[merlin/orion] Interface
claudevh
by claudevh » Tue Oct 27, 2009 10:35 pm
Hi Bruce,
So far I bought a Skywatcher Model S11320
I don't know this model S11320 !
Where do-you buy ?
:cool: Claude :cool:
UrsaMinor
by UrsaMinor » Tue Oct 27, 2009 11:03 pm
blazarus wrote:Hello Tamas (Ursa Minor)
Will your Bluetooth device work with Mac Powerbook? Also will it work with a Nikon D 90 ?
Bruce
To tell you the truth, I do not have Mac, so I cannot test if it works. Somebody in this forum has succes with Mac, please search him comment.
Tamas
claudevh
by claudevh » Tue Oct 27, 2009 11:15 pm
"120to120"
"olihar"
"Macbenutzer"
"RichG"
are Mac users with Ursaminor BT !
See our database of known users:
http://www.autopano.net/wiki-en/action/view/Merlin-Orion-Papywizard_users_feedback
by fma38 » Wed Oct 28, 2009 12:27 am
Bruce, Papywizard is already able to connect to a socket; just give the correct hostname (or IP address), and port.
But you will first have to connect the wifi module. This can be done 2 ways: you either connect all devices to an access point (managed mode), like in a standard network config (the wifi-serial device has to be first configured to use a specific ssid, WEP/WPA key and so), or you connect them together (ad-hoc) mode without access point. The problem with this mode is that you need to configure the wifi chip of your laptop/PC/nokia, and the procedure differs depending on the OS. And it often need to be root/admin. So, I have to dig that point to find a simple procedure.
If you use the wifi-serial device in managed mode, then you can already try it. Just carefully read its documentation.
blazarus
by blazarus » Wed Oct 28, 2009 5:44 am
Hi Guys,
I'm going to give the WIFI a try. I'll report back. I'm still a little worried about the Skywatcher Model S11320 I bought. So if anybody knows anything about this model I'd appreciate the feedback.
Many Thanks,
Bruce
blazarus
by blazarus » Wed Oct 28, 2009 6:58 am
Hi Guys,
I bought this mount with a telescope. Will this mount work? It was $250.00 with telescope. I might use the telescope. It seemed like a good deal. I bought it locally. Didn't want to wait for the mount to come out.
http://www.skywatcherusa.com/multifunction-mount-s21300.html
Bruce
Paul
by Paul » Wed Oct 28, 2009 8:16 am
blazarus wrote:I bought this mount with a telescope. Will this mount work?
Hi Bruce, it will work, this is the non-goto-version, which most of the merliners have - me too.
Paul
claudevh
by claudevh » Wed Oct 28, 2009 10:28 am
Hi Bruce,
As confirmed by Paul..
This is the righ one ! :)
Your experience with the "Wifi" will be key for us !
Could-you inform us on:
- Which type you will buy and where?
- What is the Price?
We will realy be "gratefull" if you can inform us "day by day" ;)
Many thanks in advance. :D
blazarus
by blazarus » Wed Oct 28, 2009 6:56 pm
Hi Guys,
I ordered it Today overnight. This WIFI device will communicate to an ipodtouch. Will Papywizard run on a ipodtouch or a iphone?
Thanks,
Bruce
by fma38 » Wed Oct 28, 2009 9:56 pm
blazarus
by blazarus » Wed Oct 28, 2009 10:46 pm
Hi Frederic,
Take a look at this link http://www.panoscan.com/iPhone.html It might be possible with Papywizard.
Regards
Bruce
blazarus
by blazarus » Wed Oct 28, 2009 11:30 pm
Hi Guys,
I think the Mocha VNC or the Jaadu VNC will work fine with Papywizard. It will make Ipodtouch or Iphone work to control Papywizard without any programming.
Regards,
Bruce
by mediavets » Thu Oct 29, 2009 12:15 am
blazarus wrote:Hi Frederic,
Regards
Bruce
Eevn if it is possible what would be the point of doing this?
blazarus
by blazarus » Thu Oct 29, 2009 5:46 am
Andrew,
Just depends on your uses for it. Take a look at this link... http://www.panoscan.com/iPhoneVid.html
Bruce
by fma38 » Thu Oct 29, 2009 8:50 am
[I can't even see the video!]
If I understand, you need to connect a laptop or so running Papywizard, then control this laptop from your iPhone through VNC?
Greg Nuspel
by Greg Nuspel » Thu Oct 29, 2009 5:10 pm
The problem I see with this if you read the text is you still need a computer to control the camera. The iPhony is using a VNC client that controls your computer remotely. So you could do this right now using a laptop. If any phone systems are to be used I would rather see an Android phone since it isn't tied to one manufacture or network.
--Greg Nuspel
blazarus
by blazarus » Thu Oct 29, 2009 6:09 pm
Frederic,
The video needs quicktime to run.
Bruce
blazarus
by blazarus » Fri Oct 30, 2009 12:24 am
Hi Frederic,
I received the WIFI Serial adapter kit. To complete the project I need the pinout for the DB-9 to the RJ-12 and the location and OHM of the resistors needed. I don't want to guess. Everything else looks fine. It should work. Need a little help.
Thanks,
Bruce
by fma38 » Fri Oct 30, 2009 9:57 am
Bruce, you can't connect the wisnap to the head without a RS232-TTL adapter (like the one Tronisoft used to sell). What I would like to see on this module is if it is possible to get the TTL signal before they turn it to RS232. If not, we will need to add a few transistors, or another MAX232 converter.
blazarus
by blazarus » Fri Oct 30, 2009 3:29 pm
Hi Frederic,
Will any of these work? Have you received yours? I'll wait for your instructions on how to hook it up. I'll still need a pinout. Did you mean resistors? "we will need to add a few transistors"
http://www.rs232-converters.com/RS232_to_TTL_Converter/RS232_to_TTL_Converters.htm
Bruce
by fma38 » Fri Oct 30, 2009 5:55 pm
I'm not sure these devices are OK, because they are powered through RS232... If you don't use such converter, you need transistors, because you have to invert the RS232 signals (+12V -> TTL 0V, -12V -> TTL 5V).
blazarus
by blazarus » Fri Oct 30, 2009 6:07 pm
Frederic,
I'll just wait for you. Did you receive your unit?
Bruce
by fma38 » Fri Oct 30, 2009 6:28 pm
Not yet.
claudevh
by claudevh » Fri Oct 30, 2009 7:17 pm
Hi Bruce,
Could-you please give me the type of WiFi you have ordered ...
So I can have a look on the spec's and help you for the connections to the Merlin head.
blazarus
by blazarus » Fri Oct 30, 2009 7:40 pm
Hi Claudevh,
Follow this link https://serialio.com//store/product_info.php?cPath=23&products_id=613
I ordered the WiSnap Embedded Kit M1. Hope you can help. The user manual resides here http://serialio.com/products/mobile/wifi/software/WiSnapSetup.php
Many Thanks,
Bruce
PreviousNext
