Workflow with APG 3.0 and PapyWizard
mark_anderson_us
by mark_anderson_us » Fri Apr 26, 2013 2:52 am
Hi Guys
Coming back to this after a few years. I had some 400-image panos with AEB (3 per position), is there a guide for best workflow?
Regards
mark
Canon EOS 30D with BG-E2 grip
50mm f1.4, 16-35mm f2.8L, 28-70mm f2.8L, 70-200mm f2.8L, 100mm f2.8 Macro
Gitzo 2531, Merlin/Orion
mark_anderson_us
by mark_anderson_us » Sat May 04, 2013 4:34 pm
no-one?
by mediavets » Sat May 04, 2013 7:37 pm
mark_anderson_us wrote:no-one?
I think the consensus would be to batch process the bracketed expsoures before stitching.
Were these images shot using a robotic pano head?
mark_anderson_us
by mark_anderson_us » Sat May 04, 2013 7:56 pm
yes shot with merlin
by mediavets » Sat May 04, 2013 8:53 pm
mark_anderson_us wrote:yes shot with merlin
If you choose to process the bracketed exposures prior to stitching and you want to use the XML file with the Papywixard Import wizard you'll need to either edit your XML data file - if you still have it - to reduce the number of recorded shots to one per shooting , or create new one by running a simulated shoot with no bracketing but otherwise similar settings.
mark_anderson_us
by mark_anderson_us » Sat May 04, 2013 9:02 pm
Thanks Mediavets
I realize that. I posted an XSL to do exactly that a couple of years ago: http://www.kolor.com/forum/t8979-converting-papywizard-xml-from-aeb-to-single-shot
