Need a new head...
tarnis
Need a new head...
by tarnis » Wed Jul 31, 2013 3:45 pm
Hi All,
Been awhile since I've done any gigapixel photography, let alone surfed through the forums. My second Merlin Head burned out a motor, first one arrived with numerous issues and with other things in life going on I put it to rest for awhile. Anyway, was hoping to get back in to shooting some gigapixel images for a trip I had coming up and I no longer see anything to use out there...
Merlin Heads which were under $200 at the time are no longer available in the US, the Panogear setup which is the same thing is priced way to high for what it is...the Allview that seems to have replaced the Merlin is a monstrosity to lug around and well...I dunno. Did I miss any other developments out there?
Hope everyone is doing well!
Matt
HansKeesom
by HansKeesom » Wed Jul 31, 2013 3:50 pm
I have no answer to your question but I do love the title of this thread ;-)
Regards, Hans Keesom
by klausesser » Wed Jul 31, 2013 4:26 pm
tarnis wrote:Hi All,
Matt
Hi Matt!
Do you know the Panoneed head?
Very good, very robust, very reliable - and costing 2000.-€ + VAT the most cost-effective one among motorized and programmable multirow-heads.
Writes XML which works with APG and PTGui.
www.panoneed.com (translation pending)
Assembled and tested by the developer´s hand - and that´s why there´s a wait list.
Artisan New
by Artisan New » Wed Jul 31, 2013 6:30 pm
Eh or a new motor....can't you screw open the Merlin (I have seen some opened and disemboweld on the net, so it must be possible) and check the motors, stepper motors are dirt cheap these days, you only need to know what motor to buy......checked the web and yes you can buy Merlin Orions in Europe by the cardload (and I bet some will be glad to ship them stateside)....but replacement parts are hard to come by. But since I bet my grannies grave that Orion/Accuter/Skywatcher/Panogear whatever are not in the business of cherning out specialised stepper motors some Chinese sweat shop must produce the motor you are looking for.
Greets, Ed.
Olympus OM-D with HLD-6, Fuji GX680, Samyang 7.5, Olympus 9-18, Sigma 19, Panasonic 14-45, Nikon 50 1.4 on Novoflex with tripod mount, Nikon 80-200, Panasonic 45-200, Fujinon 135, Fujinon 80, Fujinon 65, Fujinon 50, Gitzo Gilux Reporter 2, Sirui Ballhead and Panosaurus 2.0 NNP adapter, Motorized Panohead of Canadian (ironware)/Dutch (electronics and software) construction.
by mediavets » Wed Jul 31, 2013 6:36 pm
Artisan New wrote:Eh or a new motor....can't you screw open the Merlin (I have seen some opened and disemboweld on the net, so it must be possible) and check the motors, stepper motors are dirt cheap these days, you only need to know what motor to buy......checked the web and yes you can buy Merlin Orions in Europe by the cardload (and I bet some will be glad to ship them stateside)....but replacement parts are hard to come by. But since I bet my grannies grave that Orion/Accuter/Skywatcher/Panogear whatever are not in the business of cherning out specialised stepper motors some Chinese sweat shop must produce the motor you are looking for.
Greets, Ed.
Merlin doesn't use stepper motors. It uses uses DC motors and incremental encoders.
Artisan New
by Artisan New » Wed Jul 31, 2013 7:07 pm
Mediavets, found that out too (and stand corrected (c) Prince, 1987)).....
http://twiki.cis.rit.edu/twiki/bin/view/MVRL/BioGigapan
This is a Merlin in the nude (to keep in sync with the 1980th mr. Nelson).......at least at the bottom of this verry long page! Now replacing a motor does not seem to be that big of an issue. Question is where to find a replacement part.............
Greets, Ed.
Artisan New
by Artisan New » Wed Jul 31, 2013 7:11 pm
http://www.teleskop-austria.at/shop/index.php?lng=de&m=1&kod=%2038&r=4&i=1&om=Weitere%20Zubeh%F6re
A intercontinental phone call couldn't heart...........or a mail of course...
Greets, Ed.
by mediavets » Wed Jul 31, 2013 7:32 pm
Artisan New wrote:Mediavets, found that out too (and stand corrected (c) Prince, 1987)).....
Greets, Ed.
I have an idea that the Celestron Nextstar 4/5 SE may use the same motor/encoder assemblies?:
http://www.celestron.com/astronomy/motor-assy-alt-dec-for-the-nexstar-4-5se-series-only.html
