Broken Panogear
TukulCR
Broken Panogear
by TukulCR » Fri Dec 20, 2013 7:22 pm
The head is still rotating but not consistently. I will be very appreciative of any advice or insight.
http://www.youtube.com/watch?v=X7Wz2Ne4 ... e=youtu.be
thanks
Re: Broken Panogear
by mediavets » Fri Dec 20, 2013 10:14 pm
TukulCR wrote:The head is still rotating but not consistently. I will be very appreciative of any advice or insight.
thanks
You can get all sorts of problem if you operate it with the battery cover removed, or if light leaks through the base of the bubble level, because it upsets the optical encoders.
TukulCR
Re: Broken Panogear
by TukulCR » Fri Dec 20, 2013 10:38 pm
Right i agree. It works the same way with or without cover.
