interface with usb server, usb router and laptop question
AerialVr
by AerialVr » Thu Jan 15, 2009 6:08 pm
I was thinking i would use my laptop because i want to use remote contorl software for the rebel xsi. would it work if i used a usb to ttl converter cable into a usb server on top of a 50′ pole with a usb router on the ground conected to a laptop running papywizard? the other thing i may do with this is put it on a tethered blimp
usb server http://www.silexamerica.com/sx-2000wg.html
usb to ttl cable http://www.makershed.com/ProductDetails.asp?ProductCode=TTL232R&Redirected=Y
router http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1065011&CatId=2667
Thanks in advance for any insight on this
chris blake
by mediavets » Thu Jan 15, 2009 6:41 pm
Chris,
Why make it so complicated?
Blutooth has sufficient range to provide the connection from Papywizard running on your laptop to the Merlin head.
For USB connection to the camera you could use any of the many USB extender systems, such a this:
http://www.keene.co.uk/electronics/multi.php?mycode=C5USB
Or am I missing something?
AerialVr
by AerialVr » Thu Jan 15, 2009 6:57 pm
don't really need it to be wireless on the 50' pole but i may also want to put it on a blimp and that could be up to 500' . don't know if bluetooth can go that far
by mediavets » Thu Jan 15, 2009 7:09 pm
AerialVr wrote:don't really need it to be wireless on the 50' pole but i may also want to put it on a blimp and that could be up to 500' . don't know if bluetooth can go that far
Then in this case you may be better of with KAP type rig, or the sort of rig people use on model helicopters, using RC - rather than Merlin?
AerialVr
by AerialVr » Thu Jan 15, 2009 7:15 pm
i have a rig like that for the blimp the point was more that if i am going to buy a wireliess interface that will allow me to run the remote control software from canon i might as well have a link that would do the distance for the blimp as well even though i don't need it for the pole
by mediavets » Thu Jan 15, 2009 7:43 pm
What do want to achieve with the camera remote control software over a wireless connection?
claudevh
by claudevh » Thu Jan 15, 2009 8:48 pm
Hi Chris,
The answer for the bluetooth is "NO" ... with the best of class bluetooth (BT class 1) you can go to +/- 300' but both bluetooth' (emitor and receiver) should be "BT class 1)!
AerialVr wrote:I want to use remote contorl software for the rebel xsi. would it work if i used a usb to ttl converter cable into a usb server on top of a 50′ pole with a usb router on the ground conected to a laptop running papywizard?
I presume that you want control your REBEL XSI with "Live View Function that can be used remotely via a computer through the EOS Rebel XSi’s USB connection and Image transmission to your PC" !
In this case the answer is "YES" but for the control of the Merlin with Papywizard you should use a "Usb to RS232 converter cable" and not a "Usb to TTL convertor" connected with the Tronisoft module 4207 who is connected directly on the Merlin !
http://www.tronisoft.com/4207.php
Nice project !
:cool: Claude :cool:
AerialVr
by AerialVr » Thu Jan 15, 2009 8:58 pm
thanks Claude!
in fact i have a usb to serial converter in the drawer collecting dust. I called the mfg of the usb server and the stock range for that is about 100' good for the pole but i guess ill need some signal amplifiers and better antennas to make the jump to the blimp for high shots. most of the time 100' is plenty
Chris
by fma38 » Thu Jan 15, 2009 9:21 pm
claudevh wrote:In this case the answer is "YES" but for the control of the Merlin with Papywizard you should use a "Usb to RS232 converter cable" and not a "Usb to TTL convertor" connected with the Tronisoft module 4207 who is connected directly on the Merlin !
Or just use the USB-TTL cable directly, in place of the Tronisoft interface. Adding the 2 resistors should work (but I didn't try this cable...).
AerialVr
by AerialVr » Wed Jan 21, 2009 3:55 pm
with a wireless conection for camera control. the files will write to the laptop and i can change any setting as if the camera was in my hand. also provided remote viewfinder . see
http://www.breezesys.com/DSLRRemotePro/index.htm
AerialVr
by AerialVr » Wed Jan 21, 2009 4:22 pm
Hi Frédéric
can you tell me how one cable would connect to the other? the usb cable has 6 wires and the cable going into the merlin has 4. I can solder but i don't understand the pinouts
chris
BeeZed
by BeeZed » Wed Jan 28, 2009 10:45 pm
I don't know the specifics of the cable you want to use, but the orion info here may help: http://www.autopano.net/forum/p27797-2008-08-14-07-08-41#p27797
by mediavets » Wed Jan 28, 2009 10:56 pm
AerialVr wrote:Hi Frédéric
chris
Are you talking about this cable?:
usb to ttl cable http://www.makershed.com/ProductDetails.asp?ProductCode=TTL232R&Show=ExtInfo
AerialVr
by AerialVr » Wed Jan 28, 2009 11:09 pm
yep thats the one. my question is do i need to wire the power and ground since the cable will already have power from the usb port and the mount has power as well.
thanks
Chris
by fma38 » Wed Jan 28, 2009 11:12 pm
AerialVr
by AerialVr » Wed Jan 28, 2009 11:17 pm
thanks i missed that
