timelapse bezier generator papymerlin
franzkekko
by franzkekko » Wed Nov 13, 2013 2:02 am
Hi all, I'm using some preset generator for controlling my panogear with papymerlin (pandroidwiz on my phone). I saved scripts on my drive so I can use them offline. Unfortunately I lost the most interesting of these, a script to generate a time lapse preset based on 6 control points interpolated by bezier curves. I googled all evening but nothing, the page on this forum linked by google to the post is offline error 404. Also using forum research.
Is there anybody who saved the script? :)
Thanks in advance
Francesco
Liked in: 122 posts
Re: timelapse bezier generator papymerlin
by mediavets » Wed Nov 13, 2013 12:58 pm
franzkekko wrote:Hi all, I'm using some preset generator for controlling my panogear with papymerlin (pandroidwiz on my phone). I saved scripts on my drive so I can use them offline. Unfortunately I lost the most interesting of these, a script to generate a time lapse preset based on 6 control points interpolated by bezier curves. I googled all evening but nothing, the page on this forum linked by google to the post is offline error 404. Also using forum research.
Thanks in advance
Francesco
Which timelapse script are you seeking?
I found this one:
https://www.apertus.org/en/chronomotion
franzkekko
by franzkekko » Wed Nov 13, 2013 1:18 pm
Thanks mediavets for the reply, it's not the script I was talking about.
However, chronomotion it's really Interesting. I tried to use it last month but parameters are impossible and don't understand all settings because i cant set all value i want. Also, bezier curves get crazy if you press wrong mouse key and there's no possibility to undo.
I installed all needed libraries for Java.
Any idea? :)
Liked in: 122 posts
by mediavets » Wed Nov 13, 2013 1:32 pm
franzkekko wrote:Thanks mediavets for the reply, it's not the script I was talking about.
Any idea? :)
No, sorry.
So which script were you looking for?
franzkekko
by franzkekko » Wed Nov 13, 2013 1:37 pm
Similar to other script, but in the option settings there was the possibility to choose the position of six fixed point (pan and tilt) and then the script create a smooth movement in a total position based on my decision :)
I have an XML made with it, but lost the HTML :D
Liked in: 122 posts
by mediavets » Wed Nov 13, 2013 2:46 pm
franzkekko wrote:Similar to other script, but in the option settings there was the possibility to choose the position of six fixed point (pan and tilt) and then the script create a smooth movement in a total position based on my decision :)
Who was the author of this script - and how was it named?
franzkekko
by franzkekko » Wed Nov 13, 2013 3:16 pm
Emmm... No idea. I looked at XML code output to find a sign, but there's nothing :(
claudevh
by claudevh » Wed Nov 13, 2013 3:37 pm
Hello "franzkekko"
Welcome on board ...
With the new Forum, this is really difficult to find all back ...! :rolleyes: :rolleyes:
Anyway, here is the link for the TL Bezier generator:
http://www.kolor.com/forum/viewtopic.php?f=42&t=8684
Regards
Claude
P.S.
You will probably interested in PandroidWiz ...!!!
http://www.three60views.org.uk/pandroidwiz/viewforum.php?f=1
franzkekko
by franzkekko » Wed Nov 13, 2013 4:49 pm
Claudevh Hood job, it's the script I was looking for ;)
I'm using pandroidwiz for 2months for taking my 360 tour and some simple timelapse. Do you use it? (ore any one else) .... I didn't understand yet how does time value and time trigger works.
I use the Bluetooth module, I set 7 seconds as time value, 500ms on trigger time; 1/500s is shutter time, but however each shot is taken every 12 seconds. How does these values works? :) seem to be arbitrary :D
Excuse for eventual mistakes, I'm Italian :)
Thanks in advance for reply (hoping to not be OT) and thanks again for link.
claudevh
by claudevh » Wed Nov 13, 2013 5:12 pm
Hello again,
YES, I use it of course !!!
I am the father of the developper.
"Mediavet" have also participated more then "activelly" to the development ...
For questions about PandroidWiz and the way of using it, please join and surf on the dedicated web site.
Claude
franzkekko
by franzkekko » Fri Nov 15, 2013 5:04 pm
Thanks for the link, I just subscribed to the forum...waiting for approvation ;)
claudevh
by claudevh » Sat Nov 16, 2013 12:05 am
Approbation has been given ... ;)
Claude
