fma38 wrote:I changed it to 150! Hope it is enough...
fma38 wrote:Hello folks!
Just to say that the first stable release of the branch 2.x is online!
Enjoy!
klausesser wrote:Hi Frédéric!
Got it now. BUT: Papy generates THREE scripts at once. NONE of them works in APG 2.
Without scripts APG does well (besides of an irritating new layout . . . but maybe PC-Freaks might love it . .:cool:) . .
fma38 wrote:What do you mean by THREE scripts at once?
mediavets wrote:klausesser wrote:Hi Frédéric!
Hi Klaus,
What aspects of the layout don't you like? It hasn't changed much has it?
klausesser wrote:=the editors´s picture-size was to set very easy . now you have to click yourself to the needed size . . where is "fit to window", where is "100%" or "50%" and so on.
fma38 wrote:These are log file, not xml files! I activated the log on files, because sometimes we need to be able to read log *after* a crash.
It is normal that APG can't load them
I will change the output dir for that log files (to a temp dir, instead).
klausesser wrote:fma38 wrote:These are log file, not xml files! I activated the log on files, because sometimes we need to be able to read log *after* a crash.
I will change the output dir for that log files (to a temp dir, instead).sh . . .
- but they´re located where the Papy files usually. Where the hell are the xml located for APG?
best to you, Klaus
mediavets wrote:I set mine to be the SD card. Because then when I plug the N800 in via USB I can access those files dircetly from APG when using the Import filter, which based on my first simple test seems to work rather well.
$ sudo gainroot
# apt-get update
# apt-get upgrade
fma38 wrote:Hey, it now works (I didn't check before)!
You should try to update the packages:
- Code: Select all
$ sudo gainroot
# apt-get update
# apt-get upgrade
