Papywizard in an old N770
vaslag
by vaslag » Fri Aug 01, 2014 7:59 pm
I've found an old Nokia N770, and i'm trying to install papywizard to control panogear via bluetooth. Someone had success in installing it in that device? In the help page i've found, some of the links to the packets to install are broken...
Anyone have a copy or a rom flash with papywizard installed?
Thanks,
Re: Papywizard in an old N770
by mediavets » Fri Aug 01, 2014 8:23 pm
vaslag wrote:Hi,
Anyone have a copy or a rom flash with Papywizard installed?
Thanks,
I have Papywizard installed on a 770.
The last version that would run on the 770 is 1.6.
Is there way to transfer it to you?
Alternatively I could sell you an N800 or an N810 with UK keyboard with PW 2.x installed.
by mediavets » Fri Aug 01, 2014 8:33 pm
vaslag wrote:Hi,
Thanks,
What were you unable to find that's required to install PW on the 770.
Install instructions are here:
http://www.autopano.net/wiki-en/action/ ... _Nokia_770
You can get OS2007HE from here:
http://dl.dropbox.com/u/5584801/SU-18_2 ... R0_ARM.bin
vaslag
by vaslag » Fri Aug 01, 2014 8:44 pm
mediavets wrote:
vaslag wrote:Hi,
Thanks,
Thank you,
I've installed the OS2007, and followed this instructions, the problem is that some of the links to the packets needed are broken, and i'm unable to download and install it.
claudevh
by claudevh » Fri Aug 01, 2014 9:54 pm
You can find the Papywizard packages herafter:
[url]http://www.papymerlin.com/télechargement-papywizard/nokia/[/url]
by mediavets » Fri Aug 01, 2014 10:01 pm
vaslag wrote:
mediavets wrote:
vaslag wrote:Hi,
Thanks,
Thank you,
How far did you get with the install process?
I am (now) aware that godmode.deb is unavailable from link in instuctions and I've so far failed to find it anywhere else.
