How to install Papywizard 2 on a tablet with Bluetooth built in?
zhiker
by zhiker » Sun Mar 10, 2013 7:56 pm
Since I'm having a real problem of getting my head to wrap around the
concept of installing Papywizard 2 on a tablet (Dell Streak - Andriod 2.2.2)
with Bluetooth built in. So the question is, what are the correct steps to installing
Papywizard on a Andriod Tablet with built in Bluetooth, if they exist. So to make sure
the Bluetooth connection was available, I enabled Bluetooth on the tablet and the
PapyMerlin is discovered or "paired but not connected". Equipment being used are the
Panogear Bluetooth Transmitter Kit for the Skywatcher Merlin Non-Goto, I suspect
that is because Papywizard is not installed on the tablet yet.
Thanks in Advance For your Help.......zhiker
by mediavets » Sun Mar 10, 2013 8:27 pm
Papywizard doesn't run on Android.
However there will soon be some software that does which will allow you to shoot panos using a Merlin mount..
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Mar 11, 2013 7:43 am
mediavets wrote:Papywizard doesn't run on Android.
True but false ;) Papywizard like software exists on Android: https://play.google.com/store/apps/details?id=com.skywatcher.PanoramaApp&feature=search_result#?t=W251bGwsMSwyLDEsImNvbS5za3l3YXRjaGVyLlBhbm9yYW1hQXBwIl0. made by Claude's son and it works pretty well :)
Blog: http://www.skivr.com
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Mon Mar 11, 2013 6:22 pm
True but false ;)
true but false but unclear. The website doesnt tell any details.
Does the andro software use papywizard pattern?
Doe it generate xml files?
greetings from germany
Chrus
zhiker
by zhiker » Tue Apr 09, 2013 7:47 pm
To vincen:
You are correct that the link to the andriod software (Panoramaapp) really does
work. The only thing was, I had to get was get a ATT conection, since my GoPhone didn't
have accessibility, switched to a ATT Account. Not that big of issue, so if you you have
bluetooth on your Skywatcher Merlin Non-Goto then use google play and install the
app (PanoramaApp) great for andriod phone use. Question, do you know of a simple, quick
solution for making the slow option just a tadd faster, be nice to know.
FYI: I got the andriod phone for free, Pantech Burst (P9070), come's with Latest Sandwich
version and is Bluetooth Compatible, except slow is slow, fast works great.
Thanks for the advice.................pnwhiker.
