Which 2.5mm stero jack should I get?
barepixels
by barepixels » Wed Jun 25, 2014 8:27 pm
Hey guys. This is my first post on here :) So glad I found you guys.
So I just got an Orion GoTo 1st generation (no camera jack) :rolleyes:
I plan to solder the female jack to the controller as instructed by claudevh http://www.kolor.com/forum/viewtopic.php?f=20&t=14147
Question is which female jack will fit inside the head? Currently my head is being ship so I can't tell.
a) Panel Mount 2.5mm Female Mono Audio Cable Plug Jack Socket Adapter J24
b) 2.5mm Female Audio Connector 3 Pin SMT Stereo Phone Jack PJ208
as for the actual cable. So far I have purchased
http://www.ebay.com/itm/LS-2-5-C1-Shutter-Release-Cord-Cable-for-Yongnuo-RF-603-C1-Canon-1000D-550D-500D-/321044645355 for T2i
and
http://www.ebay.com/itm/LS-2-5-C3-Shutter-Release-Cord-Cable-f-Yongnuo-RF-603-C3-Canon-5D-7D-50D-30D-20D-/321044645315
If neither 2.5mm female jacks above wouldn't fit. Can you show me which/where to buy.
Many thanks
Re: Which 2.5mm stero jack should I get?
by gkaefer » Wed Aug 13, 2014 4:24 pm
for the Stereo plug. Have a look here for wireing...
viewtopic.php?f=14&t=5282&p=85215&hilit=merlin+stereo+cable#p85215
claudevh
by claudevh » Wed Aug 13, 2014 9:46 pm
Hello "barepixels"
You must use the "female 2.5 mm stereo model"
Please follow the next schema for the connexion
3-Connections inside the Merlin.png (6.26 KiB) Viewed 3567 times
