[papywizard v2] Annoncement, feedback, bug report
by fma38 » Sun Jun 21, 2009 9:34 am
I think there still are some previous files. As you can see, the installer can't install the new exe (because the old one is still there?). So you start the *old* exe, with the *new* Library.zip file, which contains all the scripts...
What is the size of the exe file you have, once 'installed'? It should be 49152 bytes... Also check the date.
jriley
by jriley » Sun Jun 21, 2009 5:57 pm
fma38 wrote:@jriley: Can you tell me the result of all these commands:
$ papywizard.sh (not from papywizard dir)
$ echo $PATH
$ find /usr/local -name "papywizard*"
Here is the result. I hope this helps.
john@john-eee:~$ papywizard.sh
File "<string>", line 1, in <module>
ImportError: No module named scripts.main
john@john-eee:~$ echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
john@john-eee:~$ find /usr/local -name "papywizard*"
/usr/local/share/icons/hicolor/scalable/apps/papywizard.svg
/usr/local/share/icons/hicolor/48x48/apps/papywizard.png
/usr/local/share/applications/papywizard.desktop
/usr/local/share/pixmaps/papywizard.png
/usr/local/bin/papywizard.sh
/usr/local/lib/python2.6/site-packages/papywizard-2.1.10_1-py2.6.egg-info
/usr/local/lib/python2.6/site-packages/papywizard/common/papywizard.conf
john@john-eee:~$
by fma38 » Sun Jun 21, 2009 6:05 pm
And:
$ ls /usr/local/lib/python2.6/site-packages/papywizard/
Could you also give me the result of the install process:
$ python setup.py install --prefix=/usr/local
(with sudo if needed)...
by mediavets » Sun Jun 21, 2009 6:30 pm
fma38 wrote:
mediavets wrote:
fma38 wrote:I uploaded a new dev. release (2.1.10) with some improvements of the bluetooth connection. Tell me how it works on your different OS...
Attempts to install Maemo version on N800 are failing with message that the file is corrupt.
Works fine for me. The corruption occured on your side... Anyway, there where a bug in the starting script; I uploaded a new version (same name)...
Tried again today after rebooting the N800 and it installed OK and runs OK.
jriley
by jriley » Mon Jun 22, 2009 3:29 am
fma38 wrote:And:
OK - here goes (I assume this one was for me :D )
john@john-eee:~$ ls /usr/local/lib/python2.6/site-packages/papywizard/
common controller hardware __init__.py __init__.pyc model plugins scripts view
john@john-eee:~$ ]
and (assuming you didn't intend for me to uninstall first):
john@john-eee:~/papywizard$ sudo python setup.py install --prefix=/usr/local
[sudo] password for john:
running install
running build
running build_py
running build_scripts
running install_lib
running install_scripts
changing mode of /usr/local/bin/papywizard.sh to 755
running install_data
running install_egg_info
Removing /usr/local/lib/python2.6/site-packages/papywizard-2.1.10_1-py2.6.egg-info
Writing /usr/local/lib/python2.6/site-packages/papywizard-2.1.10_1-py2.6.egg-info
by fma38 » Mon Jun 22, 2009 7:04 am
Ok, I will investigate, because it seems to be related to python2.6...
by fma38 » Mon Jun 22, 2009 7:33 pm
Ok, this is a ubuntu issue: they now use xxx/lib/python2.6/dist-packages, instead of xxx/lib/python2.6/site-packages in the path... Don't know why.
You can fix the problem with the following commands:
$ sudo mv /usr/local/lib/python2.6/site-packages/papywizard* /usr/local/lib/python2.6/dist-packages/
$ sudo rmdir /usr/local/lib/python2.6/site-packages/
$ sudo ln -s /usr/local/lib/python2.6/dist-packages/ /usr/local/lib/python2.6/site-packages
jriley
by jriley » Mon Jun 22, 2009 11:47 pm
fma38 wrote:Ok, this is a ubuntu issue: they now use xxx/lib/python2.6/dist-packages, instead of xxx/lib/python2.6/site-packages in the path... Don't know why.
I did those three commands (copying and pasting to be sure I had it right). There was no feedback (don't guess there should have been). Papywizard still fails to launch. :(
by fma38 » Tue Jun 23, 2009 7:52 am
Try this:
$ ls -l /usr/local/lib/python2.6/site-packages
$ ls usr/local/lib/python2.6/dist-packages
$ python
>>> import sys
>>> print sys.path
>>> import papywizard.scripts.main
Give me the output of these commands...
jriley
by jriley » Fri Jun 26, 2009 2:44 am
fma38 wrote:Try this:
$ python
>>> import sys
>>> print sys.path
Here you go:
john@john-eee:~$ ls -l /usr/local/lib/python2.6/site-packages
lrwxrwxrwx 1 root staff 39 2009-06-22 18:37 /usr/local/lib/python2.6/site-packages -> /usr/local/lib/python2.6/dist-packages/
john@john-eee:~$ ls usr/local/lib/python2.6/dist-packages
ls: cannot access usr/local/lib/python2.6/dist-packages: No such file or directory
john@john-eee:~$ python
Python 2.6.2 (release26-maint, Apr 19 2009, 01:56:41)
[GCC 4.3.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> print sys.path
['', '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages', '/usr/lib/python2.6/dist-packages/PIL', '/usr/lib/python2.6/dist-packages/gst-0.10', '/var/lib/python-support/python2.6', '/usr/lib/python2.6/dist-packages/gtk-2.0', '/var/lib/python-support/python2.6/gtk-2.0', '/usr/local/lib/python2.6/dist-packages']
File "<stdin>", line 1, in <module>
by fma38 » Fri Jun 26, 2009 6:47 am
Sorry, the second command is:
$ ls -lR /usr/local/lib/python2.6/dist-packages
(missing first /).
jriley
by jriley » Fri Jun 26, 2009 7:33 pm
fma38 wrote:Sorry, the second command is:
(missing first /).
OK - here is the reslt.
john@john-eee:~$ ls -lR /usr/local/lib/python2.6/dist-packages
/usr/local/lib/python2.6/dist-packages:
total 8
drwxr-sr-x 9 root staff 4096 2009-06-20 18:50 papywizard
-rw-r--r-- 1 root staff 268 2009-06-21 22:26 papywizard-2.1.10_1-py2.6.egg-info
/usr/local/lib/python2.6/dist-packages/papywizard:
total 32
drwxr-sr-x 2 root staff 4096 2009-06-20 18:50 common
drwxr-sr-x 2 root staff 4096 2009-06-20 18:50 controller
drwxr-sr-x 2 root staff 4096 2009-06-20 18:50 hardware
-rw-r--r-- 1 root staff 0 2009-06-20 18:32 __init__.py
-rw-r--r-- 1 root staff 148 2009-06-20 18:50 __init__.pyc
drwxr-sr-x 2 root staff 4096 2009-06-20 18:50 model
drwxr-sr-x 2 root staff 4096 2009-06-20 18:50 plugins
drwxr-sr-x 2 root staff 4096 2009-06-20 18:50 scripts
drwxr-sr-x 3 root staff 4096 2009-06-20 18:50 view
/usr/local/lib/python2.6/dist-packages/papywizard/common:
total 1184
-rw-r--r-- 1 root staff 3609 2009-06-20 18:32 bluetoothTransport.py
-rw-r--r-- 1 root staff 4415 2009-06-20 18:50 bluetoothTransport.pyc
-rw-r--r-- 1 root staff 9473 2009-06-20 18:32 configManager.py
-rw-r--r-- 1 root staff 10248 2009-06-20 18:50 configManager.pyc
-rw-r--r-- 1 root staff 7165 2009-06-20 18:32 config.py
-rw-r--r-- 1 root staff 5942 2009-06-20 18:50 config.pyc
-rw-r--r-- 1 root staff 2112 2009-06-20 18:32 exception.py
-rw-r--r-- 1 root staff 2811 2009-06-20 18:50 exception.pyc
-rw-r--r-- 1 root staff 5883 2009-06-20 18:32 helpers.py
-rw-r--r-- 1 root staff 6244 2009-06-20 18:50 helpers.pyc
-rw-r--r-- 1 root staff 646830 2009-06-20 18:32 i18n.py
-rw-r--r-- 1 root staff 157535 2009-06-20 18:50 i18n.pyc
-rw-r--r-- 1 root staff 155 2009-06-20 18:50 __init__.pyc
-rw-r--r-- 1 root staff 5221 2009-06-20 18:32 loggingFormatter.py
-rw-r--r-- 1 root staff 5794 2009-06-20 18:50 loggingFormatter.pyc
-rw-r--r-- 1 root staff 7951 2009-06-20 18:32 loggingServices.py
-rw-r--r-- 1 root staff 9213 2009-06-20 18:50 loggingServices.pyc
-rw-r--r-- 1 root staff 4026 2009-06-20 18:32 orderedDict.py
-rw-r--r-- 1 root staff 5404 2009-06-20 18:50 orderedDict.pyc
-rw-r--r-- 1 root staff 7710 2009-06-20 18:32 papywizard.conf
-rw-r--r-- 1 root staff 138508 2009-06-20 18:32 pixmaps.py
-rw-r--r-- 1 root staff 34264 2009-06-20 18:50 pixmaps.pyc
-rw-r--r-- 1 root staff 7317 2009-06-20 18:32 presetManager.py
-rw-r--r-- 1 root staff 9930 2009-06-20 18:50 presetManager.pyc
-rw-r--r-- 1 root staff 6648 2009-06-20 18:32 presets.xml
-rw-r--r-- 1 root staff 4312 2009-06-20 18:32 publisher.py
-rw-r--r-- 1 root staff 5663 2009-06-20 18:50 publisher.pyc
-rw-r--r-- 1 root staff 5039 2009-06-20 18:32 qLoggingFormatter.py
-rw-r--r-- 1 root staff 6356 2009-06-20 18:50 qLoggingFormatter.pyc
-rw-r--r-- 1 root staff 5046 2009-06-20 18:32 signal.py
-rw-r--r-- 1 root staff 6339 2009-06-20 18:50 signal.pyc
/usr/local/lib/python2.6/dist-packages/papywizard/controller:
total 352
-rw-r--r-- 1 root staff 5542 2009-06-20 18:31 abstractController.py
-rw-r--r-- 1 root staff 8006 2009-06-20 18:50 abstractController.pyc
-rw-r--r-- 1 root staff 2704 2009-06-20 18:31 bluetoothChooserController.py
-rw-r--r-- 1 root staff 3781 2009-06-20 18:50 bluetoothChooserController.pyc
-rw-r--r-- 1 root staff 16307 2009-06-20 18:31 configController.py
-rw-r--r-- 1 root staff 15626 2009-06-20 18:50 configController.pyc
-rw-r--r-- 1 root staff 2327 2009-06-20 18:31 helpAboutController.py
-rw-r--r-- 1 root staff 3234 2009-06-20 18:50 helpAboutController.pyc
-rw-r--r-- 1 root staff 0 2009-06-20 18:31 __init__.py
-rw-r--r-- 1 root staff 159 2009-06-20 18:50 __init__.pyc
-rw-r--r-- 1 root staff 4667 2009-06-20 18:31 loggerController.py
-rw-r--r-- 1 root staff 6100 2009-06-20 18:50 loggerController.pyc
-rw-r--r-- 1 root staff 55200 2009-06-20 18:31 mainController.py
-rw-r--r-- 1 root staff 50967 2009-06-20 18:50 mainController.pyc
-rw-r--r-- 1 root staff 3252 2009-06-20 18:31 nbPictsController.py
-rw-r--r-- 1 root staff 4097 2009-06-20 18:50 nbPictsController.pyc
-rw-r--r-- 1 root staff 14519 2009-06-20 18:31 pluginsController.py
-rw-r--r-- 1 root staff 12912 2009-06-20 18:50 pluginsController.pyc
-rw-r--r-- 1 root staff 3302 2009-06-20 18:31 pluginsStatusController.py
-rw-r--r-- 1 root staff 4257 2009-06-20 18:50 pluginsStatusController.pyc
-rw-r--r-- 1 root staff 33108 2009-06-20 18:31 shootController.py
-rw-r--r-- 1 root staff 30439 2009-06-20 18:50 shootController.pyc
-rw-r--r-- 1 root staff 5237 2009-06-20 18:31 spy.py
-rw-r--r-- 1 root staff 6344 2009-06-20 18:50 spy.pyc
-rw-r--r-- 1 root staff 3307 2009-06-20 18:31 totalFovController.py
-rw-r--r-- 1 root staff 4193 2009-06-20 18:50 totalFovController.pyc
/usr/local/lib/python2.6/dist-packages/papywizard/hardware:
total 108
-rw-r--r-- 1 root staff 4398 2009-06-20 18:32 abstractDriver.py
-rw-r--r-- 1 root staff 5947 2009-06-20 18:50 abstractDriver.pyc
-rw-r--r-- 1 root staff 3934 2009-06-20 18:32 bluetoothDriver.py
-rw-r--r-- 1 root staff 4929 2009-06-20 18:50 bluetoothDriver.pyc
-rw-r--r-- 1 root staff 4057 2009-06-20 18:32 driverFactory.py
-rw-r--r-- 1 root staff 4270 2009-06-20 18:50 driverFactory.pyc
-rw-r--r-- 1 root staff 4306 2009-06-20 18:32 ethernetDriver.py
-rw-r--r-- 1 root staff 5289 2009-06-20 18:50 ethernetDriver.pyc
-rw-r--r-- 1 root staff 2434 2009-06-20 18:32 hardwareFactory.py
-rw-r--r-- 1 root staff 2957 2009-06-20 18:50 hardwareFactory.pyc
-rw-r--r-- 1 root staff 7218 2009-06-20 18:32 head.py
-rw-r--r-- 1 root staff 9198 2009-06-20 18:50 head.pyc
-rw-r--r-- 1 root staff 157 2009-06-20 18:50 __init__.pyc
-rw-r--r-- 1 root staff 3771 2009-06-20 18:32 serialDriver.py
-rw-r--r-- 1 root staff 4990 2009-06-20 18:50 serialDriver.pyc
-rw-r--r-- 1 root staff 2051 2009-06-20 18:32 usbDriver.py
-rw-r--r-- 1 root staff 2444 2009-06-20 18:50 usbDriver.pyc
/usr/local/lib/python2.6/dist-packages/papywizard/model:
total 136
-rw-r--r-- 1 root staff 5795 2009-06-20 18:31 camera.py
-rw-r--r-- 1 root staff 7194 2009-06-20 18:50 camera.pyc
-rw-r--r-- 1 root staff 9930 2009-06-20 18:31 data.py
-rw-r--r-- 1 root staff 10799 2009-06-20 18:50 data.pyc
-rw-r--r-- 1 root staff 154 2009-06-20 18:50 __init__.pyc
-rw-r--r-- 1 root staff 3550 2009-06-20 18:31 lens.py
-rw-r--r-- 1 root staff 5140 2009-06-20 18:50 lens.pyc
-rw-r--r-- 1 root staff 12052 2009-06-20 18:31 scan.py
-rw-r--r-- 1 root staff 14895 2009-06-20 18:50 scan.pyc
-rw-r--r-- 1 root staff 23806 2009-06-20 18:31 shooting.py
-rw-r--r-- 1 root staff 24647 2009-06-20 18:50 shooting.pyc
/usr/local/lib/python2.6/dist-packages/papywizard/plugins:
total 352
-rw-r--r-- 1 root staff 6181 2009-06-20 18:31 abstractAxisPlugin.py
-rw-r--r-- 1 root staff 8472 2009-06-20 18:50 abstractAxisPlugin.pyc
-rw-r--r-- 1 root staff 2872 2009-06-20 18:31 abstractHardwarePlugin.py
-rw-r--r-- 1 root staff 4069 2009-06-20 18:50 abstractHardwarePlugin.pyc
-rw-r--r-- 1 root staff 5475 2009-06-20 18:31 abstractPluginController.py
-rw-r--r-- 1 root staff 6683 2009-06-20 18:50 abstractPluginController.pyc
-rw-r--r-- 1 root staff 6679 2009-06-20 18:31 abstractPlugin.py
-rw-r--r-- 1 root staff 8353 2009-06-20 18:50 abstractPlugin.pyc
-rw-r--r-- 1 root staff 4946 2009-06-20 18:31 abstractShutterPlugin.py
-rw-r--r-- 1 root staff 6934 2009-06-20 18:50 abstractShutterPlugin.pyc
-rw-r--r-- 1 root staff 3670 2009-06-20 18:31 abstractStandardShutterPlugin.py
-rw-r--r-- 1 root staff 5062 2009-06-20 18:50 abstractStandardShutterPlugin.pyc
-rw-r--r-- 1 root staff 2477 2009-06-20 18:31 axisPluginController.py
-rw-r--r-- 1 root staff 3117 2009-06-20 18:50 axisPluginController.pyc
-rw-r--r-- 1 root staff 10335 2009-06-20 18:31 eosUtilityPlugins.py
-rw-r--r-- 1 root staff 11913 2009-06-20 18:50 eosUtilityPlugins.pyc
-rw-r--r-- 1 root staff 2373 2009-06-20 18:31 hardwarePluginController.py
-rw-r--r-- 1 root staff 2856 2009-06-20 18:50 hardwarePluginController.pyc
-rw-r--r-- 1 root staff 156 2009-06-20 18:50 __init__.pyc
-rw-r--r-- 1 root staff 18407 2009-06-20 18:31 merlinOrionPlugins.py
-rw-r--r-- 1 root staff 22297 2009-06-20 18:50 merlinOrionPlugins.pyc
-rw-r--r-- 1 root staff 7626 2009-06-20 18:31 pluginsConnector.py
-rw-r--r-- 1 root staff 5915 2009-06-20 18:50 pluginsConnector.pyc
-rw-r--r-- 1 root staff 5638 2009-06-20 18:31 pluginsManager.py
-rw-r--r-- 1 root staff 6550 2009-06-20 18:50 pluginsManager.pyc
-rw-r--r-- 1 root staff 18006 2009-06-20 18:31 pololuServoPlugins.py
-rw-r--r-- 1 root staff 22199 2009-06-20 18:50 pololuServoPlugins.pyc
-rw-r--r-- 1 root staff 2109 2009-06-20 18:31 shutterPluginController.py
-rw-r--r-- 1 root staff 2654 2009-06-20 18:50 shutterPluginController.pyc
-rw-r--r-- 1 root staff 10727 2009-06-20 18:31 simulationPlugins.py
-rw-r--r-- 1 root staff 15042 2009-06-20 18:50 simulationPlugins.pyc
-rw-r--r-- 1 root staff 2921 2009-06-20 18:31 standardShutterPluginController.py
-rw-r--r-- 1 root staff 3605 2009-06-20 18:50 standardShutterPluginController.pyc
-rw-r--r-- 1 root staff 5751 2009-06-20 18:31 tetheredPlugins.py
-rw-r--r-- 1 root staff 8406 2009-06-20 18:50 tetheredPlugins.pyc
-rw-r--r-- 1 root staff 4859 2009-06-20 18:31 timelordPlugins.py
-rw-r--r-- 1 root staff 7620 2009-06-20 18:50 timelordPlugins.pyc
-rw-r--r-- 1 root staff 5514 2009-06-20 18:31 usbTaPlugins.py
-rw-r--r-- 1 root staff 7403 2009-06-20 18:50 usbTaPlugins.pyc
/usr/local/lib/python2.6/dist-packages/papywizard/scripts:
total 28
-rw-r--r-- 1 root staff 9837 2009-06-20 18:31 main.py
-rw-r--r-- 1 root staff 8422 2009-06-20 18:50 main.pyc
/usr/local/lib/python2.6/dist-packages/papywizard/view:
total 824
-rw-r--r-- 1 root staff 2009 2009-06-20 18:32 arthurFrame.py
-rw-r--r-- 1 root staff 2552 2009-06-20 18:50 arthurFrame.pyc
-rw-r--r-- 1 root staff 563198 2009-06-20 18:32 icons.py
-rw-r--r-- 1 root staff 137087 2009-06-20 18:50 icons.pyc
-rw-r--r-- 1 root staff 153 2009-06-20 18:50 __init__.pyc
-rw-r--r-- 1 root staff 2924 2009-06-20 18:32 logBuffer.py
-rw-r--r-- 1 root staff 3927 2009-06-20 18:50 logBuffer.pyc
-rw-r--r-- 1 root staff 4297 2009-06-20 18:32 messageDialog.py
-rw-r--r-- 1 root staff 6707 2009-06-20 18:50 messageDialog.pyc
-rw-r--r-- 1 root staff 8823 2009-06-20 18:32 pathRenderer.py
-rw-r--r-- 1 root staff 9610 2009-06-20 18:50 pathRenderer.pyc
-rw-r--r-- 1 root staff 1882 2009-06-20 18:32 pathWidget.py
-rw-r--r-- 1 root staff 2282 2009-06-20 18:50 pathWidget.pyc
-rw-r--r-- 1 root staff 8102 2009-06-20 18:32 pictureItem.py
-rw-r--r-- 1 root staff 10050 2009-06-20 18:50 pictureItem.pyc
-rw-r--r-- 1 root staff 3861 2009-06-20 18:32 pluginFields.py
-rw-r--r-- 1 root staff 6710 2009-06-20 18:50 pluginFields.pyc
-rw-r--r-- 1 root staff 9938 2009-06-20 18:32 shootingScene.py
-rw-r--r-- 1 root staff 11427 2009-06-20 18:50 shootingScene.pyc
drwxr-sr-x 2 root staff 4096 2009-06-20 18:50 ui
/usr/local/lib/python2.6/dist-packages/papywizard/view/ui:
total 180
-rw-r--r-- 1 root staff 1870 2009-06-20 18:32 bluetoothChooserDialog.ui
-rw-r--r-- 1 root staff 31806 2009-06-20 18:32 configDialog.ui
-rw-r--r-- 1 root staff 12794 2009-06-20 18:32 helpAboutDialog.ui
-rw-r--r-- 1 root staff 6232 2009-06-20 18:32 loggerDialog.ui
-rw-r--r-- 1 root staff 46101 2009-06-20 18:32 mainWindow.ui
-rw-r--r-- 1 root staff 3374 2009-06-20 18:32 nbPictsDialog.ui
-rw-r--r-- 1 root staff 2241 2009-06-20 18:32 pluginsConfigDialog.ui
-rw-r--r-- 1 root staff 10236 2009-06-20 18:32 pluginsDialog.ui
-rw-r--r-- 1 root staff 11208 2009-06-20 18:32 pluginsStatusDialog.ui
-rw-r--r-- 1 root staff 22903 2009-06-20 18:32 shootDialog.ui
-rw-r--r-- 1 root staff 3558 2009-06-20 18:32 totalFovDialog.ui
-rw-r--r-- 1 root staff 10461 2009-06-20 18:32 wizardDialog.ui
john@john-eee:~$
by fma38 » Fri Jun 26, 2009 9:51 pm
All is ok; I really don't understand what's going on, here. I tried on my wife's laptop, running ubuntu 9.04, and once I have made the symbolic link, all worked fine.
I'll try to ask on the python mailing list...
by fma38 » Thu Aug 06, 2009 2:36 pm
I confirm that there is a problem with the mosaic mode: the positions are not always visible. As I didn't change anything since a long time, I suspect a problem with Qt (4.5 vs 4.4).
The bug occurs when the pano (pitch only) is not symetrical arround the reference (yaw=0, pitch=0), which is often the case when using the start/end button to define the pano.
Could you check on you different systems if it is the case? Try to report the Qt version used (use the Help > About Qt menu)...
Thanks.
jplorge
by jplorge » Thu Aug 06, 2009 3:19 pm
fma38 wrote:Could you check on you different systems if it is the case? Try to report the Qt version used (use the Help > About Qt menu)...
Thanks.
I tryed on Nokia, win XP, and Linux Ubuntu 9, that the same
Jean-Pierre
Merlin/Orion firmware : 01.09.81 panohead + Papywizard on XP PC and Linux Ubuntu 9.1 & Nokia 800
Manfrotto 303 PAN HEAD with Nikon D70 + Nikon 18-70 in kit - Nikon 80-200 F 2.8 old - Sigma 10-20
Assembly : Ptgui 9.1.3
jplorge
by jplorge » Thu Aug 06, 2009 3:21 pm
I found a solution to this problem: choose the center of the shot with positioning the head and click on "home" then indicate the number of vertical and horizontal photos, then start shooting and watch the position of the beginning or end, if it is not wide enough, stop and add 2 photos and go to shoot, the head will move to the new position. And so on...
I know this is not great but it works
Jean-Pierre
Tipjip
by Tipjip » Sun Sep 13, 2009 12:54 pm
I'm still trying out Papywizard without a merlin head. Instead I use it as a base to do tethered bracketing panos. Since yesterday I've been trying the Papywizard Import function in APP, too. I made myself a nice preset that conforms with the way I manually shoot panos, let Papywizard run through it, fed the saved datafile to APP, everything fine.
Today I'm trying bracketing (EOS Utility via Papywizard) and I'm having a problem: The file outputted by Papywizard only reflects the number of stops, not the number of (bracketed) pictures taken at each stop. So when I do 3 shots at 2 stop points APP only expects 2 images because papywizard only tells it about two.
I'm still not sure: is this a bug (Papywizard not taking into account the brackting settings for the EOS Utility plugin) or is the problem sitting in front of the computer?
Christian
by fma38 » Sun Sep 13, 2009 3:52 pm
Christian, did you check in the log file that all bracketed pictures where really taken? If one of them failed, then it won't be recorded. It may occur because of a bug in the plugin, or a bad return value from the EOS Utility script.
Please, send me your config. file and the entire log.
Tipjip
by Tipjip » Sun Sep 13, 2009 5:24 pm
You can download the config files here: http://dreiwolf.eu/fotos/panorama/logandconfig.zip.
The pictures are taken fine. I observed that while shooting I get the message "Auslà¶ser - Bild 1/1" which probably translates into "Shutter - Picture 1/1" instead of 1/3 (which is what it actually does, 3 pictures).
Thanks!
Christian
by fma38 » Sun Sep 13, 2009 7:15 pm
In the config file, the bracketing nb picts is set to 1. That's the problem in the current version of Papywizard and all tethered plugins: if the external application take more than 1 picture, Papywizard can't know it. That's why I always search to drive picture by picture... If the external application can return the number of pictures taken, I can modify Papywizard to read it, and generate the correct number of entries in the xml file. But I don't think DSLR Remote Pro or EOS Utility can do that...
by fma38 » Mon Sep 14, 2009 9:47 pm
I uploaded a new dev. release (2.1.11), with several new features, bug fixes and other modifications (see ChangeLog for complete description).
I don't have much time, these days, by feel free to report bugs or so.
Paul
by Paul » Mon Sep 14, 2009 10:20 pm
fma38 wrote:by feel free to report bugs or so.
- preview does not fit window
- some items are not translated
- can't find setting for reverse shooting
Paul
by fma38 » Tue Sep 15, 2009 6:45 am
I didn't fix the bug for preview when not using symetrical values (in fact, this seems to be a Qt issue).
Translations will only be available for final stable release.
When using the timer repeat feature, you can enable the automatic reverse shooting at each repeat. You can also use the button at the top right of the shooting window to reverse shooting before shooting.
by fma38 » Tue Oct 13, 2009 10:17 pm
Just to say that the plugin for the PixOrb motorized panohead will be soon available. Thanks to Marc Davidson from Peace River, and Gerard Maynard, photographer, who made a lot of tests to debug it!
This plugin, as the DSLR Remote Pro on, will be added to the next dev release, in a few days.
by fma38 » Sun Oct 25, 2009 9:28 am
The new dev release (2.2.12) in on-line. I think it will be the last before I release the stable version, so, please test it, test it, test it!
The 2 new plugins (PixOrb head and DSLR Remote Pro) are available. I also fixed the preview bug Claude reported (it was not a Qt issue!).
PreviousNext
