Papywizard web site
Papywizard web site
by fma38 » Fri May 29, 2015 9:45 am
Hi!
The main Papywizard site is often down, and I apologize for that. I can't find the issue. Strange thing is I have other projects using the same app/config (Trac), which work fine...
We are going to upgrade our machine in a few weeks, and upgrade the system too (to latest debian), so it may fix this issue... or not!
So I ported the main documentation pages to the github wiki:
https://github.com/fma38/Papywizard/wiki
Hope this helps.
Best,
Re: Papywizard web site
by mediavets » Fri May 29, 2015 10:35 pm
Thanks. I refer it it quite frequently.
