[papywizard v2] Annoncement, feedback, bug report
by fma38 » Sat Feb 14, 2009 6:10 pm
Ok, Windows package is online; you may see that some buttons are not translated. This is because I have to find how Windows deals with Qt default translation files... I would like to avoid embedding them in Papywizard, as the package is already big!
by mediavets » Sat Feb 14, 2009 11:02 pm
PW 1.9.5 Nokia N800 OS2008
Crashes on load.
2009-02-14 22:04:27,227::MainThread::INFO::Starting Papywizard...
2009-02-14 22:04:29,112::MainThread::INFO::Importing modules...
2009-02-14 22:04:32,740::MainThread::EXCEPTION::main()
File "/usr/lib/python2.5/site-packages/papywizard/scripts/main.py", line 111, in main
from papywizard.controller.mainController import MainController
File "/usr/lib/python2.5/site-packages/papywizard/controller/mainController.py", line 73, in <module>
from papywizard.controller.shootController import ShootController
File "/usr/lib/python2.5/site-packages/papywizard/controller/shootController.py", line 66, in <module>
from papywizard.controller.spy import Spy
File "/usr/lib/python2.5/site-packages/papywizard/controller/spy.py", line 56, in <module>
from PyQt4 import QtCore, QtNetwork
ImportError: cannot import name QtNetwork
by fma38 » Sat Feb 14, 2009 11:04 pm
Oups, sorry; I forgot to tell you to install the network package:
# apt-get install python2.5-qt4-network
by mediavets » Sat Feb 14, 2009 11:12 pm
fma38 wrote:Oups, sorry; I forgot to tell you to install the network package:
OK - but why do we need this for 1.9.5 when we didn't need it previously?
by mediavets » Sat Feb 14, 2009 11:18 pm
Didn't complete:
"E: Couldn't find package python2.5-qt-network"
by mediavets » Sun Feb 15, 2009 12:16 am
OK - I had forgotten that I had disabled the Maemo extras devel catalogue when installing Canola 2.
PW1.9.5 is now loading OK on the N800.
by klausesser » Sun Feb 15, 2009 12:45 am
mediavets wrote:PW1.9.5 is now loading OK on the N800.
Hey Andrew, hey Frédéric!
Working ok?
best to you, Klaus
(besides: did you know that there are other stitchers? :P:cool:)
by fma38 » Sun Feb 15, 2009 9:29 am
It seems there is a problem when opening the shooting dialog: pictures are not correct (size and position). Can you confirm?
by mediavets » Sun Feb 15, 2009 11:08 am
fma38 wrote:It seems there is a problem when opening the shooting dialog: pictures are not correct (size and position). Can you confirm?
Not sure what you mean - do you have a screenshot to show the alleged problem?
by fma38 » Sun Feb 15, 2009 11:28 am
No, as it now works (after rebooting). Strange...
But I found (and fixed) another nasty bug: once connected to the hardware (and even if you disconnect), the position is not refreshed anymore. In fact, it is, but the delay is in seconds instead of milli-seconds! The consequence is that when you shutdown the app, you have to wait the end of this wrong delay: 500s instead of 0.5s if connected, and 100s instead of 0.1s in simulation mode :cool:
by fma38 » Mon Feb 16, 2009 10:07 am
Because I had to use a Qt network sockets instead of python standard ones in order to make them run in Qt threads... This is used to publish the head position, so it can be refreshed in the 3D view.
by fma38 » Mon Feb 16, 2009 10:08 am
Can you please try the 1.9.6 release? I fixed the refresh bug... If all is OK, it will be the 2.0.0 version (with translations).
by mediavets » Tue Feb 17, 2009 7:15 pm
Frederic,
Could we have a user configurable option to choose whether or not to start a new XML file with each shoot (or repetition) or instead to add new data to the same file?
by fma38 » Wed Feb 18, 2009 1:24 am
I'll see what it is possible to do...
by fma38 » Wed Feb 18, 2009 11:25 am
I think I can easily use the same xml data file for repeated panos, but it will be more difficult to manage when starting a new shooting sequence (either restarting the shooting dialog or not), because some parameters can be changed, and so, the xml data file ehader won't match anymore.
BTW, why do you want to use the same data file? Another simpler solution is to make a xslt transformation to merge serveral xml files. I can do that.
by mediavets » Thu Feb 26, 2009 5:33 pm
I think I may have uncovered a bug in 1.9.6 under Windows.
If the Bluetooth connection or serial connection is not configured correctly the attempting to connect will hang the program while 'Connecting to real hardware' is displayed in the status line with no error message and the only way out seems to be to close the program.
by mediavets » Thu Feb 26, 2009 5:39 pm
fma38 wrote:I think I can easily use the same xml data file for repeated panos, but it will be more difficult to manage when starting a new shooting sequence (either restarting the shooting dialog or not), because some parameters can be changed, and so, the xml data file ehader won't match anymore.
Why use the same data file - I was thinking of manual exposure and focus bracketing, changing the settings after each shoot, but wishing to submit all the images to APP/APG with one XML file.
While I'm still thinking about it youyr first comment about being able to use the same data file for each repeat of repeated panos would work for this BUT only if there was an option to have a pause at the end of each of the shoots in the repeat with a manual restart for next repeat - if you see what I mean?
by fma38 » Thu Feb 26, 2009 10:42 pm
Yes, I understand. I'll dig that way...
by mediavets » Fri Feb 27, 2009 2:32 am
fma38 wrote:Yes, I understand. I'll dig that way...
OK.
Did you also see this post?:
http://www.autopano.net/forum/p39786-yesterday-16-33-55#p39786
by fma38 » Fri Feb 27, 2009 7:49 am
Sorry, I forgot to answer...
The problem is that there is no timeout function implemented under Windows. So, if no connection is possible, it hangs :(
by fma38 » Wed Mar 04, 2009 8:40 am
I uploaded a new release (1.9.7), with the external shooting script support :)
For explanations how to use it, see:
http://trac.gbiloba.org/papywizard/wiki/UserGuideSvn#Tetheredshooting
by mediavets » Wed Mar 04, 2009 10:41 pm
Windows 2000 Papywizard 1.9.7-1
Just noticed bug that I've not spotted previously.
If you click the button to get to the Config tab to enable data file from the Shooting window you cannot edit the textboxes.
by fma38 » Wed Mar 04, 2009 11:04 pm
Confirmed and fixed ;)
by mediavets » Thu Mar 05, 2009 5:30 pm
WindowsXP SP3 Papywizard 1.9.7-1
New bug - Config/Data/Data_directory will not accept an entry longer than this 'C:/Documents and Settings/Administrator/My Documen' .
So when attempting to select ............./My Documents via browse button the path name gets truncated as above.
by fma38 » Thu Mar 05, 2009 8:37 pm
Ok, this field was limited to 50 chars. I changed it to 150! Hope it is enough...
PreviousNext
