[papywizard v1] Annoncement, feedback, bug report
by fma38 » Thu Jan 10, 2008 12:36 pm
I finally chose papywizard for the name of my software. I installed a subversion repository (versionning system), and un bug-tracker:
http://trac.gbiloba.org/papywizard
You can download a specific revision under TAGS, or the current dev. version under TRUNK. Use the button at the botom of the page to get a zip containing all files. I'll soon add a link for the windows binary.
by fma38 » Fri Jun 06, 2008 12:34 pm
Just to say that the 0.9beta2 version of papywizard is out (see link on previous post).
There is now a debian package usable for maemo plateform (Nokia 770, 800 et 810). Windows is not more supported at this time, but should be back in the future (only on PC, as the new graphic toolkit used for maemo does not exist for WindowsCE).
If you have a Nokia, please let me know if it installs and works correclty. For the 770, you need to upgrade the firmeware to the Hacker Edition. Feel free to contact me for more informations.
by klausesser » Fri Jun 06, 2008 2:47 pm
fma38 wrote:Just to say that the 0.9beta2 version of papywizard is out (see link on previous post).
Hi Frédéric!
That´s coincidence: yesterday i got my Nokia N800! :) Now i´m thinking about what i have to do . . . . - never had to do with such things . . but i´ll dig it (i hope) :cool:
(and thanks for your great work!!!)
by fma38 » Fri Jun 06, 2008 3:09 pm
Look at http://trac.gbiloba.org/papywizard/wiki/UserGuide#Nokia
Feel free to ask if you can't install it.
by klausesser » Fri Jun 06, 2008 8:02 pm
fma38 wrote:Look at http://trac.gbiloba.org/papywizard/wiki/UserGuide#Nokia
i´m sure, i´ll have to . . :cool:
Thank you and best from Düsseldorf, Klaus
by fma38 » Thu Jun 26, 2008 8:38 pm
Ok, the first stable release (0.9) is out!
See link at top of this thread...
by fma38 » Fri Sep 19, 2008 11:19 pm
Here it is, the 1.0 release of papywizard is out ;) The main new feature is the preset mode, which is dedicated to full-spherical panos. There are several other new minor features ; I let you discover them:
http://trac.gbiloba.org/papywizard/browser/tags/1.0/ChangeLog
If you have questions, remarks or requests, feel free to ask.
by klausesser » Sun Sep 21, 2008 1:37 pm
fma38 wrote:Here it is, the 1.0 release of papywizard is out ;) The main new feature is the preset mode, which is dedicated to full-spherical panos. There are several other new minor features ; I let you discover them:
Hi Frédéric!
The actualized version on my N800 doesn´t run at all - it doesn´t start!
I ran the usual actualization process on the Nokia N800.
by klausesser » Mon Sep 22, 2008 8:43 pm
Hi @all!
I think it should been said in plublic:
THIS IS A GREAT program, you made there, Fédéric! Even more intuitive and comfortable as before (after my son told me how to install it properly on my Nokia N800 - i missed some parts . . :rolleyes: ).
Thank you!
by fma38 » Mon Sep 29, 2008 7:46 pm
Good news, papywizard now runs under windows! Here is the installer for the dev version, which will soon be the 1.1:
http://www.gbiloba.org/download/tmp/Install.exe
(the file will remain on my server for only 1 month, but the stable release should be out
(I'm not sure the bluetooth works, because I can't test it : my VirtualBox doesn't support USB, so my bluetooth dongle don't work. Any feedback welcome).
Thanks to claudevh for his help and his patience for the many tests he made!
Paul
by Paul » Mon Sep 29, 2008 8:00 pm
Just one Q:
Windows Mobile too?
Cheers
Paul
Paul
by fma38 » Mon Sep 29, 2008 9:32 pm
No; as far as I know, PyGTK does not exist on it...
Note that the installer is for Windows 32 bits only (XP and Vista). I don't have a Vista 64 bits to install in my VirtualBox...
by fma38 » Mon Oct 06, 2008 9:30 am
The windows installer of the svn version is now in a more central place:
http://trac.gbiloba.org/papywizard/wiki/WikiStart#Developpementversion
Bluetooth still does not work (don't know why), but serial is OK (even with usb adapters).
by fma38 » Tue Oct 14, 2008 8:54 am
Here is a new dev. version (Nokia et windows) before 1.1 release:
Paul
by Paul » Tue Oct 14, 2008 9:30 am
shooting window status line: the text is french "Repos", "Deplacement" ...
cheers
Paul
Paul
by fma38 » Tue Oct 14, 2008 9:35 am
Strange... Are the other translations OK?
Paul
by Paul » Tue Oct 14, 2008 9:39 am
I did not found the activation of other languages.
If I hit N770s "+" or "-" the text in the bottom line is also french: "Debut de lacet ..." "Fin den lacet..."
Paul
by fma38 » Tue Oct 14, 2008 9:46 am
Paul wrote:I did not found the activation of other languages.
I mean, other words/sentences of the german translation... But this is a good idea: I'll add an option to force the language.
It seems that only the german strings of the GUI are correctly loaded, not the ones written from the code. I'll try something, and put another installer soon.
Paul
by Paul » Tue Oct 14, 2008 10:26 am
How is Papywizard supposed to behave? Auto-language depending on N770 settings?
My N770 (OS2007HE) is set to "german language", Papywizard shows all texts in english except those I mentioned above.
Paul
by fma38 » Tue Oct 14, 2008 10:30 am
Paul, could you try under windows? Is it the same?
Yes, Papywizard tries to detect the system settings. There are differents vars which should contain the available languages, and some may not be correctly set.
Do you have xterm installed on your Nokia? If you do, could you test this, from the python interpretor (launch 'python' command from xterm):
import os
os.environ.get('LANGUAGE', 'empty')
import locale
locale.getdefaultlocale()
If other people using a Nokia could also do this test, it will help...
Thanks!
by fma38 » Tue Oct 14, 2008 10:39 am
If you don't have xterm, try this version:
http://www.gbiloba.org/download/tmp/papywizard_r876-2_all.deb
(install from the navigator).
Then launch the app. In the Configure > Misc tab, set the logger level to debug. Close Papywizard and launch it again. Then open Help > See logs, and copy the logs related to l10n() method...
by mediavets » Tue Oct 14, 2008 10:41 am
fma38 wrote:Paul, could you try under windows? Is it the same?
Yes, many of those messages on the (English) Windows version are in French.
Paul
by Paul » Tue Oct 14, 2008 10:44 am
Sorry, can't try windows.
N770 xterm python tells me: ('de DE, 'ISO8859-1')
Paul
by fma38 » Tue Oct 14, 2008 11:29 am
Thanks for reporting this bug.
Paul, what is also the result of the os.environ.get('LANGUAGE', 'empty') command?
Paul
by Paul » Tue Oct 14, 2008 11:39 am
fma38 wrote:Paul, what is also the result of the os.environ.get('LANGUAGE', 'empty') command?
result is: 'empty'
Paul
