I'd like to know if it is possible to connect directly the output RSR 232 of the laptop by wire with the input of the HANDCONTROLLER of the PANOHEAD MERLIN?
AmdAntonio wrote:I'd like to know if it is possible to connect directly the output RSR 232 of the laptop by wire with the input of the HANDCONTROLLER of the PANOHEAD MERLIN?
Antonio
No, it is not possible to connect directly.
You need an RS232-TTL adapter in between.
The simplest and cheapest way of assembling such an adapter is to start with the Tronisoft 4201 RS232-TTL module: http://www.tronisoft.com/4201.php
Andrew Stephens Many different Nodal Ninja and Agnos pano heads. Merlin/Panogear mount with Papywizard on Nokia Internet tablets. Nikon D5100 and D40, Sigma 8mm f3.5 FE, Nikon 10.5mm FE, 35mm, 50mm, 18-55mm, 70-210mm. Promote control.
