[papywizard v2] Annoncement, feedback, bug report
by mediavets » Mon May 11, 2009 9:14 pm
fma38 wrote:Mmmm, I'm sorry, but I don't see what can cause such troubles...
BTW, I uploaded a new release (2.1.8), with a new layout for plugins/configuration...
I found a 2.1.7 but not a 2.1.8?
by fma38 » Mon May 11, 2009 9:54 pm
Yes, 2.1.7, sorry!
by mediavets » Mon May 11, 2009 11:28 pm
2.1.7 won't run on my Windows 2000 laptop.
Here's the traceback and screen shot of the error on loading.
  File "main.py", line 112, in main
  File "zipextimporter.pyo", line 82, in load_module
  File "papywizard\controller\mainController.pyo", line 73, in <module>
  File "papywizard\controller\pluginsController.pyo", line 61, in <module>
  File "papywizard\controller\bluetoothChooserController.pyo", line 61, in <module>
  File "papywizard\common\bluetoothTransport.pyo", line 76, in <module>
  File "bluetooth\__init__.pyo", line 11, in <module>
  File "zipextimporter.pyo", line 98, in load_module
ImportError: MemoryLoadLibrary failed loading bluetooth\_msbt.pyd
irpano
by irpano » Tue May 12, 2009 6:05 am
Version 2.1.7-1 Will run on windows XP service pack 3 on Vaio laptop till asked to perform shoot.
Sequence of events - Open Papywizard - Check on "Preferences" - NONE replaced with Plugins (Plugins tab in Configuration Button also)
Check configuration button and set connection etc - Plugins duplicated but not functional the same as in Plugins under "Hardware" option
Make connection OK (After reinstalling head as bluetooth device)
Connects and allows for head movement via UP down buttons.
Set Nb of picts to 2 X 1
Click shoot and shoot window appears BUT SYSTEM LOCKS UP
Here is the log up until the shoot button is clicked
2009-05-12 14:58:40,282::MainThread::INFO::Starting Papywizard...
2009-05-12 14:58:40,401::MainThread::INFO::Importing modules...
2009-05-12 14:58:40,933::MainThread::INFO::Loading i18n files...
2009-05-12 14:58:40,953::MainThread::DEBUG::Papywizard.i18n(): locale=C
2009-05-12 14:58:40,953::MainThread::WARNING::Can't find qt translation file
2009-05-12 14:58:40,953::MainThread::WARNING::Can't find papywizard translation file
2009-05-12 14:58:40,953::MainThread::INFO::Loading Style Sheets...
2009-05-12 14:58:40,973::MainThread::WARNING::No user Style Sheet found
2009-05-12 14:58:40,973::MainThread::INFO::Loading configuration...
2009-05-12 14:58:40,993::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['2', '1', '7'], user=[u'2', u'1', u'7']
2009-05-12 14:58:40,993::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2009-05-12 14:58:40,993::MainThread::INFO::Load plugins...
2009-05-12 14:58:41,032::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-12 14:58:41,032::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'yawAxis'
2009-05-12 14:58:41,032::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'pitchAxis'
2009-05-12 14:58:41,042::MainThread::DEBUG::PluginManager.register(): added 'Simulation' plugin with capacity 'shutter'
2009-05-12 14:58:41,052::MainThread::TRACE::MerlinOrionYawAxis._init()
2009-05-12 14:58:41,052::MainThread::TRACE::MerlinOrionAxis._init()
2009-05-12 14:58:41,052::MainThread::TRACE::MerlinOrionHardware._init()
2009-05-12 14:58:41,052::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-12 14:58:41,062::MainThread::TRACE::MerlinOrionAxis._init()
2009-05-12 14:58:41,062::MainThread::TRACE::MerlinOrionHardware._init()
2009-05-12 14:58:41,062::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-12 14:58:41,062::MainThread::DEBUG::PluginManager.register(): added 'Merlin-Orion' plugin with capacity 'yawAxis'
2009-05-12 14:58:41,062::MainThread::TRACE::MerlinOrionPitchAxis._init()
2009-05-12 14:58:41,072::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-12 14:58:41,072::MainThread::TRACE::MerlinOrionPitchAxis._init()
2009-05-12 14:58:41,072::MainThread::TRACE::MerlinOrionAxis._init()
2009-05-12 14:58:41,072::MainThread::TRACE::MerlinOrionHardware._init()
2009-05-12 14:58:41,082::MainThread::DEBUG::PluginManager.register(): added 'Merlin-Orion' plugin with capacity 'pitchAxis'
2009-05-12 14:58:41,082::MainThread::TRACE::MerlinOrionShutter._init()
2009-05-12 14:58:41,082::MainThread::TRACE::MerlinOrionHardware._init()
2009-05-12 14:58:41,082::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-12 14:58:41,082::MainThread::DEBUG::PluginManager.register(): added 'Merlin-Orion' plugin with capacity 'shutter'
2009-05-12 14:58:41,092::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-12 14:58:41,092::MainThread::DEBUG::PluginManager.register(): added 'Tethered' plugin with capacity 'shutter'
2009-05-12 14:58:41,102::MainThread::DEBUG::PluginManager.register(): added 'Timelord' plugin with capacity 'shutter'
2009-05-12 14:58:41,102::MainThread::TRACE::PololuServoYawAxis._init()
2009-05-12 14:58:41,102::MainThread::TRACE::PololuServoAxis._init()
2009-05-12 14:58:41,102::MainThread::TRACE::PololuServoHardware._init()
2009-05-12 14:58:41,112::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-12 14:58:41,112::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'yawAxis'
2009-05-12 14:58:41,112::MainThread::TRACE::PololuServoPitchAxis._init()
2009-05-12 14:58:41,112::MainThread::TRACE::PololuServoAxis._init()
2009-05-12 14:58:41,112::MainThread::TRACE::PololuServoHardware._init()
2009-05-12 14:58:41,112::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'pitchAxis'
2009-05-12 14:58:41,122::MainThread::TRACE::PololuServoShutter._init()
2009-05-12 14:58:41,122::MainThread::TRACE::PololuServoHardware._init()
2009-05-12 14:58:41,122::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-12 14:58:41,122::MainThread::DEBUG::PluginManager.register(): added 'Pololu Servo' plugin with capacity 'shutter'
2009-05-12 14:58:41,132::MainThread::TRACE::AbstractPlugin._loadConfig()
2009-05-12 14:58:41,132::MainThread::DEBUG::PluginManager.register(): added 'EOS Utility' plugin with capacity 'shutter'
2009-05-12 14:58:41,132::MainThread::INFO::Loading user plugins...
2009-05-12 14:58:41,132::MainThread::DEBUG::PluginManager.register(): parsing 'C:\Documents and Settings\default\Application Data\papywizard2\plugins' dir...
2009-05-12 14:58:41,132::MainThread::INFO::Activate plugins...
2009-05-12 14:58:41,142::MainThread::TRACE::MerlinOrionHardware.activate()
2009-05-12 14:58:41,142::MainThread::TRACE::MerlinOrionShutter.activate()
2009-05-12 14:58:41,142::MainThread::INFO::Creating model...
2009-05-12 14:58:41,153::Dummy-1::DEBUG::MerlinOrionAxis.run(): start 'Merlin-Orion_yawAxis' thread
2009-05-12 14:58:41,153::Dummy-2::DEBUG::MerlinOrionAxis.run(): start 'Merlin-Orion_pitchAxis' thread
2009-05-12 14:58:41,163::MainThread::WARNING::Shooting.__init__(): Remove self.hardware compatibility
2009-05-12 14:58:41,163::MainThread::INFO::Loading default presets
2009-05-12 14:58:41,213::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2009-05-12 14:58:41,213::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2009-05-12 14:58:41,223::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2009-05-12 14:58:41,223::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2009-05-12 14:58:41,223::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2009-05-12 14:58:41,223::MainThread::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2009-05-12 14:58:41,233::MainThread::INFO::Loading user presets
2009-05-12 14:58:41,233::MainThread::WARNING::No user presets found
2009-05-12 14:58:41,233::MainThread::INFO::Starting Spy...
2009-05-12 14:58:41,233::MainThread::INFO::Creating GUI...
2009-05-12 14:58:41,253::Spy::INFO::Starting Spy...
2009-05-12 14:58:41,594::MainThread::WARNING::MainController.__onKeyPressed(): fix fullScreenFlag property!!!
2009-05-12 14:58:53,601::MainThread::TRACE::MainController.__onActionHardwarePluginsActivated()
2009-05-12 14:58:56,875::MainThread::TRACE::PluginsController._onAccepted()
2009-05-12 14:58:56,885::MainThread::TRACE::MerlinOrionHardware.activate()
2009-05-12 14:58:56,885::MainThread::TRACE::AbstractPlugin._saveConfig()
2009-05-12 14:58:56,915::MainThread::DEBUG::Configuration saved
2009-05-12 14:58:56,915::MainThread::TRACE::AbstractPlugin._saveConfig()
2009-05-12 14:58:56,926::MainThread::DEBUG::Configuration saved
2009-05-12 14:58:56,946::MainThread::DEBUG::Configuration saved
2009-05-12 14:58:58,908::MainThread::TRACE::MainController.__onConfigPushButtonClicked()
2009-05-12 14:58:59,198::MainThread::DEBUG::ConfigController.__onCameraOrientationComboBoxCurrentIndexChanged(): orientation=portrait
2009-05-12 14:58:59,209::MainThread::DEBUG::ConfigController.__onLensTypeComboBoxCurrentIndexChanged(): type=rectilinear
2009-05-12 14:58:59,209::MainThread::DEBUG::ConfigController.__onLensTypeComboBoxCurrentIndexChanged(): lens type set to 'rectilinear'
2009-05-12 14:59:06,960::MainThread::DEBUG::AbstractPluginController._initWidgets(): created 'Main' tab
2009-05-12 14:59:06,960::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Time value' field
2009-05-12 14:59:06,960::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Mirror lockup' field
2009-05-12 14:59:06,960::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Bracketing nb picts' field
2009-05-12 14:59:06,970::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Bracketing intent' field
2009-05-12 14:59:06,970::MainThread::DEBUG::AbstractPluginController._initWidgets(): created 'Hard' tab
2009-05-12 14:59:06,970::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Pulse width high' field
2009-05-12 14:59:06,970::MainThread::DEBUG::AbstractPluginController._initWidgets(): added 'Pulse width low' field
2009-05-12 14:59:09,483::MainThread::TRACE::AbstractPluginController._onAccepted()
2009-05-12 14:59:09,493::MainThread::DEBUG::AbstractPluginController._onAccepted(): config={'DRIVER_TYPE': PyQt4.QtCore.QString(u'bluetooth'), 'PULSE_WIDTH_LOW': 100, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'BRACKETING_INTENT': u'exposure', 'PULSE_WIDTH_HIGH': 100}
2009-05-12 14:59:09,493::MainThread::TRACE::AbstractPlugin._saveConfig()
2009-05-12 14:59:09,513::MainThread::DEBUG::Configuration saved
2009-05-12 14:59:19,477::MainThread::TRACE::ConfigController._onAccepted()
2009-05-12 14:59:19,517::MainThread::DEBUG::Configuration saved
2009-05-12 14:59:28,009::MainThread::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2009-05-12 14:59:28,009::MainThread::INFO::Establishing connection...
2009-05-12 14:59:28,059::Dummy-4::TRACE::MerlinOrionAxis.establishConnection()
2009-05-12 14:59:28,069::Dummy-4::TRACE::BluetoothDriver._init()
2009-05-12 14:59:28,069::Dummy-4::DEBUG::BluetoothDriver._init(): trying to connect to 00:12:6F:02:21:60...
2009-05-12 14:59:37,052::Dummy-4::DEBUG::BluetoothDriver._init(): successfully connected to 00:12:6F:02:21:60
2009-05-12 14:59:37,553::Dummy-4::DEBUG::MerlinOrionHardware._initMerlinOrion(): full circle count=0xe62d3
2009-05-12 14:59:37,654::Dummy-4::DEBUG::MerlinOrionHardware._initMerlinOrion(): sidereal rate=0x6f9
2009-05-12 14:59:37,654::Dummy-4::TRACE::MerlinOrionAxis.establishConnection()
2009-05-12 14:59:37,904::Dummy-4::DEBUG::MerlinOrionHardware._initMerlinOrion(): full circle count=0xe62d3
2009-05-12 14:59:37,984::Dummy-4::DEBUG::MerlinOrionHardware._initMerlinOrion(): sidereal rate=0x6f9
2009-05-12 14:59:37,984::Dummy-4::TRACE::MerlinOrionShutter.establishConnection()
2009-05-12 14:59:37,984::Dummy-4::DEBUG::MainController.__onHardwareConnected(): flag=True
2009-05-12 14:59:37,994::MainThread::INFO::Connection established
2009-05-12 14:59:42,490::MainThread::TRACE::MainController.__onYawMoveMinusToolButtonPressed()
2009-05-12 14:59:43,892::MainThread::TRACE::MainController.__onYawMoveMinusToolButtonReleased()
2009-05-12 14:59:44,753::MainThread::TRACE::MainController.__yawMovePlusToolButtonPressed()
2009-05-12 14:59:45,825::MainThread::TRACE::MainController.__yawMovePlusToolButtonReleased()
2009-05-12 14:59:46,526::MainThread::TRACE::MainController.__pitchMovePlusToolButtonPressed()
2009-05-12 14:59:47,749::MainThread::TRACE::MainController.__pitchMovePlusToolButtonReleased()
2009-05-12 14:59:48,609::MainThread::TRACE::MainController.__onPitchMoveMinusToolButtonPressed()
2009-05-12 14:59:49,732::MainThread::TRACE::MainController.__onPitchMoveMinusToolButtonReleased()
2009-05-12 14:59:50,602::MainThread::TRACE::MainController.__onSetReferenceToolButtonClicked()
2009-05-12 14:59:50,602::MainThread::INFO::Set hardware reference
2009-05-12 14:59:51,755::MainThread::TRACE::MainController.__onNbPictsPushButtonClicked()
2009-05-12 14:59:54,509::MainThread::TRACE::NbPictsController._onAccepted()
2009-05-12 14:59:54,509::MainThread::DEBUG::NbPictsController._onAccepted(): nb picts set to yaw=2, pitch=1
2009-05-12 15:00:04,693::MainThread::TRACE::MainController.__onShootPushButtonClicked()
2009-05-12 15:00:04,923::MainThread::DEBUG::ShootController._initWidgets()
File "papywizard\controller\shootController.pyo", line 150, in _initWidgets
File "papywizard\model\scan.pyo", line 104, in _setIndex
IndexError: position index out of range
2009-05-12 15:00:14,387::MainThread::TRACE::AbstractModalDialogController._onRejected()
2009-05-12 15:00:18,854::MainThread::TRACE::MainController.__onActionHelpViewLogActivated()
by fma38 » Tue May 12, 2009 6:35 am
mediavets wrote:2.1.7 won't run on my Windows 2000 laptop.
Does it work on XP?
by fma38 » Tue May 12, 2009 6:47 am
irpano wrote:Version 2.1.7-1 Will run on windows XP service pack 3 on Vaio laptop till asked to perform shoot.
My fault! I corrected the bug and uploaded a new version, under the same name. It should be available in a few minutes for Windows (maemo package had the same bug, and is already on-line).
by mediavets » Tue May 12, 2009 5:36 pm
Does it work on XP?
Yes.
I've tried again with the very latest 2.1.7-1 but it still fails on Windows 2000 - same errors.
Strange, because all previous 2.x versions have run just fine including 2.1.6-1.
by fma38 » Tue May 12, 2009 7:34 pm
Strange... Did you try to uninstall all Papywizard stuff, and re-install it? I remember it has solved problems, in the past.
by mediavets » Tue May 12, 2009 8:28 pm
fma38 wrote:Strange... Did you try to uninstall all Papywizard stuff, and re-install it? I remember it has solved problems, in the past.
Yes, I tried that thinking it would work but it didn't.
Yet removing 2.1.7-1 using the regular uninstall and then installing 2.1.6-1 always works.
I'll continue to experiment.
by fma38 » Tue May 12, 2009 11:03 pm
I changed the way the bluetooth module is imported, but I don't see why it does not work under Win2000, as it works fine under XP. Maybe that f...ing zip importer?
by mediavets » Tue May 12, 2009 11:29 pm
fma38 wrote:I changed the way the bluetooth module is imported, but I don't see why it does not work under Win2000, as it works fine under XP.
Yes, it does. No problema at all with three different XP systems.
I think that's maybe the problem. I've tried everything I know and can't get it to work with Windows 2000.
irpano
by irpano » Wed May 13, 2009 2:08 am
Frederic, Just confirming that the latest version 2.1.7 downloaded this hour and installed on my Vaio XP SP# notebook woks well to the point of what I have tested.
It also established a connection without me having to reinstall the head onto the system (?????)
I use it in conjunction with Breeze systems DSLR Pro software (Tethered plugin)and everything functioned as designed. Great for me and Thank you for your efforts.
One question, and pardon my muddled thinking but "What is the reason for having the plugin option in two places - in HARDWARE and in CONFIGURATION.
Is this what you are still working on in the interface design.
by fma38 » Wed May 13, 2009 6:35 am
As you can see, the Plugins sub-menu is greyed-out once your are connected. If not, you could change plugins and driver while using them, which can cause serious troubles ;)
mm
by mm » Wed May 13, 2009 3:34 pm
Hi folks!
I have created a custom preset file for my tele lens - a copy of that file can be found at: http://www.mit2m.de/downloads/presets.xml
When I put this file into my home directory I get the following exception from Papywizard:
---8<---
Exception
Unhandled exception
list index out of range
File "main.py", line 163, in main
File "papywizard\model\shooting.pyo", line 111, in __init__
File "papywizard\model\scan.pyo", line 356, in __init__
File "papywizard\common\presetManager.pyo", line 239, in PresetManager
File "papywizard\common\presetManager.pyo", line 214, in __init__
File "papywizard\common\presetManager.pyo", line 226, in importPresetFile
File "papywizard\common\presetManager.pyo", line 101, in __init__
IndexError: list index out of range
---8<---
papywizard.log reports:
---8<---
2009-05-13 16:16:28,405::MainThread::INFO::Starting Papywizard...
2009-05-13 16:16:28,483::MainThread::INFO::Importing modules...
2009-05-13 16:16:28,500::MainThread::DEBUG::Shooting.start(): loading user external shooting script
File "papywizard\model\shooting.pyo", line 70, in <module>
ImportError: No module named shoot
2009-05-13 16:16:28,500::MainThread::WARNING::No user external shooting script found
2009-05-13 16:16:28,578::MainThread::INFO::Loading i18n files...
2009-05-13 16:16:28,578::MainThread::DEBUG::Papywizard.i18n(): locale=de_DE
2009-05-13 16:16:28,578::MainThread::WARNING::Can't find qt translation file
2009-05-13 16:16:28,578::MainThread::INFO::Loading Style Sheets...
2009-05-13 16:16:28,578::MainThread::WARNING::No user Style Sheet found
2009-05-13 16:16:28,578::MainThread::INFO::Loading configuration...
2009-05-13 16:16:28,578::MainThread::DEBUG::ConfigManager.__init__(): versions: dist=['2', '0', '0'], user=[u'2', u'0', u'0']
2009-05-13 16:16:28,578::MainThread::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2009-05-13 16:16:28,578::MainThread::INFO::Creating model...
2009-05-13 16:16:28,592::MainThread::INFO::Loading default presets
2009-05-13 16:16:28,592::MainThread::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2009-05-13 16:16:28,592::MainThread::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2009-05-13 16:16:28,592::MainThread::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2009-05-13 16:16:28,592::MainThread::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2009-05-13 16:16:28,592::MainThread::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2009-05-13 16:16:28,592::MainThread::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2009-05-13 16:16:28,592::MainThread::INFO::Loading user presets
2009-05-13 16:16:28,640::MainThread::DEBUG::Preset.__init__(): loading name='360x180 - 20 Rows + Z + N'
2009-05-13 16:16:28,640::MainThread::EXCEPTION::main()
---8<---
I also tried to import my preset using the program menu and substituted the default preset.xml with my custom one - similar results... :-(
I could not find any recent posts discussing this topic.
What can I do to get this up and running?
I am using Papywizard 2.0.0 on a Win XP Pro SP3 machine.
FYI: I get the same error ("list index out of range") with slightly different line numbers for Papywizard 2.1.7.
Best regards,
Matthias
by fma38 » Wed May 13, 2009 4:38 pm
When I see 'None' , I use the previous position. But if 'None' is use on the first position, there is no previous one! So it fails... To solve your problem, just put "0." instead of "None".
claudevh
by claudevh » Wed May 13, 2009 4:48 pm
Hi mm
Welcome on board !
http://www.autopano.net/wiki-en/action/view/Merlin-Orion-Papywizard_users_feedback#mm
Could-you fill your user profile (I.E. Where you live) and give some info's on your Camera, lenses, Platform for Papywizard, interface for Merlin etc...
This could help us for giving help and knowing you !
:cool:
:cool: Claude :cool:
by mediavets » Wed May 13, 2009 5:08 pm
mm wrote:Hi folks!
When I put this file into my home directory ....
Matthias
Matthias,
Welcome to the forum.
I had a quick look at your custom preset.
That's gonna be one hell of a 360x180 - what camera body and lens are you using, and what is the focal length you plan to shoot at?
What will you do with such a hi-res spherical?
BTW there's no need to put your custom preset in any special directory nor to give it any special name if you are happy just to load custom presets on a session-by-session basis, in which case you can use the File/Import Preset File... command.
I like to have my custom presets each in a separate file with a name I can easily identify, such as nikkor105.xml, and then I load whatever preset I need for each shoot rather than making all my custom presets part of the default set.
mm
by mm » Wed May 13, 2009 5:18 pm
@Frédéric
D*h, so damn simple... ;-)
Indeed, that did the trick - I thought "None" was a special value for zenith/nadir when I copied the positions from the default preset file.
Thanks alot!
@claudevh
Thank you for your warm welcome!
I will provide more information to my user-profile as soon as I have figured out what setup I will use... :-)
@mediavets
Sorry for me answering so lately - I somehow overlooked your message...
This is a rough preset for a 105mm lens on a cropped Canon with tons of overlap.
It is more or less a mere test case - I mainly want to extract arbitrary rectilinear views afterwards for integrating them as zoomable "areas of interest" into a low-res version of the panorama.
In other words: I am just playing around... ;-)
Best regards,
Matthias
claudevh
by claudevh » Mon May 18, 2009 3:53 pm
Hi Frederic,
Could you cange the URL of the Manual in the Help menu (still the old one http://trac.gbiloba.org/papywizard/wiki/UserGuide)
by fma38 » Mon May 18, 2009 4:41 pm
This is already done in the current subversion files ;)
claudevh
by claudevh » Mon May 18, 2009 5:28 pm
fma38 wrote:This is already done in the current subversion files ;)
Hi Frederic,
2.1.7-1 Windows is the version on my Laptop and this send still allways to :
:rolleyes:
by fma38 » Mon May 18, 2009 10:22 pm
Yes, because I made the change after the 2.1.7 release ('current subversion files' means commited in the version manager, but not yet in a named release).
Let's try the 2.1.8 I just uploaded ;) There is also the extension of the mosaic limits to 200x200...
sjhenry
by sjhenry » Tue May 19, 2009 3:02 am
I finally updated my user profile on the wiki.
Jones
irpano
by irpano » Tue May 19, 2009 6:50 am
Frederic. FYI -I have downloaded and installed PY 2.1.8 successfully and it works on my Vaio windows XP SP3
The configuration box at startup is a good idea and alerts the user to perform the confi before connection and shooting. If I may suggest a little further instruction in the message , especially for the first time users. Otherwise Good Job
John
by fma38 » Tue May 19, 2009 6:59 am
What would you like to see, in the message? I was thinking to also open the Configuration dialog after the first one is closed, at the Plugins tab (or at the first one, don't know)... What do you think?
PreviousNext
