::MainThread::DEBUG::PluginManager.register(): parsing '/Users/aix/.config/papywizard2/plugins' dir...
2009-06-01 19:55:01,917::MainThread::INFO::Activate plugins...
2009-06-01 19:55:01,917::MainThread::TRACE::MerlinOrionHardware.activate()
2009-06-01 19:55:01,918::MainThread::TRACE::MerlinOrionShutter.activate()
2009-06-01 19:55:01,918::MainThread::INFO::Creating model...
2009-06-01 19:55:01,923::MainThread::WARNING::Shooting.__init__(): Remove self.hardware compatibility
2009-06-01 19:55:01,923::MainThread::INFO::Loading default presets
2009-06-01 19:55:01,934::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2009-06-01 19:55:01,935::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2009-06-01 19:55:01,935::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2009-06-01 19:55:01,936::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2009-06-01 19:55:01,936::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2009-06-01 19:55:01,938::MainThread::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2009-06-01 19:55:01,939::MainThread::INFO::Loading user presets
2009-06-01 19:55:01,939::MainThread::WARNING::No user presets found
2009-06-01 19:55:01,940::MainThread::INFO::Starting Spy...
2009-06-01 19:55:01,940::MainThread::INFO::Creating GUI...
2009-06-01 19:55:01,940::Spy::INFO::Starting Spy...
2009-06-01 19:55:02,034::MainThread::WARNING::MainController.__onKeyPressed(): fix fullScreenFlag property!!!
MacPro - MacBook - OS X 10.6.2 - D300 - D700 - Fuji S5 - PhaseOne P65+/P30+
8mm/10,5mm/10-20mm/17-35mm/18mm/25mm/85mm/etc. - wired + BT Merlin/Orion
macbenutzer
by macbenutzer » Mon Jun 01, 2009 7:06 pm
fma38 wrote:Es-tu bien passé en mode debug ?
How do i do that in the current version 2.1.6.1?
Peter
by fma38 » Mon Jun 01, 2009 7:19 pm
In the last tab of the Configuration dialog...
The error you get is very strange; it seems that the bluetooth module or MacOS is buggy!
120to120
by 120to120 » Mon Jun 01, 2009 7:43 pm
hallo macbenutzer,
hat PW mit Bluetooth schon einmal am macbook funktioniert? Verwendest du integrierte Bluetooth, oder externen Bluetoothstecker? Hast du mit dem macbook mit irgend einem Bluetooth-Gerà¤te konstanten Kontakt?
Verwendest du mac os-x mit oder ohne Paralles?
Beantworte bitte diese Fragen.
(*Merlin/Orion_BT - teleskop-austria.*); FTDI USB-TTL cable; Macbook (Intel) OS X10.5.6 / ext. Bluetooth Dongle_VIVANCO_B1002270209 / PW 2.1.20; Go-To / TA *Nokia N810 / PW 2.1.20 * Sony F717 / Sony R1 ; JJC SR-828; 15m Mast;
macbenutzer
by macbenutzer » Mon Jun 01, 2009 9:53 pm
120to120 wrote:hallo macbenutzer,
Hi, i will stay in english so everybody can follow - ok?
Yes: PW does work with a connection via "serial" and something like "/dev/tty.PapyMerlin-DevB-1" i the serial setting tab.
Yes: i use the internal bluetooth from my MacBook.
Yes: i have no problems with a BT connection to my Merlin via the above connection.
Yes: i only rum under OS X - no paralles or equal.
No: i can not get a connection with the BT integrated in PW - PW hangs when trying to connect.
Cheers - Gruesse - Peter
macbenutzer
by macbenutzer » Mon Jun 01, 2009 9:56 pm
fma38 wrote:In the last tab of the Configuration dialog...
Ok - i oversaw this. It was in "debug"-mode.
fma38 wrote:The error you get is very strange; it seems that the bluetooth module or MacOS is buggy!
This BT module runs fine under this OS X with the "serial"-setting. Just the PW bluetooth setting does not work :-(
Do you need any more informations? Something more i could deliver?
Peter
by fma38 » Mon Jun 01, 2009 11:25 pm
I was talking about the python bluetooth module, lightblue. It is not the same under windows/linux...
About the log, once the app. has crashed, send me le log in /tmp/papywizard.log (without restarting Papywizard)...
by mediavets » Mon Jun 01, 2009 11:28 pm
macbenutzer wrote:Yes: PW does work with a connection via "serial" and something like "/dev/tty.PapyMerlin-DevB-1" i the serial setting tab.
So what's the problem?
Does it matter whether you configure the BT wireless connection as a virtual serial connection - as I understand it that works OK so what are you worrying about?
by fma38 » Tue Jun 02, 2009 7:05 am
Well, it would be nice to have the same features in all plateforms, and to be able to browser the BT address of the devices arround from Papywizard...
by mediavets » Tue Jun 02, 2009 7:43 am
fma38 wrote:Well, it would be nice to have the same features in all plateforms
True - FWIW I only ever got a functional wireless BT connection from the T23 under Windows 2000 using a USB BT device when configured as a virtual serial port.
Sadly at present Papywizard 2.1.8 does not run on Windows 2000 at all! So I can use no version more recent than 2.1.6 on my old Thinkpad T23 laptop.:rolleyes:
macbenutzer
by macbenutzer » Tue Jun 02, 2009 9:18 am
mediavets wrote:So what's the problem?
fma38 wrote:Well, it would be nice to have the same features in all plateforms, and to be able to browser the BT address of the devices arround from Papywizard...
Excactly - that is what i wanted to help with. The virtual port is a bit "handmade" and as PW crashes when trying to select a BT device it should be worked on...
@Fred: I will send you the log tonight.
Peter
by mediavets » Tue Jun 02, 2009 10:04 am
macbenutzer wrote:The virtual port is a bit "handmade"
Peter
It is a perfectly viable/proper form of BT connection. BT supports many profiles.
macbenutzer
by macbenutzer » Tue Jun 02, 2009 12:42 pm
mediavets wrote:It is a perfectly viable/proper form of BT connection. BT supports many profiles.
Yes, i know. But it is not "Plug&Play" as a normal Mac-User is used to :-)
He has to go to the BT-Systemsetting, add the BT module to the list, copy the /dev/-path and insert that in PW manually. That is what i ment with "handmade".
It would be easier to just select the BT-module within PW...
Peter
PreviousNext
