User Experience Of Batteries And Battery Life
by mediavets » Mon Nov 03, 2008 7:07 pm
I've not yet had an opportunity to run my Merlin head on battery power because the battery holders were missing when it was delivered. But I am due to receive a replacement tomorrow.
FWIW the Merlin worked fine using a 12V 500ma mains adapter.
I am interested in hearing about user experiences with batteries and battery life with the Merlin head.
What batteries are you using?
What would you reommend?
What sort of battery life are you getting?
Do you have/use an 8 battery charger?
Are you using very high speed chargers?
by fma38 » Mon Nov 03, 2008 7:39 pm
I use Ni-mH batteries. I didn't yet make tests, but I think the (used) Nokia batteries will be the problem.
by klausesser » Mon Nov 03, 2008 9:03 pm
mediavets wrote:I've not yet had an opportunity to run my Merlin head on battery power because the battery holders were missing when it was delivered. But I am due to receive a replacement tomorrow.
I tested a campact battery from a motorcycle - fixed it to a tripod-leg. Worked fine - would have done it constantly for some days i think . . :cool:
For my N800 i´m gonna get a scond accu . . but here also i´m looking for a bigger one which connects at the load-jack.
by fma38 » Mon Nov 03, 2008 9:14 pm
I wonder if it could not be possible to power the Nokia from the Merlin... Don't know if it requires a special electronic (constant curent source), or not...
by mediavets » Mon Nov 03, 2008 9:56 pm
fma38 wrote:I wonder if it could not be possible to power the Nokia from the Merlin... Don't know if it requires a special electronic (constant curent source), or not...
Would that not rather undermine the notion- and benefits - of having a wireless connection between the head and the Papywizard host system?
What aspect of Papywizard running on Nokia uses so much (most) power - is it the Bluetooth?
Ar people using genuine Nokia batteries in their Tablets or third party batteries?
by mediavets » Mon Nov 03, 2008 9:59 pm
Seems some have found a way to extend battery autonomy for Nokia Tablets:
http://www.theinquirer.net/gb/inquirer/news/2007/10/12/nokia-n800-external-battery
http://blog.russnelson.com/770/N800-external-battery.html
http://www.internettablettalk.com/forums/showthread.php?t=18860
claudevh
by claudevh » Mon Nov 03, 2008 11:17 pm
It is possible to use an "external battery" with the reference "EDC004U".
You can find it by a search on Google.
For France you can find-it by following the next link :
http://www.globale-batterie.com/advanced_search_result.php?osCsid=74017e5747b5f705d2b1706964272b28&keywords=EDC004U
Claude
:cool:
:cool: Claude :cool:
BeeZed
by BeeZed » Mon Nov 03, 2008 11:27 pm
I just finished assembling my unit yesterday, so I can't speak to battery tests. ( A thanks to everyone who has written about their experiences, and a big thanks to Frederic for Papywizard!)
I was thinking of exploring the use of those rechargeable batteries used in cordless drills. They come in 9v or 12V and are relatively compact. My local recycle centre often has them for a couple of dollars. If they worked, it might be worth buying a new one.
My Nokia 770 came with a 12V car charger. I wonder if I could adapt it to run off of the Orion power out. It could be handy for emergencies.
claudevh
by claudevh » Mon Nov 03, 2008 11:29 pm
by mediavets » Mon Nov 03, 2008 11:50 pm
claudevh wrote:It is possible to use an "external battery" with the reference "EDC004U".
Claude
:cool:
And for the US:
http://www.digital-camera-battery.net//Universal-External-battery/EDC004U.htm
And for the UK:
http://gogo-power.co.uk/product_info.php/products_id/2904
by mediavets » Wed Nov 05, 2008 8:57 pm
If shooting using Papywizard on a Nokia Tablet is it worth shutting down the Bluetooth connection between pano shoots to extend battery autonomy - or does it make no difference?
by fma38 » Wed Nov 05, 2008 9:12 pm
Yes, bluetooth uses a lot of current. Shutting it down is a good idea. As well as turning off the display (using the power button followed by the square button.
by mediavets » Wed Nov 05, 2008 9:59 pm
fma38 wrote:Yes, bluetooth uses a lot of current. Shutting it down is a good idea. As well as turning off the display (using the power button followed by the square button.
OK - thanks for the tips.
But that implies that it would be good to turn off the BT-RS232-TTL combo device interfacing with the Merlin head too? Currently there is only one way to do this - physically disconnect the RJ11 cable or turn off the whole head - would you advocate doing this too?
by fma38 » Wed Nov 05, 2008 10:03 pm
Yes, better switch off the head.
by mediavets » Thu Nov 06, 2008 3:10 pm
External lead acid battery packs - good for Merlin?:
http://www.opticalvision.co.uk/astronomical_accessories/power_tanks
by fma38 » Thu Nov 06, 2008 4:09 pm
Yes, sure. 9V is enough.
