Panohead Too Fast
jkoenig01
Panohead Too Fast
by jkoenig01 » Tue Jan 27, 2015 8:20 pm
So last night I was tinkering, and I think what happened was I plugged in the hand controller while a command was being sent over bluetooth, and now my "fast" (#5 on the keypad) goto/slew speed is faster than it was, and I don't know how to make it go back. I'm afraid I'll wear something out if I leave it like this.
Any ideas?
Re: Panohead Too Fast
by klausesser » Wed Jan 28, 2015 12:17 am
jkoenig01 wrote:So last night I was tinkering, and I think what happened was I plugged in the hand controller while a command was being sent over bluetooth, and now my "fast" (#5 on the keypad) goto/slew speed is faster than it was, and I don't know how to make it go back. I'm afraid I'll wear something out if I leave it like this.
Any ideas?
Hi!
I guess you´re talking about the Panoshoot?
jkoenig01
by jkoenig01 » Wed Jan 28, 2015 8:06 am
Thanks for responding so quickly.
Sorry, it's the Merlin/Orion head.
Using either the wired keypad or bluetooth it goes faster than normal. Somehow I reprogrammed it's default "fast" speed faster, and it saved it...
When I talk directly to it over bluetooth, I can still tell it to start moving at a specific speed and it works properly. However, when I tell it to go to a specific position either over bluetooth or with the keypad, it's faster than normal.
I also noticed that if I tell it to go to a saved position, it overshoots it, and then slows down and goes back to where it should have stopped...
by mediavets » Wed Jan 28, 2015 9:24 am
What are you using to 'talk directly to it over Bluetooth'?
jkoenig01
by jkoenig01 » Wed Jan 28, 2015 10:17 am
I have a bluetooth-serial adapter and a usb bluetooth dongle. I wrote a python script to send commands to it.
by mediavets » Wed Jan 28, 2015 10:49 am
Do you use papywizard too?
jkoenig01
by jkoenig01 » Wed Jan 28, 2015 11:28 am
I don't normally, but I just checked, and the Move buttons in papywizard make it turn at the proper normal speed. It is not a permanent change though.
--When it does a "Shoot" routine, it too goes at the new faster speed...
by mediavets » Wed Jan 28, 2015 12:06 pm
I'm out of ideas. I cannot imagine how you can have reprogrammed the firmware doing what you said you were doing.
jkoenig01
by jkoenig01 » Tue Feb 24, 2015 8:06 pm
I was able to update the firmware to version 02.09.84, and now it goes at the normal speed again.
*phew*
