Need help with DSLR Remote Pro + Papywizard setup
yoshiharra
by yoshiharra » Fri Feb 08, 2013 3:28 am
I am a Mac user, but realize it does not work with Mac.
I have MSI U100 netbook, but not a Windows expert. Can someone point me to a step-by-step instruction that I can follow to setup my netbook?
TIA
Canon EOS T3i, EF 100-400mm, Tokina 100mm, Sigma 15mm, Samyang 8mm, Nodal Ninja 5L & R10, Merlin - Papywizard on Nokia N810
by klausesser » Fri Feb 08, 2013 12:17 pm
yoshiharra wrote:I am a Mac user, but realize it does not work with Mac.
TIA
There´s a Mac version of DSLR Remore Pro!
yoshiharra
by yoshiharra » Fri Feb 08, 2013 4:31 pm
Hi Klaus
I read in this thread somewhere that DSLR Remote Pro can not be used with Pappywizard as a plugin on Mac?
by mediavets » Fri Feb 08, 2013 6:58 pm
yoshiharra wrote:Hi Klaus
If you are seeking a way of performing extended exposure bracketing then the Promote Control seems to be the best solution and it will work when using Papywizard on the N810 (or using the T&C Touch Controller) with no need for a tethered laptop.
by klausesser » Fri Feb 08, 2013 7:09 pm
Why not? (didn´t read the thread)
yoshiharra
by yoshiharra » Fri Feb 08, 2013 9:43 pm
mediavets wrote:If you are seeking a way of performing extended exposure bracketing then the Promote Control seems to be the best solution and it will work when using Papywizard on the N810 (or using the T&C Touch Controller) with no need for a tethered laptop.
Can you tell me more on Promote Control using with N810?
Klaus, I think Frédéric mentioned it in this thread somewhere (I think) -
http://www.kolor.com/forum/t5220-papywizard-v2-annoncement,feedback,bug-report
by mediavets » Fri Feb 08, 2013 9:55 pm
The Promote has an 'external trigger' connector - so you connect the Promote in-line between the Merlin Snap connector and the camera.
There is no connection between the N810 and the Promote.
by gkaefer » Fri Feb 08, 2013 10:17 pm
the Promote Control is this one:
http://www.promotesystems.com/products/Promote-Control.html
(you can connect the promote control to Canon and Nikons via shutter cable and via usb cable. additional the promote has an "remote Sensor port". this remote sensor port can be connected with the merlin snap port or you can connect it with the TC handcontroller device too)
I do with mine following: promote directly connected to my canon eos via USB and shutter release cable. the promote remote sensor is connected with the TC handcontroller which itels is connected to the merlin head....)
PS: promote manual is one year old, download the latest firmaware zip, which includes the most recent 2.6 manual:
https://support.promotesystems.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=23&nav=0,4,6
by klausesser » Fri Feb 08, 2013 10:49 pm
Andrew and Georg mentioned it already: Promote sits between the head and the camera. So instead of the head triggering the camera directly the promote gets triggered by the head and triggers the camera then.
Using DSLR Remote Pro with PW basically should be the same - but i doubt that Papy on PC can trigger DSLR in the same PC which then triggers the head . . i don´t know.
Fact is: Promote triggers teh camera, DSLR Remote Pro triggers the camera. Both of them do not control the head.
If you´re using a Canon (don´t know how it is with Nikon) you might use Magic Lantern. This one resides in the camera. So Papy can trigger the camera and ML inside the camera does extended bracketing up to 9 steps.
That would be the easiest solution! http://www.magiclantern.fm/
PS: correction - Promote can do more than 9 steps of bracketing. I stoppped counting the steps at about 25 . . . . :cool:
yoshiharra
by yoshiharra » Sat Feb 09, 2013 12:23 am
klausesser wrote:... If you are seeking a way of performing extended exposure bracketing then the Promote Control seems to be the best solution and it will work when using Papywizard on the N810 (or using the T&C Touch Controller) with no need for a tethered laptop.
Hi Klaus
I am intrigued, are you saying that I don't need the Promote Controller if I have ML installed in my Canon T3i(600D)?!
I have already ML installed in my T3i, I am trying to bracket 5 or 7 frames at 1ev apart. Can you give me some settings/info as to how should I setup, pappywizard and MagicLantern?
@Andrew and Georg, Thanks for the info. At this time I will try and avoid investing on Promote, if I can help it. I will give MagicLantern a try.
yoshiharra
by yoshiharra » Sat Feb 09, 2013 1:56 am
HI Klaus
I think I have come full circle (see my post here http://www.kolor.com/forum/t16296-papywizard-magic-lantern-hdr-problem,please-help and your reply), I was trying to make a 5 or 7 frame bracketing with ML with my EOS T3i (600D). Daylight, manual mode, manual focus, center speed at 1/125. So am not hitting the 30sec. limit either.
Being a photographer, I am technically challenged (altho, I was very proud after I was able to install Python and Pappywizard on my N810!) :D
So, now all I want to do is 5/7 bracket, 1ev apart, daylight, manual exposer, manual focus, with N810 and T3i(600D)/MagiLantern. Any information that will help me achive this will be greatly appreciated.
Did yo find out the pulse-values(Pappywizard) from Josef? How important is LiveView mode, as this will be a concern fro battery life.
by mediavets » Sat Feb 09, 2013 10:32 am
You may find this overview of extended exposure bracketing options of interest?:
http://wiki.panotools.org/Extended_bracketing_control
by klausesser » Sat Feb 09, 2013 2:00 pm
yoshiharra wrote:I am intrigued, are you saying that I don't need the Promote Controller if I have ML installed in my Canon T3i(600D)?!
Right! :cool:
yoshiharra wrote:I have already ML installed in my T3i, I am trying to bracket 5 or 7 frames at 1ev apart. Can you give me some settings/info as to how should I setup, pappywizard and MagicLantern?
The strategy of measuring/exposuring you should find by try and error! That´s the best way to learn about it. It´s depending on individual ways of working.
best and good luck, Klaus
PS - the Promote gives you more flexibility and a wider range of extending the bracketing. But the 7 or 9 steps ML provides in most cases definitely are sufficient.
by klausesser » Sat Feb 09, 2013 2:12 pm
yoshiharra wrote:HI Klaus
It´s quite simple: you need the N810 - or whatever controller - to move the head and to trigger the camera. When the camera gets triggered it starts the brackting sequence. Of course you must set PW to wait until the sequence is finished before it moves the head further.
I suggest to work in live-view-mode: this way the mirror doesen´t move during the sequence - and so you avoid mirror-shaking.
Usually 3 steps of 1,5 or 2 EV are sufficient in most cases. But dealing with bright lights like shooting into the sunset most likely 3 steps are not enough. Here 7 or 9 steps are preferable - the more the better, because the less the EV-differences between the steps the smoother the result.
Just test it! It´s learning by doing.
yoshiharra
by yoshiharra » Sat Feb 09, 2013 8:23 pm
Ok, Finally I tested ML with N810 successfully!! But had to create a shutter cable without the focus connection, this avoids the pause after the firs exposure of every node. Some misc. errors (http://www.kolor.com/forum/t16296-papywizard-magic-lantern-hdr-problem,please-help) were user errors.
I tested 7x @1ev, 9colums by 4 rows. Everything went smoothly.
Thanks every one for help. :D
