Papywizard mac osx 10.9 mavericks
trelobyte
by trelobyte » Wed Jan 15, 2014 12:07 pm
Before upgrading to mavericks until February as instructed by apple i would like to know if there is any plan to release papywizard for this osx version or if anybody has successfully make it work.
thanks
jriley
Re: Papywizard mac osx 10.9 mavericks
by jriley » Tue Jan 21, 2014 4:32 pm
I can share that it does NOT work for me on Mavericks (MackBook Air 11.6", OS X 10.9.1). I am considering trying to build it from source code. I still have a Nokia N800 and Asus eee that I run it on, but they are both getting old and decrepit, with poor battery life.
Is there anyone out there who can build a package installer for Mavericks?
by mediavets » Tue Jan 21, 2014 6:15 pm
jriley wrote:I can share that it does NOT work for me on Mavericks (MackBook Air 11.6", OS X 10.9.1). I am considering trying to build it from source code. I still have a Nokia N800 and Asus eee that I run it on, but they are both getting old and decrepit, with poor battery life.
Batteries are easy to source.
And I could sell you an N800 or N810 if you want another.
jriley
by jriley » Tue Jan 21, 2014 6:35 pm
I will remember that if it gets to the point of not functioning sufficiently. It isn't quite there yet, but I sure would like to be able to run Papywizard on my MacBook Air.
by mediavets » Tue Jan 21, 2014 6:39 pm
jriley wrote: but I sure would like to be able to run Papywizard on my MacBook Air.
Would the Windows version run under whatever process is used to run Windows programs on Mac platforms? I guess you can tell I'm not a Mac user.
jriley
by jriley » Tue Jan 21, 2014 7:30 pm
Maybe if I were running Windows under Bootcamp or other similar. I don't really want to do that because of limited disk space. It may be worth trying to run using CrossOver (Wine) emulation.
trelobyte
by trelobyte » Tue Jan 21, 2014 8:48 pm
Thanks for replying guys,
I guess i can see 4 possible solutions.
1. run parallels with windows and hope that the bluetooth driver will be stable.
2. run pandroidwiz on android but i will have to get an android for that.
3. run the equivalent on old nokia phone but i will have to get a nokia for that.
4. compile papywizard to run on mac osx mavericks which is the best solution.
Any daring soul willing to compile this for mavericks ?
i remember the last working version was for lion ...not even mountain lion.
come on kolor...please...
by mediavets » Tue Jan 21, 2014 8:57 pm
trelobyte wrote:2. run pandroidwiz on android but i will have to get an android for that.
Be aware that PandroidWiz currently uses Papywizard compatible custom presets for shooting all panoramas.
It does not have a built-in mechanism for calculating shooting positions, not even for mosaic panos.
Papywizard in simulation mosaic mode can be used to create XML format data files that can then be converted into custom preset files.
There is a different preset generator for creating presets for shooting spherical panos which can be used with Papywizard or PandroidWz:
http://exposedbykevin.com/PapySpheric/papyspheric.html
trelobyte
by trelobyte » Tue Jan 21, 2014 9:15 pm
thanks mediavets actually this is the one i use for generating presets but i find that for my use cases i make my presets by hand.
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Tue Apr 01, 2014 4:49 pm
trelobyte wrote:ny daring soul willing to compile this for mavericks ?
well if I remember well Kolor told they would support the project as Fred had no more time for it but I have never seen any work since and now we are stuck with Mac users unable to run easily Papywizard on their platform =(
pu2wxp
by pu2wxp » Thu May 15, 2014 12:25 am
I solved the problem of Mavericks.
And it was very easy!
I had the papywizard installed on Snow Leopard in application folder. Simply copy and paste it on the machine with Mavericks and it will run.
If you do not have the app installed on another machine I can send my papywizard that is running on Mavericks.
pu2wxp
by pu2wxp » Thu May 15, 2014 12:28 am
pu2wxp wrote:I solved the problem of Mavericks.
Before trying this, I has downloaded the papywizard and tried to make a new installation on the Mavericks, and the app did not work.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu May 15, 2014 6:23 am
pu2wxp wrote:I had the papywizard installed on Snow Leopard in application folder. Simply copy and paste it on the machine with Mavericks and it will run.
Would be nice to do a zip (archive) of your running PW for Mavericks and share it here ;)
pu2wxp
by pu2wxp » Thu May 15, 2014 2:21 pm
Here you are:
https://dl.dropboxusercontent.com/u/50591245/Papywizard.zip
I believe you will have to reconfigure the bluetooth address.
Luciano Correa
Vista Panoramica
Campos do Jordao SP Brasil
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri May 16, 2014 2:51 pm
pu2wxp wrote:Here you are:
Thanks a lot, very surprised you have been able to run it with Bluetooth, I expected you would have used it in Serial mode !
Vincèn
