[Papywizard v2] Open talk - general design, ideas...
by fma38 » Thu Apr 08, 2010 6:08 pm
I still have to do that :P
by fma38 » Wed Apr 14, 2010 2:22 pm
Ok, I implemented it through a menu entry.
panoguy
by panoguy » Mon Apr 19, 2010 5:18 pm
not sure if this on the feature list already?
it would be useful to display the battery voltage level of the motorized head in Papywizard.
An additional command could request the battery level from the slave, let's say after each shot
and update a small graph in Papywizard.
For example a command like:
A<axis> x (where x could be a plain value from 0-10)
The value would represent 0 to 100% and could be used regardless of how many batteries (total voltage) are used to drive the head.
by fma38 » Mon Apr 19, 2010 5:53 pm
That's a good idea. I put it on my TODO list...
by mediavets » Tue Apr 20, 2010 8:56 am
fma38 wrote:That's a good idea. I put it on my TODO list...
But would it actually be useful?
My understanding is that the nature of the NiMH discharge curve is such that it would not be useful.
"NiMh cells maintain most of their voltage for about 80% of their discharge cycle even at high discharge rates.":
http://www.starbatteries.com/dischargecurve.html
Here's how different battery types vary WRT discharge curves:
http://www.mpoweruk.com/performance.htm
Info about battery monitoring:
http://homepages.which.net/~paul.hills/Circuits/BatteryMonitor/BatteryMonitor.html
panoguy
by panoguy » Tue Apr 20, 2010 12:15 pm
Who is still using NiMh cells ??? even the good old NiCd cells had much higher lifetime :lol:
Of course I was thinking of Lithium Ion or Lithium Fe cells.
by mediavets » Tue Apr 20, 2010 1:02 pm
panoguy wrote:Who is still using NiMh cells ??? even the good old NiCd cells had much higher lifetime :lol:
Same issue, I think - a very flat discharge curve.
Photosbykev
Likes: 9 posts
Liked in: 4 posts
by Photosbykev » Wed Apr 21, 2010 11:35 pm
I used the Merlin head on Monday to try to track the sun during a timelapse video using the x1 tracking speed. When the video was processed it was clear that the head was travelling faster than the sun. The timelapse session took 2 hours and the sun was clearly lagging the sun as shown in the vimeo video here http://vimeo.com/11070686. Why it was lagging has been explained by a user on the Timelapse forum site i.e. the sun at the horizon doesn't visually travel at 15 degrees/hour it is nearer 12 degrees/hour.
Using the N800 and papywizard how difficult would it be to programme the merlin to run at the slower speed i.e 12 degrees/hour? or it a non-starter?
regards
Kev
by fma38 » Thu Apr 22, 2010 8:19 am
Kev, Papywizard is dedicated to panoramic shooting; I recently decided not to add timelapse features, as it is a very different usage. Putting all in the same app would lead to a complex GUI and a messy code.
As I already said, I'm about to build our new house, and don't have time to write a timelapse dedicated app. But I will as soon as I have finished our house (end of 2011, I hope), unless someone else develop such app.
claudevh
by claudevh » Thu Apr 22, 2010 9:15 am
Hello Kev,
I can't see your video on Vimeo !?! :(
You have the "Non-Goto" mount, I believe ...
Normally this one have only "sideral rates"
The "Goto Version" have (via the hand controler) Sideral, Lunar and Solar rates ...
By composing a "timelapse preset" you should normally be able to simulate the "Solar rate" but this will not be so easy ! :rolleyes:
You sould post in forums for astronomy in order to get more info's !
:cool: Claude :cool:
by klausesser » Thu Apr 22, 2010 11:56 am
fma38 wrote:As I already said, I'm about to build our new house . . .
Did you plan a listening room for your audio already? :cool:
best to you and your family, Klaus - and have fun building your new home!
Paul
by Paul » Thu Apr 22, 2010 2:10 pm
claudevh wrote:I can't see your video on Vimeo !?! :(
try this link: http://href.to/eHR
Paul
Photosbykev
Likes: 9 posts
Liked in: 4 posts
by Photosbykev » Thu Apr 22, 2010 6:12 pm
Thank you Paul I slipped a random fullstop into the url http://vimeo.com/11070686
Fma: thanks for the response I fully understand your priority, I've been there lol. I use papywizard for running the merlin for panos very successfully, it's a great piece of software. The reason for querying the use for programming the speed of the merlin was purely because the interfacing and control between the n800/merlin has already been done.
Claude: I'm part way through the design for a panning mount of my own :) This is specced to have a infinitely variable speed control from as low as 10 degrees/hour and should be able to handle my Canon 7D and 600mm prime lens.
tived
by tived » Fri Mar 04, 2011 3:32 am
on a side note, Kevin, you have some lovely shots on your website!!!
Henrik
A Dane Down Under
ReflectorBlock
by ReflectorBlock » Tue May 15, 2012 1:33 pm
Is it possible to drive manually to specific position with the papywizard?
The best soultion would be, if I can enter pitch and yaw, and press a "go to" button. After that the photohead moves to this position ( ex. 35° / 20° ).
I use the merlin photohead and papywizard for doing some measurements with a Reflector Block which we track with a infrared camera.
We have an algorithm to process the current position of the reflector block from the images of the camera.
It would be very nice to add this feature to papywizard or someon can tell me how to do this.
Last edited by ReflectorBlock on Tue May 15, 2012 1:35 pm, edited 1 time in total.
by mediavets » Tue May 15, 2012 2:22 pm
ReflectorBlock wrote:Is it possible to drive manually to specific position with the papywizard?
Welcome to the forum....
I think this is what you are looking for?:
ReflectorBlock
by ReflectorBlock » Wed May 16, 2012 8:00 am
Great, that is that waht I'm searching for.
But in my version of the software the menu looks different.
I am using version 2.0.0.
Which version of papywizard should I use?
by mediavets » Wed May 16, 2012 8:16 am
ReflectorBlock wrote:Great, that is that waht I'm searching for.
Use what's termed the latest development version - v. 2.1.21:
http://www.papywizard.org/wiki/Download#Developementversions
Previous
