Install Papywizard On Nokia 770, N800 And N810
by mediavets » Tue Oct 21, 2008 5:05 pm
fma38 wrote:r918 also used to crash for me, but does not crash anymore. But then, r927 crashes... Did you try without gpe-filemanager?
I have uninstalled gpe-filemanager and shut down and restarted the tablet and, yes, it still crashes on the Help menu with r927.
fma38 wrote:Uninstalling an application never removes the preferences in you home dir; it just removes system-wide preferences...
And this is OK? I mean when you install a newer version of Paywizard is it OK to leave this file or should you remove it before installing a newer version?
by fma38 » Tue Oct 21, 2008 6:09 pm
As long as the application starts, it is safe to leave it. If you have a traceback at startup, related to config flle, them remove it. This problem should only occurs when using dev releases... I'm working on a better config file version handling...
by mediavets » Tue Oct 28, 2008 11:07 am
Might this help simplify installation of Papywizard on Nokia Internet Tablets?:
http://www.gronmayer.com/it/index.php?lang=en&system=maemo3
by fma38 » Tue Oct 28, 2008 11:15 am
Good idea! I'll add an entry...
edit: done!
by mediavets » Tue Oct 28, 2008 11:30 am
fma38 wrote:Good idea! I'll add an entry...
edit: done!
And entries for repositories needed to install gpe-filemanager and osso x-term?
I guess there's no way to simplify installation of the Python run-time stuff?
by fma38 » Tue Oct 28, 2008 1:28 pm
No, I don't think so.
Gordon
by Gordon » Tue Oct 28, 2008 6:51 pm
Install Papywizard on Nokia N95 is this possible?
2000th Member :D
GigaPixel Experimenter
by fma38 » Tue Oct 28, 2008 7:05 pm
Is it running maemo system?
by mediavets » Tue Oct 28, 2008 7:36 pm
As far as I know only Nokia 770, N800 and N810 Internet Tablets run Maemo.
N95 runs S60 software on Symbian OS. It has 320x240 colour display and no touch screen.
http://www.nokia.co.uk/A4275003
Gordon
by Gordon » Thu Nov 13, 2008 12:03 am
mediavets wrote:As far as I know only Nokia 770, N800 and N810 Internet Tablets run Maemo.
OK I see now, I'm going to have a look and and go about getting a Nokia 770, It looks like a nice little Linux box, although I'm not very comfortable with Linux as it's a bit unfamilier, I'll dive in and see what I can do with it and Papywizard.
2000th Member :D
by mediavets » Thu Nov 13, 2008 12:22 am
I wasn't - and am not - 'comfortable' with Linux either. It's best just to not get too anxious about that and to just follow the install instructions to the letter for Papywizard and you'll be fine.
Previous
