N800 users wanted for testing Papywizard 1.5.6-1.
by mediavets » Wed Jan 07, 2009 12:00 pm
* Calling all Nokia N800 and N810 Tablet users. *
Frederic needs more Nokia N800/N810 Tablet users to test with the latest development version of Papywizard - 1.5.6-1:
http://trac.gbiloba.org/papywizard/#Developpementversion
http://www.gbiloba.org/download/papywizard/papywizard_1.5.6-1_all.deb
I find it doesn't load and run on my Nokia N800 which is running the latest update of the OS2008 operating system and, at the moment, we cannot figure out why this is. 1.5.6-1 runs OK on the Nokia 770 Tablet, and Frederic has also tested it on Linux and Windows and it also runs OK on those platforms.
So it would be very helpful if other N800/N810 users could try 1.5.6-1 too and report their experiences here.
Don't worry about trying 1.5.6-1 - if it doesn't work you can always easily uninstall it from the Application Manager and re-install 1.5.4-1 which works fine:
http://www.gbiloba.org/download/papywizard/papywizard_1.5.4-1_all.deb
by klausesser » Wed Jan 07, 2009 2:28 pm
Hi Andrew, hi Frédéric!
I loaded PW via my N800. Information says "0,0MB" (!!??)
Proceeding it updated the pevious version nevertheless.
Appl. manager says PAPYWIZARD 1.5.6.1 and 1,7MB.
Starting PW flashes a white screen - that´s all.
Loaded the 1.5.4.1 version again - works ok.
by mediavets » Wed Jan 07, 2009 2:36 pm
klausesser wrote:Hi Andrew, hi Frédéric!
Thanks - that's just what 1.5.6-1 does on my N800.
Can you check in the Settings/Control Panel/About product on your N800 and report the Version data of the OS2008 on your Tablet (mine is 5.2008.43-7).
by fma38 » Wed Jan 07, 2009 2:57 pm
Andrew, what about the latest version I sent to you?
by klausesser » Wed Jan 07, 2009 3:40 pm
mediavets wrote:Can you check in the Settings/Control Panel/About product on your N800 and report the Version data of the OS2008 on your Tablet (mine is 5.2008.43-7).
Sorry - i forgot. So is mine!
by mediavets » Wed Jan 07, 2009 4:07 pm
fma38 wrote:Andrew, what about the latest version I sent to you?
I have sent email.
Basically the same behaviour as before, and the log looks the same to me at first glance. :(
Is it worth asking Klaus to test that version too - in case there's something different between out N800s even if they report using the same version of OS2008?
Is it worth my re-flashing and starting over?
by fma38 » Wed Jan 07, 2009 4:17 pm
No, I don't think reflashing will change anything...
Klaus, if you want to make a test with the latest version, it is here:
http://www.gbiloba.org/download/tmp/papywizard_1.5.6-1_all.deb
by fma38 » Wed Jan 07, 2009 4:22 pm
Andrew, can you tell me what pygtk versions are installed on your 770 and N800?
$ apt-cache show python2.5-gtk2 | grep Version
by mediavets » Wed Jan 07, 2009 5:21 pm
fma38 wrote:Andrew, can you tell me what pygtk versions are installed on your 770 and N800?
Looks like you may be on the right track?
They are different.
For 770:
~ $ apt-cache show python2.5-gtk2 | grep Version
Version: 2.10.3-1osso9
Version: 2.10.3-1osso8
Version: 2.10.3-1osso6
Version: 2.10.3-1osso5
Version: 2.10.3-1osso4
Version: 2.10.3-1osso3
For N800:
Version: 2.12.1-1osso4
Version: 2.12.1-1osso3
Version: 2.12.1-1osso2
Version: 2.12.1-1osso1
Version: 2.12.0-1osso5
Version: 2.12.0-1osso4
Version: 2.12.0-1osso2
by klausesser » Wed Jan 07, 2009 5:29 pm
fma38 wrote:No, I don't think reflashing will change anything...
Hi Wizard :cool:!
I trid already - the same behavier as two hours ago!
by fma38 » Wed Jan 07, 2009 8:36 pm
Are you sure you tried it *after* I posted the message? I uploaded a new version with the same name... It seems that it is working for Andrew. Can you confirm?
by mediavets » Wed Jan 07, 2009 8:48 pm
fma38 wrote:Are you sure you tried it *after* I posted the message? I uploaded a new version with the same name... It seems that it is working for Andrew. Can you confirm?
Yes, Klaus do try it again - during the testing and debugging process Frederic has posted several variations under the same filename - it is only the most recently posted version of 1.5.6-1 that worked for me.
The URL for this version is:
Not the same as the URL for downlaoding from the link on the Wiki.
by fma38 » Wed Jan 07, 2009 9:02 pm
by mediavets » Wed Jan 07, 2009 9:02 pm
Frederic,
I am using 1.5.6-1 from the Wiki on 770:
1. Fullscreen function is not working.
2. Head speed change is not working.
3. Menu/File causes program to crash.
I am using your most recent 'special' version of 1.5.6-1 on the N800:
3. License and Credits buttons not working.
by fma38 » Wed Jan 07, 2009 9:13 pm
Can you open the shoot dialog? Does it work?
by mediavets » Wed Jan 07, 2009 9:21 pm
fma38 wrote:Can you open the shoot dialog? Does it work?
On N800?
Yes, I can open the Shoot dialogue and it works.
by fma38 » Wed Jan 07, 2009 9:26 pm
Strange, because I have the same thing in this dialog than in the main dialog which causes the problem...
by mediavets » Wed Jan 07, 2009 9:48 pm
Frederic
I have now installed latest 'special' dev 1.5.6-1 on 770 - strange to go back to the 770 I'd forgotten how much more generally sluggish a 770 is compared to an N800.:
1. Got Logger window on first run after install, but ran OK after re-boot.
2. Menu/File causes program to crash.
3. Licence and Credits buttons ARE functional (weren't on N800).
4. I can open Shoot dialogue and it works.
by fma38 » Wed Jan 07, 2009 11:29 pm
Did you try to re-install the version xx-crash, to confirm the problem?
http://www.gbiloba.org/download/tmp/papywizard_1.5.6-1-crash_all.deb
by mediavets » Thu Jan 08, 2009 12:19 am
fma38 wrote:Did you try to re-install the version xx-crash, to confirm the problem?
Yes, I have reinstalled it and can confirm that version xx-crash does not run on N800.
by mediavets » Thu Jan 08, 2009 12:29 am
I have re-installed version xx-crash on 770.
It does run and Shoot dialogue open and works.
BUT Menu/File crashes the program.
by fma38 » Thu Jan 08, 2009 7:42 am
Ok, thanks.
by mediavets » Thu Jan 08, 2009 3:24 pm
fma38 wrote:Ok, thanks.
Which variant of 1.5.6-1 is currently linked to the Dowmlaod section of the Papywizard wiki?
by fma38 » Thu Jan 08, 2009 3:31 pm
An old one, the first I've generated.
by fma38 » Thu Jan 08, 2009 10:16 pm
mediavets wrote:Frederic
Is it the same behaviour on the N800?
