Bluetooth connection problem (working fine! Nokia/windows 7 same error
yoshiharra
by yoshiharra » Thu Apr 18, 2013 2:07 am
Today after a long time (over a month) I was testing my setup and getting ready for a trip to Mexico. I normally use Nokia 810 with my Merlin head. This morning when I tried to connect to the head from my Nokia it indicated it is connected but Init is not! To troubleshoot, I deleted the pairing in Nokia, created a new pair, same result (see attached)!!
The I tried with my netbook with Windows 7 and had same problem!
Please help
Roy
Canon EOS T3i, EF 100-400mm, Tokina 100mm, Sigma 15mm, Samyang 8mm, Nodal Ninja 5L & R10, Merlin - Papywizard on Nokia N810
by klausesser » Thu Apr 18, 2013 2:51 am
yoshiharra wrote:Today after a long time (over a month) I was testing my setup and getting ready for a trip to Mexico. I normally use Nokia 810 with my Merlin head. This morning when I tried to connect to the head from my Nokia it indicated it is connected but Init is not! To troubleshoot, I deleted the pairing in Nokia, created a new pair, same result (see attached)!!
Please help
Roy
http://i50.tinypic.com/34o2cmw.png
Several times had the same experience - that´s why i stopped using the Nokia with Merlin and used the T&C handheld instead. Never had any problem with that one . . :cool:
I´m afraid this whole simulation-stuff in PapyWizard causes errors very quick. Check the simulation settings!
yoshiharra
by yoshiharra » Thu Apr 18, 2013 4:10 am
Thanks Klaus for your reply, but where is "simulation settings" ? (never mind I understand)
If I am going to buy TC Controller, I would just get the Panoneed.
Roy
by fma38 » Thu Apr 18, 2013 6:08 am
Can you post the logs?
yoshiharra
by yoshiharra » Thu Apr 18, 2013 10:43 am
Realized my Nokia clock was not set correctly, it should be 2013-04-17 instead of 2013-03-14.
Thanks Frédéric
2013-03-14 05:32:52,142::Main::INFO::Starting Papywizard...
2013-03-14 05:32:52,154::Main::DEBUG::main(): platform=maemo
2013-03-14 05:32:54,704::Main::INFO::Importing modules...
2013-03-14 05:32:59,092::Main::INFO::Loading i18n files...
2013-03-14 05:32:59,206::Main::DEBUG::main(): locale=en_US
2013-03-14 05:32:59,224::Main::WARNING::Can't find qt translation file
2013-03-14 05:32:59,252::Main::INFO::Loading Style Sheets...
2013-03-14 05:32:59,343::Main::WARNING::No user Style Sheet found
2013-03-14 05:32:59,354::Main::INFO::Loading configuration...
2013-03-14 05:32:59,435::Main::DEBUG::ConfigManager.__init__(): versions: dist=['2', '1', '21'], user=[u'2', u'1', u'21']
2013-03-14 05:32:59,447::Main::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2013-03-14 05:32:59,458::Main::INFO::Load plugins...
2013-03-14 05:32:59,598::Main::DEBUG::DslrRemoteProShutter._defineConfig()
2013-03-14 05:32:59,610::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:32:59,627::Main::DEBUG::AbstractPlugin._loadConfig(): config={'USER_EXPOSURE_COMPENSATION_LIST': '-2, 0, +2', 'DRY_RUN': False, 'MIRROR_LOCKUP': False, 'FILENAME_PREFIX': '', 'CAMERA_EXPOSURE_COMPENSATION_LIST': u'\xb12@1/3', 'OUTPUT_DIR': '/home/user', 'PROGRAM_PATH': 'C:\\Program Files\\BreezeSys\\DSLR Remote Pro\\DSLRRemoteTest\\DSLRRemoteTest.exe'}
2013-03-14 05:32:59,638::Main::DEBUG::PluginsManager.register(): added 'DSLR Remote Pro' plugin with capacity 'shutter'
2013-03-14 05:32:59,669::Main::TRACE::EOSUtilityShutter._defineConfig()
2013-03-14 05:32:59,681::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:32:59,697::Main::DEBUG::AbstractPlugin._loadConfig(): config={'FOCUS_DIRECTION': u'far', 'BRACKETING_TYPE': '0-+', 'BULB_ENABLE': False, 'DRY_RUN': True, 'BULB_BASE_EXPOSURE': 1, 'FOCUS_NB_PICTS': 1, 'BRACKETING_NB_PICTS': 1, 'FOCUS_STEP_COUNT': 1, 'FOCUS_ENABLE': False, 'EOS_UTILITY_VERSION': u'new', 'PROGRAM_PATH': 'C:\\Program Files\\Papywizard\\EOSBracket.exe', 'BRACKETING_STEP': '1', 'FOCUS_STEP': u'medium'}
2013-03-14 05:32:59,708::Main::DEBUG::PluginsManager.register(): added 'EOS Utility' plugin with capacity 'shutter'
2013-03-14 05:32:59,740::Main::TRACE::GenericTetheredShutter._defineConfig()
2013-03-14 05:32:59,751::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:32:59,766::Main::DEBUG::AbstractPlugin._loadConfig(): config={'MIRROR_LOCKUP_COMMAND': 'gphoto2 --capture-image', 'MIRROR_LOCKUP': False, 'PARAM_4': '', 'PARAM_1': '', 'PARAM_0': '', 'SHOOT_COMMAND': 'gphoto2 --capture-image', 'PARAM_2': '', 'TIME_VALUE': 0.10000000000000001, 'PARAM_3': ''}
2013-03-14 05:32:59,777::Main::DEBUG::PluginsManager.register(): added 'Generic Tethered' plugin with capacity 'shutter'
2013-03-14 05:32:59,850::Main::TRACE::GigaPanBotAxis._init()
2013-03-14 05:32:59,862::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:32:59,874::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:32:59,886::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0}
2013-03-14 05:32:59,898::Main::DEBUG::PluginsManager.register(): added 'GigaPanBot' plugin with capacity 'yawAxis'
2013-03-14 05:32:59,909::Main::TRACE::GigaPanBotAxis._init()
2013-03-14 05:32:59,921::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:32:59,932::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:32:59,945::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0}
2013-03-14 05:32:59,956::Main::DEBUG::PluginsManager.register(): added 'GigaPanBot' plugin with capacity 'pitchAxis'
2013-03-14 05:32:59,968::Main::TRACE::GigaPanBotShutter._init()
2013-03-14 05:32:59,979::Main::TRACE::ShutterPlugin._init()
2013-03-14 05:32:59,990::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,001::Main::TRACE::ShutterPlugin._defineConfig()
2013-03-14 05:33:00,013::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,027::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2013-03-14 05:33:00,039::Main::DEBUG::PluginsManager.register(): added 'GigaPanBot' plugin with capacity 'shutter'
2013-03-14 05:33:00,075::Main::TRACE::GphotoBracketShutter._defineConfig()
2013-03-14 05:33:00,087::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,104::Main::DEBUG::AbstractPlugin._loadConfig(): config={'BRACKETING_EV_STEP': 1, 'BRACKETING_EV_LIST': '0', 'BRACKETING_PLUS_STEP': 1, 'MIRROR_LOCKUP_COMMAND': 'gphoto2 --capture-image', 'MIRROR_LOCKUP': False, 'DOWNLOAD_DIR': '/home/user', 'BRACKETING_MINUS_STEP': 1, 'DOWNLOAD_ENABLE': False, 'BRACKETING_NB_PICTS': 1, 'BRACKETING_MINUS_NB_PICTS': 0, 'BRACKETING_EV_BIAS': 0, 'BRACKETING_ADVANCED': False, 'BRACKETING_PLUS_NB_PICTS': 0, 'DOWNLOAD_THEN_DELETE': False, 'PROGRAM_PATH': 'gphoto2', 'DOWNLOAD_AFTER': u'Each shot'}
2013-03-14 05:33:00,116::Main::DEBUG::PluginsManager.register(): added 'Gphoto Bracket' plugin with capacity 'shutter'
2013-03-14 05:33:00,159::Main::TRACE::MerlinOrionAxis._init()
2013-03-14 05:33:00,171::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,183::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,203::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'bluetooth', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': False}
2013-03-14 05:33:00,215::Main::TRACE::MerlinOrionAxis._init()
2013-03-14 05:33:00,228::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,239::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,258::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'bluetooth', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': False}
2013-03-14 05:33:00,277::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'yawAxis'
2013-03-14 05:33:00,290::Main::TRACE::MerlinOrionAxis._init()
2013-03-14 05:33:00,302::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,314::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,333::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'bluetooth', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': False}
2013-03-14 05:33:00,345::Main::TRACE::MerlinOrionAxis._init()
2013-03-14 05:33:00,357::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,369::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,388::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'bluetooth', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': False}
2013-03-14 05:33:00,400::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'pitchAxis'
2013-03-14 05:33:00,412::Main::TRACE::MerlinOrionShutter._init()
2013-03-14 05:33:00,423::Main::TRACE::ShutterPlugin._init()
2013-03-14 05:33:00,434::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,445::Main::TRACE::ShutterPlugin._defineConfig()
2013-03-14 05:33:00,459::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,481::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': u'bluetooth', 'PULSE_WIDTH_LOW': 150, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 5, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200, 'TRIGGER_ONLY_ONCE': True}
2013-03-14 05:33:00,492::Main::TRACE::MerlinOrionShutter._init()
2013-03-14 05:33:00,503::Main::TRACE::ShutterPlugin._init()
2013-03-14 05:33:00,515::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,526::Main::TRACE::ShutterPlugin._defineConfig()
2013-03-14 05:33:00,537::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,559::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': u'bluetooth', 'PULSE_WIDTH_LOW': 150, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 5, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200, 'TRIGGER_ONLY_ONCE': True}
2013-03-14 05:33:00,570::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'shutter'
2013-03-14 05:33:00,595::Main::DEBUG::NkRemoteShutter._defineConfig()
2013-03-14 05:33:00,607::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,620::Main::DEBUG::AbstractPlugin._loadConfig(): config={'USER_EXPOSURE_COMPENSATION_LIST': '-2, 0, +2', 'DRY_RUN': False, 'MIRROR_LOCKUP': False, 'FILENAME_PREFIX': '', 'CAMERA_EXPOSURE_COMPENSATION_LIST': u'\xb15@1/2', 'OUTPUT_DIR': '/home/user', 'PROGRAM_PATH': 'C:\\Program Files\\BreezeSys\\NKRemote\\NKRemoteLibTest.exe'}
2013-03-14 05:33:00,632::Main::DEBUG::PluginsManager.register(): added 'NK Remote' plugin with capacity 'shutter'
2013-03-14 05:33:00,677::Main::TRACE::PanoduinoAxis._init()
2013-03-14 05:33:00,689::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,700::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,716::Main::DEBUG::AbstractPlugin._loadConfig(): config={'NEUTRAL_POSITION': 1000, 'HIGH_LIMIT': 360.0, 'DIRECTION': u'forward', 'ANGLE_1MS': 315.0, 'ACCEL': 1, 'LOW_LIMIT': -360.0, 'DRIVER_TYPE': 'bluetooth', 'ADDITIONAL_DELAY': 0.5, 'SPEED': 5, 'CHANNEL': 0}
2013-03-14 05:33:00,727::Main::DEBUG::PluginsManager.register(): added 'Panoduino' plugin with capacity 'yawAxis'
2013-03-14 05:33:00,739::Main::TRACE::PanoduinoAxis._init()
2013-03-14 05:33:00,751::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,764::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,780::Main::DEBUG::AbstractPlugin._loadConfig(): config={'NEUTRAL_POSITION': 1500, 'HIGH_LIMIT': 360.0, 'DIRECTION': u'reverse', 'ANGLE_1MS': 330.0, 'ACCEL': 1, 'LOW_LIMIT': -360.0, 'DRIVER_TYPE': 'bluetooth', 'ADDITIONAL_DELAY': 0.5, 'SPEED': 5, 'CHANNEL': 1}
2013-03-14 05:33:00,791::Main::DEBUG::PluginsManager.register(): added 'Panoduino' plugin with capacity 'pitchAxis'
2013-03-14 05:33:00,804::Main::TRACE::PanoduinoShutter._init()
2013-03-14 05:33:00,814::Main::TRACE::ShutterPlugin._init()
2013-03-14 05:33:00,826::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,837::Main::TRACE::ShutterPlugin._defineConfig()
2013-03-14 05:33:00,848::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,864::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'SHUTTER_ON': 2000, 'SHUTTER_OFF': 1000, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'CHANNEL': 2, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2013-03-14 05:33:00,877::Main::DEBUG::PluginsManager.register(): added 'Panoduino' plugin with capacity 'shutter'
2013-03-14 05:33:00,916::Main::TRACE::PixOrbAxis._init()
2013-03-14 05:33:00,928::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:00,939::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:00,953::Main::DEBUG::AbstractPlugin._loadConfig(): config={'AXIS_ACCURACY': 0.10000000000000001, 'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'SPEED_INDEX': 9, 'AXIS_WITH_BREAK': False}
2013-03-14 05:33:00,964::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'yawAxis'
2013-03-14 05:33:00,977::Main::TRACE::PixOrbAxis._init()
2013-03-14 05:33:00,988::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:01,000::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,013::Main::DEBUG::AbstractPlugin._loadConfig(): config={'AXIS_ACCURACY': 0.10000000000000001, 'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'SPEED_INDEX': 9, 'AXIS_WITH_BREAK': False}
2013-03-14 05:33:01,025::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'pitchAxis'
2013-03-14 05:33:01,038::Main::TRACE::PixOrbShutter._init()
2013-03-14 05:33:01,049::Main::TRACE::ShutterPlugin._init()
2013-03-14 05:33:01,060::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:01,071::Main::TRACE::ShutterPlugin._defineConfig()
2013-03-14 05:33:01,082::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,097::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2013-03-14 05:33:01,108::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'shutter'
2013-03-14 05:33:01,147::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,163::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'SPEED': 30, 'LOW_LIMIT': -360.0}
2013-03-14 05:33:01,174::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'yawAxis'
2013-03-14 05:33:01,188::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,204::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'SPEED': 30, 'LOW_LIMIT': -360.0}
2013-03-14 05:33:01,215::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'pitchAxis'
2013-03-14 05:33:01,228::Main::TRACE::AbstractShutterPlugin._defineConfig()
2013-03-14 05:33:01,239::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,256::Main::DEBUG::AbstractPlugin._loadConfig(): config={'TIME_VALUE': 0.5, 'TRIGGER_ONLY_ONCE': False, 'BRACKETING_NB_PICTS': 1, 'MIRROR_LOCKUP': False}
2013-03-14 05:33:01,267::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'shutter'
2013-03-14 05:33:01,291::Main::TRACE::TimelordShutter._defineConfig()
2013-03-14 05:33:01,301::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,313::Main::DEBUG::AbstractPlugin._loadConfig(): config={'PROGRAM_PATH': 'C:\\Program Files\\OxfordEye\\Timelord\\Timelord.exe', 'LRD_FILE': 'C:\\Documents and Settings\\win2k\\My Documents\\timelord.lrd'}
2013-03-14 05:33:01,325::Main::DEBUG::PluginsManager.register(): added 'Timelord' plugin with capacity 'shutter'
2013-03-14 05:33:01,351::Main::TRACE::UrsaMinorBt2Shutter._init()
2013-03-14 05:33:01,362::Main::TRACE::ShutterPlugin._init()
2013-03-14 05:33:01,373::Main::TRACE::UrsaMinorBt2Shutter._defineConfig()
2013-03-14 05:33:01,384::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:01,395::Main::TRACE::ShutterPlugin._defineConfig()
2013-03-14 05:33:01,406::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,422::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'FOCUS_PULSE_WIDTH': 0.5, 'FOCUS_MAINTAIN': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'FOCUS_ENABLE': False, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2013-03-14 05:33:01,433::Main::TRACE::UrsaMinorBt2Shutter._init()
2013-03-14 05:33:01,444::Main::TRACE::ShutterPlugin._init()
2013-03-14 05:33:01,455::Main::TRACE::UrsaMinorBt2Shutter._defineConfig()
2013-03-14 05:33:01,466::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:01,477::Main::TRACE::ShutterPlugin._defineConfig()
2013-03-14 05:33:01,488::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,503::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'FOCUS_PULSE_WIDTH': 0.5, 'FOCUS_MAINTAIN': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'FOCUS_ENABLE': False, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2013-03-14 05:33:01,515::Main::DEBUG::PluginsManager.register(): added 'Ursa Minor BT2' plugin with capacity 'shutter'
2013-03-14 05:33:01,543::Main::TRACE::UrsaMinorUsbShutter._init()
2013-03-14 05:33:01,554::Main::TRACE::ShutterPlugin._init()
2013-03-14 05:33:01,565::Main::TRACE::UrsaMinorUsbShutter._defineConfig()
2013-03-14 05:33:01,576::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:01,587::Main::TRACE::ShutterPlugin._defineConfig()
2013-03-14 05:33:01,598::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,613::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'TRIGGER_LINE_INVERTED': False, 'BRACKETING_NB_PICTS': 1, 'TRIGGER_LINE': 'RTS', 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2013-03-14 05:33:01,624::Main::DEBUG::PluginsManager.register(): added 'Ursa Minor USB' plugin with capacity 'shutter'
2013-03-14 05:33:01,664::Main::TRACE::ClaussAxis._init()
2013-03-14 05:33:01,676::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:01,687::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,701::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'PARK_POSITION': '0.', 'SPEED_FAST': 100, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'PARK_ENABLE': False, 'SPEED_NORMAL': 50, 'SPEED_SLOW': 10}
2013-03-14 05:33:01,712::Main::DEBUG::PluginsManager.register(): added 'Clauss' plugin with capacity 'yawAxis'
2013-03-14 05:33:01,726::Main::TRACE::ClaussAxis._init()
2013-03-14 05:33:01,737::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:01,748::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,762::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'PARK_POSITION': '0.', 'SPEED_FAST': 100, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'PARK_ENABLE': True, 'SPEED_NORMAL': 50, 'SPEED_SLOW': 10}
2013-03-14 05:33:01,775::Main::DEBUG::PluginsManager.register(): added 'Clauss' plugin with capacity 'pitchAxis'
2013-03-14 05:33:01,789::Main::TRACE::ClaussShutter._init()
2013-03-14 05:33:01,799::Main::TRACE::ShutterPlugin._init()
2013-03-14 05:33:01,811::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2013-03-14 05:33:01,822::Main::TRACE::ShutterPlugin._defineConfig()
2013-03-14 05:33:01,833::Main::TRACE::AbstractPlugin._loadConfig()
2013-03-14 05:33:01,848::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 250, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'FOCUS_TIME': 1.5, 'BRACKETING_NB_PICTS': 1, 'DUAL_TIME': 2.0, 'TIME_VALUE': 0.5, 'FOCUS_ENABLE': False, 'DUAL_ENABLE': False, 'PULSE_WIDTH_HIGH': 250, 'TRIGGER_ONLY_ONCE': False}
2013-03-14 05:33:01,860::Main::DEBUG::PluginsManager.register(): added 'Clauss' plugin with capacity 'shutter'
2013-03-14 05:33:01,871::Main::INFO::Loading user plugins...
2013-03-14 05:33:01,882::Main::DEBUG::PluginsManager.register(): parsing '/home/user/.config/papywizard2/plugins' dir...
2013-03-14 05:33:01,893::Main::INFO::Activate plugins...
2013-03-14 05:33:01,912::Main::TRACE::MerlinOrionPlugin.activate()
2013-03-14 05:33:01,931::Main::TRACE::MerlinOrionPlugin.activate()
2013-03-14 05:33:01,958::Main::INFO::Creating model...
2013-03-14 05:33:02,035::Main::INFO::Loading default presets
2013-03-14 05:33:02,400::Main::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2013-03-14 05:33:02,431::Merlin-Orion_yawAxis::DEBUG::MerlinOrionAxis.run(): start thread
2013-03-14 05:33:02,445::Merlin-Orion_pitchAxis::DEBUG::MerlinOrionAxis.run(): start thread
2013-03-14 05:33:02,420::Main::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2013-03-14 05:33:02,465::Main::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2013-03-14 05:33:02,490::Main::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2013-03-14 05:33:02,511::Main::DEBUG::Preset.__init__(): loading name='6@30 + 6@-30'
2013-03-14 05:33:02,534::Main::DEBUG::Preset.__init__(): loading name='6@0 + Z + N'
2013-03-14 05:33:02,556::Main::DEBUG::Preset.__init__(): loading name='6@-10 + 1@+60'
2013-03-14 05:33:02,576::Main::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2013-03-14 05:33:02,614::Main::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2013-03-14 05:33:02,665::Main::INFO::Loading user presets
2013-03-14 05:33:04,097::Main::DEBUG::Preset.__init__(): loading name='Sigma 15mm 360'
2013-03-14 05:33:04,125::Main::DEBUG::Preset.__init__(): loading name='50mm-360VR 9rows/29column'
2013-03-14 05:33:04,417::Main::DEBUG::Preset.__init__(): loading name='200mm_T3i 6X30column'
2013-03-14 05:33:04,626::Main::DEBUG::Preset.__init__(): loading name='3516P_200_6_30_preview'
2013-03-14 05:33:04,647::Main::INFO::Starting Spy...
2013-03-14 05:33:04,658::Main::INFO::Creating GUI...
2013-03-14 05:33:05,134::Spy::INFO::Starting Spy...
2013-03-14 05:33:05,145::Spy::INFO::Spy suspended
2013-03-14 05:33:07,798::Main::WARNING::MainController.__getFullScreenFlag(): fix fullScreenFlag property!!!
by fma38 » Thu Apr 18, 2013 11:39 am
Please, post the logs *after* you tried to establish the connection ;)
yoshiharra
by yoshiharra » Thu Apr 18, 2013 11:47 am
OK, I will do it again and post as soon as I can.
by klausesser » Thu Apr 18, 2013 1:51 pm
yoshiharra wrote:If I am going to buy TC Controller, I would just get the Panoneed.
You can get the TC for Merlin or for Panoneed direct from T&C for 180.-€ +VAT.
http://www.bonnmedia.de/TundC/index.php?ln=de&tp=hhc_preise
yoshiharra
by yoshiharra » Thu Apr 18, 2013 2:40 pm
Hi Frédéric
Here it is -
2013-04-18 09:25:15,170::Main::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2013-04-18 09:25:15,183::Main::INFO::Starting connection. Please wait...
2013-04-18 09:25:15,254::Main::DEBUG::PluginsConnector.start(): 'yawAxis' establish connection
2013-04-18 09:25:15,283::Main::DEBUG::BluetoothDriver._init(): trying to connect to 00:12:6F:22:44:A9...
2013-04-18 09:25:26,864::Main::DEBUG::BluetoothDriver._init(): successfully connected to 00:12:6F:22:44:A9
2013-04-18 09:25:26,897::Main::DEBUG::PluginsConnector.start(): 'yawAxis' init
2013-04-18 09:25:28,623::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/merlinOrionHardware.py", line 145, in __sendCmd
    c = self._driver.read(1)
  File "/usr/lib/python2.5/site-packages/papywizard/driver/bluetoothDriver.py", line 110, in read
    data = self._sock.recv(size)
  File "<string>", line 5, in recv
BluetoothError: timed out
2013-04-18 09:25:28,675::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:30,248::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:30,286::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:31,850::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:31,886::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:33,462::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:33,502::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:35,069::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:35,110::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:35,141::Main::EXCEPTION::PluginsConnector.connectPlugins()
  File "/usr/lib/python2.5/site-packages/papywizard/plugins/pluginsConnector.py", line 89, in start
    plugin.init()
  File "/usr/lib/python2.5/site-packages/papywizard/plugins/merlinOrionPlugins.py", line 157, in init
    AbstractHardwarePlugin.init(self)
  File "/usr/lib/python2.5/site-packages/papywizard/plugins/abstractHardwarePlugin.py", line 104, in init
    self._hardware.init()
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/merlinOrionHardware.py", line 178, in init
    self.__sendCmd("L")
  File "/usr/lib/python2.5/site-packages/papywizard/hardware/merlinOrionHardware.py", line 164, in __sendCmd
    raise HardwareError("axis %d can't send command %s" % (self._axis, repr(cmd)))
HardwareError: axis 1 can't send command ':L1\r'
2013-04-18 09:25:35,219::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' establish connection
2013-04-18 09:25:35,252::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' init
2013-04-18 09:25:36,826::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:36,865::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':L2\r'. Retrying...
2013-04-18 09:25:38,429::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:38,468::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':L2\r'. Retrying...
2013-04-18 09:25:40,037::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:40,076::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':L2\r'. Retrying...
2013-04-18 09:25:41,647::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:41,684::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':L2\r'. Retrying...
2013-04-18 09:25:43,256::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:43,294::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 2 can't sent command ':L2\r'. Retrying...
2013-04-18 09:25:43,326::Main::EXCEPTION::PluginsConnector.connectPlugins()
  File "/usr/lib/python2.5/site-packages/papywizard/plugins/pluginsConnector.py", line 108, in start
    plugin.init()
    self.__sendCmd("L")
HardwareError: axis 2 can't send command ':L2\r'
2013-04-18 09:25:43,426::Main::DEBUG::PluginsConnector.start(): 'shutter' establish connection
2013-04-18 09:25:43,454::Main::DEBUG::PluginsConnector.start(): 'shutter' init
2013-04-18 09:25:45,006::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:45,047::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:46,615::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:46,653::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:48,217::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:48,255::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:49,819::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:49,877::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:51,449::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2013-04-18 09:25:51,465::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2013-04-18 09:25:51,477::Main::EXCEPTION::PluginsConnector.connectPlugins()
  File "/usr/lib/python2.5/site-packages/papywizard/plugins/pluginsConnector.py", line 126, in start
    plugin.init()
  File "/usr/lib/python2.5/site-packages/papywizard/plugins/merlinOrionPlugins.py", line 333, in init
    self.__sendCmd("L")
2013-04-18 09:25:51,496::Main::ERROR::Connection failed to start
2013-04-18 09:25:57,823::Main::DEBUG::MainController.__onActionHardwareConnectToggled(False)
2013-04-18 09:25:57,843::Main::DEBUG::PluginsConnector.start(): 'yawAxis' stop connection
2013-04-18 09:25:57,869::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' stop connection
2013-04-18 09:25:57,899::Main::DEBUG::PluginsConnector.start(): 'shutter' stop connection
@Klaus
Thanks for the inf, but do you think if I buy the hand controller, later if I decide to buy Panoneed, I can buy the kit without the hand controller?
Thanks to both
Roy
by fma38 » Thu Apr 18, 2013 2:48 pm
Ok, there is a communication issue. Ar you sure you didn't change the baudrate of the bluetooth module ? Or a broken wire?
by mediavets » Thu Apr 18, 2013 3:01 pm
yoshiharra wrote:Hi Frédéric
Here it is -
    plugin.init()
    self.__sendCmd("L")
    plugin.init()
    self.__sendCmd("L")
    plugin.init()
    self.__sendCmd("L")
Roy
Was this log from your N810?
by klausesser » Thu Apr 18, 2013 3:36 pm
yoshiharra wrote:@Klaus
Thanks to both
Roy
Yes. The hand controller can be flashed to work with the Panoneed-head.
yoshiharra
by yoshiharra » Thu Apr 18, 2013 5:00 pm
@Frédéric
I handle the BT module with, not sure.
@Andrew
Yes it is from Nokia 810
@Klaus
by mediavets » Thu Apr 18, 2013 6:00 pm
yoshiharra wrote:@Frédéric
@Andrew
Do you have the Deltawave PapyMerlin Bluetooth adapter in the blue case?:
yoshiharra
by yoshiharra » Thu Apr 18, 2013 6:01 pm
OK, I figured it out. The Merlin head is not powering up! The way I found it out is, I removed the BT, connected the HC powered it on, no power to the HC!!
Can any one help me fix this? I am pretty good with soldering, just need guidance to fix it.
yoshiharra
by yoshiharra » Thu Apr 18, 2013 6:02 pm
@Andrew
Yes it is
by mediavets » Thu Apr 18, 2013 6:26 pm
yoshiharra wrote:OK, I figured it out. The Merlin head is not powering up! The way I found it out is, I removed the BT, connected the HC powered it on, no power to the HC!!
Are you using internal AA batteries, the Panogear/T&C internal Lithium Ion batteries, or an external power source?
yoshiharra
by yoshiharra » Thu Apr 18, 2013 8:18 pm
Finally I solved the problem! It is not you BT module, not the Panohead or the batteries, but Chinise made power adapter!!
I use mono-block portable power pack (http://www.paulcbuff.com/vagabond.php), with an A/C adapter. Fortunately I had a spare ..., plugged it in and Volla!
Thanks to every one for your time and effort to help me. :D
