Setting up my Merlin and USB Adapter
Viatorus
by Viatorus » Tue Mar 18, 2014 1:18 pm
Hey Community,
I have got a merlin panorama head, an USB interface controller and a hand controller. Now I like to setup a simple 360° panorama.
I wrote this xml:
<?xml version="1.0" encoding="utf-8"?>
<papywizard version="c">
    <preset name="Panorama 1">
        <tooltip>
            12 pics @ 0°
        </tooltip>
        <shoot>
           <pict yaw="0" pitch="0.0" />
           <pict yaw="30" pitch="0.0" />
           <pict yaw="60" pitch="0.0" />
           <pict yaw="90" pitch="0.0" />
           <pict yaw="120" pitch="0.0" />
           <pict yaw="150" pitch="0.0" />
           <pict yaw="180" pitch="0.0" />
           <pict yaw="210" pitch="0.0" />
           <pict yaw="240" pitch="0.0" />
           <pict yaw="270" pitch="0.0" />
           <pict yaw="300" pitch="0.0" />
           <pict yaw="330" pitch="0.0" />
        </shoot>
    </preset>
</papywizard>
If I load this preset into papywizard it works well. Now I want to use this preset without usb/bluetooth connection to the merlin panorama head (wilderness without pc). Is it possible - how?
Thank you in advance.
Re: Setting up my Merlin and USB Adapter
by mediavets » Tue Mar 18, 2014 1:41 pm
Viatorus wrote:Hey Community,
What 'USB interface controller' do you have?
Is this something that runs Papywizard?
I am confused.
Viatorus
by Viatorus » Tue Mar 18, 2014 1:50 pm
Hey mediavets,
ATDCUMi USB Interface
http://www.teleskop-austria.at/shop/ind ... atd-kac-hu
Actually I run papywizard over laptop -> usb interface -> merlin.
Is a laptop / device always needed?
by mediavets » Tue Mar 18, 2014 2:12 pm
Viatorus wrote:Hey mediavets,
Some sort of device is always needed.
The Merlin mount itself is a 'dumb' device.
If you want something smaller and more portable - than say a Windows netbook with a Bluetooth connection - there are three options:
1. Use Papywizard on a Nokia N800 or N810 Internet Tablet; requires the Deltawave Papymerlin Bluetooth-TTL interface device for the Merlin.
http://magasin.skivr.com/en/accessoires ... -head.html
2. Use PandroidWiz on an Android device; requires the Deltawave Papymerlin Bluetooth-TTL interface device for the Merlin.
http://www.papymerlin.com/pandroidwiz/w ... ndroidwiz/
3. Use the T&C Touch Controller:
http://www.typeandcolour.de/index.php?ln=en&tp=hhc_home
by klausesser » Tue Mar 18, 2014 2:25 pm
The advantage of the T&C handheld is: you don´t need BT or WLan. Plug it in and shoot.
see here: http://www.panoneed.com
The small device you can see plugged to the head ist the controller. Abosut the size of a cigarrette pack:
http://www.klausesser.de/Head.mov read about he controller here:
http://panoneed.com/S4.html
Viatorus
by Viatorus » Tue Mar 18, 2014 3:10 pm
Well, bad news, thank you anyway.
Is it possible to use the Laptop->ATDCUMi USB Interface->Merlin over command line? Or is there only the papywizard gui out there.
by mediavets » Tue Mar 18, 2014 3:24 pm
Viatorus wrote:Well, bad news, thank you anyway.
AFAIK Papywizard cannot be run from a command line in that way.
If you have an Android phone or tablet with Bluetooth then the cheapest way to have a portable controller if to use it with the PandroidWiz app. You'll need that Papymerlin Bluetooth interface for the Merlin.
Pandroid Wiz works with Papywizard-compatible presets.
Alternatively Nokia N800 and N810 Internet tablets are relatively cheap via eBay these days.
Where are you located anyway?
Viatorus
by Viatorus » Tue Mar 18, 2014 3:38 pm
Okay, thank you for your fast answer.
I am from Germany. Greetings to you - I will take a roadtrip to the UK next summer. ;)
