Connecting Mac via USB to TTL level Converter to Merlin/Orion head?
yoshiharra
by yoshiharra » Wed Apr 24, 2013 6:13 pm
Has any one succeeded connecting Merlin head with MacBook via USB to TTL level Converter cable? I managed to make it work with Windows 7 successfully, can't seems to make it work with Mac!
If so, I would appreciate if you can share the sep-by step.
Canon EOS T3i, EF 100-400mm, Tokina 100mm, Sigma 15mm, Samyang 8mm, Nodal Ninja 5L & R10, Merlin - Papywizard on Nokia N810
