[Papywizard] Alternate shooting area (text mode)
by fma38 » Fri Nov 28, 2008 12:42 pm
An alternate shooting area without graphical representation of the mosaic has been requested. When there are too much shooting position, this can be usefull to show less things.
Do you have any idea of the informations you would like to see, and how to present them?
by klausesser » Fri Nov 28, 2008 1:27 pm
fma38 wrote:An alternate shooting area without graphical representation of the mosaic has been requested. When there are too much shooting position, this can be usefull to show less things.
Hi Frédéric!
I can´t see an advantage in that - it could be very small lines when shooting extremely many pictures, ok. But the alternative could be a blank plane or a plane filled with dots . . how could that be helpful?
Maybe to make the shooting area scrollable when it has to expand?
by mediavets » Fri Nov 28, 2008 1:42 pm
Hi Frédéric!
I'm not sure but I think what people who requested this may have had in mind was a simple display of numbers - such as the row and column numbers of last or current or next shooting position plus something like number of shots taken/of total number in the matrix?
by fma38 » Fri Nov 28, 2008 2:01 pm
Yes, that's the idea: no graphical representation, but a summary of total positions, and current/next position to shoot...
by klausesser » Fri Nov 28, 2008 2:03 pm
mediavets wrote:I'm not sure but I think what people who requested this may have had in mind was a simple display of numbers - such as the row and column numbers of last or current or next shooting position plus something like number of shots taken/of total number in the matrix?
Oh - i see . . :cool:
by fma38 » Fri Nov 28, 2008 4:35 pm
Is something like that OK?
Paul
by Paul » Fri Nov 28, 2008 4:53 pm
is it possible to add something like Current: n of nn, row n of nn, col n of nn ?
where n is actual and nn is total
Paul
by fma38 » Fri Nov 28, 2008 5:21 pm
In the Shooting position widget, you have both angle and index in the mosaic. I also added a widget with the total number of pictures for yaw and pitch.
by mediavets » Fri Nov 28, 2008 5:40 pm
Can/could you make the numbers LARGE and BOLD and black on a white ground so that they are easy to read outdoors at a glance?
by fma38 » Fri Nov 28, 2008 6:52 pm
They will be bold, as in other windows (this is done in the controller, not in the GUI editor).
