pocket pc version
AerialVr
pocket pc version
by AerialVr » Thu Jan 29, 2009 2:27 pm
forgive my ignorance but i was wondering if there is a way to run papywizard on a pocket pc? is it just a question of recompiling the soarcecode for another operating system or is it rewritting the whole deal? is there something i could install on my pocket pc that would allow it to run as it is?
Chris BLake
by fma38 » Thu Jan 29, 2009 3:35 pm
There is no need to compile Papywizard, as it is written in python, a script language. But you need to install the python interpretor, and python modules used in Papwyizard (PyQt4, bluetooth...).
I think python exists (you need 2.5), but I don't know for PyQt4. If you have time to dig, it would help (I have an old PocketPC so I can make some tests).
AerialVr
by AerialVr » Thu Jan 29, 2009 3:41 pm
Hi Frederick,
this is good news then i could have an option to use my laptop when i want to use dslr remote for pole shots and my pocket pc that i already have for tripod shots when its easy to touch the camera. do you know where i get he interpreter?
thanks
Chris
by fma38 » Thu Jan 29, 2009 4:15 pm
Try from http://www.python.org to find a binary installer for PocketPC... I'll ask on python ML.
by fma38 » Thu Jan 29, 2009 4:18 pm
PythonCE is available here:
http://pythonce.sourceforge.net
I will dig for pyqt4...
AerialVr
by AerialVr » Thu Jan 29, 2009 4:28 pm
funny i just found that. still don't quite know what to do with it. do i need an interpreter for pyqt4? or is pyqt4 a module in python. obviously im in over my head here but thats ok
AerialVr
AerialVr
by AerialVr » Thu Jan 29, 2009 4:36 pm
what kind of blue tooth protocalls does my pocket pc need to support?
by mediavets » Thu Jan 29, 2009 4:39 pm
AerialVr wrote:obviously im in over my head here but thats ok
Could be - pythons can swallow very large prey. ;)
I think you would be better off getting hold of a used Nokia N800/N810 Internet Tablet, and forget about trying to run Papywizard on a Pocket PC.
by fma38 » Thu Jan 29, 2009 4:45 pm
PyQT4 is the python binding of the Qt4 C++ library. It needs to be cross-compiled for PocketPC plateform: this is not something I can do myself (I'm alrady fighting at work to cross-compile python itself for a VME embedded system!). I hope there are already binaries arround.
For python, it is the same: the interpretor is written in C, so needs to be compiled for PocketPC. PythonCE is the binary for that platform. So you can install it (I did that for an earlier version, and it works fine).
About bluetooth, it will work, don't worry.
But there will be an issue: screen size. Papywizard is not designed for vertical screens...
AerialVr
by AerialVr » Thu Jan 29, 2009 5:55 pm
is there a previous stable version thats in python that doesent use pyqt4? that would work with just he python interpreter? if so what version would that be?
Chris
AerialVr
by AerialVr » Mon Feb 09, 2009 7:19 pm
fma38 wrote:PythonCE is available here:
Hi Frederick,
I got this installed ok and all the source code for 1.6.1 on my pocket pc. then i clicked on the main papywizard script and its looking for a pygtk module and not finding it. were do get that and where should i put it? did I get the correct version? thanks for your help
Chris Blake
by fma38 » Mon Feb 09, 2009 11:00 pm
Well, you need PyGTK for WindowsCE... I don't know if it has been packaged.
I think we'll have much success searching for PyQt, for the v2 (release 1.9.3 as the same features as the 1.6.1 - and even more - except internationalization).
AerialVr
by AerialVr » Tue Feb 10, 2009 1:45 pm
ok thanks I'll keep looking for now im going to us my laptop
by mediavets » Wed Feb 11, 2009 10:03 am
AerialVr wrote:ok thanks I'll keep looking for now im going to us my laptop
A wise choice.
Meanwhile you could look out for a used Nikoa N800/N810 at a good price.
