general setup question
Paul
by Paul » Sun Feb 08, 2009 1:06 pm
as I am just installing my modified crown, rail and clamp:
Where is Merlins vertical arm when you look from behind the cam on the Merlin? Right or left ?
Photos will follow ...
Paul
by mediavets » Sun Feb 08, 2009 1:38 pm
Right. Camera handgrip uppermost when camera mounted in portrait orientation.
Paul
by Paul » Sun Feb 08, 2009 3:04 pm
crown mod ready, original crown removed and replaced with custom crown
material:
- 1 disk POM, made on own lathe
- 1 rail aluminium profile 10x20mm 165mm
- 1 quenox qr01 qick release
- 3 screws, 2 nuts, 1 slotnut
the quick release is npp adjustable moving back or forth inside the rails slot
next step: engrave a scale on rail for correct npp setting
Paul
by mediavets » Sun Feb 08, 2009 4:07 pm
Having done all this how much did you gain on the 'A' dimension?
Paul
by Paul » Sun Feb 08, 2009 4:54 pm
just compare the pics
left crown mod: rail behind bubble
right case mod (moved arm, claudevh?): rail in front of bubble
Paul
