[papywizard v2] Annoncement, feedback, bug report
by fma38 » Tue Apr 06, 2010 10:52 pm
Have a look here:
http://forum.opensubtitles.org/viewtopic.php?t=881
Does it solve the problem?
by mediavets » Wed Apr 07, 2010 6:53 pm
fma38 wrote:Have a look here:
No.
I seem to have many copies of that file all over the filesystem:
by fma38 » Wed Apr 07, 2010 6:59 pm
In the link, they say to put it in the same dir that the executable...
by mediavets » Wed Apr 07, 2010 7:14 pm
fma38 wrote:In the link, they say to put it in the same dir that the executable...
Yes, that's where I put it after downloading - did I put it in the wrong place?:
by fma38 » Wed Apr 07, 2010 8:07 pm
According to the link, it should be OK. The problem seems to be elsewhere...
by fma38 » Thu Apr 15, 2010 6:13 pm
Release 2.1.18 is online :cool:
ChangeLog:
+ new menu to trigger the shutter manually
+ added more settings to 'Panoduino' plugin
+ shooting counter support (in data file and display dialog)
+ added custom params to 'Generic Tethered' plugin
+ added alternate drive angle param to 'Merlin-Orion' plugin
- Set Reference feature moved from button to menu
- new xml data file format (version 'c')
- 'Panoduino' plugin now uses Pololu Micro Maestro controller
by mediavets » Thu Apr 15, 2010 8:58 pm
fma38 wrote:Release 2.1.18 is online :cool:
I don't seem able to install this version on my N800.
See screenshots:
Gordon
by Gordon » Thu Apr 15, 2010 9:30 pm
Hmm it worked for me.
Best
Gordon
2000th Member :D
GigaPixel Experimenter
jplorge
by jplorge » Thu Apr 15, 2010 9:35 pm
Good evening,
For me, no problem on Nokia N800.
Jean-Pierre
Merlin/Orion firmware : 01.09.81 panohead + Papywizard on XP PC and Linux Ubuntu 9.1 & Nokia 800
Manfrotto 303 PAN HEAD with Nikon D70 + Nikon 18-70 in kit - Nikon 80-200 F 2.8 old - Sigma 10-20
Assembly : Ptgui 9.1.3
by fma38 » Thu Apr 15, 2010 9:58 pm
Andrew, try to download the file again...
Photosbykev
Liked in: 4 posts
by Photosbykev » Thu Apr 15, 2010 10:03 pm
installed without problems on my N800
by mediavets » Thu Apr 15, 2010 10:05 pm
fma38 wrote:Andrew, try to download the file again...
I have tried many times. I have had to go all the way back to 1.6.1 to get PW to install.
On the other hand I had no trouble doing the update from 2.1.17 to 2.1.18 on a second N800.
I must be doing wrong but I can't see what.
jplorge
by jplorge » Thu Apr 15, 2010 10:06 pm
it seems,the head is moving faster.
I try others system now
Jean-Pierre
by fma38 » Thu Apr 15, 2010 10:16 pm
jplorge wrote:it seems,the head is moving faster.
Can you confirm that by downgrading to a previous version?
jplorge
by jplorge » Thu Apr 15, 2010 10:19 pm
Mode B, don't work well on Nikon D70 with "Gentled-IR". only the open do, not the close (when i put time 40") without mode B selected
if i select mode B the sutter start-stop continually and shots interval 1s approx.
Jean-Pierre
jplorge
by jplorge » Thu Apr 15, 2010 10:21 pm
i try it before update on vista, is that good for you?
Jean-Pierre
by fma38 » Thu Apr 15, 2010 10:30 pm
jplorge wrote:Mode B, don't work well on Nikon D70 with "Gentled-IR". only the open do, not the close (when i put time 40") without mode B selected
I'm not surprised: the pulse param. was introduced specifically for the Gentle-IR... You can't use a long delay with it, because it does not let the shutter opened, but rather send several pulses.
jplorge wrote:i try it before update on vista, is that good for you?
Yes.
jplorge
by jplorge » Thu Apr 15, 2010 10:43 pm
sorry, I say it too quickly : same time for 3x2 shot at 6" = 89" total
In fact I'd say well, here is the print screen copy:
first is new version 78"
This version is also more stable, the old often crash at "connect"
Jean-Pierre
claudevh
by claudevh » Thu Apr 15, 2010 10:56 pm
Sorry Fréderic ...
The installation of Papywizard 2-18 give a failure ...
Paywizard can't find the configuration file , and this is correct the path is wrong ...
:cool: Claude :cool:
by mediavets » Thu Apr 15, 2010 11:17 pm
claudevh wrote:Sorry Fréderic ...
I saw that too on first run from the installer.
Click on Close and run PW again and it loads and runs just fine - at least it did for me on XP 32-bit with SP3.
jplorge
by jplorge » Thu Apr 15, 2010 11:24 pm
I tried 5 times to see if it is stable in motion, each time with a starting at "reference point 0,0", here is the xml
<?xml version="1.0" encoding="utf-8"?>
<papywizard version="c">
    <header>
        <general>
            <title>
                Entrer le titre ici
            </title>
            <gps>
                Entrer les coordonnées ici
            </gps>
            <comment>
                Généré par Papywizard 2.1.18
            </comment>
        </general>
        <shooting mode="mosaic">
            <headOrientation>
                up
            </headOrientation>
            <cameraOrientation>
                portrait
            </cameraOrientation>
            <stabilizationDelay>
                0.5
            </stabilizationDelay>
            <counter>
                005
            </counter>
            <startTime>
                2010-04-16_00h19m10s
            </startTime>
            <endTime>
                2010-04-16_00h20m27s
            </endTime>
        </shooting>
        <camera>
            <timeValue>
                6.0
            </timeValue>
            <bracketing nbPicts="1"/>
            <sensor coef="1.5" ratio="3:2"/>
        </camera>
        <lens type="rectilinear">
            <focal>
                24.0
            </focal>
        </lens>
        <mosaic>
            <nbPicts pitch="2" yaw="3"/>
            <overlap minimum="0.25" pitch="0.25" yaw="0.25"/>
        </mosaic>
    </header>
    <shoot>
        <pict bracket="1" id="1">
            <time>
                2010-04-16_00h19m22s
            </time>
            <position pitch="20.0" roll="90.0" yaw="-29.7"/>
        </pict>
        <pict bracket="1" id="2">
            <time>
                2010-04-16_00h19m35s
            </time>
            <position pitch="20.0" roll="90.0" yaw="2.8"/>
        </pict>
        <pict bracket="1" id="3">
            <time>
                2010-04-16_00h19m46s
            </time>
            <position pitch="20.0" roll="90.0" yaw="30.5"/>
        </pict>
        <pict bracket="1" id="4">
            <time>
                2010-04-16_00h20m00s
            </time>
            <position pitch="-20.9" roll="90.0" yaw="27.6"/>
        </pict>
        <pict bracket="1" id="5">
            <time>
                2010-04-16_00h20m14s
            </time>
            <position pitch="-19.9" roll="90.0" yaw="-0.0"/>
        </pict>
        <pict bracket="1" id="6">
            <time>
            </time>
            <position pitch="-19.9" roll="90.0" yaw="-27.7"/>
        </pict>
    </shoot>
</papywizard>
Jean-Pierre
jplorge
by jplorge » Thu Apr 15, 2010 11:45 pm
on linux with Papywizard 2.1.16, i have the same time...
<papywizard version="b">
<header>
<general>
<title>
Entrer le titre ici
</title>
<gps>
</gps>
<comment>
Généré par Papywizard 2.1.16
</comment>
</general>
<headOrientation>
up
</headOrientation>
<cameraOrientation>
portrait
0.5
<startTime>
2010-04-16_00h40m40s
</startTime>
<endTime>
2010-04-16_00h41m58s
</endTime>
</shooting>
<camera>
<timeValue>
6.0
</timeValue>
</camera>
Here is print screen on linux ubuntu 9.10
Jean-Pierre
Gordon
by Gordon » Fri Apr 16, 2010 12:25 am
Nokia N800 works fine so far no extensive testing completed yet, numerical shot marker works fine.
Thanks fma38 for including this so quickly.
Best
Gordon
2000th Member :D
Tipjip
by Tipjip » Fri Apr 16, 2010 12:22 pm
In 2.1.18 under Windows 7 32bits I can't open the "about"-dialogue. When I try nothing happens. So, technically, I'm not sure it really is the 2.1.18 I'm trying it with because I installed it over an older version. :o
Anyone else who can verify this?
Christian
PreviousNext
