[papywizard v2] Annoncement, feedback, bug report
claudevh
by claudevh » Fri Mar 19, 2010 12:52 am
:) Thats the correct one ...! ;)
:cool: Claude :cool:
by klausesser » Fri Mar 19, 2010 1:21 am
btw., Frédéric: can i have 1.6.1 and the actual version both on my N800?
best to you, Klaus
by fma38 » Fri Mar 19, 2010 7:57 am
Yes, Klaus, no problem.
About the speed, I have to check, but I'm pretty sure I had it working with 200mm focal lens... Could you post the log for a 2 pictures pano? Activate the 'trace' log level...
bvogl
by bvogl » Fri Mar 19, 2010 8:23 am
Argh! - I think it is time to go crazy!
I changed settings to create the log, started the panorama and the head moved faster! Exept changing the log level to debug, i did nothing what i haven't done yesterday and all the days before!
I create a log for the developer and the d*** thing speeds up.... :-)
I'll try to track down the cause of this behavior in the evening (there is a chance that it has to do with the BT connection). Meanwhile for reference only, here is the trace log:
2010-03-20 08:03:24,571::Main::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2010-03-20 08:03:24,571::Main::INFO::Starting connection. Please wait...
2010-03-20 08:03:24,664::Main::DEBUG::PluginsConnector.start(): 'yawAxis' establish connection
2010-03-20 08:03:24,664::Main::TRACE::AbstractHardwarePlugin.establishConnection()
2010-03-20 08:03:24,680::Main::TRACE::AbstractDriver.establishConnection()
2010-03-20 08:03:24,680::Main::TRACE::BluetoothDriver._init()
2010-03-20 08:03:24,680::Main::DEBUG::BluetoothDriver._init(): trying to connect to 00:0A:84:01:C6:77...
2010-03-20 08:03:34,601::Main::DEBUG::BluetoothDriver._init(): successfully connected to 00:0A:84:01:C6:77
2010-03-20 08:03:34,601::Main::TRACE::AbstractPlugin.establishConnection()
2010-03-20 08:03:34,601::Main::DEBUG::PluginsConnector.start(): 'yawAxis' init
2010-03-20 08:03:34,601::Main::TRACE::MerlinOrionAxis.init()
2010-03-20 08:03:34,601::Main::TRACE::AbstractHardwarePlugin.init()
2010-03-20 08:03:34,726::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020681
2010-03-20 08:03:34,757::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2010-03-20 08:03:34,805::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2010-03-20 08:03:34,805::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' establish connection
2010-03-20 08:03:34,805::Main::TRACE::AbstractHardwarePlugin.establishConnection()
2010-03-20 08:03:34,805::Main::TRACE::AbstractDriver.establishConnection()
2010-03-20 08:03:34,805::Main::TRACE::AbstractPlugin.establishConnection()
2010-03-20 08:03:34,805::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' init
2010-03-20 08:03:34,821::Main::TRACE::MerlinOrionAxis.init()
2010-03-20 08:03:34,821::Main::TRACE::AbstractHardwarePlugin.init()
2010-03-20 08:03:34,930::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020681
2010-03-20 08:03:34,976::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2010-03-20 08:03:35,007::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2010-03-20 08:03:35,007::Main::DEBUG::PluginsConnector.start(): 'shutter' establish connection
2010-03-20 08:03:35,023::Main::TRACE::AbstractHardwarePlugin.establishConnection()
2010-03-20 08:03:35,023::Main::TRACE::AbstractDriver.establishConnection()
2010-03-20 08:03:35,023::Main::TRACE::AbstractPlugin.establishConnection()
2010-03-20 08:03:35,023::Main::DEBUG::PluginsConnector.start(): 'shutter' init
2010-03-20 08:03:35,023::Main::TRACE::MerlinOrionShutter.init()
2010-03-20 08:03:35,023::Main::TRACE::AbstractHardwarePlugin.init()
2010-03-20 08:03:35,132::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020681
2010-03-20 08:03:35,178::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2010-03-20 08:03:35,226::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2010-03-20 08:03:35,242::Main::INFO::Connection started
2010-03-20 08:03:35,428::Spy::INFO::Spy resumed
2010-03-20 08:03:36,832::Main::TRACE::MainController.__onShootPushButtonClicked()
2010-03-20 08:03:37,426::Main::TRACE::ShootingView.resizeEvent()
2010-03-20 08:03:39,437::Main::TRACE::ShootController.__startPushButtonClicked()
2010-03-20 08:03:39,437::Shooting::TRACE::Shooting.start()
2010-03-20 08:03:39,437::Main::TRACE::ShootController.__onShootingStarted()
2010-03-20 08:03:39,469::Main::TRACE::ShootController.__onShootingProgress()
2010-03-20 08:03:39,469::Shooting::INFO::Start shooting process...
2010-03-20 08:03:39,484::Shooting::DEBUG::Shooting.start(): create mosaic data object
2010-03-20 08:03:39,484::Shooting::DEBUG::Data.__init__(): create xml tree
2010-03-20 08:03:39,516::Shooting::DEBUG::Data.createHeader(): values={'comment': u'Generated by Papywizard 2.1.16', 'cameraOrientation': u'portrait', 'yawNbPicts': '2', 'pitchNbPicts': '1', 'title': u'Here goes the title', 'bracketingNbPicts': '1', 'timeValue': '1.0', 'stabilizationDelay': '0.0', 'overlap': '0.30', 'headOrientation': 'up', 'lensType': u'rectilinear', 'yawRealOverlap': '0.30', 'pitchRealOverlap': '1.00', 'sensorCoef': '1.0', 'sensorRatio': u'3:2', 'roll': '90.0', 'focal': '400.0', 'gps': u'Here goes the location'}
2010-03-20 08:03:39,516::Shooting::DEBUG::Data._addNode(): parent=header, tag=general, value=None, attr={}
2010-03-20 08:03:39,516::Shooting::DEBUG::Data._addNode(): parent=general, tag=title, value=Here goes the title, attr={}
2010-03-20 08:03:39,516::Shooting::DEBUG::Data._addNode(): parent=general, tag=gps, value=Here goes the location, attr={}
2010-03-20 08:03:39,516::Shooting::DEBUG::Data._addNode(): parent=general, tag=comment, value=Generated by Papywizard 2.1.16, attr={}
2010-03-20 08:03:39,516::Shooting::DEBUG::Data._addNode(): parent=header, tag=shooting, value=None, attr={'mode': 'mosaic'}
2010-03-20 08:03:39,516::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=headOrientation, value=up, attr={}
2010-03-20 08:03:39,532::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=cameraOrientation, value=portrait, attr={}
2010-03-20 08:03:39,532::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=stabilizationDelay, value=0.0, attr={}
2010-03-20 08:03:39,532::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=startTime, value=2010-03-20_08h03m39s, attr={}
2010-03-20 08:03:39,532::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=endTime, value=2010-03-20_08h03m39s, attr={}
2010-03-20 08:03:39,532::Shooting::DEBUG::Data._addNode(): parent=header, tag=camera, value=None, attr={}
2010-03-20 08:03:39,532::Shooting::DEBUG::Data._addNode(): parent=camera, tag=timeValue, value=1.0, attr={}
2010-03-20 08:03:39,532::Shooting::DEBUG::Data._addNode(): parent=camera, tag=bracketing, value=None, attr={'nbPicts': '1'}
2010-03-20 08:03:39,546::Shooting::DEBUG::Data._addNode(): parent=camera, tag=sensor, value=None, attr={'ratio': u'3:2', 'coef': '1.0'}
2010-03-20 08:03:39,546::Shooting::DEBUG::Data._addNode(): parent=header, tag=lens, value=None, attr={'type': u'rectilinear'}
2010-03-20 08:03:39,546::Shooting::DEBUG::Data._addNode(): parent=lens, tag=focal, value=400.0, attr={}
2010-03-20 08:03:39,546::Shooting::DEBUG::Data._addNode(): parent=header, tag=mosaic, value=None, attr={}
2010-03-20 08:03:39,546::Shooting::DEBUG::Data._addNode(): parent=mosaic, tag=nbPicts, value=None, attr={'yaw': '2', 'pitch': '1'}
2010-03-20 08:03:39,546::Shooting::DEBUG::Data._addNode(): parent=mosaic, tag=overlap, value=None, attr={'yaw': '0.30', 'minimum': '0.30', 'pitch': '1.00'}
2010-03-20 08:03:39,546::Shooting::TRACE::Data.serialize()
2010-03-20 08:03:39,562::Shooting::DEBUG::Shooting.start(): repeat 1/1
2010-03-20 08:03:39,562::Main::TRACE::ShootController.__onShootingRepeat()
2010-03-20 08:03:39,578::Main::TRACE::ShootController.__onShootingProgress()
2010-03-20 08:03:39,578::Shooting::DEBUG::Shooting.start(): pict #1 of 2, index=(1, 1, 1), yaw=-1.2, pitch=0.0
2010-03-20 08:03:39,578::Main::DEBUG::ShootController.__onShootingUpdate(): index=(1, 1, 1), yaw=-1.2, pitch=0.0, state=None, next=True
2010-03-20 08:03:39,625::Shooting::INFO::Moving
2010-03-20 08:03:39,625::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2010-03-20 08:03:39,625::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -1.2
2010-03-20 08:03:39,703::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to 0.0
2010-03-20 08:03:40,000::Merlin-Orion_yawAxis::TRACE::MerlinOrionAxis._alternateDrive()
2010-03-20 08:03:40,030::Merlin-Orion_yawAxis::DEBUG::MerlinOrionAxis._alternateDrive(): alternate speed move
2010-03-20 08:03:41,232::Merlin-Orion_yawAxis::DEBUG::MerlinOrionAxis._alternateDrive(): final move
2010-03-20 08:03:44,539::Shooting::INFO::Mirror lockup
2010-03-20 08:03:44,539::Main::DEBUG::ShootController.__onShootingSequence(): sequence=mirror
2010-03-20 08:03:44,539::Shooting::TRACE::AbstractStandardShutterPlugin.lockupMirror()
2010-03-20 08:03:44,555::Shooting::TRACE::AbstractStandardShutterPlugin._ensurePulseWidthLowDelay()
2010-03-20 08:03:44,555::Shooting::TRACE::AbstractStandardShutterPlugin._triggerShutter()
2010-03-20 08:03:44,851::Shooting::INFO::Stabilization
2010-03-20 08:03:44,851::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2010-03-20 08:03:44,851::Shooting::INFO::Shutter cycle
2010-03-20 08:03:44,867::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2010-03-20 08:03:44,867::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2010-03-20 08:03:44,867::Shooting::TRACE::AbstractStandardShutterPlugin.shoot()
2010-03-20 08:03:44,867::Shooting::TRACE::AbstractStandardShutterPlugin._ensurePulseWidthLowDelay()
2010-03-20 08:03:45,053::Shooting::TRACE::AbstractStandardShutterPlugin._triggerShutter()
2010-03-20 08:03:46,411::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-1.2, pitch=0.0, roll=90.0
2010-03-20 08:03:46,411::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '1'}
2010-03-20 08:03:46,411::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2010-03-20_08h03m46s, attr={}
2010-03-20 08:03:46,411::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-1.2', 'roll': '90.0', 'pitch': '0.0'}
2010-03-20 08:03:46,411::Shooting::TRACE::Data.serialize()
2010-03-20 08:03:46,443::Main::TRACE::ShootController.__onShootingProgress()
2010-03-20 08:03:46,457::Main::DEBUG::ShootController.__onShootingUpdate(): index=(1, 1, 1), yaw=-1.2, pitch=0.0, state=ok, next=None
2010-03-20 08:03:46,473::Shooting::DEBUG::Shooting.start(): position index=(2, 2, 1), yaw=1.2, pitch=0.0
2010-03-20 08:03:46,489::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=1.2, pitch=0.0, state=None, next=True
2010-03-20 08:03:46,536::Shooting::DEBUG::Shooting.start(): pict #2 of 2, index=(2, 2, 1), yaw=1.2, pitch=0.0
2010-03-20 08:03:46,536::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=1.2, pitch=0.0, state=None, next=True
2010-03-20 08:03:46,566::Shooting::INFO::Moving
2010-03-20 08:03:46,582::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2010-03-20 08:03:46,582::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 1.2
2010-03-20 08:03:46,677::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to 0.0
2010-03-20 08:03:46,926::Merlin-Orion_yawAxis::TRACE::MerlinOrionAxis._alternateDrive()
2010-03-20 08:03:47,003::Merlin-Orion_yawAxis::DEBUG::MerlinOrionAxis._alternateDrive(): alternate speed move
2010-03-20 08:03:48,798::Merlin-Orion_yawAxis::DEBUG::MerlinOrionAxis._alternateDrive(): final move
2010-03-20 08:03:51,887::Shooting::INFO::Mirror lockup
2010-03-20 08:03:51,887::Main::DEBUG::ShootController.__onShootingSequence(): sequence=mirror
2010-03-20 08:03:51,887::Shooting::TRACE::AbstractStandardShutterPlugin.lockupMirror()
2010-03-20 08:03:51,887::Shooting::TRACE::AbstractStandardShutterPlugin._ensurePulseWidthLowDelay()
2010-03-20 08:03:51,887::Shooting::TRACE::AbstractStandardShutterPlugin._triggerShutter()
2010-03-20 08:03:52,167::Shooting::INFO::Stabilization
2010-03-20 08:03:52,167::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2010-03-20 08:03:52,167::Shooting::INFO::Shutter cycle
2010-03-20 08:03:52,183::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2010-03-20 08:03:52,183::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2010-03-20 08:03:52,183::Shooting::TRACE::AbstractStandardShutterPlugin.shoot()
2010-03-20 08:03:52,183::Shooting::TRACE::AbstractStandardShutterPlugin._ensurePulseWidthLowDelay()
2010-03-20 08:03:52,371::Shooting::TRACE::AbstractStandardShutterPlugin._triggerShutter()
2010-03-20 08:03:53,634::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=1.2, pitch=0.0, roll=90.0
2010-03-20 08:03:53,634::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '2'}
2010-03-20 08:03:53,650::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2010-03-20_08h03m53s, attr={}
2010-03-20 08:03:53,650::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '1.2', 'roll': '90.0', 'pitch': '0.0'}
2010-03-20 08:03:53,650::Shooting::TRACE::Data.serialize()
2010-03-20 08:03:53,697::Main::TRACE::ShootController.__onShootingProgress()
2010-03-20 08:03:53,711::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=1.2, pitch=0.0, state=ok, next=None
2010-03-20 08:03:53,759::Main::DEBUG::ShootController.__onShootingUpdate(): index=(3, 2, 1), yaw=1.2, pitch=0.0, state=None, next=True
2010-03-20 08:03:53,775::Shooting::INFO::Shoot process finished
2010-03-20 08:03:53,789::Main::DEBUG::ShootController.__onShootingStopped(): status=ok
2010-03-20 08:04:02,884::Main::TRACE::ShootController.__onStopFinishPushButtonClicked()
2010-03-20 08:04:04,835::Main::TRACE::AbstractModalDialogController._onRejected()
by fma38 » Fri Mar 19, 2010 8:27 am
:) Let me know if it happens again (and post the log)...
bvogl
by bvogl » Sat Mar 20, 2010 12:56 am
Hello Frederic
As far as i can tell now, the "slow moving head problem" is computer dependent.
Here is the log from another computer where the situation re-appeared:
2010-03-20 00:34:57,015::Main::TRACE::AbstractModalDialogController._onRejected()
2010-03-20 00:35:11,390::Main::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2010-03-20 00:35:11,405::Main::INFO::Starting connection. Please wait...
2010-03-20 00:35:11,421::Main::DEBUG::PluginsConnector.start(): 'yawAxis' establish connection
2010-03-20 00:35:11,421::Main::TRACE::AbstractHardwarePlugin.establishConnection()
2010-03-20 00:35:11,421::Main::TRACE::AbstractDriver.establishConnection()
2010-03-20 00:35:11,421::Main::TRACE::BluetoothDriver._init()
2010-03-20 00:35:11,421::Main::DEBUG::BluetoothDriver._init(): trying to connect to 00:0a:84:01:c6:77...
2010-03-20 00:35:21,780::Main::DEBUG::BluetoothDriver._init(): successfully connected to 00:0a:84:01:c6:77
2010-03-20 00:35:21,780::Main::TRACE::AbstractPlugin.establishConnection()
2010-03-20 00:35:21,780::Main::DEBUG::PluginsConnector.start(): 'yawAxis' init
2010-03-20 00:35:21,780::Main::TRACE::MerlinOrionAxis.init()
2010-03-20 00:35:21,780::Main::TRACE::AbstractHardwarePlugin.init()
2010-03-20 00:35:21,921::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020681
2010-03-20 00:35:21,983::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2010-03-20 00:35:22,046::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2010-03-20 00:35:22,046::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' establish connection
2010-03-20 00:35:22,046::Main::TRACE::AbstractHardwarePlugin.establishConnection()
2010-03-20 00:35:22,046::Main::TRACE::AbstractDriver.establishConnection()
2010-03-20 00:35:22,046::Main::TRACE::AbstractPlugin.establishConnection()
2010-03-20 00:35:22,046::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' init
2010-03-20 00:35:22,046::Main::TRACE::MerlinOrionAxis.init()
2010-03-20 00:35:22,046::Main::TRACE::AbstractHardwarePlugin.init()
2010-03-20 00:35:22,187::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020681
2010-03-20 00:35:22,250::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2010-03-20 00:35:22,296::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2010-03-20 00:35:22,296::Main::DEBUG::PluginsConnector.start(): 'shutter' establish connection
2010-03-20 00:35:22,296::Main::TRACE::AbstractHardwarePlugin.establishConnection()
2010-03-20 00:35:22,296::Main::TRACE::AbstractDriver.establishConnection()
2010-03-20 00:35:22,296::Main::TRACE::AbstractPlugin.establishConnection()
2010-03-20 00:35:22,296::Main::DEBUG::PluginsConnector.start(): 'shutter' init
2010-03-20 00:35:22,296::Main::TRACE::MerlinOrionShutter.init()
2010-03-20 00:35:22,296::Main::TRACE::AbstractHardwarePlugin.init()
2010-03-20 00:35:22,453::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020681
2010-03-20 00:35:22,500::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2010-03-20 00:35:22,546::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2010-03-20 00:35:22,546::Main::INFO::Connection started
2010-03-20 00:35:22,717::Spy::INFO::Spy resumed
2010-03-20 00:35:25,671::Main::TRACE::MainController.__onShootPushButtonClicked()
2010-03-20 00:35:25,875::Main::TRACE::ShootingView.resizeEvent()
2010-03-20 00:35:29,405::Main::TRACE::ShootController.__startPushButtonClicked()
2010-03-20 00:35:29,405::Shooting::TRACE::Shooting.start()
2010-03-20 00:35:29,405::Main::TRACE::ShootController.__onShootingStarted()
2010-03-20 00:35:29,405::Main::TRACE::ShootController.__onShootingProgress()
2010-03-20 00:35:29,405::Shooting::INFO::Start shooting process...
2010-03-20 00:35:29,405::Shooting::DEBUG::Shooting.start(): create mosaic data object
2010-03-20 00:35:29,405::Shooting::DEBUG::Data.__init__(): create xml tree
2010-03-20 00:35:29,421::Shooting::DEBUG::Data.createHeader(): values={'comment': u'Generated by Papywizard 2.1.16', 'cameraOrientation': u'portrait', 'yawNbPicts': '2', 'pitchNbPicts': '1', 'title': u'Here goes the title', 'bracketingNbPicts': '1', 'timeValue': '0.5', 'stabilizationDelay': '0.0', 'overlap': '0.30', 'headOrientation': 'up', 'lensType': u'rectilinear', 'yawRealOverlap': '0.30', 'pitchRealOverlap': '1.00', 'sensorCoef': '1.0', 'sensorRatio': u'3:2', 'roll': '90.0', 'focal': '400.0', 'gps': u'Here goes the location'}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=header, tag=general, value=None, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=general, tag=title, value=Here goes the title, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=general, tag=gps, value=Here goes the location, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=general, tag=comment, value=Generated by Papywizard 2.1.16, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=header, tag=shooting, value=None, attr={'mode': 'mosaic'}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=headOrientation, value=up, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=cameraOrientation, value=portrait, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=stabilizationDelay, value=0.0, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=startTime, value=2010-03-20_00h35m29s, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=shooting, tag=endTime, value=2010-03-20_00h35m29s, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=header, tag=camera, value=None, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=camera, tag=timeValue, value=0.5, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=camera, tag=bracketing, value=None, attr={'nbPicts': '1'}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=camera, tag=sensor, value=None, attr={'ratio': u'3:2', 'coef': '1.0'}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=header, tag=lens, value=None, attr={'type': u'rectilinear'}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=lens, tag=focal, value=400.0, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=header, tag=mosaic, value=None, attr={}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=mosaic, tag=nbPicts, value=None, attr={'yaw': '2', 'pitch': '1'}
2010-03-20 00:35:29,421::Shooting::DEBUG::Data._addNode(): parent=mosaic, tag=overlap, value=None, attr={'yaw': '0.30', 'minimum': '0.30', 'pitch': '1.00'}
2010-03-20 00:35:29,421::Shooting::TRACE::Data.serialize()
2010-03-20 00:35:29,437::Shooting::DEBUG::Shooting.start(): repeat 1/1
2010-03-20 00:35:29,437::Main::TRACE::ShootController.__onShootingRepeat()
2010-03-20 00:35:29,437::Main::TRACE::ShootController.__onShootingProgress()
2010-03-20 00:35:29,437::Shooting::DEBUG::Shooting.start(): pict #1 of 2, index=(1, 1, 1), yaw=-1.2, pitch=0.0
2010-03-20 00:35:29,437::Main::DEBUG::ShootController.__onShootingUpdate(): index=(1, 1, 1), yaw=-1.2, pitch=0.0, state=None, next=True
2010-03-20 00:35:29,453::Shooting::INFO::Moving
2010-03-20 00:35:29,453::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2010-03-20 00:35:29,453::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to -1.2
2010-03-20 00:35:29,530::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to 0.0
2010-03-20 00:35:29,703::Merlin-Orion_yawAxis::TRACE::MerlinOrionAxis._directDrive()
2010-03-20 00:35:36,108::Shooting::INFO::Stabilization
2010-03-20 00:35:36,108::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2010-03-20 00:35:36,108::Shooting::INFO::Shutter cycle
2010-03-20 00:35:36,108::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2010-03-20 00:35:36,108::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2010-03-20 00:35:36,108::Shooting::TRACE::AbstractStandardShutterPlugin.shoot()
2010-03-20 00:35:36,108::Shooting::TRACE::AbstractStandardShutterPlugin._ensurePulseWidthLowDelay()
2010-03-20 00:35:36,108::Shooting::TRACE::AbstractStandardShutterPlugin._triggerShutter()
2010-03-20 00:35:36,890::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=-1.2, pitch=0.0, roll=90.0
2010-03-20 00:35:36,890::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '1'}
2010-03-20 00:35:36,890::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2010-03-20_00h35m36s, attr={}
2010-03-20 00:35:36,890::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '-1.2', 'roll': '90.0', 'pitch': '0.0'}
2010-03-20 00:35:36,905::Shooting::TRACE::Data.serialize()
2010-03-20 00:35:36,905::Main::TRACE::ShootController.__onShootingProgress()
2010-03-20 00:35:36,905::Main::DEBUG::ShootController.__onShootingUpdate(): index=(1, 1, 1), yaw=-1.2, pitch=0.0, state=ok, next=None
2010-03-20 00:35:36,921::Shooting::DEBUG::Shooting.start(): position index=(2, 2, 1), yaw=1.2, pitch=0.0
2010-03-20 00:35:36,921::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=1.2, pitch=0.0, state=None, next=True
2010-03-20 00:35:36,937::Shooting::DEBUG::Shooting.start(): pict #2 of 2, index=(2, 2, 1), yaw=1.2, pitch=0.0
2010-03-20 00:35:36,937::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=1.2, pitch=0.0, state=None, next=True
2010-03-20 00:35:36,937::Shooting::INFO::Moving
2010-03-20 00:35:36,953::Main::DEBUG::ShootController.__onShootingSequence(): sequence=moving
2010-03-20 00:35:36,953::Shooting::DEBUG::MerlinOrionAxis.drive(): 'yawAxis' drive to 1.2
2010-03-20 00:35:37,000::Shooting::DEBUG::MerlinOrionAxis.drive(): 'pitchAxis' drive to 0.0
2010-03-20 00:35:37,250::Merlin-Orion_yawAxis::TRACE::MerlinOrionAxis._directDrive()
2010-03-20 00:35:46,937::Shooting::INFO::Stabilization
2010-03-20 00:35:46,937::Main::DEBUG::ShootController.__onShootingSequence(): sequence=stabilization
2010-03-20 00:35:46,937::Shooting::INFO::Shutter cycle
2010-03-20 00:35:46,937::Shooting::DEBUG::Shooting.start(): bracket #1 of 1
2010-03-20 00:35:46,937::Main::DEBUG::ShootController.__onShootingSequence(): sequence=shutter
2010-03-20 00:35:46,937::Shooting::TRACE::AbstractStandardShutterPlugin.shoot()
2010-03-20 00:35:46,937::Shooting::TRACE::AbstractStandardShutterPlugin._ensurePulseWidthLowDelay()
2010-03-20 00:35:46,937::Shooting::TRACE::AbstractStandardShutterPlugin._triggerShutter()
2010-03-20 00:35:47,750::Shooting::DEBUG::Data.addPicture(): bracket=1, yaw=1.2, pitch=0.0, roll=90.0
2010-03-20 00:35:47,750::Shooting::DEBUG::Data._addNode(): parent=shoot, tag=pict, value=None, attr={'bracket': '1', 'id': '2'}
2010-03-20 00:35:47,750::Shooting::DEBUG::Data._addNode(): parent=pict, tag=time, value=2010-03-20_00h35m47s, attr={}
2010-03-20 00:35:47,750::Shooting::DEBUG::Data._addNode(): parent=pict, tag=position, value=None, attr={'yaw': '1.2', 'roll': '90.0', 'pitch': '0.0'}
2010-03-20 00:35:47,750::Shooting::TRACE::Data.serialize()
2010-03-20 00:35:47,765::Main::TRACE::ShootController.__onShootingProgress()
2010-03-20 00:35:47,765::Main::DEBUG::ShootController.__onShootingUpdate(): index=(2, 2, 1), yaw=1.2, pitch=0.0, state=ok, next=None
2010-03-20 00:35:47,780::Main::DEBUG::ShootController.__onShootingUpdate(): index=(3, 2, 1), yaw=1.2, pitch=0.0, state=None, next=True
2010-03-20 00:35:47,780::Shooting::INFO::Shoot process finished
2010-03-20 00:35:47,780::Main::DEBUG::ShootController.__onShootingStopped(): status=ok
2010-03-20 00:35:50,483::Main::TRACE::ShootController.__onStopFinishPushButtonClicked()
2010-03-20 00:35:52,171::Main::TRACE::AbstractModalDialogController._onRejected()
2010-03-20 00:35:55,875::Main::TRACE::MainController.__onActionHelpViewLogActivated()
2010-03-20 00:37:30,500::Main::TRACE::AbstractController._onCloseEvent()
2010-03-20 00:37:32,953::Main::DEBUG::MainController.__onActionHardwareConnectToggled(False)
2010-03-20 00:37:32,953::Main::INFO::Stopping connection. Please wait...
2010-03-20 00:37:32,967::Main::DEBUG::PluginsConnector.start(): 'yawAxis' shutdown
2010-03-20 00:37:32,967::Main::TRACE::MerlinOrionAxis.shutdown()
2010-03-20 00:37:33,125::Spy::INFO::Spy suspended
2010-03-20 00:37:33,328::Main::DEBUG::PluginsConnector.start(): 'yawAxis' stop connection
2010-03-20 00:37:33,328::Main::TRACE::AbstractHardwarePlugin.stopConnection()
2010-03-20 00:37:33,328::Main::TRACE::AbstractDriver.shutdownConnection()
2010-03-20 00:37:33,328::Main::TRACE::AbstractPlugin.stopConnection()
2010-03-20 00:37:33,328::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' shutdown
2010-03-20 00:37:33,328::Main::TRACE::MerlinOrionAxis.shutdown()
2010-03-20 00:37:33,655::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' stop connection
2010-03-20 00:37:33,655::Main::TRACE::AbstractHardwarePlugin.stopConnection()
2010-03-20 00:37:33,655::Main::TRACE::AbstractDriver.shutdownConnection()
2010-03-20 00:37:33,655::Main::TRACE::AbstractPlugin.stopConnection()
2010-03-20 00:37:33,655::Main::DEBUG::PluginsConnector.start(): 'shutter' shutdown
2010-03-20 00:37:33,655::Main::TRACE::MerlinOrionShutter.shutdown()
2010-03-20 00:37:33,703::Main::DEBUG::PluginsConnector.start(): 'shutter' stop connection
2010-03-20 00:37:33,703::Main::TRACE::AbstractHardwarePlugin.stopConnection()
2010-03-20 00:37:33,703::Main::TRACE::AbstractDriver.shutdownConnection()
2010-03-20 00:37:33,703::Main::TRACE::AbstractPlugin.stopConnection()
2010-03-20 00:37:33,703::Main::INFO::Connection stopped
2010-03-20 00:37:37,250::Main::TRACE::MainController.__onActionHelpViewLogActivated()
by fma38 » Sat Mar 20, 2010 8:57 am
There is nothing unusual in the logs. I will need to send you a version with additionnal logs. What plateform?
Paul
by Paul » Sat Mar 20, 2010 9:57 am
bvogl wrote:As far as i can tell now, the "slow moving head problem" is computer dependent.
that means you use different BT-Modules on the different computers?
may be the problems is on this side ...
Paul
claudevh
by claudevh » Sat Mar 20, 2010 10:37 am
Bernhard,
You have a Samsung N220 Netbook with Windows 7, could you please (via the control panel) tell us :
- The Brand name and type of your internal BT module ?
- The Bluetooth stack used by the computer ?
bvogl
by bvogl » Sat Mar 20, 2010 11:38 am
Yes, these are different BT devices on different computers.
All computers communicate via default Microsoft stack.
- The Samsung Netbook uses an internal "Broadcom BCM2070 2.1+EDR USB Device"
- The other machine which still has problems uses an internal "Broadcom BT 2.0 EDR USB Device" with Windows XP.
- I have also tried on a 3rd machine using a pluggable USB dongle ("Generic Bluetooth Adapter") running Windows 7 and it worked on the first attempt.
All i can say at the moment is, that the first 2 machines that have/had problems are portable devices, so maybe some power saving policies may interfere with the BT connection.
by fma38 » Sat Mar 20, 2010 11:44 am
Does it work fine when you use higher steps (shorter focal)? If it is a communication problem, you should get the same issue...
claudevh
by claudevh » Sat Mar 20, 2010 12:04 pm
Hello Bernhard,
My experience ...
"Normally" original Microsoft or Broadcom give no problems ....
"Normally" Broadcom hardware are not giving problems ....
The Bt problems are generally coming with"exotic" BT stacks like Toshiba and also Toshiba BT devices, this is the case with most of the MAC computers and Eee PC's where i advise allways to use a "standard uiversal BT dongle" ... this solve 99 % of the BT problems ... this was the situation till the recent commercialisation of machines based on the "Pine Trail platform" like your Samsung N220 serie!
Those Pine Trail platforms are specially designed for "extra low electric consumption"...
So I am affraid that your analyse of "power saving management" is correct ...
May-be, that it will be possible to fine tune this management and that the usage of external Bt dongles will escape to this power saving management ...
Conclusion, till beter advise , plugging a BT dongle in your laptop is probably the best solution ...
Stupid isn't ???
In french we said "LE MIEUX EST L' ENNEMI DU BIEN ..." ;)
bvogl
by bvogl » Sat Mar 20, 2010 12:26 pm
"Normally" i try to avoid BT connections whenever possible ;-)
I think i'm now on the right path of finding the root cause of the problem: The farther away the head from the sending device, the more problems i get. Also true if the head itself occludes the direct connection.
I didn't replay all combinations now as i want to go out shooting photos ;-) - however, above makes sense as power management will decrease transmission power and reduce communication quality. I'll try later by disabling power management for the BT device and see if this makes the problem more reproduceable.
by klausesser » Sat Mar 20, 2010 1:55 pm
bvogl wrote:The farther away the head from the sending device, the more problems i get. Also true if the head itself occludes the direct connection.
I had the Nokia N800 and the Merlin with an Aircable dongle running at about 10m - direct sight - distance without any problem. Above this distance it becomes less reliable.
I didn´t try an USB cable of that length yet . . . . :cool:
At another time a taped the Nokia to the tripod and started the sequence - then i had some currywursts around the corner . . . . :lol:
best to you, Klaus
bvogl
by bvogl » Sat Mar 20, 2010 7:56 pm
I see, i see - i missed the step with the currywurst in my workflow. That's the reason ;-)
Stop laughing and think about it: BT - like WiFi - uses a high frequency wave band around 2,5 Ghz which is roughly the same frequency as a microwave oven uses. This frequency is easily absorbed by water - the most frequent element in the human body. So if you go around the corner and eat a sausage, you're helping your controlling device to have a more stable connection to the head.
Best
Bernhard
Paul
by Paul » Sat Mar 20, 2010 8:05 pm
bvogl wrote:a more stable connection to the head.
so today, when i shot a pano someone in the near must have put his currywurst into the microwave ...
the head went crazy and turned around the horizontal axis :cool:
Paul
bvogl
by bvogl » Sat Mar 20, 2010 8:13 pm
Paul wrote:the head went crazy and turned around the horizontal axis :cool:
I think this is intended behavior - as long as the shutter triggers every now and then ;-)
To make the discussion more serious, i have a request for the PC/Mac version:
It would be fine to be able to manually move the head with the standard cursor keys. It is a little tedious to watch the image section and tap the buttons.
Also, i would appreciate an audible signal if the panorama is finished.
Best
Bernhard
by mediavets » Sat Mar 20, 2010 8:30 pm
bvogl wrote:To make the discussion more serious, i have a request for the PC/Mac version:
You can - at least it works as you describe on my Windows XP PC using the cursor keys on the numeric pad.
That's a nice idea.
bvogl
by bvogl » Sat Mar 20, 2010 8:45 pm
mediavets wrote:You can - at least it works as you describe on my Windows XP PC using the cursor keys on the numeric pad.
Thanks for the hint! But doesn't work with the lates beta on my computer(s). :-(
Also, it would be useful to activate the standard cursor keys as numeric keybads are not very common on mobile computers :-)
by fma38 » Sat Mar 20, 2010 10:01 pm
It used to works with the cursor keys, but I remove this feature: I never find a nice way to bind the keys, and the way I did it was messing up other applications (focus problem, if I remember correctly). I agree it was nice to move the head this way, but...
by mediavets » Sat Mar 20, 2010 11:03 pm
Ooops - it seems I wasn't looking at the latest version.
It was working with 2.1.10 if you fancy going back to that version.
by fma38 » Sat Apr 03, 2010 9:45 am
I uploaded a new release (2.1.17).
Main new features are:
- Pitch arm side param
- Bulb mode in shutter plugins
- 'Gphoto Bracket' plugin (jeongyun patch)
See ChangeLog for complete changes.
I won't be availabe this week-end; but feel free to report bugs here.
by mediavets » Sat Apr 03, 2010 8:31 pm
fma38 wrote:I uploaded a new release (2.1.17).
Thank you.
If checked this means that shutter switch contact is closed for entire duration of Time value - as was the case in much earlier versions of Papywizard - is that correct?
Pulse width high max. duration remains 1000ms. Do you have plans to increase this limit?
by fma38 » Mon Apr 05, 2010 5:10 pm
mediavets wrote:
fma38 wrote:- Pitch arm side param
Thank you.
:) Does it works fine? I didn't test it very much...
Yes.
Why do you need longer pulse width? What value would you like?
by mediavets » Tue Apr 06, 2010 7:56 pm
Windows 2000 SP4 & PW 2.1.17
I am returning to an earlier issue/bug.
I've never been able to run any version of PW later than 2.1.6 with Windows 2000 with SP4.
All later versions fail to load: the error message is always the same -
File "main.py", line 112, in main
File "zipextimporter.pyo", line 82, in load_module
File "papywizard\controller\mainController.pyo", line 74, in <module>
File "papywizard\controller\pluginsController.pyo", line 61, in <module>
File "papywizard\driver\bluetoothTransport.pyo", line 80, in <module>
File "bluetooth\__init__.pyo", line 11, in <module>
File "zipextimporter.pyo", line 98, in load_module
ImportError: MemoryLoadLibrary failed loading bluetooth\_msbt.pyd
Is there any likelihood of resolving this?
PreviousNext
